  3. A smart home vs an automated home
59 Posts 8 Posters 24.6k Views 8 Watching
    You are pretty much facing the same problems as all the engineers working on self driving cars or whatever is using computer vision (which is going to be tricky to be handled by an arduino alone, and that is why many services are relying on cloud computing)
    wallyllamaW
    wallyllamaW
    wallyllama
    @gohan true for the larger goals, but this sensor is 64 pixels (256 w/interpolation) and we need to track a dot, i think an arduino could gather the data, do a bit of preprocessing, and (the mysensors part) transmit the data to a raspberry pi for "whole house" tracking.
    This is pretty low res and I think a pi could handle it. If not, Intel has a movidius usb stick meant for computer vision/ai acceleration, I believe opencv has been ported to it. So while this is on the edge, some of the blood has dried.
    The other plus is houses move slower than cars, unless people are running indoors, a 2 to 3 second refresh rate should be accurate enough.
    This is a large project and mysensors would only be a portion of it, so for now I'll try to limit myself to talking about how a node based on this sensor would work and if it fits into mysensors properly or not. There is plenty there to discuss.
    @dbemowsk again sorry for hijacking your thread, I'm going to look at the guides for submitting a node to openhardware.io, i dont promise I'll be fast so dont stop working your own ideas.
    NeverDieN gohanG 2 Replies Last reply
    • wallyllamaW wallyllama
      @wallyllama
      To what degree will detection range be an issue with these sensors?
      wallyllamaW 1 Reply Last reply
        @wallyllama I think an easier way to do tracking of people in the house would be through BT tags, this way you have also identification. Image preprocessing on Arduino I think would be hard to achieve, maybe on a pi zero.
          @wallyllama
          wallyllamaW
          wallyllamaW
          wallyllama
          @NeverDie data sheet says 7 meters max, there is probably enough margin, at least for typical room sizes in the US. I think the 60° fov will be the bigger issue, getting coverage. Imagine you place the sensor in the center of your ceiling. The room is square, 14ft on a side and 8 ft high (~4X2.4 M), the sensors field of view would exactly cover the floor, but it is shaped like a pyramid with the sensor at the peak, so if you stand flat against a wall, only your feet would be in view.
          @gohan's suggestion of bluetooth tags doesnt have that problem, it can be seen anywhere the signal gets to. You can have multiple detectors for coverage and triangulation. If you have a smartwatch or phone you always carry then youndont even need a separate tag. It is relatively cheap and simple, and most of the tech is done already.
          (Now here is where I loop around and start spinning in circles) I dont want to have to carry anything, it should be possible to detect my presence by all the signals bouncing off me already, like light, or ir, or wifi, or radar, then the googling happens......
          • alowhumA
            alowhumA
            alowhum
            Perhaps an alternative definition of smart home could be whether it connects to the cloud? Or whether it uses Big Data / Machine Learning / aggregation of the habits of many households to find solutions to things?
            Yet another, for me, is whether smart means 'ethical'. For example, a cloud connected home that shared my life patterns with third parties (which is most devices these days..) should never be called smart.
            gohanG 1 Reply Last reply
            • alowhumA alowhum
              @alowhum well... it all goes to the point "do you have enough money/time/skills to invest in a homemade Big Data / Machine learning project"? Do you even have an idea of how complicated that system would be to setup and maintain later on?
                #34
                Instead of going off on wild tangents about privacy and the like, I suggest we re-focus by asking what good or useful thing we might accomplish if we could make the thermal 8x8 pixel sensor work. After all, this is the first thread to consider it, and it would be a shame to waste the opportunity.
                  @NeverDie I agree but it is pretty much related as I really don't think image processing could be done on a microcontroller without the help of a backend server that would actually collects all data from sensors, correlates them and then give them a meaning that can actually be used.
                    #36
                    In that case, I suggest @wallyllama start a new thread devoted just to the sensor and how best to make use of it. I wager something can be accomplished without resorting to full blown data fusion. Plainly if you tie your success to difficult, unsolved research problems that have long resisted solution, you will quickly bog down.
                    The two obvious things are: direction of movement and, as has already been mentioned, a finer location granularity within a room. Since it's thermal, it could know that you're sitting on the couch even if you're not moving. That's big. Just think of all the occupancy sensors that wrongly conclude the room is empty if nothing is moving. We've all had that experience, I'm sure.
                    • dbemowskD
                      dbemowskD
                      You guys are thinking of a complex solution to this that is a single package that does it all. What if you dumb down the scenario a bit. Don't try to think of making a determination using only one type of sensor. After doing some more research on the guy that did the infrared doorway sensors, he said that it was a pretty reliable way of counting room occupants. Maybe you use the infrared doorway sensors as a way of counting the number of people in an area. Now you have a reliable way of counting the number of people in an area, now you start looking at ways of identifying who those occupants are if needed. Thinking in a broad sense, putting some fuzzy logic behind data from a number of other sensors, whatever that may be, may give you some kind of fingerprint for a person that could be used to identify people. using that approach may give you a little better accuracy too depending on the sensors and logic you use.
                      • dbemowskD dbemowsk
                        @dbemowsk that "fuzzy logic" is what big companies are spending millions to develop and that's why I'm not expecting much from a few sensors and Arduinos
                        dbemowskD 1 Reply Last reply
                          dbemowskD
                          dbemowskD
                          @gohan I get it, but at this stage, any bits and pieces that you can put together that can even do a fraction of it is better than nothing. I figure if I can start with the counting people part and somehow layer things on from there I'll be a little ahead of the game.
