  3. Domoticz
  4. Are folks here happy with Domoticz?
63 Posts 28 Posters 56.1k Views 24 Watching
    @wergeld said in Are folks here happy with Domoticz?:
    Has interesting issue lately where if I lose power to the Pi I lose all data back to May 23 of this year. I have a cron job that backs up the DB nightly and send to my NAS so I can lose hours instead of days. But, man, is this annoying - I have not tracked down the reason yet.
    You may want to consider using a Pi UPS, either for that reason or just in general. Lots of different ones available now--or simply make one yourself--which should allow enough time for an orderly shutdown. I would tend to favor one based on a supercap, for longevity sake, but maybe that's just me. Perhaps @ceech has something you could use that you might like. Ideally, of course, you want one with an auto-restart feature too, to resume after power is restored and your power source charges up (yet another reason to possibly prefer a supercap: charging speed).
    W
    W
    wergeld
    Yes, I do have it on a UPS. What I meant is that if I power down the PI. I think the SD cards is toast on it. Nothing seems to be saved to disk - I made a cron job and saved it. But, after a reboot of the Pi the cron job was no longer there. Oh well.
    I have stated to mess with dashticz - looks promising but not ready for prime time. Documentation is thin, to say the least. Also, the config switch to use F instead of C works for the numeric value shown - but the suffix is still "C". Also, the culture set is using (for the US, anyway) the wrong thousands separator and decimal point characters. I can add in my Google Maps API key in the locations in the config (with my lat/lon) but it does not appear to "do" anything and I see nothing in the docs on what block or section I need to create to show the maps.
    Still, I do like Domoticz.
    • nagelcN
      nagelcN
      nagelc
      I've been using Domoticz for about 2 years and am happy with it. I tried a couple of others before, but Domoticz had a better look and worked with well with MySensors. I am comfortable with Lua, so that was OK for me.
      I use the Domoticz phone app to monitor when I am away. It's basic, but seems to work well.
      I've been able to set it up to respond to Alexa commands.
      Gizmocuz seems to be responsive in keeping it up to date with MySensors.
      • sinczeS
        sinczeS
        sincze
        MySensors Evangelist
        In the beginning I worked with DomotiGa on a raspberry. However due to all the crashes of my SD card and the long restore time (rebuilding / recompiling of DomotiGa) I had a shadow system on a separate Raspberry with Domoticz to figure out how it worked. In the end I also moved Domoticz from SD to an SSD using a Cubietruck backend. To speed Domoticz a little bit more I moved away from the standard (integrated) scripts and lua to Pass2PHP. Now all automatic controls are dealt with by PHP while still being able to use all de 'hardware' features and interface of domoticz itself. . As a result I have a fast responding system that integrates with all my domotica hardware flawless. The community is really big. And yes. Sometimes you run into a bug. But I assume that can happen anywhere.
        • W wergeld
          I have used Domoticz for about 2+ years. I like it a lot but wish for something...more.
          Pros:
          Quick setup for mysensors nodes
          One-stop location for data storage and data presentation
          Android app is very good
          Customizable scripting options once you leave their scripting environment and use API values.
          Cons:
          Event scripting (lua? really?) needs more advanced features.
          Graphs are just sort of...there. I do data viz at my job and use Highcharts (Domoticz' charting library) daily. The charts in Domoticz need a lot of work.
          I have started writing my own front end that calls data from the Domoticz API (as well as other APIs) for showing info in our house. Nothing crazy cool, but it will eventually work fine for me.
          Which brings me to the point - there is no perfect controller. You need to find the one that is right for you.
          Sweetpants
          @wergeld, You can't blame domoticz for loosing power, that's a risk with all SD-card based systems. After a similar experience I run domoticz now on a intel NUC for about 4 years without any major issues, and I'm on Beta
          W 1 Reply Last reply
          • rmtuckerR
            rmtuckerR
            rmtucker
            I am trying to get away from Domoticz because of the 5 minute log interval that is built in to it.
            I have changed it to 1 minute but it is still useless for my boiler sensor.
            Sometimes the Boiler is only on 30-45 secs and the temperatures on the flow and return are completely missed.
            There has to be something better.
            I have been trying myHouse lately but the updates for fixes and enhancements have slowed down as the developer is busy with other things.
