  3. 💬 MDMSGate
💬 MDMSGate
atsha204amysensors gatewayesp8266ethernetmysensorsgatewaynrf24l01usbatmega328rfm69
82 Posts 22 Posters 42.5k Views 25 Watching
  • kalinaK kalina
    New batch of devices is in stock and available now ...
    MagnusF
    @kalina I'm new to "MySensors" and I think this device will suits me very well. My plan is to use MQTT and Wi-Fi mode.
    Is this possible? To use Wi-Fi / Ethernet, as I understand, IP addresses for Gateway, router and controller must be defined but I have read that you in all modes is using the serial gateway sketch which not have IP adresses defined.
    I wonder if there is any other gateway sketch that shall be used or how to solve this?
    kalinaK 1 Reply Last reply
    • M MagnusF
      kalinaK
      kalinaK
      kalina
      #65
      @MagnusF said in 💬 MDMSGate:
      My plan is to use MQTT and Wi-Fi mode. Is this possible?
      Unfortunately, no. This gateway uses a microcontroller PIC18F67J60. Firmware of this uC doesnt support MQTT protocol (in future I probably add this feature). You can only use it as a ethernet gateway. In Wi-Fi mode, the ESP-12 module acts as well as the PIC18F67J60 microcontroller - converts the packets of TCP/IP to UART and vice versa.
      Connection to controller through Ethernet :
      1. Connect MDMSGate to the router (network). After this router will define IP address for gateway through DHCP (for example 192.168.1.6). You also can see this adress in router web interface.
      2. Open web interface of the controller and fill "IP address" and "Port" for the Ethernet gateway.
      3. Click "Connect" button and work!
      Connecting through Wi-Fi a bit more complicated. If you want I can explain.
      • kalinaK
        kalinaK
        kalina
        #66
        I have uploaded a small instruction "MDMSGate. Connection to Domoticz". This instruction explains how connect MDMSGate to Domoticz via LAN.
        • kalinaK
          kalinaK
          kalina
          #67
          Now available in pcb (lot with 10 pcs) ...
            marvin78
            Could you please describe the "WLAN way"? Tank you.
            • M marvin78
              kalinaK
              kalinaK
              kalina
              #69
              @marvin78 Hi, as i understand you got MDMSGate without Wi-Fi (ESP-12), because you didn't specify it in the order. I have written a small manual that describes how to start work in Wi-Fi mode in this case. Please, go to "Design files" menu and download "MDMSGate. Manual for installing Wi-Fi.pdf" file.
              • kalinaK kalina
                marvin78
                wrote on last edited by marvin78
                #70
                @kalina You're right. But it is no problem for me to solder in the ESP-12. So thank you.
                One question: will I be able to use Wifi, Serial OR (not and) LAN if I follow the steps from your instruction? As in just change jumper positions and use the other one? Does the sketch support that?
                • M marvin78
                  kalinaK
                  kalinaK
                  kalina
                  #71
                  @marvin78 said in 💬 MDMSGate:
                  Yes, you're absolutely right. It was the main goal. The mode changing just with change jumpers position. And as for sketch - in all 3 modes it is standard serial gateway sketch. I have written about it befor ....
                  • G
                    G
                    giltesa
                    Hello Kalina,
                    On April 7, I presented my domotics nodes at the Arduino Day in Zaragoza, Spain. Your gateway worked all day like a champion!
                    https://giltesa.com/wp-content/uploads/2018/04/ArduinoDayZgz2018_stand.jpg
                    I have a question, would it be possible to get the Arduino sketch that has recorded the Atmega328P?
                    Is this code? Do you only need that to work for NRF24L01+Ethernet?
                    https://github.com/DmytroKalinkin/MDMS/blob/master/Gateway_2.4GHz/Gateway_2.4GHz.ino
                    Kind regards.
                    • G giltesa
                      Hello Kalina,
                      Kind regards.
                      kalinaK
                      kalinaK
                      kalina
                      #73
                      @giltesa said in 💬 MDMSGate:
                      Nice to hear! MDMSGate is my first and the best device))
                      Is this code? https://github.com/DmytroKalinkin/MDMS/blob/master/Gateway_2.4GHz/Gateway_2.4GHz.ino
                      Yes, MDMSGate is programmed by standard serial gateway sketch.
