  3. nRF5 action!
nRF5 action!
    @NeverDie not sure if it applies to this case, but at 18:04 in https://youtu.be/JXQLI-nXqmQ it is mentioned that the chip's identifier needs to be included in some list when the softdevice is compiled (or something along those lines, I am not yet familiar with the vocabulary).
    My understanding (which may be wrong) is that in this context a "softdevice" is a veiled reference to the bluetooth stack and/or related bluetooth code, which at present the mysensors code isn't using. In any case, when I programmed both the adafruit and the sparkfun using the mysensors code, I didn't include a chip identifier in a list, nor any soft devices, and it worked anyway.
    @NeverDie sorry, the ID doesn't need to be in the softdevice. It needs to be in the code for the black magic probe. Might still not be related though.
      @NeverDie stupid question: did you try to power it NOT from DK board and vise versa?
      Just now tried it, and unfortunately it didn't make a difference. :(
      The actual text of the error message that I always receive is:
      c:/users/david/appdata/local/arduino15/packages/sandeepmistry/tools/gcc-arm-none-eabi/5_2-2015q4/bin/../lib/gcc/arm-none-eabi/5.2.1/../../../../arm-none-eabi/bin/ld.exe: warning: changing start of section .heap by 4 bytes
      c:/users/david/appdata/local/arduino15/packages/sandeepmistry/tools/gcc-arm-none-eabi/5_2-2015q4/bin/../lib/gcc/arm-none-eabi/5.2.1/../../../../arm-none-eabi/bin/ld.exe: warning: changing start of section .stack_dummy by 4 bytes
      Sketch uses 26932 bytes (5%) of program storage space. Maximum is 524288 bytes.
      Licensed under GNU GPL v2
      For bug reports, read
      debug_level: 0
      swd
      adapter speed: 10000 kHz
      xPSR: 0x01000000 pc: 0x000008e4 msp: 0x20000400
      ** Programming Started **
      auto erase enabled
      Error: failed erasing sectors 0 to 6
      in procedure 'program'
      in procedure 'program_error' called at file "embedded:startup.tcl", line 510
      the selected serial port at file "embedded:startup.tcl", line 454
      So maybe the root of the problem is that I need to do something to enable it to erase the protected sector at 0x0? That seems to be the point after which everything falls apart.
      Could this be related to the readback protection? The video I linked before recommends issuing "monitor erase_mass" to completely reset the device and any protection.
      NeverDieN d00616D 2 Replies Last reply
        #370
        Good one! I have a hunch you may have just cracked the problem.
        I see no harm in trying a mass erase before the programming step, so I'll give it a go.
          Is no one else able to download the files either?
          From the forum, no. From hightail, yes.
          I don't know which program to open them in though.
          wrote on last edited by Nca78
          #371
          Direct click fails. But if you press Control key while you click, to open in a new tab, then you should be able to download files from the forum ;)
            d00616D
            d00616D
            d00616
            This is a simple sketch for mass erasing a nRF5 MCU. Just compile it with the option a SoftDevice is present, when a SoftDevice is present:
            #include "nrf.h"
            void wait_for_ready()
                    while (NRF_NVMC->READY == NVMC_READY_READY_Busy) {
                    // Enable erasing flash
                    NRF_NVMC->CONFIG = NVMC_CONFIG_WEN_Een << NVMC_CONFIG_WEN_Pos;
                    wait_for_ready();
                    // Erase Flash and UICR
                    NRF_NVMC->ERASEALL = 1;
                    wait_for_ready();
                    // Disable erasing
                    NRF_NVMC->CONFIG = NVMC_CONFIG_WEN_Ren << NVMC_CONFIG_WEN_Pos;
                    wait_for_ready();
              #373
              You would think that the programmer device would just do a mass erase as part of its standard procedure, though, so it's a bit odd that it would require me to do it manually. The mass erase that Roger Clark did with his Black Magic Probe seemed nearly instant. I don't have a Black Magic Probe though.
              In any case, I can't use the above sketch to do ia mass erase because it presumes I can already load a sketch onto the target--i.e. it presumes the fundamental problem is solved already.
              What's the preferred way to do a mass erase? I seem to remember seeing a mass erase as an option in one of the Nordic utility softwares, but I don't recall now which one. Anyone happen to know?
                #374
                Looking further into it, what I may need to first do is UNLOCK the Ebyte module, which appears to be a separate step from mass erasing: https://mcuoneclipse.com/2014/10/05/unlocking-and-erasing-flash-with-segger-j-link/
                  Toyman
                  @NeverDie may be some hints here:
                  https://learn.adafruit.com/bluefruit-nrf52-feather-learning-guide/flashing-the-bootloader
                  And also pay attention to their Adalink tool. The support for nrf52 was added recently.
