  3. nRF5 action!
nRF5 action!
  • O
    O
    Omemanti
    Hi Guys,
    Since this topic passed the 1000 posts, can someone tell me if the NRF5* , for mysensors, is worth diving into?
    And could someone be so kind, to sum up some pro/cons?
    Would be much appreciated since I wasn't able to follow since post 400.
    mfalkviddM NeverDieN d00616D 3 Replies Last reply
    • O Omemanti
      Hi Guys,
      #1086
      @Omemanti this thread has very litte information related to MySensors, so you haven't missed much on that topic.
      https://forum.mysensors.org/topic/6705/mysensors-nrf5-platform is better for MySensors-related stuff. But the summary is that you'll need to be prepared to do troubleshooting and maybe also some coding. Some things are known broken, and a lot of things are not well tested.
      On the other hand, nrf5* is an interesting solution, and real-world testing would be very valuable for making the MySensors support better.
      • O Omemanti
        Hi Guys,
        I think when the nRF52840 gets released and made widely available, most people will eventually want it. It's a game changer. Right now it's early adopters with the nRF52832 and nRF51822, but even those offer smaller size, better range, much faster computation, and better radio power consumption.
        O 1 Reply Last reply
          O
          O
          Omemanti
          @NeverDie @mfalkvidd : Thnx!,,
          @NeverDie ; what do you mean with gamechanger? a completely new standard? will it be able to talk with the nrf24 like the nrf52382, of do you need to start all over again with a blank sheet?
          • O Omemanti
            @Omemanti
            Not sure I can explain it beyond pointing to the much longer range of the 840 together with gobs of memory. Each node could be its own webserver, for instance. Having been exposed to the nRF52832, I have no desire to go back to the old ways of doing things. Even PPI is a very powerful tool that just doesn't exist in the old architecture.
            • O
              O
              Omemanti
              So you would drop the NRF5382 for a 840?
              • O Omemanti
                #1091
                @Omemanti
                I don't think it will be either/or. It will be both. Pricing will probably favor the 52832. I'm even intrigued by the 51822, because you can buy it on a breakout for around $2.50, and it's very small, complete with a very small pcb antenna. I mean, where else can you find a complete system for that little money on such a small size? You can fit it in practically anywhere.
                JokgiJ T 2 Replies Last reply
                • O Omemanti
                  Hi Guys,
                  d00616D
                  d00616D
                  d00616
                  I'm not neutral ;-). I have ported MySensors to the NRF5 platform and completely reimplemented the NRF24 protocol, because at the point of starting Nordics License for the ESB protocol was not compatible with Open Source Licenses.
                  @Omemanti said in nRF5 Bluetooth action!:
                  I you are able to do more than described in the MySensors example sketches, you should give it a try. It's a little bit more complicated than starting with ATMEGA based boards.
                  Pros:
                  • Enough Flash and RAM
                  • Faster CPU
                  • periphery can do a lot of things while the CPU is sleeping (PPI, SHORTS)
                  • Small footprint of sensors
                  • Mostly free pin mapping in your Sketch
                  • NRF24 compatible
                  • Same price like ATMEGA + NRF24
                  • No bad clones like NRF24
                  • Better range than NRF24 (
                  • Flexibility to change the radio protocol
                  • BLE Long range, USB with the upcomming NRF52840
                  • Most complete 32 Bit implementation for MySensors (at the moment) supporting sleep(), hardware random numbers, soft signing and an internal EEPROM emulation without additional hardware.
                  • Great hardware included
                  • Can be mixed with other radio modules like NRF24 (useless but tested) or RFM (untested)
                  • Enough resources for better security concepts
                  • No need for ATSHA204 when you don't require read back protection. Enabling read back protection depends on OTA updates, which are not implemented at the moment.
                  • Well documented MCU's
                  Cons:
                  • Not all Arduino functionality available like EEPROM (available in MySensors or externaly via emulation), Tone library
                  • Maybe some bugs in the arduino implementation or radio implementation
                  • OTA firmware update is missing for MySensors, but it's possible
                  • BLE with MySensors is not supported/tested at the moment. I think BLE support needs a little bit of porting code to SoftDevice API
                  • Beta: Needs field testing
                  • Multiple NRF5 Arduino ports like (arduino-NRF5 or Primo). Only arduino-nrf5 without SoftDevice is supported at the moment.
                  Neutral:
                  • Radio is for 2.4GHz only which means less regulations but shorter transmit distance
                  • The NRF24 protocol isn't a good protocol for encryption or battery powered nodes permanently listening for packages, the protocol can be replaced in 100% NRF5 networks in the future
                  I think there is no future for 8 Bit Controllers in the Arduino world. If you want to do more without diving into the PROGMEM hell, then it's time to switch to 32 bit controllers. The NRF5 is an interesting and highly integrated choice for 2.4GHz networks.
