  3. nRF5 action!
nRF5 action!
    One thing I notice on the Ebyte module is that no RESET pin is exposed. Isn't that a bit odd?
    Also, there appears to be a typo on the silkscreen, where there are two pin 7's on the silkscreen, but probably one of them is actually pin 6.
    #359
    Correction: According to the Nordic datasheet, PO.21, which is exposed on the Ebyte modle, can also serve as the reset pin. I was thrown off because Sparkfun labeled it RESET on their board's silkscreen, not "PO.21".
    • Nca78N Nca78
      @mtiutiu I have ordered a few of those modules too, the big question is antenna performance as it seems rather small.
      It's incredibly cheap and has enough pins to drive most of the MySensors nodes, too bad it's missing the 32K crystal for low power Bluetooth :(
      Do let us know if either of you are able to program it. After this Ebyte experience, I won't be taking it for granted anymore.
        #361
        @NeverDie not sure if it applies to this case, but at 18:04 in https://youtu.be/JXQLI-nXqmQ it is mentioned that the chip's identifier needs to be included in some list when the softdevice is compiled (or something along those lines, I am not yet familiar with the vocabulary).
          #362
          My understanding (which may be wrong) is that in this context a "softdevice" is a veiled reference to the bluetooth stack and/or related bluetooth code, which at present the mysensors code isn't using. In any case, when I programmed both the adafruit and the sparkfun using the mysensors code, I didn't include a chip identifier in a list, nor any soft devices, and it worked anyway.
          d00616D mfalkviddM 2 Replies Last reply
            I was thinking that maybe the Ebyte module is stuck in some kind of reset mode, but I just now checked pin P0.21 (the reset pin), and it measures high at 3.3v. This is the same as for the Sparkfun board, which I have no trouble programming. Reset is active low.
            T JokgiJ 2 Replies Last reply
              d00616D
              d00616D
              d00616
              I haven't tested MySensors with a present SoftDevice. The drivers/NVM code (EEPROM emulation) conflicts with the DFU bootloader.
              It's better to see the SoftDevice as an Operating System providing BLE functionality and some hardware abstraction, while MySensors is directly ported to the hardware.
                Toyman
                @NeverDie stupid question: did you try to power it NOT from DK board and vise versa?
                • T Toyman
                  #366
                  Thanks for the suggestion! So far I've tried powering it from a USB 3.3v source (which is how I successfully programmed the adafruit and sparkfun boards), but I'll now try powering it from the DK and see if it makes a difference.
                  By the way, I found an alternate way to confirm that the board is using the built-in LDO rather than the DCDC converter. DEC4 is the output of the LDO, and it measures 1.3v (which is also the expected voltage output by the LDO if it were active). DCC is the output of the DCDC converter, and it measures 0.0v. So, empirical confirmation of what you all inferred earlier. :)
                  • T Toyman
                    #367
                    Just now tried it, and unfortunately it didn't make a difference. :(
                    The actual text of the error message that I always receive is:
                    c:/users/david/appdata/local/arduino15/packages/sandeepmistry/tools/gcc-arm-none-eabi/5_2-2015q4/bin/../lib/gcc/arm-none-eabi/5.2.1/../../../../arm-none-eabi/bin/ld.exe: warning: changing start of section .heap by 4 bytes
                    c:/users/david/appdata/local/arduino15/packages/sandeepmistry/tools/gcc-arm-none-eabi/5_2-2015q4/bin/../lib/gcc/arm-none-eabi/5.2.1/../../../../arm-none-eabi/bin/ld.exe: warning: changing start of section .stack_dummy by 4 bytes
                    Sketch uses 26932 bytes (5%) of program storage space. Maximum is 524288 bytes.
                    Licensed under GNU GPL v2
                    For bug reports, read
                    debug_level: 0
                    swd
                    adapter speed: 10000 kHz
                    xPSR: 0x01000000 pc: 0x000008e4 msp: 0x20000400
                    ** Programming Started **
                    auto erase enabled
                    Error: failed erasing sectors 0 to 6
                    in procedure 'program'
                    in procedure 'program_error' called at file "embedded:startup.tcl", line 510
                    the selected serial port at file "embedded:startup.tcl", line 454
                    So maybe the root of the problem is that I need to do something to enable it to erase the protected sector at 0x0? That seems to be the point after which everything falls apart.
                      @NeverDie sorry, the ID doesn't need to be in the softdevice. It needs to be in the code for the black magic probe. Might still not be related though.
                        debug_level: 0
                        swd
                        auto erase enabled
                        Could this be related to the readback protection? The video I linked before recommends issuing "monitor erase_mass" to completely reset the device and any protection.
