  3. PIR AM312/412/612
PIR AM312/412/612
31 Posts 8 Posters 17.9k Views 12 Watching
  • Nca78N Nca78
    I can't open your document.
    You confirm that the test is with he double PIR PCB under one lens ?
    I'm surprised that this work as the lens is supposed to focus the IR on the two sides of the sensor, and if you move them away of the center it should lower sensitivity.
    @Nca78 said in PIR AM312/412/612:
    Strange. It's an ordinary PDF. I'm even able to open it on my wife's computer.
    What I tested was just a single am612 PIR under one lens. I re-tested last night to be sure, and, indeed, it seems to have excellent sensitivity and no meaningful blinds spots.
    TerrenceT 1 Reply Last reply
      TerrenceT
      TerrenceT
      Terrence
      @NeverDie I can't open it either. Here is the error message.
      0_1498846572300_upload-64a0320f-21fa-40e7-9563-88704a8a609b
      • TerrenceT Terrence
        @Terrence
        Thanks! Not sure what's going wrong. Let's try it again from a different computer:
        0_1498851552407_Schematic for AM612 Breakout v402.pdf
        In case that still doesn't work, here it is as a .PNG file:
        which is large enough to be legible and will serve the purpose.
          I guess answering my own question, I removed my load switch as well as all of the capacitors from my breadboard circuit, and the remaining am612 circuit still appears to function just fine. :)
            I updated the board, and it's now 23mmx24.5mm:
            It also has pads for an LED for range testing purposes.
            J 1 Reply Last reply
              I also ordered some of these lenses:
              https://www.aliexpress.com/item/FREE-SHIPPING-50PCS-PIR-D203S-LHI874-LHI878-RE200B-P228-Fresnel-lens-PIR-Sensor/1295771560.html?spm=2114.01010208.3.31.Be4wmU&ws_ab_test=searchweb0_0,searchweb201602_5_10152_10065_10151_10068_10130_10084_10083_10119_10080_10082_10081_10110_10178_10136_10137_519_10111_10060_10112_10113_10155_10114_437_10154_10056_10055_10054_10182_10059_303_100031_10099_10078_10079_10103_10073_10102_10120_10052_10053_10142_10107_142_10050_10051-10120,searchweb201603_49,ppcSwitch_4&btsid=f043368c-9fc4-4f1a-ae33-850a00860ef5&algo_expid=2cec72d6-8e82-4481-92b3-9a4b26711616-4&algo_pvid=2cec72d6-8e82-4481-92b3-9a4b26711616
              They look a little different, so I thought them worth a try. While not plug compatible with the exist SR501-type layout, maybe they can somehow (?) grip the outside of the PCB instead, allowing an even slightly smaller PCB. If only they had manufactured the barbs facing inward rather than outward, they might have been perfect!
                @NeverDie said in PIR AM312/412/612:
                It's a somewhat surprising result, because even the cheapskate am312 sensors appear to use caps:
                https://www.aliexpress.com/item/Mini-IR-Pyroelectric-Infrared-PIR-Motion-Human-Sensor-Automatic-Detector-Module-high-reliability-12mm-x-25mm/32749737125.html?spm=2114.01010208.3.32.JSXzcv&ws_ab_test=searchweb0_0,searchweb201602_5_10152_10065_10151_10068_10130_10084_10083_10119_10080_10082_10081_10110_10178_10136_10137_519_10111_10060_10112_10113_10155_10114_437_10154_10056_10055_10054_10182_10059_303_100031_10099_10078_10079_10103_10073_10102_10120_10052_10053_10142_10107_142_10050_10051-10120,searchweb201603_49,ppcSwitch_4&btsid=b87e2064-287c-4fe9-ba44-53ca575f5350&algo_expid=3e550c0f-0a35-465b-8691-27d092d21bbd-4&algo_pvid=3e550c0f-0a35-465b-8691-27d092d21bbd
                I coun't three caps there. Surely not all of them are there because of the LDO?
                Nca78N 1 Reply Last reply
                  @NeverDie you would have to check the LDO datasheet but it's possible.
                  Sorry on holidays without computer so I cannot check.
                    Has anyone here run across a highly directional version of either the AM312/612 or some other PIR sensor?
                    I have an application (https://forum.mysensors.org/topic/7388/how-to-detect-wild-animal-pests-in-a-windy-garden/1) which would benefit from that.
                      Is there an SMD version of the PIR AM312/412/612 (it may have a different number, of course)?
                        #23
                        Closing the loop on my earlier questions, I finally did some long overdue experiments involving the AM612. It turns out that the 75K and 100K resistors aren't doing much, if anything. They can be replaced with simple shorts. So, in future designs, I'll be eliminating them.
                        On the other hand, the 1Megaohm resistor appears to be necessary. If I simply removed it, the PIR no longer did detections. If I put it back, the PIR worked again.
                          At time index 6:20 this guy finds that using the AM312 is a solution to his intermittent problems that he was having with a the more commonplace PIR sensor:
                          https://www.youtube.com/watch?v=jpjfVc-9IrQ
                          • C
                            C
                            Chacal
                            Just a quick question about these AM612 sensors.. What is the shortest trigger delay that can be achieved by connecting the SENS pin to ground? The datasheet suggests that by connecting ONTIME to ground a 2.3s "ontime" would be created, but does this also apply to the triggering delay?
                            I'm asking as I'm planning on using these sensors to switch on lights at home and obviously would like to have as little delay as possible between the actual detection and output trigger. AM312 seems to have a fixed ~2s delay, but how is it with the more tunable AM612? Maybe @NeverDie has some first hand experience?
                            berkseoB 1 Reply Last reply
                            • alowhumA
                              alowhumA
                              alowhum
                              (A lot of the comments in that video mention MySensors :-) )
                              • C Chacal
                                berkseoB
                                berkseoB
                                berkseo
                                @chacal said in PIR AM312/412/612:
                                The output trigger is triggered as soon as the movement is fixed. A fixed delay of 2 seconds, here we mean that the HIGH level will be on the output trigger for 2 seconds.
                                  J
                                  J
                                  Just4 Electronics
                                  @neverdie hello, can you please provide the final schematic which one worked best for you with minimum no. of components
                                    J
                                    J
                                    Just4 Electronics
                                    @neverdie is this board without any capacitors working well??I want to test AM612 so I want testing circuit that works well
                                    O 1 Reply Last reply
                                      https://www.openhardware.io/view/420/AM612-Passive-Infrared-Sensor-Breakout-Board#tabs-design
                                      • J Just4 Electronics
                                        O
                                        O
                                        Omemanti
                                        wrote on last edited by Omemanti
                                        #31
                                        @just4-electronics In also using the setup(am612) from NeverDie, and I'm pretty pleased with it. I mapped an extra cap to the setup but that's just for my pease of mind. 😀
