  3. nRF5 action!
nRF5 action!
  • M Mike_Lemo
    @NeverDie I just made the antenna on my PCB stick out so there is no fiber glass under the antenna even.
    Also what is a good library for using NFC and the bluetooth peripheral of that MCU?
    I came across that library:
    https://github.com/sandeepmistry/arduino-BLEPeripheral
    but the page doesn't seem to support the BLE capability of the NRF52832
    and no luck for the NFC
    #322
    Yeah, that's what I opted for on Version 2 of my breakout board for the Ebyte nRF52832 module. Seems like the cleanest solution.
    The MDBT42Q is a lot smaller than the Ebyte module, so although I was bashing it for its performance on the Adafruit (which in their case may turn out to be ground plane related), that might be an acceptable trade-off for the smaller size.
    You have lots of good questions. Keep asking! I'm hoping to learn from the answers too.
      #323
      OK, here's my plan:
      1. It's possible the connections on my first attempt were a bit dodgy. I'll try again, but this time soldering a fresh new module to a prototype PCB so that they won't be mechanically stressed as I interconnect wires. Not as ideal as my breakout board will be, but I'll have to make do until it arrives.
      2. If it still fails to program after step #1, then I'll check to confirm whether or not the oscillators are, uh, oscillating, at the proper frequency by using an oscilliscope after powering it up. I'm assuming they are, but it's at least easy to check and then cross off the list of suspects.
      3. If still no clues, then what's next? Logic probe on the two SW lines for a compare/contrast against a successful programming of a sparkfun nRF52832 board? That's sure to generate at least some palpable data as to where the problem is occurring.
      I welcome other suggestions though on how to proceed. The above is just my best guess, and I'm sure others here are better at troubleshooting this than I am.
        Mike_Lemo
        Yeah well at least I managed to flash a blink program to my pcb and confirm that it works but now I'm planning to abanded from Arduino anyways sins alot of functionality isn't supported.
        • M Mike_Lemo
          If your abandoning from Arduino, what will you be abandoning to?
            Mike_Lemo
            Probably eclipse
            • M Mike_Lemo
              Probably eclipse
              #327
              Probably eclipse
              I'm rather hazy on the differences. I guess that way you can use all the Nordic libraries the way they were intended?
                #328
                Eclipse is just an IDE ;) like Arduino IDE, or VS etc.
                I think he means he wants to leave arduino core (mysensors rely on arduino core) to use nordic sdk with other ide (like eclipse, mbed, keil etc..). Because using eclipse with arduino core won't unlock features. It still needs coding.
                • scalzS scalz
                  Toyman
                  @scalz arduino.org ble library that's based on sandeepmistry's one seems very extensive.
                  I believe one need pretty substantial reasons to migrate from arduino unless you are a professional developer
                    #330
                    Bluetooth is everywhere, and that's great, but I'm developing the impression that Bluetooth is rather arduous to program in its "native" format. Maybe this is an opportunity to build something simpler/easier that runs on top of Bluetooth, and yet can still interact with normal bluetooth devices in the native bluetooth that they understand? I think the Arduino's wide acceptance more or less proves that "easy is good."
                      Toyman
                      @NeverDie fully agree
                        OK, here's my plan:
                        #332
                        OK, here's my plan:
                        I executed step #1 of my plan with no change in results on the second attempt of programming. The module is definitely getting 3.3v power on the VCC pin.
                        So, I executed step #2. I don't see any oscillation at all on the 32.7khz oscillator. The faster oscillator is mostly quiet, but it periodically gives short little bursts of activity--here's a screenshot of one:
                        Not sure if this is normal or not, but that's what is going on.
                        • T Toyman
                          Mike_Lemo
                          @Toyman what is that libray? I think of you refer to bel peripheral v0.3 it might not support the nrf52832 as I was asking before.
                            #334
                            So, for comparison, I measured the Sparkfun nRF52832 board, because (unlike the adafruit with its Raytac module), both oscillators are exposed for measurement. Unfortunately, it is already programmed, so it is not a true apples-to-apples comparison, but, anyway, the measurements were definitely different. First of all, the 32.7Khz oscillator was continuously oscillating at around 32.9Khz:
                            and the faster oscillator was also continuously oscillating:
                            I guess to have an apples-to-apples I would have to completely erase the firmware on the Sparkfun board.
                            Anyhow, I think I'm getting the urge to order some Raytac modules.... It sounds as though they are not such a mystery.
                              One thing I notice on the Ebyte module is that no RESET pin is exposed. Isn't that a bit odd?
                              Also, there appears to be a typo on the silkscreen, where there are two pin 7's on the silkscreen, but probably one of them is actually pin 6.
                                By the way, those short bursts on activity on the Ebyte module's fast oscillator happen pretty regularly, about every 22ms or so:
                                • Nca78N
                                  @NeverDie how many GND pins did you connect ?
                                  It might be a stupid suggestion but maybe all GND pins are not connected together ?
                                  • M Mike_Lemo
                                    Toyman
                                    @Mike_Lemo
                                    http://www.arduino.org/learning/reference/ble
                                    This is their "homework" in anticipation of Primo launch. It does support nrf52
                                    • mtiutiuM
                                      mtiutiuM
                                      mtiutiu
                                      #339
                                      Ok, so after posting some questions to CDSENET Aliexpress store(in regards to the E73-2G4M04S module):
                                      1. Is the nrf52832 IC DEC1 pin decoupled with a 100nF capacitor as per Nordic datasheet recommendations?
                                      2. Is the nrf52832 IC  DEC2 pin decoupled with a 100pF capacitor as per Nordic datasheet recommendations?
                                      3. Are all the power pins of the nrf52832 IC decoupled as per  Nordic datasheet recommendations?
                                      4. Are the external components already provided so that the internal DC-DC converter can be used?
                                      I received this part of schematic:
                                      The module that I bought is this one: CDSENET E73-2G4M04S
                                      I hope that it helps demystify some things in regards to this module. Maybe @NeverDie can confirm this by checking his module connections as seen in the above schematic. I'm saying this because Chinese support is well..not so user friendly in my experience and I don't know if the above schematic is indeed what they used on their module or they just provided me an example schematic of how to use the NRF52832 IC in general instead.
                                        #340
                                        @Mike_Lemo @Toyman
                                        BLEPeripheral lib from sandeep is working fine with nrf52832, as i'm using it ;)
                                        Regarding the sch above, it looks like a classic circuit (in LDO mode, not surprising as DCDC mode is optional). I'm not using same values but this should work..
                                          They sent me two files, but I have no idea what they are, or how to open them. Maybe someone here recognizes them or can open them?
                                          0_1500890784640_E73-2G4M04S-PCBLIB.PCBLIB
                                          0_1500890793687_E73-2G4M04S-PCB-V1.0.PCBDOCPreview