            So back to the drawing board.
            sinczeS 1 Reply Last reply
              You could use node-red to log data to an external db and do whatever you want after that: it should be easier than replace the entire controller
                #35
                @gohan said in Are folks here happy with Domoticz?:
                In that scenario, would Node Red be getting the sensor message first and then just somehow quickly piping it to Domoticz and a copy to the external database (e.g. MySQL)?
                gohanG tbowmoT 2 Replies Last reply
                • S Sweetpants
                  W
                  W
                  wergeld
                  @Sweetpants Oh, I am not. Just saying that the issues I am having with logging do not have to do with Domoticz.
                    @NeverDie no, both Domoticz and node-red are connecting to ethernet/mqtt gateway (I don't remember which one is supported), so they both get the same data coming from the gateway and would keep working independently
                    • sundberg84S sundberg84
                      Just to clarify I think Domoticz is very versatile and flexible when it comes to hardware but when it comes to GUI and how to visually show everything it's very nice but not configurable.
                      markjgabbM
                      markjgabbM
                      markjgabb
                      @sundberg84 i dont know about you, but i use imperihome as a front end over the top of domoticz with mydomoathome.....that way you get the strong base of domoticz, but i more user friendly and customisable front end
                      • rmtuckerR rmtucker
                        sinczeS
                        sinczeS
                        sincze
                        @rmtucker I move the data directly from Domoticz into influxDB. This is as accurate as you will get it ;-) Data for example of my smartmeter every 10 seconds. If the device is updated in Domoticz (energy sensor for example) this will add data to influxDB and you will get the bet graphs. Accurate for me.
                        • K
                          K
                          kany
                          Hello guys,
                          I am a beginner with Domoticz. I would like to ask you a question. Can i find a way to recover the data from a sensor like temperature or smartmeter to be installed in local?
                          I am working with Rasperbery +domoticz + Smartplug Fibaro.
                          Firstly, i install domoticz in raspberry and i configure the plug fibaro to communicate with a usb Zwave. And it works. i can see the graph but I do not succed to retrieve the data locally into the raspberry.
                          Someone has a solution to propose me?
                          Thanks guys
                          gohanG 1 Reply Last reply
                          • K kany
                            Hello guys,
                            Thanks guys
                            @kany are you referring to save data to something like influxdb?
                            K 1 Reply Last reply
                              K
                              K
                              kany
                              @gohan yeah!! Possible.My goal is to use machine learning with the data i collect.
                              So if you give me link where the explain how it's working influxdb it Will be good
                              Thnnk@gohan for your reply
                              • K kany
                                W
                                W
                                wergeld
                                @kany Well, the data is in a SQLite database for domoticz already. You can move to InfluxDB easily. See this post on the Domoticz forum - this is how I set it up using these instructions.
                                My qualms with InfluxDB is that deleting a value is nearly impossible.
                                  tbowmoT
                                  tbowmoT
                                  tbowmo
                                  I use node-red with domoticz, MySensor data hits node-red first (serial gateway) which then pipes the data to domoticz via a fake serial port. That way I can manipulate data that I send to domoticz, and can inject fake mysensor sensors into domoticz as well..
                                  Node-red also dumps all data to influxdb for data storage, and then I use grafana for graphing purposes. Besides that I have created my own dashboard for tablets.
                                  Currently I mostly use domoticz as scripting engine (lua), for some basic events. For example turning on TV if someone starts streaming to my chromecast, and automatically turn it off again if chromecast have been in idle state for 2 minutes (the same for my chromecast audio, that just turn on amplifier instead of TV).
                                  W gohanG 2 Replies Last reply
                                  • tbowmoT tbowmo
                                    W
                                    W
                                    wergeld
                                    wrote on last edited by wergeld
                                    #45
                                    @tbowmo Do you have a link to your node-red setup? I would like to filter the output of my sensor nodes as well (got a flaky one that sends -47.5 F temp every once in a while.
                                    Found your github!
                                    For others looking it is here.
                                    tbowmoT 1 Reply Last reply
                                    • tbowmoT tbowmo
                                      @tbowmo would that work also for ethernet/mqtt gateway?
                                      • W wergeld
                                        Found your github!
