  3. 💬 MultiRF MultiVoltage ProtoBox
3.3vbmp280atsha204aam312otarfm69nrf24l01+bh1750pirsi7021
20 Posts 6 Posters 7.4k Views 6 Watching
  • openhardware.ioO
    openhardware.ioO
    openhardware.io
    https://www.openhardware.io/view/422/MultiRF-MultiVoltage-ProtoBox
      Would you please provide a link to the PIR lens that you're using?
      KoreshK 1 Reply Last reply
        KoreshK
        KoreshK
        Koresh
        wrote on last edited by Koresh
        @NeverDie No problem :)
        http://en.nysenba.com/index.php/page-7-26.html - summary.
        • KoreshK Koresh
          @Koresh said in 💬 MultiRF MultiVoltage ProtoBox:
          Where do you buy them from?
            KoreshK
            KoreshK
            Koresh
            @NeverDie I bought this lens in the radio shop next street :) It is very difficult to buy something in my country so I hope it will be not so hard to find such lens in China.
            • MiKaM
              MiKaM
              MiKa
              Could cyou please share BOM?
              • MiKaM MiKa
                KoreshK
                KoreshK
                Koresh
                @MiKa oh.. pdf doesn't have some component names, sorry. I will try to share bom today. And of course I will update schematic after I test the board if needed.
                • KoreshK Koresh
                  OK, thanks for the answer. If anyone reading this finds it, please post where you found it.
                  TerrenceT 1 Reply Last reply
                    TerrenceT
                    TerrenceT
                    Terrence
                    @NeverDie why are you asking? Does this lens seem better than the one you are currently working with?
                    • TerrenceT Terrence
                      @Terrence
                      Just scoping out alternatives in case it's ever needed.
                      • KoreshK
                        KoreshK
                        Koresh
                        I am not sure this board is useful, but it works properly :wink:
                        • KoreshK
                          KoreshK
                          Koresh
                          This board fits the box good :wink:
                            may I ask how did you solder all the small SMD parts?
                            • KoreshK Koresh
                              @Koresh
                              Nice work! It looks like a commercial product.
                              What about the antenna?
                              gohanG KoreshK 2 Replies Last reply
                              • MiKaM
                                MiKaM
                                MiKa
                                And which battery? Small 250 mAh Li-ion? ;)
                                  @Koresh
                                  @NeverDie said in 💬 MultiRF MultiVoltage ProtoBox:
                                  Maybe this could fit
                                  https://www.aliexpress.com/item/10Pcs-433MHz-Helical-Antenna-2-5dBi-32mm-for-Remote-Contorl/32608690665.html
                                    @Koresh
                                    KoreshK
                                    KoreshK
                                    Koresh
                                    Thanks a lot for your high appraisal of this device. I designed this board just for fun but now I really like it with this enclosure. I would plan to improove this board a little (omit unnecessary functions and add useful features) and to start production of this device.
                                    I use very simple solution for all my boards. I just solder wire and fix it with glue pen to the board to improve reliability. Not very ideal for 433MHz board (~20cm) but perfect for 868MHz (~10cm). By the way I tested different modules with Yury (433/866). we found 868Mhz optimal frequency. Excellent range (up to 10x compareble to NRF) and very good feedthrough. So may be it is the most optimal rf solution.
                                    @MiKa said in 💬 MultiRF MultiVoltage ProtoBox:
                                    May be. With usb and onboard charger of course :wink:
                                    @gohan said in 💬 MultiRF MultiVoltage ProtoBox:
                                    I soldered all of my prototypes by hand. I use simple soldering gun and flux. All boards batches are assembled on the factory of course (manually or automatic, depends on the batch size).
                                    I really do not recommend to use springs like this. It is not antenna it is... mechanical spring. I tried to use many of them and all of them are much worse compareble with single wire antenna. It has very bad characteristic. :-1: I verified it in modeling software and in real life.
                                    • KoreshK Koresh
                                      Do you have a photo of this?
                                        KoreshK
                                        KoreshK
                                        Koresh
                                        @NeverDie I will make a photo on Monday.
                                          KoreshK
                                          KoreshK
                                          Koresh
                                          @NeverDie Sorry for delay... This is example (improved version with 3d printed fixer)
