  3. Double Micro (nano) Ampere meter
54 Posts 9 Posters 24.2k Views 11 Watching
  • korttomaK
    korttomaK
    korttoma
    Seems like it cannot communicate with the HX711 so it gets stuck at "scale.begin"
    Need to look in to that. I'm using A3 and A6 for the dout and sck this should work right? Or do I have to use A0 and A1?
    • Tomas
    • korttomaK
      korttomaK
      korttoma
      Seems I can't use A6 since A6 and A7 are "Analog Exclusively Pins". Darn, need to disassemble and correct...
      • Tomas
      • Nca78N
        Looking great !
        @NeverDie check the pinout of the IC on the datasheet and check if the jumper is connected to RATE pin on one side.
        korttomaK NeverDieN 2 Replies Last reply
        • Nca78N Nca78
          Looking great !
          korttomaK
          korttomaK
          korttoma
          @Nca78 Seems to be working now :D I should not have deviated from the instructions :blush:
          • Tomas
          • korttomaK korttoma
            Hi guyes!
            Finished my device yesterday but to my surprise the display is blank all the time when running the "Double Micro Ampere meter" sketch. I tested the display with the "Hello World!" example from the Lib and it seems to work. What might I be doing wrong?
            #49
            @korttoma
            The banana plugs (is that what they are?) look very smart.
            • Nca78N Nca78
              Looking great !
              #50
              @Nca78 said in Double Micro (nano) Ampere meter:
              Yup, it is. Thanks! Another mystery solved.
              Nca78N 1 Reply Last reply
                @NeverDie said in Double Micro (nano) Ampere meter:
                Then you might have to solder it if you're not ready to very very patient :p
                • Nca78N Nca78
                  I have the same problem, I don't have a jumper on my HX711 board so I soldered directly the pin of the IC with a small wire.
                  It has clearly improved things, but it's still slow so I will try to reduce number of samples and if it's not enough switch to TTP223 touch buttons in toggle mode, one to reset, one to change screen, so I will never miss a press.
                  I just now ordered these:
                  https://www.aliexpress.com/item/10PCS-LOT-Touch-Sensor-Jog-type-touch-module-capacitive-touch-buttons/32416625224.html?spm=2114.13010608.0.0.IOBe1p
                  Is it the kind you're using? I guess the solder bridge determines whether or not it latches?
                    wrote on last edited by Nca78
                    #53
                    Not using them yet. But using them for other boards and the "big" solder bridge in the corner is for adding a capacitor to set sensitivity (up to 50pF, the higher the less sensitive it is so by default it's at max sensitivity). Toggle mode is set using the the "B" tiny jumper in the middle of the board.
                    Jumper A is for AHLB pin, it inverses the logic level of the output.
                      Once I decided to power the HX711 externally rather than through the solar node, it has turned out to be a nice little current monitor. Typical charging currents for indoor solar nodes that are far from windows is only around 50ua, and the HX711 seems good enough for monitoring charge currents at around that amount. :)
                      Thanks @AWI for posting the project!