                                        tbowmoT
                                        tbowmoT
                                        tbowmo
                                        @wergeld
                                        the module is available through NPM as well.. So npm install node-red-contrib-mysensors :)
                                        The basic node-red mysensors is pasted below, my setup is starting to be quite extensive, with reporting to slack channels, creating a websocket for my custom dashboard etc. But isn't necessary for the basic domoticz/nodered
                                        For connecting node-red/domoticz together I use socat to create a virtual serial port:
                                        socat PTY,link=/dev/ttyS81,mode=666,group=dialout,raw PTY,link=/dev/ttyUSB21,mode=666,group=dialout,raw &
                                        node-red:
                                                "id": "9b272654.9ad688",
                                                "type": "subflow",
                                                "name": "Influx processing",
                                                "info": "",
                                                "in": [
                                                        "x": 220,
                                                        "y": 280,
                                                        "wires": [
        "id": "5cfd0e8.fa302f"
                                                "out": [
                                                        "x": 960,
                                                        "y": 240,
                                                        "wires": [
        "id": "55204322.aadfbc",
        "port": 0
                                                        "x": 960,
                                                        "y": 380,
                                                        "wires": [
        "id": "d6b8cf3e.6954c",
        "port": 0
                                                "type": "function",
                                                "z": "9b272654.9ad688",
                                                "name": "Influx conditioner",
                                                "func": "msg_env = null;\nmsg_utility = null;\nmsg_debug = null;\nst = msg.subType;\nif (msg.messageType == 1 && (st === 0 || st == 1 || st == 4 || st == 17)) {\n    var tags = {};var data = {}\n    tags.node = msg.nodeId.toString();\n    tags.sensor = msg.childSensorId.toString();\n    data.value=parseFloat(msg.payload);\n    switch (st) {\n        case 0 : type = \"temperature\";break;\n        case 1 : type = \"humidity\"; break;\n        case 4 : type = \"barometer\"; break;\n        case 17: type = \"electricity\"; break;\n    }\n    msg.payload = [data, tags];\n    msg.measurement = type;\n    msg_debug = msg;\n    if (msg.subType==17) \n        msg_utility = msg;\n    else \n        msg_env = msg;\n} \nelse \n    msg = null;\nreturn [msg_debug, msg_env, msg_utility];",
                                                "outputs": "3",
                                                "noerr": 0,
                                                "x": 790,
                                                "y": 280,
                                                "wires": [
                                                        "c042117a.3fbdf"
                                                        "f6bdc7dc.77c758"
                                                "id": "5cfd0e8.fa302f",
                                                "type": "mysdecenc",
                                                "name": "",
                                                "x": 350,
                                                "y": 280,
                                                "wires": [
                                                        "55204322.aadfbc",
                                                        "d6b8cf3e.6954c"
                                                "id": "c042117a.3fbdf",
                                                "type": "influxdb out",
                                                "influxdb": "9dbdc7c7.624238",
                                                "name": "",
                                                "measurement": "",
                                                "x": 1020,
                                                "y": 280,
                                                "wires": []
                                                "id": "f6bdc7dc.77c758",
                                                "influxdb": "9de2e4ed.fdcfc8",
                                                "name": "Utility",
                                                "measurement": "",
                                                "x": 990,
                                                "y": 320,
                                                "wires": []
                                                "type": "function",
                                                "name": "Watt/Hour calculator",
                                                "func": "/* Takes input on subType 24, calculates difference\n   from last time, if around 60 seconds have passed\n   since last report.\n   It passes the value on as subType 17, and\n   childSensorId 2 */\n\nif ((msg.subType===24) && (msg.nodeId===99)) {\n    var uTime = Math.floor(Date.now()/60000);\n    var lastTime = context.get('lastTime')||0;\n    if (lastTime === 0) {\n        context.set('lastTime', uTime);\n        context.set('lastCount', msg.payload);\n    } else {\n        if (uTime != lastTime) {\n            lastCount = context.get('lastCount');\n            currentCount = msg.payload;\n            context.set('lastTime', uTime);\n            context.set('lastCount', currentCount)\n            msg.subType = 17;\n            msg.childSensorId = \"2\";\n            msg.payload = currentCount - lastCount;\n            return msg;\n        }\n    }\n}",
                                                "outputs": 1,
                                                "noerr": 0,
                                                "x": 560,
                                                "y": 340,
                                                "wires": [
                                                        "55204322.aadfbc"
                                                "id": "9dbdc7c7.624238",
                                                "type": "influxdb",
                                                "z": "67deb464.98214c",
                                                "hostname": "127.0.0.1",
                                                "port": "8086",
                                                "database": "environment",
                                                "name": "Environment DB"
                                                "id": "9de2e4ed.fdcfc8",
                                                "type": "influxdb",
                                                "port": "8086",
                                                "database": "utility",
                                                "name": "Utility DB"
                                                "id": "4c13992e.b3ec68",
                                                "type": "subflow",
                                                "name": "Logging filter",
                                                "in": [
                                                        "x": 105.5,
                                                        "y": 240,
                                                        "wires": [
        "id": "c2063804.3df9c8"
                                                "out": [
                                                        "x": 600,
                                                        "y": 260,
                                                        "wires": [
