  3. Vera
  4. Sometimes nodes NOT created???
12 Posts 6 Posters 3.6k Views 1 Watching
  • P Offline
    P Offline
    p0lar
    They are not really needed right other than info about the device?
    R 1 Reply Last reply
    • P p0lar
      R Offline
      R Offline
      RJ_Make
      @p0lar "Needed" no, the sensor seems to work just fine without the node. I use the battery and last updated fields for processing so I make sure I get the node to 'show up'
      RJ_Make
      • P Offline
        P Offline
        p0lar
        OK. ill try inclusion again trick..
        • C Offline
          C Offline
          C.r.a.z.y.
          Dear admin whats is your suggestion? Is this a bug?
          • hekH Offline
            hekH Offline
            The reason is failed transmission. The node (normally) sends its presentation at startup. Introducing a short delay between transmissions could help (allowing your attached capacitor to charge up).
            N 1 Reply Last reply
            • P p0lar
              Sometimes when I add a sensor the corresponding NODE entry in the devices list does not get created. is this important? any way to debug that?
              M Offline
              M Offline
              m26872
              @p0lar Which gateway and controller?
              P 1 Reply Last reply
                N Offline
                N Offline
                NotYetRated
                wrote on last edited by NotYetRated
                I will try the delay as well, as I have this issue sometimes. Thanks for the good advice.
                • M m26872
                  P Offline
                  P Offline
                  p0lar
                  @m26872 Vera Lite running something and an Ethernet gateway with 1.4.1 code on senors and gateway... I am using the example code on these sensors... is there an example delay in there already?
                  • P p0lar
                    M Offline
                    M Offline
                    m26872
                    wrote on last edited by m26872
                    @p0lar You don't have a serial gateway to try instead? I use the serial gw for inclusion only. Then when it comes to running, the eth-gw is much better.
                    • P Offline
                      P Offline
                      p0lar
                      Nope. No serial gateway. Also re including does not create the missing ones. Hmmmm