                    #376
                    By switching to a Windows 10 computer, I was able to get J-link working over USB from windows. Then I opened up J-Link Command, which mostly utiizes a command line interface. It turns out that for unlocking, the nRF52836 is not on the list of devices (see below), so I simply then issued a mass erase command, which looks as though it may have worked:
                    J-Link>unlock
                    Syntax: unlock <DeviceName>
                    ---Supported devices---
                      LM3Sxxx [<Auto>]
                      Kinetis
                      EFM32Gxxx
                      LPC5460x
                    J-Link>erase
                    Erasing device (nRF52832_xxAA)...
                    J-Link: Flash download: Total time needed: 0.336s (Prepare: 0.064s, Compare: 0.000s, Erase: 0.263s, Program: 0.000s, Verify: 0.000s, Restore: 0.008s)
                    Erasing done.
                    J-Link>mem 0 100
                    00000000 = FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
                    00000010 = FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
                    00000020 = FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
                    00000030 = FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
                    00000040 = FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
                    00000050 = FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
                    00000060 = FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
                    00000070 = FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
                    00000080 = FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
                    00000090 = FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
                    000000A0 = FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
                    000000B0 = FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
                    000000C0 = FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
                    000000D0 = FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
                    000000E0 = FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
                    000000F0 = FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
                    J-Link>
                    Nca78N 1 Reply Last reply
                      I received the following message from the Ebyte seller:
                      Sorry that the two files are incorrect, please just ignore or delete them.
                      We will send correct files later.
                      Thank you!
                        #378
                        It worked! After doing the above mass erase, the nRF52832 Ebyte Module successfully programmed from the NRF52 DK. I uploaded the mysensors lightsensor sketch, and the serialGateway running on the NRF52 DK is receiving its messages. :)
                        Many thanks to mfalkvidd for his mass erase suggestion and for his link to the Roger Clark youtube video, which had further mass erase commentary.
                        Also, many thanks to d00616 for his excellent guide:
                        https://www.openhardware.io/view/376/MySensors-NRF5-Platform
                        Without that, I would have been lost on how to set anything up.
                        Thanks to everyone else too who made comments and suggestions. This has been a great group effort with a successful outcome. :) :) :)
                          Toyman
                          @NeverDie wow!!! Will you write a short tutorial? Is mas erase needed for EVERY time the sketch is uploaded?
                          • Nca78N
                            That's great news @NeverDie, thank you for your efforts and thank you also to everyone who helped !
                            My modules will arrive tomorrow or on Wednesday and you have saved me hours of suffering :D
                              #381
                              Just now did a very quick range test, and the Ebyte nRF52832 module seems roughly comparable to the nRF52 DK for range. i.e. much better than the Adafruit nRF52832 Feather and also much better than the non-amplified nRF24L01+'s. So, whew! What a relief that is. At least for me, that means I won't need to wait for the nRF52840.
                              So, now the next question is whether the Ebyte nRF52832 can be made to run in DCDC mode, instead of LDO mode, to make it more suited for battery operation. At the moment, I'm not even sure how big or small a power savings that would equate to. Anyone know?
                              d00616D 1 Reply Last reply
                                d00616D
                                d00616D
                                d00616
                                So, now the next question is whether the Ebyte nRF52832 can be made to run in DCDC mode, instead of LDO mode, to make it more suited for battery operation. However, at the moment, I'm not even sure how big or small a power savings that would equate to. Anyone know?
                                There is no DCDC support for ESB radio at the moment. The DCDC mode is only efficient on high current states, like enabled radio and should only enabled in an defined voltage range.
                                • T Toyman
                                  Roger Clark says not. I can't say for sure yet, as I haven't yet tried. I think the answer will probably turn out to be that if you aren't doing anything to specifically protect certain flash memory locations after programming it, then you would only need to do it once to undo and erase whatever came on the chip from the factory.
                                    #384
                                    like said above DCDC needs to be enabled. Then, the mcu will automatically switch between LDO mode (for light loads) and DCDC mode for higher currents loads like when mcu is wake up, or during radio comms etc.. Can be interesting in some cases.
                                    in datasheet, DCDC mode can divide by two mcu power consumption. Side effects could be -1dB sensitivity, so it's better to filter well by using two inductors (see ref design)
                                    • d00616D
                                      d00616D
                                      d00616
                                      I have found a simple way to mass erase the MCU. Select "None" as SoftDevice and use the "Burn Bootloader" function. There is an error generated but the device is erased.
                                        #386
                                        I'm going to try this one too when I have time wt51822-s4at
                                        I used your link to order some of those modules just now. They're so small and cheap that they might be nice for simple things.
                                        With the Ebyte module now working, I'm feeling emboldened again. :)
                                        mtiutiuM 1 Reply Last reply
                                          Which nRF52832 pins do I use for the mysensors implementation of UART Tx and Rx on the nRF52832? When I looked in Nordic's nRF52832 datasheet (http://infocenter.nordicsemi.com/pdf/nRF52832_PS_v1.3.pdf), I didn't see any pins specifically assigned/reserved for that purpose.