        "id": "b57b1f3.f4a84e",
        "port": 1
                                                "id": "c2063804.3df9c8",
                                                "z": "4c13992e.b3ec68",
                                                "name": "",
                                                "x": 230,
                                                "y": 240,
                                                "wires": [
                                                        "b57b1f3.f4a84e"
                                                "type": "function",
                                                "name": "Filter battery msg",
                                                "func": "var battMsg = null;\nvar debugMsg = null;\nvar sketchMsg = null;\nif (msg.messageType==3) {\n    if (msg.subType===0)\n        battMsg = msg;\n    if (msg.subType==9)\n        debugMsg = msg;\n    if (msg.subType==11 || msg.subType==12)\n        sketchMsg = msg;\n}\n\nreturn [battMsg, debugMsg, sketchMsg];",
                                                "outputs": "3",
                                                "noerr": 0,
                                                "x": 430,
                                                "y": 240,
                                                "wires": [
                                                        "dec3cc44.213c3",
                                                        "d8b91167.2746f"
                                                        "b521bd95.4ade4"
                                                "id": "dec3cc44.213c3",
                                                "name": "",
                                                "x": 650,
                                                "y": 180,
                                                "wires": [
                                                        "1b4decbb.e4b213"
                                                "id": "38f9ab87.c70654",
                                                "type": "file",
                                                "name": "Battery log",
                                                "filename": "/var/tmp/battlog.txt",
                                                "appendNewline": false,
                                                "createDir": false,
                                                "overwriteFile": "false",
                                                "x": 1050,
                                                "y": 180,
                                                "wires": []
                                                "id": "1b4decbb.e4b213",
                                                "type": "function",
                                                "name": "inject date",
                                                "func": "var date = new Date();\nvar str = date.getFullYear() + \"-\" + (date.getMonth() + 1) + \"-\" + date.getDate() + \" \" +  date.getHours() + \":\" + date.getMinutes() + \":\" + date.getSeconds();\nmsg.payload = str + \" - \" + msg.payload;\nreturn msg;",
                                                "outputs": 1,
                                                "noerr": 0,
                                                "x": 830,
                                                "y": 180,
                                                "wires": [
                                                        "38f9ab87.c70654"
                                                "id": "d8b91167.2746f",
                                                "type": "function",
                                                "name": "Check batt level",
                                                "func": "var date = new Date();\nvar str = date.getFullYear() + \"-\" + (date.getMonth() + 1) + \"-\" + date.getDate() + \" \" +  date.getHours() + \":\" + date.getMinutes() + \":\" + date.getSeconds();\nmsg.date = str;\nif (parseInt(msg.payload)<5)\nreturn msg;",
                                                "outputs": 1,
                                                "noerr": 0,
                                                "x": 660,
                                                "y": 220,
                                                "wires": [
                                                        "c44e1c28.3bb1e"
                                                "id": "c44e1c28.3bb1e",
                                                "type": "template",
                                                "name": "BatLow message",
                                                "field": "payload",
                                                "fieldType": "msg",
                                                "format": "handlebars",
                                                "syntax": "mustache",
                                                "template": "{{date}} - Battery level is low on node {{nodeId}} : {{payload}} !",
                                                "x": 850,
                                                "y": 220,
                                                "wires": [
                                                        "e9231639.16dce8"
                                                "id": "e9231639.16dce8",
                                                "type": "twitter out",
                                                "twitter": "",
                                                "name": "Tweet",
                                                "x": 1030,
                                                "y": 220,
                                                "wires": []
                                                "id": "b478903e.4b877",
                                                "type": "file",
                                                "name": "Presentation log",
                                                "filename": "/var/tmp/presentation.txt",
                                                "appendNewline": true,
                                                "createDir": false,
                                                "x": 840,
                                                "y": 300,
                                                "wires": []
                                                "id": "b521bd95.4ade4",
                                                "name": "",
                                                "x": 650,
                                                "y": 300,
                                                "wires": [
                                                        "b478903e.4b877"
                                                "id": "bed2e35d.412d2",
                                                "type": "subflow",
                                                "name": "Domoticz conditioner",
                                                "info": "Inverts lockstate for domoticz, as domoticz has inverted the logic in their code, compared to mysensors",
                                                "in": [
                                                        "x": 280,
                                                        "y": 220,
                                                        "wires": [
        "id": "8afd136d.7502f"
                                                "out": [
                                                        "x": 1000,
                                                        "y": 220,
                                                        "wires": [
        "id": "91eb6b4c.6e1498",
        "port": 0
                                                "id": "8afd136d.7502f",
                                                "z": "bed2e35d.412d2",
                                                "name": "",
                                                "x": 410,
                                                "y": 220,
                                                "wires": [
