  2. Announcements
  3. šŸ’¬ Serial Protocol - 2.x
43 Posts 17 Posters 20.1k Views 13 Watching
  • M musthafa
    Can we have S_SWITCH for Wall switches, door bell switches etc ?
    @musthafa is there a reason S_BINARY can't be used for those cases?
      musthafa
      Thanks. Didn't look at it. Solved my problem.
      • M musthafa
        @musthafa great! Thanks for reporting back.
        • G
          G
          gvorster
          Where can I find the structure for the payload of the internal command I_LOG_MESSAGE ? e.g. payload "TSF:MSG:SEND,211-0-220-220,s=211,c=1,t=23,pt=2,l=2,sg=0,ft=0,st=OK:69"
          I know I'm sending a value from node 211 to node 220 with the value 69. What does c=1, t=23, pt=2, l=2, sg=0,ft=0 mean?
          • G gvorster
            @gvorster see https://forum.mysensors.org/post/43373
            G 1 Reply Last reply
              G
              G
              gvorster
              @mfalkvidd said in šŸ’¬ Serial Protocol - 2.x:
              Thanks, got it now.
              • siodS
                siodS
                siod
                wrote on last edited by siod
                #22
                how can I handle sendheartbeat() messages in my controller? What payload will be sent? 1 or 0, True or False...?
                ps I“m using openhab
                still learning...
                • siodS siod
                  G
                  G
                  gvorster
                  @siod said in šŸ’¬ Serial Protocol - 2.x:
                  I just tested this using a Serial gateway.
                  Sending sendHeartbeat() from node displays this on my Serial gateway:
                  214;255;3;0;22;73
                  214;255;3;0;22;108
                  214;255;3;0;22;143
                  3=internal message
                  0=nack
                  22=I_HEARTBEAT_RESPONSE
                  In MyTransport.cpp I found
                  uint32_t transportGetHeartbeat(void)
                  	return transportTimeInState();
                  uint32_t transportTimeInState(void)
                  	return hwMillis() - _transportSM.stateEnter;
                  So the payload is some elapsed time in milliseconds.
                  siodS 1 Reply Last reply
                  • G gvorster
                    214;255;3;0;22;73
                    214;255;3;0;22;108
                    214;255;3;0;22;143
                    3=internal message
                    0=nack
                    siodS
                    siodS
                    siod
                    @gvorster Thank you for explanation!
                    One more thing: I wanted to implement a sendHeartbeat() into a Repeater node (which should never sleep!), where should I put this function and how? When putting it just into the loop it is of course spamming my gateway with heartbeat messages...Is it possible anyway?
                    still learning...
                    • siodS siod
                      G
                      G
                      gvorster
                      There are many examples code how to do this. One Timer library I use myself is this https://playground.arduino.cc/Code/Timer
                      e.g. for a repeater you could use this:
                      #include "Timer.h"
                      Timer t;
                          t.every(60000, sendImAlive);
                          t.update();
                      void sendImAlive() {
                          sendHeartbeat();
                        shabba
                        What is the best for a push button? I have a button to open a lock. The button cannot lock the lock however. So binary is not really a proper option?
                          ATM scene controller is probably the best option.
                          https://github.com/mysensors/MySensors/issues/724
                          • D
                            dmurphy
                            S_SPRINKLER is defined as having V_STATUS and V_TRIPPED - no V_ARMED....but V_ARMED says it is in S_SPRINKLER...Which way should I code this up for my controller??
                            • jjkJ
                              jjkJ
                              jjk
                              Hi there,
                              do you know that, you've built a node like a 100 times and I think it's all routine and then something that completely bluffs you? I happened to me with a simple Temp/Hum node (DHT22) that keeps sending me messages that I can't seem to figure out: 43;255;3;0;33;300000 and 43;255;3;0;32;500 - They seem to show up in the frequency that other nodes send a heartbeat signal, but no heartbeat is sent from this node. The regular DHT22 datapoints are sent as normal. Anyone knows what this means?
                                Are you using smart sleep?
                                • jjkJ
                                  jjkJ
                                  jjk
                                  yes, I do - like on every other DHT node as well, but never had that...?! Plus, I can't seem to figure out what the messages mean.
                                    I assume the 300000 is the sleep time you set while the 500 is the smart sleep embedded 500ms wait that lets the controller know the node is about to go to sleep but it is going to wait for 500ms for queued commands to be sent to the node
                                    • jjkJ
                                      jjkJ
                                      jjk
                                      hm, you might be right on the 300000 as that#s indeed the smartsleep wait time I'm setting. Not sure about the 500, but certainly possible (is that documented somewhere?) I'm wondering, though, why this node is sending this info, but not the other ones?! I don't think I have changed anything t the sketch other than the node-id and node name...
                                        500ms is the default setting when using smartsleep
                                        • jjkJ
                                          jjkJ
                                          jjk
                                          o.k., fair enough, that's a great explanation! - I'm still struggling, though, with why this node is sending this (but no heartbeat), but none of the previous ones I did...
                                          With your input, this post could be even better šŸ’—
