  3. nRF5 action!
nRF5 action!
  • rmtuckerR rmtucker
    Yes being able to change the prescaler dynamically would help a great deal as 125ms / 582.542 hours is not really useful for most applications with a 250ms overrun.
    The sleep() function is now more precise for sleeping <512s:
    https://github.com/mysensors/MySensors/pull/909
    The PR is waiting for merge.
    Hmm just tried the latest commit and it is giving me 306ms for sleep(10000).
    Something not quite right.
    @rmtucker
    How are you measuring how long it's sleeping?
    rmtuckerR 1 Reply Last reply
      @rmtucker
      rmtuckerR
      rmtuckerR
      rmtucker
      @rmtucker
      Just using hwMillis() before and after sleep and subtracting one from the other.
      It was just reading + 250ms until @d00616 commited some changes a few hours ago.
      rmtuckerR NeverDieN 2 Replies Last reply
        @rmtucker
        rmtuckerR
        rmtuckerR
        rmtucker
        something wrong in here:-
        // Calculate sleep time and prescaler
        		if (ms<512000) {
        			// prescaler 0, 30.517 μs resolution -> max 512 s sleep
        			MY_HW_RTC->PRESCALER =  0;
        			// Set compare register to 1/30.517 µs to garantee event triggering
        			// A minimum of 2 ticks must be guaranteed
        			// (1000/32768)<<12 == 125
        			MY_HW_RTC->CC[0] = max((ms<<12 / 125), 2);
        			// 8 Hz -> max 582.542 hours sleep.
        			MY_HW_RTC->PRESCALER = 4095;
        			// Set compare register to 1/125ms
        			MY_HW_RTC->CC[0] = max((ms / 125), 2);
          @rmtucker
          #754
          @rmtucker
          I thought so. The point being: doesn't millis stop when you're deep sleeping? Well, at least on an Arduino it does. Not sure what it does on the nRF5.
            @rmtucker
            rmtuckerR
            rmtuckerR
            rmtucker
            wrote on last edited by rmtucker
            #755
            No the nrf5 has a rtc.(Real time Counter)
            It can even keep time while sleeping.(just found this out myself!).
            That is a great leap forward on the arduino.
              rmtuckerR
              rmtuckerR
              rmtucker
              Try it just print the time out then put it to sleep for a minute then print the time out again.
                rmtuckerR
                rmtuckerR
                rmtucker
                #757
                The problem must be this line but i don't speak nrf5.:frowning:
                			MY_HW_RTC->CC[0] = max((ms<<12 / 125), 2);```
                  rmtuckerR
                  rmtuckerR
                  rmtucker
                  #758
                  The only other thing it could be is the deletion of this line in the commit.
                  nrf5_rtc_event_triggered = false
                  • d00616D d00616
                    Thanks! I just now ordered one of your boards so that in the future we can share a common platform for comparing numbers.
                    Ok. I have measured my Ebyte with the same sketch and in the µA range of my VC165 multimeter. Sleep current is 9.9µA with two ports in INPUT_PULLUP and one Port in OUTPUT_H0H1 mode. (b.t.w. this module costs actually 3,82€)
                    in that case, you need to set it as a floating input i think, like it's generally at reset.
                    In datasheet, section 20 (p111), is explained how works the GPIO. You have a Bit for disconnecting it. See the PIN_CNF[n] registers. For instance, p.140, you can see how it looks for the P0.10, and the Bit 1.
                    This should do the job..
                    Should I add a DISCONNECTED mode to hwPinMode()?
                    rmtuckerR
                    rmtuckerR
                    rmtucker
                    @d00616
                    Should be:-
                    MY_HW_RTC->CC[0] = max(((ms << 12) / 125), 2));
                    rmtuckerR mfalkviddM d00616D 3 Replies Last reply
                      @d00616
                      Should be:-
                      rmtuckerR
                      rmtuckerR
                      rmtucker
                      @d00616
                      Just checked and it now returns 10002 for a sleep(10000).
                      Much better after the above alteration.
                        Epilog: I made the changes so that just prior to taking a measurement the sense pin is hwPinMode'd to an input pin, and then immediately after the measurement I disconnect it. Seems to be working, and without the usurious power drain I was experiencing previously. :)
                          rmtuckerR
                          rmtuckerR
                          rmtucker
                          Good news
                          So what is the current usage now when sleeping?
                            Good news
                            Good news
                            About 6ua on this particular Ebyte nRF52832. I'm pretty sure it would be higher on my other Ebyte nRF52832, though I haven't measured it again. Haven't tested any additional ones as of yet.
                              @d00616
                              Should be:-
                              @rmtucker very nice work, thanks for locating the problem.
                              It occurs because 12/125 will be evaluated before the bit shift. http://en.cppreference.com/w/c/language/operator_precedence for details.
                                @d00616
                                Should be:-
                                d00616D
                                d00616D
                                d00616
                                Should be:-
                                Thank you. This was the result of merging some commits. I haven't seen I reversed that change. I had tested the code before merging some commits into one.
                                Actually I check the result of sleep(511999) and sleep(512001). When it's finished I fix that in MySensors.
                                • scalzS scalz
                                  for unused pins, it should be floating, not pullup. set the pin register you need to 0x02.
                                  Something like that
                                  NRF_GPIO->PIN_CNF[ulPin] = 0x02;
                                  that will put pin in same state like it's on reset. Everything disabled/default, floating, with disconnect bit set.
                                  (see datasheet gpio).
                                  make sense to have it for input too.. i agree :simple_smile:
                                  d00616D
                                  d00616D
                                  d00616
                                  What's the best name for this mode? DISCONNECTED or INPUT_DISCONNECTED. I prefer the first variant.
                                  I have to play a little bit with the port modes. Maybe it saves some current when the serial port pins are put into the disconnected mode while sleeping.
                                  scalzS 1 Reply Last reply
                                  • d00616D
                                    d00616D
                                    d00616
                                    Is fixed in development branch.
                                    https://github.com/mysensors/MySensors/pull/917
                                    • d00616D d00616
                                      #768
                                      agree too for the first one should be enough :simple_smile:
                                      yes, for lower power consumption, better disconnect pins which are not needed.
                                      it's the same for a simple 328p though (setting the right pin states).
                                        As a follow-up to rmtucker's line of inquiry, what is currently the shortest deep sleep that's supported? Is it one millisecond, or something else?
                                        rmtuckerR d00616D 2 Replies Last reply
                                          rmtuckerR
                                          rmtuckerR
                                          rmtucker
                                          #770
                                          Theoretically it is 2 clock ticks at 32768khz so 0.000061035secs i think.
                                          But how long it takes to go into sleep mode and come out of sleep mode i am not sure.
                                          But of course the sleep function only allows millis.
