  2. Announcements
  3. 💬 Serial Protocol - 2.x
43 Posts 17 Posters 19.5k Views 13 Watching
  • G gvorster
    Where can I find the structure for the payload of the internal command I_LOG_MESSAGE ? e.g. payload "TSF:MSG:SEND,211-0-220-220,s=211,c=1,t=23,pt=2,l=2,sg=0,ft=0,st=OK:69"
    I know I'm sending a value from node 211 to node 220 with the value 69. What does c=1, t=23, pt=2, l=2, sg=0,ft=0 mean?
    @gvorster see https://forum.mysensors.org/post/43373
    G 1 Reply Last reply
      G
      G
      gvorster
      @mfalkvidd said in 💬 Serial Protocol - 2.x:
      Thanks, got it now.
      • siodS
        siodS
        siod
        wrote on last edited by siod
        #22
        how can I handle sendheartbeat() messages in my controller? What payload will be sent? 1 or 0, True or False...?
        ps I´m using openhab
        still learning...
        • siodS siod
          G
          G
          gvorster
          @siod said in 💬 Serial Protocol - 2.x:
          I just tested this using a Serial gateway.
          Sending sendHeartbeat() from node displays this on my Serial gateway:
          214;255;3;0;22;73
          214;255;3;0;22;108
          214;255;3;0;22;143
          3=internal message
          0=nack
          22=I_HEARTBEAT_RESPONSE
          In MyTransport.cpp I found
          uint32_t transportGetHeartbeat(void)
          	return transportTimeInState();
          uint32_t transportTimeInState(void)
          	return hwMillis() - _transportSM.stateEnter;
          So the payload is some elapsed time in milliseconds.
          siodS 1 Reply Last reply
          • G gvorster
            214;255;3;0;22;73
            214;255;3;0;22;108
            214;255;3;0;22;143
            3=internal message
            0=nack
            siodS
            siodS
            siod
            @gvorster Thank you for explanation!
            One more thing: I wanted to implement a sendHeartbeat() into a Repeater node (which should never sleep!), where should I put this function and how? When putting it just into the loop it is of course spamming my gateway with heartbeat messages...Is it possible anyway?
            still learning...
            • siodS siod
              G
              G
              gvorster
              There are many examples code how to do this. One Timer library I use myself is this https://playground.arduino.cc/Code/Timer
              e.g. for a repeater you could use this:
              #include "Timer.h"
              Timer t;
                  t.every(60000, sendImAlive);
                  t.update();
              void sendImAlive() {
                  sendHeartbeat();
                shabba
                What is the best for a push button? I have a button to open a lock. The button cannot lock the lock however. So binary is not really a proper option?
                  ATM scene controller is probably the best option.
                  https://github.com/mysensors/MySensors/issues/724
                  • D
                    dmurphy
                    S_SPRINKLER is defined as having V_STATUS and V_TRIPPED - no V_ARMED....but V_ARMED says it is in S_SPRINKLER...Which way should I code this up for my controller??
                    • jjkJ
                      jjkJ
                      jjk
                      Hi there,
                      do you know that, you've built a node like a 100 times and I think it's all routine and then something that completely bluffs you? I happened to me with a simple Temp/Hum node (DHT22) that keeps sending me messages that I can't seem to figure out: 43;255;3;0;33;300000 and 43;255;3;0;32;500 - They seem to show up in the frequency that other nodes send a heartbeat signal, but no heartbeat is sent from this node. The regular DHT22 datapoints are sent as normal. Anyone knows what this means?
                        Are you using smart sleep?
                        • jjkJ
                          jjkJ
                          jjk
                          yes, I do - like on every other DHT node as well, but never had that...?! Plus, I can't seem to figure out what the messages mean.
                            I assume the 300000 is the sleep time you set while the 500 is the smart sleep embedded 500ms wait that lets the controller know the node is about to go to sleep but it is going to wait for 500ms for queued commands to be sent to the node
                            • jjkJ
                              jjkJ
                              jjk
                              hm, you might be right on the 300000 as that#s indeed the smartsleep wait time I'm setting. Not sure about the 500, but certainly possible (is that documented somewhere?) I'm wondering, though, why this node is sending this info, but not the other ones?! I don't think I have changed anything t the sketch other than the node-id and node name...
                                500ms is the default setting when using smartsleep
                                • jjkJ
                                  jjkJ
                                  jjk
                                  o.k., fair enough, that's a great explanation! - I'm still struggling, though, with why this node is sending this (but no heartbeat), but none of the previous ones I did...
                                    Try reflash the older node, maybe you updated library or else. Why do you need heatbeat if the node is sending every 5 minutes?
                                    jjkJ 1 Reply Last reply
                                      jjkJ
                                      jjkJ
                                      jjk
                                      @gohan fair question, I don't need it, it's just still in the code and besides, the 5 min message from smartsleep seems to show up every two mins (the heartbeaat rate)
                                      And yes, I did indeed update the library, so maybe that's why. Turns out, the bigger problem is that these message seem to cause an exception in the openhab mysensor binding, so at best I'd like to figure out how to stop the node from sending them... Will do some digging
                                        Are you sure it is the smartsleep? Since you are debugging, use https://www.mysensors.org/build/parser to decode messages to a more human readable format
                                        • jjkJ
                                          jjkJ
                                          jjk
                                          yes, I am sure now: https://forum.mysensors.org/topic/8933/mysensors-2-2-0-released/27
                                          Looks like the only way to eliminate the messages is to not use smartsleep ;)
