  3. nRF5 action!
nRF5 action!
    They sent me two files, but I have no idea what they are, or how to open them. Maybe someone here recognizes them or can open them?
    0_1500890784640_E73-2G4M04S-PCBLIB.PCBLIB
    0_1500890793687_E73-2G4M04S-PCB-V1.0.PCBDOCPreview
    Opening the first file in notepad, I notice that it says, "PCB 6.0 Binary Library File ". I had asked Ebyte for either the module schematic or a reference design using their part, so I'm guessing this is it, in some sort of PCB CAD file.
    mtiutiuM
    mtiutiuM
    mtiutiu
    #352
    Can you upload those files somewhere so that I can download them? I can't do that from the links you pasted here in this forum.
    I also found this altium -> kicad online converter but I don't know how well it works.
    • mtiutiuM mtiutiu
      https://spaces.hightail.com/space/WMbime1pXn
      mtiutiuM 1 Reply Last reply
        mtiutiuM
        mtiutiuM
        mtiutiu
        Doesn't work for me so maybe it would be best to obtain a pdf or something readable for all of us from the manufacturer.
          Is no one else able to download the files either?
          • Nca78N Nca78
            @NeverDie how many GND pins did you connect ?
            It might be a stupid suggestion but maybe all GND pins are not connected together ?
            Good question. I connected to just one GND pin. However, I just now checked with a DMM, and all the exposed GND pins on the module have continuity to one another. So, based on that, I'm assuming any additional outside connections would be redundant anyway?
              From the forum, no. From hightail, yes.
              I don't know which program to open them in though.
              NeverDieN Nca78N 2 Replies Last reply
                #358
                The current theory (see above) is that maybe it's Altium Designer, which has a free viewer.
                  One thing I notice on the Ebyte module is that no RESET pin is exposed. Isn't that a bit odd?
                  Also, there appears to be a typo on the silkscreen, where there are two pin 7's on the silkscreen, but probably one of them is actually pin 6.
                  #359
                  Correction: According to the Nordic datasheet, PO.21, which is exposed on the Ebyte modle, can also serve as the reset pin. I was thrown off because Sparkfun labeled it RESET on their board's silkscreen, not "PO.21".
                  • Nca78N Nca78
                    @mtiutiu I have ordered a few of those modules too, the big question is antenna performance as it seems rather small.
                    It's incredibly cheap and has enough pins to drive most of the MySensors nodes, too bad it's missing the 32K crystal for low power Bluetooth :(
                    Do let us know if either of you are able to program it. After this Ebyte experience, I won't be taking it for granted anymore.
                      #361
                      @NeverDie not sure if it applies to this case, but at 18:04 in https://youtu.be/JXQLI-nXqmQ it is mentioned that the chip's identifier needs to be included in some list when the softdevice is compiled (or something along those lines, I am not yet familiar with the vocabulary).
                        #362
                        My understanding (which may be wrong) is that in this context a "softdevice" is a veiled reference to the bluetooth stack and/or related bluetooth code, which at present the mysensors code isn't using. In any case, when I programmed both the adafruit and the sparkfun using the mysensors code, I didn't include a chip identifier in a list, nor any soft devices, and it worked anyway.
                        d00616D mfalkviddM 2 Replies Last reply
                          I was thinking that maybe the Ebyte module is stuck in some kind of reset mode, but I just now checked pin P0.21 (the reset pin), and it measures high at 3.3v. This is the same as for the Sparkfun board, which I have no trouble programming. Reset is active low.
                          T JokgiJ 2 Replies Last reply
                            d00616D
                            d00616D
                            d00616
                            I haven't tested MySensors with a present SoftDevice. The drivers/NVM code (EEPROM emulation) conflicts with the DFU bootloader.
                            It's better to see the SoftDevice as an Operating System providing BLE functionality and some hardware abstraction, while MySensors is directly ported to the hardware.
                              Toyman
                              @NeverDie stupid question: did you try to power it NOT from DK board and vise versa?
                              • T Toyman
                                #366
                                Thanks for the suggestion! So far I've tried powering it from a USB 3.3v source (which is how I successfully programmed the adafruit and sparkfun boards), but I'll now try powering it from the DK and see if it makes a difference.
                                By the way, I found an alternate way to confirm that the board is using the built-in LDO rather than the DCDC converter. DEC4 is the output of the LDO, and it measures 1.3v (which is also the expected voltage output by the LDO if it were active). DCC is the output of the DCDC converter, and it measures 0.0v. So, empirical confirmation of what you all inferred earlier. :)
                                • T Toyman
                                  #367
                                  Just now tried it, and unfortunately it didn't make a difference. :(
                                  The actual text of the error message that I always receive is:
                                  c:/users/david/appdata/local/arduino15/packages/sandeepmistry/tools/gcc-arm-none-eabi/5_2-2015q4/bin/../lib/gcc/arm-none-eabi/5.2.1/../../../../arm-none-eabi/bin/ld.exe: warning: changing start of section .heap by 4 bytes
                                  c:/users/david/appdata/local/arduino15/packages/sandeepmistry/tools/gcc-arm-none-eabi/5_2-2015q4/bin/../lib/gcc/arm-none-eabi/5.2.1/../../../../arm-none-eabi/bin/ld.exe: warning: changing start of section .stack_dummy by 4 bytes
                                  Sketch uses 26932 bytes (5%) of program storage space. Maximum is 524288 bytes.
                                  Licensed under GNU GPL v2
                                  For bug reports, read
                                  debug_level: 0
                                  swd
                                  adapter speed: 10000 kHz
                                  xPSR: 0x01000000 pc: 0x000008e4 msp: 0x20000400
                                  ** Programming Started **
                                  auto erase enabled
                                  Error: failed erasing sectors 0 to 6
                                  in procedure 'program'
                                  in procedure 'program_error' called at file "embedded:startup.tcl", line 510
                                  the selected serial port at file "embedded:startup.tcl", line 454
                                  So maybe the root of the problem is that I need to do something to enable it to erase the protected sector at 0x0? That seems to be the point after which everything falls apart.
                                    @NeverDie sorry, the ID doesn't need to be in the softdevice. It needs to be in the code for the black magic probe. Might still not be related though.
                                      debug_level: 0
                                      swd
                                      auto erase enabled
                                      Could this be related to the readback protection? The video I linked before recommends issuing "monitor erase_mass" to completely reset the device and any protection.
                                      NeverDieN d00616D 2 Replies Last reply
                                        #370
                                        Good one! I have a hunch you may have just cracked the problem.
                                        I see no harm in trying a mass erase before the programming step, so I'll give it a go.
                                          wrote on last edited by Nca78
                                          #371
                                          Direct click fails. But if you press Control key while you click, to open in a new tab, then you should be able to download files from the forum ;)
