  3. 230V power supply to Arduino
67 Posts 25 Posters 78.5k Views 22 Watching
  • jocke4uJ
    jocke4uJ
    jocke4u
    I have a number of sensors powered via 230V USB chargers and it works fine but I would like to have a similar power supply (great if encapsulated) with screw terminals to be placed in a small box.
    Do you have a good option to use? (and if it's easily available in Sweden it's very good :) )
    • axillentA
      axillentA
      axillent
      The one similar to this you can solder on top of your PCB or assemble near your PCB in any case type http://www.aliexpress.com/item/20-pcs-lot-4-8W-400mA-Switching-Power-Supply-Board-Voltage-Regelator-Module-AC-90V-240V/1421878190.html
      5V or 12V version can be easily found
      sense and drive
      • H
        H
        Hausner
        wrote on last edited by Hausner
        I have with succes used these:
        http://www.aliexpress.com/item/Travel-Convenient-EU-Plug-Wall-USB-Charger-Adapter-For-Samsung-Galaxy-S5-S4-S3-Note-3/32220133044.html
        They are really easy to dismatle, and the result is this - https://www.dropbox.com/s/ep43uyve5v0msv6/20141206_214210.jpg?dl=0
        At $1.10 I didn't even think about making my own PSU :)
        jocke4uJ axillentA 2 Replies Last reply
        • tbowmoT
          tbowmoT
          tbowmo
          What is the efficiency of these "cheap" mains -> 12V/5V converters?
          Also, it means that you need a second regulator (be that a linear, or a switching) from 12/5V -> 3.3V.
          If you KNOW what you are doing, you could use SR036 from supertex, that can deliver 3.3V directly from mains (non isolated output).
          it could probably be used for mysensor connected dimers / light switches on mains. (something where human interface is not needed).
          Again, ONLY if you realy know what you are messing with :)
          axillentA 1 Reply Last reply
          • tbowmoT tbowmo
            axillentA
            axillentA
            axillent
            they are quite efficient. 5V version can deliver 400mA while unloaded supply consumes only 0.2W
            output voltage is defined by output resistor divider. I have an experience on changing 12V output to 5V by replacing a single SMD resistor. Theoretically the same way you can get 3.3V directly from the supply.
            that is true. I have the experience with SR036 (SR037 provides 5V output) and can say that you will never find smaller supply. But the output current will not exceed 50mA and this will depends on your mosfet output capability. Such a supply consumes about 1W while unloaded. Etc. not that green from the power consumption. This is my one side SR037 supply:
            if you know what you are doing it is also other choice - linkswitch chips LNK302/304/306. The last one can deliver up to 350mA not isolated power directly 5V or 3.3V. It is as efficient as isolated - unloaded it will consume about 0.2W. A bit bigger than SR036. Easy to construct because you do not need custom transformers. For example Duwi zwave wall switches are using this type of the supply. This is my one side SMD version with regulated output:
            next one is a classical low frequency transformer. The smallest here http://www.hahn-trafo.com/english/pcb-transformers-bv20.php - BV 201 0128 is ideal to power low power arduino device. It will consume unloaded about 1W. Can deliver about 60mA with linear regulator or about 100mA back regulated at 3.3V output. This one is my light controlling arduino using BV 201 0128:
            and the last one is capacitive supply. Most chinice cheap devices are using this type, most cheap supply:
            sense and drive
            tbowmoT themolochT 2 Replies Last reply
            • axillentA axillent
              tbowmoT
              tbowmoT
              tbowmo
              I just took a quick google, where the SR036 showed up, so no in depth analysis of alternatives.
              That one seems very interesting, for powering arduino things (from an efficiency point of view).
              Only one problem, I don't have the time for it at the moment.. I have to restrict my self, in starting new projects :). So for the moment it's battery powered sensors, that are getting my attention,
              • tbowmoT tbowmo
                axillentA
                axillentA
                axillent
                SR036/037 is very hard to purchase. Even ebay/ali you will find very limited proposal.
                It seams that Supertex has stopped a production
                sense and drive
                • H Hausner
                  jocke4uJ
                  jocke4uJ
                  jocke4u
                  Yes, that is an option. I did it with one and it was pretty easy.