                      No, I also use (in some case) serial and Wi-Fi connection. For the serial connection just change jumpers position. As for Wi-Fi connection you can read this
                      https://www.openhardware.io/dl/5782866b09fcb093053825e4/design/MDMSGate. Manual for installing Wi-Fi.pdf
                      The sketch the same in all modes.
                      G 1 Reply Last reply
                      • kalinaK kalina
                        G
                        G
                        giltesa
                        wrote on last edited by giltesa
                        #74
                        @kalina
                        I find it surprising that without writing any line of programming code, apart from the constants, the MySensors library takes care of everything, it's great!
                        My intention was to change the channel of the NRF24L01, the transfer speed, and configure the ATSHA204A.
                        I think I read that the MDMSGate does not support MQTT because of hardware stuff, do you plan to release a second version?
                        The truth is that I am not sure that it is essential either, but I ask you out of curiosity.
                        Edit:
                        More questions...
                        Why is the sketch configured with MY_RF24_PA_LEVEL = RF24_PA_LOW? Would not it be better to use the value RF24_PA_HIGH or RF24_PA_MAX?
                        kalinaK AnticimexA 2 Replies Last reply
                        • G giltesa
                          @kalina
                          Edit:
                          More questions...
                          kalinaK
                          kalinaK
                          kalina
                          #75
                          You can make any changes that the MySensors library allows.
                          I am completely satisfied with this version. But despite this,
                          i think about a new version all the time: RS485, Bluetooth, MQTT ... what else???, So, i still don't see "the main feature" of the second version. As soon as i will find it, second version will be released immediately.
                          Because RF24_PA_LOW configuration completely covers an area on which all my nodes are located. And I see no reason to increase the power.
                          • G giltesa
                            @kalina
                            Edit:
                            More questions...
                            AnticimexA
                            AnticimexA
                            Anticimex
                            @giltesa many power their devices through USB on their computers for bringing up nodes.
                            Often the radio is powered by the same source, and driving it at max makes the nrf24 unstable if the power supply is not rock solid.
                            Besides, having the default being at the lowest power, you have reasonable power optimization by default for battery powered nodes.
                            If it does not work you can always gradually crank it up. And not the other way around.
                            • kalinaK
                              kalinaK
                              kalina
                              The new batch of the MDMSGate (without an enclosure and cheaper) is already available....
                              • A
                                Animal64
                                @kalina I'm new to MySensors and exploring if there are gateways that suite my needs. Yours looks particularly interesting. However in this topic I read MQTT is not supported. I assume that this means you cannot run a MQTT broker on the MDMSGate but that it can be an MQTT client correct? Also I do need both RFM69 and NRF2401 radios can both be active at the same time on the device or is it mutually exclusive and does one need a gateway for each radio? Please explain. Many thanx in advance.
                                • A Animal64
                                  kalinaK
                                  kalinaK
                                  kalina
                                  Hi @animal64, we are glad to welcome you in the MySensors community.
                                  I don't use MQTT, but one of users, who took the gateway, did some work in this direction, you can find on this link - https://gitlab.com/denissp/mdmsgate_mqtt/
                                  Yes, for each type of radio module you need your own gateway, its own subnet. This means that two gateways are needed.
                                  If you have any questions, please contact us, we will always be happy to help ;)
                                  • kalinaK
                                    kalinaK
                                    kalina
                                    I am going to production a new batch of gateways, but before that I want to upgrade it. Does anyone have any suggestions for improving current version MDMSGate?
                                    berkseoB 1 Reply Last reply
                                    • kalinaK kalina
                                      berkseoB
                                      berkseoB
                                      berkseo
                                      @kalina said in 💬 MDMSGate:
                                      Hi, put away the black radio and put the EBYTE green radio :). The remaining problems do not concern HW.
                                      ps/ Where have you gone?
                                      • berkseoB berkseo
                                        kalinaK
                                        kalinaK
                                        kalina
                                        Hi @berkseo. Thanks for the suggestion, but could you describe in more detail? As for my TODO list, there is already a task to add 485 interface to the gateway. My latest device "xRoom" have this interface.
                                        I have been working on "xRoom" shield. A small announce:
                                        Do you remember the discussion about multinode? So, it will be available soon))