                                                        "126152bf.ed9ead"
                                                "id": "126152bf.ed9ead",
                                                "type": "function",
                                                "name": "Invert lockstate for domoticz",
                                                "func": "if (msg.subType == 36) {\n    if (msg.payload== \"1\") msg.payload=\"0\";\n    else msg.payload=\"1\";\n}\nreturn msg;",
                                                "outputs": 1,
                                                "noerr": 0,
                                                "x": 640,
                                                "y": 220,
                                                "wires": [
                                                        "91eb6b4c.6e1498"
                                                "name": "",
                                                "x": 870,
                                                "y": 220,
                                                "wires": [
                                                "id": "2257718.fdda88e",
                                                "type": "subflow",
                                                "name": "Energy meter",
                                                "info": "Converts input from arduino sketch, to a \nMysensors compatible protocol format, usable\nfor injecting into the message stream from\nnormal Mysensors nodes\n\nOutputs data as nodeId 99.",
                                                "in": [],
                                                "out": [
                                                        "x": 1020,
                                                        "y": 200,
                                                        "wires": [
        "id": "9d92273c.626dd8",
        "port": 0
                                                "id": "12db17ce.ed24e8",
                                                "type": "serial in",
                                                "z": "2257718.fdda88e",
                                                "name": "Meter input",
                                                "serial": "acfe3226.5301d",
                                                "x": 240,
                                                "y": 200,
                                                "wires": [
                                                        "e56f30b7.1a90d"
                                                "id": "1dcfb48.fe2304c",
                                                "type": "mysencap",
                                                "name": "V_WATT node 99",
                                                "nodeid": "99",
                                                "childid": "1",
                                                "subtype": "17",
                                                "internal": "0",
                                                "ack": false,
                                                "msgtype": "1",
                                                "presentation": false,
                                                "presentationtype": "13",
                                                "presentationtext": "Watt",
                                                "fullpresentation": false,
                                                "firmwarename": "",
                                                "firmwareversion": "",
                                                "x": 650,
                                                "y": 160,
                                                "wires": [
                                                        "9d92273c.626dd8"
                                                "id": "f9b89df5.06476",
                                                "type": "mysencap",
                                                "name": "V_KWH node 99",
                                                "nodeid": "99",
                                                "childid": "1",
                                                "subtype": "18",
                                                "internal": "0",
                                                "ack": false,
                                                "msgtype": "1",
                                                "presentation": true,
                                                "presentationtext": "Kwh",
                                                "fullpresentation": true,
                                                "firmwarename": "MeterNode",
                                                "firmwareversion": "0.1",
                                                "x": 650,
                                                "y": 200,
                                                "wires": [
                                                        "9d92273c.626dd8"
                                                "name": "",
                                                "x": 890,
                                                "y": 200,
                                                "wires": [
                                                "id": "e56f30b7.1a90d",
                                                "type": "function",
                                                "name": "Split meter data",
                                                "func": "var m=msg.payload.split(';');\nvar msg1 = {payload:m[0]};\nvar msg2 = {payload:m[1]/1000};\nvar msg3 = {payload:m[1]};\nreturn [msg1, msg2, msg3];",
                                                "outputs": "3",
                                                "noerr": 0,
                                                "x": 420,
                                                "y": 200,
                                                "wires": [
                                                        "1dcfb48.fe2304c"
                                                        "f9b89df5.06476"
                                                        "dfd92894.2026d8",
                                                        "11f1e54.721221b"
                                                "id": "dfd92894.2026d8",
                                                "type": "file",
                                                "name": "meter counter output to file",
                                                "filename": "/var/tmp/meascache.txt",
                                                "createDir": false,
                                                "overwriteFile": "true",
                                                "x": 680,
                                                "y": 280,
                                                "wires": []
                                                "id": "11f1e54.721221b",
                                                "type": "mysencap",
                                                "name": "V_VAR1 (Wh node 99)",
                                                "nodeid": "99",
                                                "childid": "10",
                                                "subtype": "24",
                                                "internal": 0,
                                                "ack": false,
                                                "msgtype": "1",
                                                "presentationtype": 0,
                                                "presentationtext": "",
                                                "firmwarename": "",
                                                "x": 660,
                                                "y": 240,
                                                "wires": [
                                                        "9d92273c.626dd8"
                                                "id": "acfe3226.5301d",
                                                "type": "serial-port",