                  My small home network is completely NRF5 based. From time to time a node stops receiving packages. The problem is known and documented by Nordic. I working on a fix.
                  There are some differences in timing between NRF24 and NRF5 which are no problem, I think. The NRF24 is ~12µs earlier in RX mode and the NRF5 is ~400µS earlier in TX mode. If this is a problem, it's catched by a retransmit. Instead of tuning this protocol, I think it's better to invest the time in creating a protocol which allows battery powered nodes to listen for packages and allowing better security than the NRF24 ESB protocol.
                  O T 2 Replies Last reply
                    @Omemanti
                    JokgiJ
                    JokgiJ
                    Jokgi
                    wrote on last edited by Jokgi
                    #1093
                    @NeverDie Check out the new nRF52810. It is a stripped down version of the nRF52840.. Not as much memory and the peripherals are lower in count. But it has a Cortex M4 (Not F) and some of the targets are sensors, wearable, beacons, etc. On air compatible with nRF24L series and nRF52 series. Some limitations on BT 5.0 however.
                    d00616D 1 Reply Last reply
                    • d00616D d00616
                      Pros:
                      • Faster CPU
                      • NRF24 compatible
                      Cons:
                      Neutral:
                      O
                      O
                      Omemanti
                      @d00616 & @NeverDie
                      Thnx, this saved me hours :+1:
                      Will dig into the NRF52832. Already got some Ebyte module's and some other thingies to sort out.
                      It was eaghter dig into the NRF52832 or give the NRF24 another chance. NRF5* it is.
                      Thnx so far!
                        I posted the files for a remote control based on the power amplified nRF52832:
                        https://www.openhardware.io/view/482
                        TerrenceT 1 Reply Last reply
                          TerrenceT
                          TerrenceT
                          Terrence
                          wrote on last edited by Terrence
                          #1096
                          @NeverDie Please read post in "Harvey Rainmaker" thread about Nordic class in Austin.
                          https://forum.mysensors.org/topic/7403/harvey-the-rainmaker/11
                          • O Omemanti
                            Oh, and let's not forget the Bluetooth 5 capabilities of these chips, which I expect will allow the leverage of a lot of other bluetooth devices. Despite the title of this thread, we've barely even scratched the surface on that topic (yet). I'm looking forward to it.
                            JokgiJ 1 Reply Last reply
                              JokgiJ
                              JokgiJ
                              Jokgi
                              @NeverDie The really nice thing about the nRF52832 and other nRF52 variants is that running the BTLE stack (Softdevice ) you can run BTLE and proprietary somewhat simultaneously. You choose where you want to have them running this. Each node or just one for Smart Device connectivity.
                                @Omemanti
                                Toyman
                                do you have an example? The lowest I can find is ca. $4 (incl.S&H).
                                Don't get me wrong, $4 is more then adequate for 328+24L01 replacement, but $2.5 is even better :-)))
                                Nca78N 1 Reply Last reply
                                • d00616D d00616
                                  Pros:
                                  • Faster CPU
                                  • NRF24 compatible
                                  Cons:
                                  Neutral:
                                  Toyman
                                  wrote on last edited by Toyman
                                  #1100
                                  @d00616 absolutely excellent summary, thank you.We definitelly needed some kind of "what do we know so far"
                                  Is it confirmed that the range and power consumption are on par with 328+24L01 combo? I don't mean any "scientific" proof, but something like "I have placed nrf52 node at the same location in my house as nrf24 node and had no issues"
                                  I am awaiting components to make "u-current meter" and test current consumption by myself
                                  • T Toyman
                                    Type nrf51822-04 in AliExpress search bar, you will find the cheapest module. Not many pins broken out because it's supposed to be used as a Bluetooth interface, but it's enough for many applications like door sensor, switches, etc etc
                                    https://www.aliexpress.com/item/NRF51822-04-BLE4-0-Wireless-Bluetooth-Module-TTL-Low-Power-Consumption-3-3V-New/32821044213.html
                                    T NeverDieN 2 Replies Last reply
                                    • Nca78N Nca78
                                      Toyman
                                      @Nca78 cool, thx
                                      • T Toyman
                                        Yes, it's better in both dimensions.
                                        • JokgiJ Jokgi
                                          d00616D
                                          d00616D
                                          d00616
                                          Where are the long range BLE modes? I think long range BLE modes are one of the best features of the 840 series.