                          I don't want anyone to worry that you are hijacking my thread. Speak freely, this is how good ideas come to be. Precisely why I started this thread. I figured it would spark some creativity from the community.
                          • dbemowskD
                            dbemowskD
                            So looking at the MySensors end of this, would it be too far off to think of adding a new node type, "person". A person node could have customizable properties that would allow you to define different useful bits of data related to that person. For example, preferred room temperature, or preferred light level. Heck, you could even have a room or area property that would get set when the system sees you move to a different area. So when you do figure out better occupancy sensing, you can automatically set user preferred light levels and room temps based on who is in the room, and dial them down after a person leaves the room. If you have more than one person in a room, it could take an average of the properties of all in the room to determine a setting like room temperature to provide a happy medium.
                            • wallyllamaW
                              wallyllamaW
                              wallyllama
                              I think @dbemowsk is hinting at something that fits my understanding of "emergent behavior", individual simple things interact and create more complex results. How many, and whom are different questions. Counters in doorways plus a list of whose phones are at home, maybe add in some hostorical data of who likes to sit in which chair. There are probably better combinations, but that is what I got from hisnrecent comments.
                                wallyllamaW
                                wallyllamaW
                                wallyllama
                                wrote on last edited by wallyllama
                                #42
                                @dbemowsk said in A smart home vs an automated home:
                                I'd like to hear more about how you would use it. Below is my two pennies worth.
                                My thinking is that mysensors is a transport for relatively simple data, like state, value, counts etc, things nodes would need to set the environment up, or report back to central command.
                                A complex object like "person" could have all kinds of attributes and preferences, which would modify values sent to nodes. Example the curtain controller knows to open during the day, close at night, and maybe close for an hour at 10 am in the summer when the sun shines directly in and heats up the house( could also be a light sensor), but if the weather says it is clear, and kent is in the living room and it is night open the curtains up, and that would be an override coming from central. The node controlling the curtain doesnt need to know it is me in the room, it just needs to accept the modifiers.
                                I say this mostly because as @gohan points out arduinos arent terribly powerful, and telling them too much info may just confuse them.
                                I liken it to the body. E.g. your finger doesnt have to know if you are walking up as you are pushing a doorbell, it just extends on command and reports that it made contact, moved forward slightly and hit a stop. Your spine may get involved if the finger reports excessive heat, or something gooey on the switch, and pulls the hand back in reflex.
                                  dbemowskD
                                  dbemowskD
                                  @wallyllama As to your first comment about "emergent behavior", that's pretty much what I was getting at.
                                  As to the MySensors node, my thoughts when I mentioned the "person" node were possibly some kind of MySensorized identifier or tag for a person much like a bluetooth tag. The more I thought about it though, you are correct that there would be all kinds of attributes, and most of them wouldn't need to be tied to the tag. The "person" though might be on the controller side where the processing power is greater and where most of that data would be dealt with anyway.
                                    wallyllamaW
                                    wallyllamaW
                                    wallyllama
                                    @dbemowsk interestingly, as I thought about these ir cameras, they may require a smarter node (maybe something like a nanopi neo2) to preprocess the data, and then a person tag may be useful.
                                    For example 64 pixels, 2 bytes to encode temperature value, 1hz refresh would mean 1280 bytes/s. Which If I have been reading this right, is pretty high for mysensors. There are some ways to reduce that, but it is unkown if an arduino could keep up.
                                    I've mostly been doing research on sensors, and only built one node and a gateway, so alot of what I have been saying about my sensors is assumption.
                                    Does it have a defined method of extending the data types? Or a board that decides? A Glorious Leader we need to cajole? Maybe "user defined" types?
                                    Im kind of in love with these IR array sensors, and I'm probably not objective about what is best for mysensors as a whole, but I have boxes of opinions I'd like to get rid of, so just ask if you want some
                                    • dbemowskD
                                      dbemowskD
                                      Again, doing some more brain cell searching and reflecting on the subject of a "person" node for MySensors, I am more and more starting to realize that this part of things may not be in the realm of MySensors. Not to say it shouldn't be part of an HA system, just not handled by MySensors. I think it could be a different module/plugin for whatever controller people are using, e.g Vera, Domoticz, OpenHAB, etc... As was mentioned, a "person" node would probably have a great number of properties and attributes that define a person. That in itself I think is a great argument as to why it should NOT be a MySensors node. Some of those properties and attributes may be defined by one or more different MySensors nodes, but it may also take data from a different kind of node based on something like what @wallyllama mentions which might require a more complex processor such as a nanopi. The ways in which a person may be identified could differ greatly between systems and could range from simple to complex. Again I get back to the simple IR doorway occupancy sensor that can count the number of people in a room. I think that this could be a great starting point for something like this and could be something simple enough for MySensors to handle. Going with something like this and later finding varying ways to determine who the occupants of a space are may be a way to get this started.
                                        @dbemowsk that's something that netatmo did with their smart ip camera that is able to recognize who entered the room or your garden and with that you can set some rules in a HA system and I bet it is far from simple to be done on a DIY project
                                        • wallyllamaW
                                          wallyllamaW
                                          wallyllama
                                          @gohan Openmv has a single board camera with opencv and micropython, another option.
                                          I think @dbemowsk idea of door sensors fits nicely with mysensors as he has said. Is there a more appropriate forum for the more complex devices that anyone knows of? Im thinking if I come up with a node, I can add it like any other, but there will be a lot of talk that ends up a bit off topic.
                                          On topic, are there controllers that are more amenable to the kind of combining of different nodes to identify people that we are talking about? I've used Mr. House for other things, and domoticz for my one test node, not enough to really have an opinion.
                                          12.5k
