  3. Irrigation Controller (up to 16 valves with Shift Registers)
371 Posts 56 Posters 322.3k Views 52 Watching
  • dbemowskD dbemowsk
    Okay, so I was just looking over the code. I first did a search for "Valve Data:" as that was what was showing on the screen. I found that in the goGetValveTimes() method. According to the code, that is only supposed to show if the inSetup variable evaluates to true. I then searched on that variable, and in the code just before the setup() method, I see this:
    bool inSetup = true;
    But I don't see anywhere in the code where it sets that value to false. So every time the main loop() calls goGetValveTimes();, it is going to display that since inSetup never gets changed to false. At the very end of the setup routine I see this bit of code:
      for (byte i = 1; i <= NUMBER_OF_VALVES; i++)
        lcd.clear();
        goGetValveTimes();
      lcd.clear();
    I think that it is just after that for loop, or after the lcd.clear(); that it is supposed to set inSetup to false. I have not tested this theory yet as I need to unmount my controller and open it up to push the new code to it, but I am pretty sure that this is the issue. That would explain why everything else with it appears to work normally.
    I double checked with the example code on the build page to see if possibly I may have deleted something when doing my edits. Looking it over, I found the same thing. If you ask me, this looks to be a bug in the code and it should be fixed and updated.
    Topdawg2881
    @dbemowsk
    I am in front of my computer and I have my controller in front of me and hooked up. Give me a couple minutes and I will run it. See what happens.
    • dbemowskD
      dbemowskD
      #295
      I just made the change and tested it. That was definitely the problem. Works perfect now.
      Not sure who can change the example code, but all that needs to be added is this:
          lcd.clear();
          goGetValveTimes();
        lcd.clear();
        //Add this line
        inSetup = false;
            lcd.clear();
            goGetValveTimes();
          lcd.clear();
          //Add this line
          inSetup = false;
        Topdawg2881
        @dbemowsk
        You beat me too it. I added the same line in same location and it works perfect. Every so often I see the raindrop icon to show that it is pulling data to update the valve times.
        • dbemowskD
          dbemowskD
          So it is definitely a confirmed bug. I ended up finding some old sample code from when I started this last year and this bit of code was actually in the setup method and not in goGetValveTimes:
                lcd.print(F(" Updating  "));
                lcd.setCursor(0, 1);
                lcd.print(valveIndex);
          So some time in the past year the sample code had been changed.
            BulldogLowellB
            BulldogLowellB
            BulldogLowell
            @dbemowsk
            good to see you found it. I haven't looked at the code for two years, and mine is still working. (@petewill 's demo worked well too). there must have been some change that managed its way into the source
            maybe look on GitHub and do a pull request if you the problem is there...
            • tombstoneT
              tombstoneT
              tombstone
              Hi I just order all the parts that was listed. Do I need to read the 230 post or it's ok just watched the video.
              dbemowskD 1 Reply Last reply
              • tombstoneT tombstone
                dbemowskD
                dbemowskD
                @tombstone You shouldn't need to read all the posts. Maybe just search the thread if you run into any snags. What kind of setup are you dropping this into? Do you currently have valves installed? Does your setup have a master valve or pump relay? Is it a standard 24V AC system?
                • tombstoneT
                  tombstoneT
                  tombstone
                  Ok I read it all. Just want to start with the basic then change to pH reader soil reader water reader rain detector.
                  • tombstoneT
                    tombstoneT
                    tombstone
                    It's really hard to work out what's good post over bad post. Lol
                    • tombstoneT
                      tombstoneT
                      tombstone
                      Its my 1st project and I have learnt alot but have got myself a snag and I am getting this....
                      Arduino: 1.8.3 (Windows 10), Board: "Arduino Pro or Pro Mini, ATmega328 (5V, 16 MHz)"
                      C:\Users\HTPC\Documents\Arduino\Irrigation_Controller_1\Irrigation_Controller_1..ino:82:21: fatal error: TimeLib.h: No such file or directory
                      #include <TimeLib.h>
                      compilation terminated.
                      exit status 1
                      Error compiling for board Arduino Pro or Pro Mini.
                        go to library manager and install Time library
                        tombstoneT 1 Reply Last reply
                        • tombstoneT
                          tombstoneT
                          tombstone
                          • tombstoneT
                            tombstoneT
                            tombstone
                            • tombstoneT
                              tombstoneT
                              tombstone
                                tombstoneT
                                tombstoneT
                                tombstone
                                • tombstoneT
                                  tombstoneT
                                  tombstone
                                  ok I almost there :-D but my pro mini has just Analog 1 to 3. I say I have to change the coda were abouts...
                                  I also have not setup up my Vera Controller as I see you have to pay...
                                  Is there another one that is eazy as I have try some but can not get it to work. eg HomeGenie is download and on my pc but don't think its not to good. don't know how to find my pro mini. happy to chagaen to someing eazer to get me started thanks guys....
                                  • tombstoneT
                                    tombstoneT
                                    tombstone
                                    Domoticz LOOKS :-D GOOD
                                    BUT new to all this :-D
                                    • Black CatB
                                      Black CatB
                                      Black Cat
                                      If you are looking for Software, try openhab.
                                      You need to buy Vera, but the software is free.
                                      • Black CatB Black Cat
                                        tombstoneT
                                        tombstoneT
                                        tombstone
                                        @Black-Cat thanks 😁
                                        • tombstoneT
                                          tombstoneT
                                          tombstone
                                          ok so when adding to Domoticz..
                                          I go to hardware...
                                          I name is..... test...
                                          then choose.. MySensors Gateway with LAN interface....
                                          Data Timeout: .... Disabled.....
                                          Remote Address.... (I have tryed)....
                                          IP Address, Subnet Mask, Default Gateway, Primary DNS, Secondary DNS.
                                          (i try everythinbg I can think of and still not work)
                                          Port: ... 5003
                                          My pro min has the red light on and blink blue occassionally.
                                          what I get from the Domoticz log is
                                          2017-07-30 18:00:00.627 Error: MySensors: Can not connect to: 61.9.211.33:5003
                                          2017-07-30 18:00:00.627 TCP: Connection problem (Unable to connect to specified IP/Port)
                                          2017-07-30 18:00:00.627 TCP: Reconnecting in 30 seconds...
