  3. 💬 MultiRF MultiVoltage ProtoBox
3.3vbmp280atsha204aam312otarfm69nrf24l01+bh1750pirsi7021
20 Posts 6 Posters 7.2k Views 6 Watching
    @Koresh said in 💬 MultiRF MultiVoltage ProtoBox:
    @NeverDie No problem :)
    http://en.nysenba.com/index.php/page-7-26.html - summary.
    Where do you buy them from?
    KoreshK
    KoreshK
    Koresh
    @NeverDie I bought this lens in the radio shop next street :) It is very difficult to buy something in my country so I hope it will be not so hard to find such lens in China.
    • MiKaM
      MiKaM
      MiKa
      Could cyou please share BOM?
      KoreshK 1 Reply Last reply
      • MiKaM MiKa
        KoreshK
        KoreshK
        Koresh
        @MiKa oh.. pdf doesn't have some component names, sorry. I will try to share bom today. And of course I will update schematic after I test the board if needed.
        • KoreshK Koresh
          OK, thanks for the answer. If anyone reading this finds it, please post where you found it.
          TerrenceT 1 Reply Last reply
            TerrenceT
            TerrenceT
            Terrence
            @NeverDie why are you asking? Does this lens seem better than the one you are currently working with?
            • TerrenceT Terrence
              @Terrence
              Just scoping out alternatives in case it's ever needed.
              • KoreshK
                KoreshK
                Koresh
                wrote on last edited by Koresh
                I am not sure this board is useful, but it works properly :wink:
                • KoreshK
                  KoreshK
                  Koresh
                  This board fits the box good :wink:
                    may I ask how did you solder all the small SMD parts?
                    • KoreshK Koresh
                      @Koresh
                      Nice work! It looks like a commercial product.
                      What about the antenna?
                      gohanG KoreshK 2 Replies Last reply
                      • MiKaM
                        MiKaM
                        MiKa
                        And which battery? Small 250 mAh Li-ion? ;)
                          @Koresh
                          @NeverDie said in 💬 MultiRF MultiVoltage ProtoBox:
                          Maybe this could fit
                          https://www.aliexpress.com/item/10Pcs-433MHz-Helical-Antenna-2-5dBi-32mm-for-Remote-Contorl/32608690665.html
                            @Koresh
                            KoreshK
                            KoreshK
                            Koresh
                            Thanks a lot for your high appraisal of this device. I designed this board just for fun but now I really like it with this enclosure. I would plan to improove this board a little (omit unnecessary functions and add useful features) and to start production of this device.
                            I use very simple solution for all my boards. I just solder wire and fix it with glue pen to the board to improve reliability. Not very ideal for 433MHz board (~20cm) but perfect for 868MHz (~10cm). By the way I tested different modules with Yury (433/866). we found 868Mhz optimal frequency. Excellent range (up to 10x compareble to NRF) and very good feedthrough. So may be it is the most optimal rf solution.
                            @MiKa said in 💬 MultiRF MultiVoltage ProtoBox:
                            May be. With usb and onboard charger of course :wink:
                            @gohan said in 💬 MultiRF MultiVoltage ProtoBox:
                            I soldered all of my prototypes by hand. I use simple soldering gun and flux. All boards batches are assembled on the factory of course (manually or automatic, depends on the batch size).
                            I really do not recommend to use springs like this. It is not antenna it is... mechanical spring. I tried to use many of them and all of them are much worse compareble with single wire antenna. It has very bad characteristic. :-1: I verified it in modeling software and in real life.
                            • KoreshK Koresh
                              Do you have a photo of this?
                                KoreshK
                                KoreshK
                                Koresh
                                @NeverDie I will make a photo on Monday.
                                  KoreshK
                                  KoreshK
                                  Koresh
                                  @NeverDie Sorry for delay... This is example (improved version with 3d printed fixer)