                                                "z": "",
                                                "serialport": "/dev/ttyUTILITY",
                                                "serialbaud": "115200",
                                                "databits": "8",
                                                "parity": "none",
                                                "stopbits": "1",
                                                "newline": "\\n",
                                                "bin": "false",
                                                "out": "char",
                                                "addchar": true
                                                "id": "67deb464.98214c",
                                                "type": "tab",
                                                "label": "Mysensors"
                                                "id": "5b8bba4c.a47444",
                                                "name": "Mysensors NRF",
                                                "serial": "821a7286.7de59",
                                                "x": 200,
                                                "y": 460,
                                                "wires": [
                                                        "a056d087.fb87f",
                                                        "8cb827f.b90b8d8"
                                                "id": "47b5936e.b84a6c",
                                                "type": "serial out",
                                                "x": 1340,
                                                "y": 180,
                                                "wires": []
                                                "id": "4755dfb8.b8aa2",
                                                "name": "Domoticz",
                                                "serial": "b5105521.4aefa8",
                                                "x": 1320,
                                                "y": 420,
                                                "wires": []
                                                "id": "8b4a855.f74b578",
                                                "type": "debug",
                                                "name": "Mysensors in",
                                                "active": false,
                                                "console": "false",
                                                "complete": "true",
                                                "x": 1110,
                                                "y": 340,
                                                "wires": []
                                                "id": "8caee560.735118",
                                                "type": "subflow:2257718.fdda88e",
                                                "x": 190,
                                                "y": 640,
                                                "wires": [
                                                        "44592b43.bba6d4",
                                                        "d7b40093.e136f"
                                                "id": "44592b43.bba6d4",
                                                "type": "debug",
                                                "name": "Energy meter output",
                                                "active": false,
                                                "console": "false",
                                                "complete": "true",
                                                "x": 420,
                                                "y": 640,
                                                "wires": []
                                                "id": "9e471178.61b8f",
                                                "type": "subflow:bed2e35d.412d2",
                                                "name": "",
                                                "x": 420,
                                                "y": 220,
                                                "wires": [
                                                        "173aba02.e8c546",
                                                        "9aecc18f.21f6d"
                                                "id": "9bdc2a5b.6423d8",
                                                "name": "Domoticz out",
                                                "x": 1110,
                                                "y": 420,
                                                "wires": [
                                                        "4755dfb8.b8aa2"
                                                "id": "9ebb1391.6144f",
                                                "type": "debug",
                                                "name": "gw debug",
                                                "active": false,
                                                "console": "false",
                                                "complete": "true",
                                                "x": 1320,
                                                "y": 480,
                                                "wires": []
                                                "id": "49c6c17b.b6394",
                                                "type": "subflow:4c13992e.b3ec68",
                                                "x": 1110,
                                                "y": 480,
                                                "wires": [
                                                        "9ebb1391.6144f"
                                                "id": "602db35f.9fd24c",
                                                "name": "Domoticz (20)",
                                                "x": 190,
                                                "y": 220,
                                                "wires": [
                                                        "9e471178.61b8f"
                                                "id": "173aba02.e8c546",
                                                "type": "debug",
                                                "name": "Domoticz in",
                                                "active": false,
                                                "console": "false",
                                                "complete": "payload",
                                                "x": 650,
                                                "y": 180,
                                                "wires": []
                                                "id": "3ff64036.ae116",
                                                "type": "subflow:9b272654.9ad688",
                                                "name": "InfluxDB",
                                                "x": 1100,
                                                "y": 380,
                                                "wires": [
                                                        "aec232d3.2860b"
                                                        "1d454a20.ff7ae6"
                                                "id": "aec232d3.2860b",
                                                "type": "debug",
                                                "name": "",
                                                "active": false,
                                                "console": "false",
                                                "complete": "true",
                                                "x": 1310,
                                                "y": 340,
                                                "wires": []
                                                "id": "a056d087.fb87f",
                                                "type": "change",
                                                "name": "mark NRF",
                                                "rules": [