                  Also found this https://github.com/openhardwarelabs/arduino-power-supply and I like some parts being isolated/encapsulated .
                  https://raw.githubusercontent.com/openhardwarelabs/arduino-power-supply/master/pictures/IMG_8030.jpg
                  • jocke4uJ jocke4u
                    axillentA
                    axillentA
                    axillent
                    myrra also provides regulated modules without need of external regulator
                    for example this one http://ru.farnell.com/myrra/47121/power-supply-3-3v-2-5w/dp/1825772
                    sense and drive
                    • RJ_MakeR
                      RJ_MakeR
                      RJ_Make
                      What kind of protections are embedded?
                      RJ_Make
                      • RJ_MakeR
                        RJ_MakeR
                        RJ_Make
                        Never mind...
                        http://www.farnell.com/datasheets/606238.pdf
                        RJ_Make
                        • klimK
                          klimK
                          klim
                          SR036/SR037 are discontinued products.
                          Take a look at supertex (microchip) SR086 (Fixed 3.3V) or SR087 (Fixed 5V) or SR10 instead.
                          • axillentA
                            axillentA
                            axillent
                            thanks for the reference. interesting chip even it requires more external parts than sr036/037
                            sr036 is still possible to purchase from China
                            sr086 is available only in brand stores like farnel
                            sense and drive
                            • klimK
                              klimK
                              klim
                              Here i found a size example of that chips:
                              power supply
                              SR086, SR087 and SR10 you can get at ali too.
                              • axillentA
                                axillentA
                                axillent
                                very cool picture! easy to imagine
                                SR10 the most interesting for low power
                                do you have any links to aliexpress?
                                I'm not able to find any new chips
                                sense and drive
                                • klimK
                                  klimK
                                  klim
                                  Hi, sorry not available at aliexpress anymore, maybe it was just temporary.
                                  But the SR10 (fqn is SR10LG-G) is available at RS-Components and Alibaba.
                                  Powering the mcu and some peripherals is ok, but do you know the maximum burst time of the NRF24l01 when sending? As all of the chips are limited in current by a few mA, i'm not shure if it will work reliable. I know that big capacitors can fix such issues, but is it sufficient?
                                  • axillentA
                                    axillentA
                                    axillent
                                    All is fine) I found them at local seller
                                    Will be cool to try
                                    NRF24L01 + MCU needs 15mA
                                    If you have other things to connect you need to count them too
                                    for example SSR needs at least +10mA
                                    I'm currently looking for a small supply for the wall switch build based on arduino.
                                    So, I will need 15 + 10 = 25mA. Both SR086 and SR10LG can be sufficient,
                                    SR10LG datasheet has very clear table - power ability is very depends on input capacitor.
                                    25mA should be not a problem. For 240V you need 0.68uF with full rectifier schema
                                    For 120V you will need at minimum 1uF with full rectifier schema
                                    sense and drive
                                    • H Hausner
                                      axillentA
                                      axillentA
                                      axillent
                                      Just got it today and made some tests. Price is cool, but I will not recommend to use this for loads higher than 500mA and also will not recommend to supply arduino without an additional 1000uF capacitor. It is a conclusion from the measurement:
                                      • without load 5.34V output with 440mV pulsation, 0.1W consuption
                                      • 10 Om load gives 470mA current 4.74V output with 440mV pulsation, 3.5W consuption
                                      • 5 Om load gives 848mA current 4.43V output with 520mV pulsation, 6W consuption
                                      • 3.33 Om load gives 1.06mA current 4.07V output with 880mV pulsation, 7.4W consuption
                                      sense and drive
                                      • tbowmoT
                                        tbowmoT
                                        tbowmo
                                        @axillent
                                        What if you place a 3v3 ldo at the 5V output, what is the ripple then, at the different loads?
                                        • tbowmoT tbowmo
                                          @axillent
                                          axillentA
                                          axillentA
                                          axillent
                                          with good ldo supported by sufficient capacitors it can be fine for arduino
                                          but still I will not recommend to go above 500mA with this supply
                                          sense and drive
