  3. RPi as a 'node'?
RPi as a 'node'?
11 Posts 5 Posters 3.7k Views 3 Watching
  • skywatchS Offline
    skywatchS Offline
    skywatch
    Now I have a rpi 2, I am thinking of using the curent one to stream music and video in a room.
    The thought occured to me that I could still attach a nrf24l01+ to this as well as sensors on the gpio. So I wondered if it's possible to have a pi as a node to send back data to the 'base' pi?
    I would think it's possible to do, but how?
    S.
    • B Offline
      B Offline
      Bens
      Hi Skywatch,
      Not sure you are still looking into this.
      It can be done, and I have done it. Actually, all the documentation is there.
      You can directly connect the radio to the Pi2 and you could modify the PiSerialGateway not to act as a gateway, but simply use the sending part.
      Never stop trying
      -Ben
      K 1 Reply Last reply
      • B Bens
        Hi Skywatch,
        K Offline
        K Offline
        Kurtsejr
        @Bens
        Do you have a link to the documentation, please?
        /Kurt
        • T Offline
          T Offline
          TheoL
          I'm also interested in the link
          • skywatchS Offline
            skywatchS Offline
            skywatch
            Ok - long delay I know, but I am now looking at this again.
            Any updates out there?
            • mfalkviddM Online
              mfalkviddM Online
              I'm not sure if anyone has actually tried it, but according to the documentation you can follow the instructions for creating a raspberry pi gateway, and turn it into a node by adding
               --my-gateway=none
              It would be interesting to hear what your use cases are. Wouldn't it be easier to send data over the rpi's network connection?
              • skywatchS Offline
                skywatchS Offline
                skywatch
                Thanks for the fast reply!
                As you know I am still on a learning curve with this, but getting more focused as I go.
                My use case would be mainly to use a raspberry pi zero attached to touch screens at various locations for display and control. I think that this approach would give the best processing bang for the buck, certainly faster at screen refersh and processing that a pro mini. More memory too for the screen as well....
                Secondly I would be thinking of using pi zero with a camera and using motion detection and the possibility to send snapshot images (not sure how to implement this yet!).
                • skywatchS skywatch
                  mfalkviddM Online
                  mfalkviddM Online
                  @skywatch cool ideas. Thanks for sharing.
                  skywatchS 1 Reply Last reply
                    skywatchS Offline
                    skywatchS Offline
                    skywatch
                    @mfalkvidd Thanks for the helpful hints! :) Theres a long cold winter to fill!
                    • mfalkviddM Online
                      mfalkviddM Online
                      • skywatchS Offline
                        skywatchS Offline
                        skywatch
                        I forgot to add that the pi zeros should not be on ethernet or wifi and therefore I would like to do it all via the NRF24L01+. It would probably be cheaper to use android tablets, but that would require wifi (unless anyone has attached a working nrf to a tablet?) and wifi is not that secure.
                        I have a lot to learn before I get to that point though! ;)