                                                        "t": "set",
                                                        "p": "radio",
                                                        "pt": "msg",
                                                        "to": "nrf",
                                                        "tot": "str"
                                                "action": "",
                                                "property": "",
                                                "from": "",
                                                "to": "",
                                                "reg": false,
                                                "x": 390,
                                                "y": 480,
                                                "wires": [
                                                        "581b2ac8.2248c4"
                                                "id": "ba16f31f.9adc5",
                                                "type": "change",
                                                "name": "mark RFM",
                                                "rules": [
                                                        "t": "set",
                                                        "p": "radio",
                                                        "pt": "msg",
                                                        "to": "rfm",
                                                        "tot": "str"
                                                "action": "",
                                                "property": "",
                                                "from": "",
                                                "to": "",
                                                "reg": false,
                                                "x": 390,
                                                "y": 520,
                                                "wires": [
                                                        "581b2ac8.2248c4"
                                                "id": "5990dc86.7a2ef4",
                                                "type": "function",
                                                "name": "net detect",
                                                "func": "var net = flow.get('network') || {};\nvar msg2 = {};\nnet[msg.nodeId] = msg.radio;\nflow.set('network', net);\nmsg2.payload = net;\nreturn [msg, msg2];",
                                                "outputs": "2",
                                                "noerr": 0,
                                                "x": 720,
                                                "y": 500,
                                                "wires": [
                                                        "1202b756.eb6449"
                                                        "ee23ee4a.b5f14"
                                                "id": "ee23ee4a.b5f14",
                                                "type": "debug",
                                                "name": "",
                                                "active": false,
                                                "console": "false",
                                                "complete": "false",
                                                "x": 890,
                                                "y": 520,
                                                "wires": []
                                                "id": "581b2ac8.2248c4",
                                                "name": "",
                                                "x": 570,
                                                "y": 500,
                                                "wires": [
                                                        "5990dc86.7a2ef4",
                                                        "b10cb69c.3e3d18",
                                                        "ea57b38e.eecb5"
                                                "id": "1202b756.eb6449",
                                                "name": "",
                                                "x": 890,
                                                "y": 480,
                                                "wires": [
                                                        "8b4a855.f74b578",
                                                        "49c6c17b.b6394",
                                                        "9bdc2a5b.6423d8",
                                                        "3ff64036.ae116"
                                                "id": "22f329c0.24f896",
                                                "type": "function",
                                                "name": "Net switch",
                                                "func": "var net = flow.get('network');\nmsg_nrf = null;\nmsg_rfm = null;\nmsg_nodered = null;\nif (msg.nodeId in net) {\n    var network = net[msg.nodeId];\n    if (network == 'rfm') msg_rfm = msg;\n    if (network == 'nrf') msg_nrf = msg;\n    if (network == 'nodered') msg_nodered = msg;\n} else {\n    msg_nrf = msg;\n    msg_rfm = msg;\n    msg_nodered = msg;\n}\nreturn [msg_nrf,msg_rfm, msg_nodered];\n",
                                                "outputs": "3",
                                                "noerr": 0,
                                                "x": 890,
                                                "y": 220,
                                                "wires": [
                                                        "56c9c62f.f1cbc8"
                                                        "4c477db.4619e84"
                                                "id": "9aecc18f.21f6d",
                                                "name": "",
                                                "x": 650,
                                                "y": 220,
                                                "wires": [
                                                        "22f329c0.24f896",
                                                        "b10cb69c.3e3d18"
                                                "id": "56c9c62f.f1cbc8",
                                                "name": "",
                                                "x": 1110,
                                                "y": 180,
                                                "wires": [
                                                        "47b5936e.b84a6c",
                                                        "932ebb67.4968d8"
                                                "id": "4c477db.4619e84",
                                                "name": "",
                                                "x": 1110,
                                                "y": 240,
                                                "wires": [
                                                        "6b2fe680.509218",
                                                        "aac8db1a.8aa468"
                                                "id": "932ebb67.4968d8",
                                                "type": "debug",
                                                "name": "msg_nrf",
                                                "active": false,
                                                "console": "false",
                                                "x": 1320,
                                                "y": 140,
                                                "wires": []
                                                "id": "6b2fe680.509218",
                                                "type": "debug",
                                                "name": "msg_rfm",
                                                "active": false,
                                                "console": "false",
                                                "x": 1320,