                        NeverDieN d00616D 2 Replies Last reply
                          #370
                          Good one! I have a hunch you may have just cracked the problem.
                          I see no harm in trying a mass erase before the programming step, so I'll give it a go.
                            Is no one else able to download the files either?
                            From the forum, no. From hightail, yes.
                            I don't know which program to open them in though.
                            wrote on last edited by Nca78
                            #371
                            Direct click fails. But if you press Control key while you click, to open in a new tab, then you should be able to download files from the forum ;)
                              d00616D
                              d00616D
                              d00616
                              This is a simple sketch for mass erasing a nRF5 MCU. Just compile it with the option a SoftDevice is present, when a SoftDevice is present:
                              #include "nrf.h"
                              void wait_for_ready()
                                      while (NRF_NVMC->READY == NVMC_READY_READY_Busy) {
                                      // Enable erasing flash
                                      NRF_NVMC->CONFIG = NVMC_CONFIG_WEN_Een << NVMC_CONFIG_WEN_Pos;
                                      wait_for_ready();
                                      // Erase Flash and UICR
                                      NRF_NVMC->ERASEALL = 1;
                                      wait_for_ready();
                                      // Disable erasing
                                      NRF_NVMC->CONFIG = NVMC_CONFIG_WEN_Ren << NVMC_CONFIG_WEN_Pos;
                                      wait_for_ready();
                                #373
                                You would think that the programmer device would just do a mass erase as part of its standard procedure, though, so it's a bit odd that it would require me to do it manually. The mass erase that Roger Clark did with his Black Magic Probe seemed nearly instant. I don't have a Black Magic Probe though.
                                In any case, I can't use the above sketch to do ia mass erase because it presumes I can already load a sketch onto the target--i.e. it presumes the fundamental problem is solved already.
                                What's the preferred way to do a mass erase? I seem to remember seeing a mass erase as an option in one of the Nordic utility softwares, but I don't recall now which one. Anyone happen to know?
                                  #374
                                  Looking further into it, what I may need to first do is UNLOCK the Ebyte module, which appears to be a separate step from mass erasing: https://mcuoneclipse.com/2014/10/05/unlocking-and-erasing-flash-with-segger-j-link/
                                    Toyman
                                    @NeverDie may be some hints here:
                                    https://learn.adafruit.com/bluefruit-nrf52-feather-learning-guide/flashing-the-bootloader
                                    And also pay attention to their Adalink tool. The support for nrf52 was added recently.
                                      #376
                                      By switching to a Windows 10 computer, I was able to get J-link working over USB from windows. Then I opened up J-Link Command, which mostly utiizes a command line interface. It turns out that for unlocking, the nRF52836 is not on the list of devices (see below), so I simply then issued a mass erase command, which looks as though it may have worked:
                                      J-Link>unlock
                                      Syntax: unlock <DeviceName>
                                      ---Supported devices---
                                        LM3Sxxx [<Auto>]
                                        Kinetis
                                        EFM32Gxxx
                                        LPC5460x
                                      J-Link>erase
                                      Erasing device (nRF52832_xxAA)...
                                      J-Link: Flash download: Total time needed: 0.336s (Prepare: 0.064s, Compare: 0.000s, Erase: 0.263s, Program: 0.000s, Verify: 0.000s, Restore: 0.008s)
                                      Erasing done.
                                      J-Link>mem 0 100
                                      00000000 = FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
                                      00000010 = FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
                                      00000020 = FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
                                      00000030 = FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
                                      00000040 = FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
                                      00000050 = FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
                                      00000060 = FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
                                      00000070 = FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
                                      00000080 = FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
                                      00000090 = FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
                                      000000A0 = FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
                                      000000B0 = FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
                                      000000C0 = FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
                                      000000D0 = FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
                                      000000E0 = FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
                                      000000F0 = FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
                                      J-Link>
                                      Nca78N 1 Reply Last reply
                                        I received the following message from the Ebyte seller:
                                        Sorry that the two files are incorrect, please just ignore or delete them.
                                        We will send correct files later.
                                        Thank you!
                                          #378
                                          It worked! After doing the above mass erase, the nRF52832 Ebyte Module successfully programmed from the NRF52 DK. I uploaded the mysensors lightsensor sketch, and the serialGateway running on the NRF52 DK is receiving its messages. :)
                                          Many thanks to mfalkvidd for his mass erase suggestion and for his link to the Roger Clark youtube video, which had further mass erase commentary.
                                          Also, many thanks to d00616 for his excellent guide:
                                          https://www.openhardware.io/view/376/MySensors-NRF5-Platform
                                          Without that, I would have been lost on how to set anything up.
                                          Thanks to everyone else too who made comments and suggestions. This has been a great group effort with a successful outcome. :) :) :)
