  3. Vera
  4. Sometimes nodes NOT created???
12 Posts 6 Posters 3.7k Views 1 Watching
  • P p0lar
    Sometimes when I add a sensor the corresponding NODE entry in the devices list does not get created. is this important? any way to debug that?
    RJ_MakeR
    RJ_MakeR
    RJ_Make
    @p0lar That has happened to me also (many times), I typically run the inclusion again and most of the time it picks it up.
    RJ_Make
    • P
      P
      p0lar
      They are not really needed right other than info about the device?
      RJ_MakeR 1 Reply Last reply
      • P p0lar
        RJ_MakeR
        RJ_MakeR
        RJ_Make
        @p0lar "Needed" no, the sensor seems to work just fine without the node. I use the battery and last updated fields for processing so I make sure I get the node to 'show up'
        RJ_Make
        • P
          P
          p0lar
          OK. ill try inclusion again trick..
          • C
            C
            C.r.a.z.y.
            Dear admin whats is your suggestion? Is this a bug?
              The reason is failed transmission. The node (normally) sends its presentation at startup. Introducing a short delay between transmissions could help (allowing your attached capacitor to charge up).
              N 1 Reply Last reply
              • P p0lar
                m26872M
                m26872M
                m26872
                @p0lar Which gateway and controller?
                P 1 Reply Last reply
                  N
                  N
                  NotYetRated
                  wrote on last edited by NotYetRated
                  I will try the delay as well, as I have this issue sometimes. Thanks for the good advice.
                  • m26872M m26872
                    P
                    P
                    p0lar
                    @m26872 Vera Lite running something and an Ethernet gateway with 1.4.1 code on senors and gateway... I am using the example code on these sensors... is there an example delay in there already?
                    m26872M 1 Reply Last reply
                    • P p0lar
                      m26872M
                      m26872M
                      m26872
                      wrote on last edited by m26872
                      @p0lar You don't have a serial gateway to try instead? I use the serial gw for inclusion only. Then when it comes to running, the eth-gw is much better.
                      • P
                        P
                        p0lar
                        Nope. No serial gateway. Also re including does not create the missing ones. Hmmmm