                                                "y": 280,
                                                "wires": []
                                                "id": "8919748d.f19738",
                                                "type": "debug",
                                                "name": "RFM Input",
                                                "active": false,
                                                "console": "false",
                                                "x": 390,
                                                "y": 560,
                                                "wires": []
                                                "id": "8155e57b.a7b2e8",
                                                "name": "Mysensors RFM",
                                                "serial": "48886e04.c4cc6",
                                                "x": 200,
                                                "y": 540,
                                                "wires": [
                                                        "ba16f31f.9adc5",
                                                        "8919748d.f19738"
                                                "id": "aac8db1a.8aa468",
                                                "x": 1340,
                                                "y": 240,
                                                "wires": []
                                                "id": "8cb827f.b90b8d8",
                                                "type": "debug",
                                                "name": "NRF input",
                                                "active": false,
                                                "console": "false",
                                                "x": 380,
                                                "y": 440,
                                                "wires": []
                                                "id": "b10cb69c.3e3d18",
                                                "type": "link out",
                                                "name": "UI link",
                                                "links": [
                                                    "2f8a6093.73ef7",
                                                    "6d7cc489.0bb81c",
                                                    "ad2dd4f0.d2c718",
                                                    "d6fb4a23.fcf218"
                                                "x": 755,
                                                "y": 320,
                                                "wires": []
                                                "id": "cc31c979.e15578",
                                                "type": "link in",
                                                "name": "",
                                                "links": [
                                                    "5d82dd49.5350d4"
                                                "x": 755,
                                                "y": 360,
                                                "wires": [
                                                        "1202b756.eb6449",
                                                        "22f329c0.24f896"
                                                "id": "d7b40093.e136f",
                                                "type": "change",
                                                "name": "mark nodered",
                                                "rules": [
                                                        "t": "set",
                                                        "p": "radio",
                                                        "pt": "msg",
                                                        "to": "nodered",
                                                        "tot": "str"
                                                "action": "",
                                                "property": "",
                                                "from": "",
                                                "to": "",
                                                "reg": false,
                                                "x": 400,
                                                "y": 600,
                                                "wires": [
                                                        "581b2ac8.2248c4"
                                                "id": "1d454a20.ff7ae6",
                                                "type": "link out",
                                                "name": "Trigger KWH to dashboard",
                                                "links": [
                                                    "1e4f3d9a.978582"
                                                "x": 1275,
                                                "y": 380,
                                                "wires": []
                                                "id": "ea57b38e.eecb5",
                                                "type": "debug",
                                                "name": "",
                                                "active": false,
                                                "console": "false",
                                                "complete": "true",
                                                "x": 710,
                                                "y": 580,
                                                "wires": []
                                                "id": "821a7286.7de59",
                                                "z": "",
                                                "serialport": "/dev/ttyNRF24",
                                                "databits": "8",
                                                "parity": "none",
                                                "stopbits": "1",
                                                "newline": "\\n",
                                                "bin": "false",
                                                "out": "char",
                                                "addchar": true
                                                "id": "b5105521.4aefa8",
                                                "serialport": "/dev/ttyS80",
                                                "databits": "8",
                                                "parity": "none",
                                                "stopbits": "1",
                                                "newline": "\\n",
                                                "bin": "false",
                                                "out": "char",
                                                "addchar": true
                                                "id": "48886e04.c4cc6",
                                                "serialport": "/dev/ttyRFM69",
                                                "databits": "8",
                                                "parity": "none",
                                                "stopbits": "1",
                                                "newline": "\\n",
                                                "bin": "false",
                                                "out": "char",
                                                "addchar": true
                                          tbowmoT
                                          tbowmoT
                                          tbowmo
                                          @gohan
                                          In theory it should work, as you can set node-red up to receive MQTT messages, which could then be manipulated, and send off to domoticz (if needed).
                                          I think that @Anticimex made some experiments with mqtt/ethernet gateways using node-red. But can't remember details..
                                          AnticimexA 1 Reply Last reply
