  3. Vera
  4. Sometimes nodes NOT created???
12 Posts 6 Posters 3.7k Views 1 Watching
  • P
    P
    p0lar
    Sometimes when I add a sensor the corresponding NODE entry in the devices list does not get created. is this important? any way to debug that?
    RJ_MakeR m26872M 2 Replies Last reply
    • P p0lar
      RJ_MakeR
      RJ_MakeR
      RJ_Make
      @p0lar That has happened to me also (many times), I typically run the inclusion again and most of the time it picks it up.
      RJ_Make
      • P
        P
        p0lar
        They are not really needed right other than info about the device?
        RJ_MakeR 1 Reply Last reply
        • P p0lar
          RJ_MakeR
          RJ_MakeR
          RJ_Make
          @p0lar "Needed" no, the sensor seems to work just fine without the node. I use the battery and last updated fields for processing so I make sure I get the node to 'show up'
          RJ_Make
          • P
            P
            p0lar
            OK. ill try inclusion again trick..
            • C
              C
              C.r.a.z.y.
              Dear admin whats is your suggestion? Is this a bug?
                The reason is failed transmission. The node (normally) sends its presentation at startup. Introducing a short delay between transmissions could help (allowing your attached capacitor to charge up).
                N 1 Reply Last reply
                • P p0lar
                  m26872M
                  m26872M
                  m26872
                  @p0lar Which gateway and controller?
                  P 1 Reply Last reply
                    N
                    N
                    NotYetRated
                    wrote on last edited by NotYetRated
                    I will try the delay as well, as I have this issue sometimes. Thanks for the good advice.
                    • m26872M m26872
                      P
                      P
                      p0lar
                      @m26872 Vera Lite running something and an Ethernet gateway with 1.4.1 code on senors and gateway... I am using the example code on these sensors... is there an example delay in there already?
                      m26872M 1 Reply Last reply
                      • P p0lar
                        m26872M
                        m26872M
                        m26872
                        wrote on last edited by m26872
                        @p0lar You don't have a serial gateway to try instead? I use the serial gw for inclusion only. Then when it comes to running, the eth-gw is much better.
                        • P
                          P
                          p0lar
                          Nope. No serial gateway. Also re including does not create the missing ones. Hmmmm
