  2. Announcements
  3. 💬 Serial Protocol - 2.x
43 Posts 17 Posters 20.1k Views 13 Watching
  • tbowmoT tbowmo
    @robosensor
    the protocol spec is still in very early draft.. That said, I would really like to keep things as simple as possible on the node side, in order to conserve flash / ram space as much as possible..
    But let's see, it might be a year before we have something ready.. And it will probably be mysensors 3.0 that will get the new protocol, as it will probably break compatibility in every way possible :D
    Z
    Z
    Zeph
    @tbowmo I agree with keeping things simple to implement, particularly on the Node & Gateway side. And it doesn't hurt that this would likely also keep things simpler to implement on the Controller side (ie: simpler plug-ins/adapters/drivers to write, which is a positive even when resources are not so tight.).
    We might be able to nevertheless implement some kind of multi-value packet concept tho. I added a comment to the 3.0 doc about a simple and low overhead way to allow homogeneous arrays. That might or might not be worthwhile.
    Robosensors's use case would involve some kind of tagged sub-unit approach, with multiple id/value pairs, yet another concept worth considering.
    • martinhjelmareM
      martinhjelmareM
      martinhjelmare
      Regarding V_POSITION and using semi-colons inside the payload, that will in my view break the API message structure. At least home assistant/pymysensors will not work with this. I'll build for and recommend users of that controller to use comma instead of semi-colon to split info inside the payload for V_POSITION.
      • R
        R
        RWoerz
        This is just what I've been looking for. I do however have a suggestion. I'm building a solar heater (water) for my shop and need to keep track of at least 3 temps (solar panel, storage tank, and inside shop), 1 water pressure and 1 water flow meter (for solar panel Pump) . There doesn't seem to be V_ or S_ variables for direct water pressure or flow. Would you please add something for them.
        • R
          R
          RWoerz
          Sorry I found V_FLOW 34 Flow of water (in meter) S_WATER. What exactly does "in meter" mean?
            musthafa
            Can we have S_SWITCH for Wall switches, door bell switches etc ?
            • M musthafa
              @musthafa is there a reason S_BINARY can't be used for those cases?
                musthafa
                Thanks. Didn't look at it. Solved my problem.
                • M musthafa
                  @musthafa great! Thanks for reporting back.
                  • G
                    G
                    gvorster
                    Where can I find the structure for the payload of the internal command I_LOG_MESSAGE ? e.g. payload "TSF:MSG:SEND,211-0-220-220,s=211,c=1,t=23,pt=2,l=2,sg=0,ft=0,st=OK:69"
                    I know I'm sending a value from node 211 to node 220 with the value 69. What does c=1, t=23, pt=2, l=2, sg=0,ft=0 mean?
                    • G gvorster
                      @gvorster see https://forum.mysensors.org/post/43373
                      G 1 Reply Last reply
                        G
                        G
                        gvorster
                        @mfalkvidd said in 💬 Serial Protocol - 2.x:
                        Thanks, got it now.
                        • siodS
                          siodS
                          siod
                          wrote on last edited by siod
                          #22
                          how can I handle sendheartbeat() messages in my controller? What payload will be sent? 1 or 0, True or False...?
                          ps I´m using openhab
                          still learning...
                          • siodS siod
                            G
                            G
                            gvorster
                            @siod said in 💬 Serial Protocol - 2.x:
                            I just tested this using a Serial gateway.
                            Sending sendHeartbeat() from node displays this on my Serial gateway:
                            214;255;3;0;22;73
                            214;255;3;0;22;108
                            214;255;3;0;22;143
                            3=internal message
                            0=nack
                            22=I_HEARTBEAT_RESPONSE
                            In MyTransport.cpp I found
                            uint32_t transportGetHeartbeat(void)
                            	return transportTimeInState();
                            uint32_t transportTimeInState(void)
                            	return hwMillis() - _transportSM.stateEnter;
                            So the payload is some elapsed time in milliseconds.
                            siodS 1 Reply Last reply
                            • G gvorster
                              214;255;3;0;22;73
                              214;255;3;0;22;108
                              214;255;3;0;22;143
                              3=internal message
                              0=nack
                              siodS
                              siodS
                              siod
                              @gvorster Thank you for explanation!
                              One more thing: I wanted to implement a sendHeartbeat() into a Repeater node (which should never sleep!), where should I put this function and how? When putting it just into the loop it is of course spamming my gateway with heartbeat messages...Is it possible anyway?
                              still learning...
                              • siodS siod
                                G
                                G
                                gvorster
                                There are many examples code how to do this. One Timer library I use myself is this https://playground.arduino.cc/Code/Timer
                                e.g. for a repeater you could use this:
                                #include "Timer.h"
                                Timer t;
                                    t.every(60000, sendImAlive);
                                    t.update();
                                void sendImAlive() {
                                    sendHeartbeat();
                                  shabba
                                  What is the best for a push button? I have a button to open a lock. The button cannot lock the lock however. So binary is not really a proper option?
                                    ATM scene controller is probably the best option.
                                    https://github.com/mysensors/MySensors/issues/724
                                    • D
                                      dmurphy
                                      S_SPRINKLER is defined as having V_STATUS and V_TRIPPED - no V_ARMED....but V_ARMED says it is in S_SPRINKLER...Which way should I code this up for my controller??
                                      • jjkJ
                                        jjkJ
                                        jjk
                                        Hi there,
                                        do you know that, you've built a node like a 100 times and I think it's all routine and then something that completely bluffs you? I happened to me with a simple Temp/Hum node (DHT22) that keeps sending me messages that I can't seem to figure out: 43;255;3;0;33;300000 and 43;255;3;0;32;500 - They seem to show up in the frequency that other nodes send a heartbeat signal, but no heartbeat is sent from this node. The regular DHT22 datapoints are sent as normal. Anyone knows what this means?
                                          Are you using smart sleep?
