  3. STM32?
STM32?
82 Posts 19 Posters 47.2k Views 19 Watching
    I have no idea then... I never used serial GW
    • O ooznerol
      HI @freynder ,
      I just realize that when you speak about SERIAL_USB you really speak about.....Serial through USB connector :grinning: .
      I believe you speak about Virtual Com Port through USB in ST-LINK.
      So I had change R10 on my blue pill and install maple driver.
      Now I have a Maple Serial COM mounted when I connect my blue pill with the USB connector :grinning: .
      And......................TADA.................It is working. I had output on my terminal.
      Thanks again:+1:
      F
      F
      freynder
      Hi @ooznerol,
      Glad serial output is working now. Unfortunately I have no experience with serial gateway either, sorry.
      O 1 Reply Last reply
      • F freynder
        Hi @ooznerol,
        O
        O
        ooznerol
        @freynder
        Too bad...... Do you have any idea how we can debug this?
        F 1 Reply Last reply
        • O ooznerol
          @freynder
          F
          F
          freynder
          wrote on last edited by freynder
          #65
          @ooznerol
          In general: isolating the problem and then tracing through the code. I understand you already isolated the problem to the combination of serial gateway and RFM69. First make sure this actually the case by uploading a sketch again you knew was working before with RFM69 (to eliminate any hardware / wiring issues that may have happened between your tests). If you can confirm that, you can start by looking at the code and find what is specific for the combination of these specific directives.
          • F freynder
            @ooznerol
            O
            O
            ooznerol
            @freynder
            Instead facing through the code , I think about compile with a debugger (like IAR ou Keil for example). Do you think it is possible?
            • O ooznerol
              @freynder
              F
              F
              freynder
              @ooznerol No experience with those I'm afraid. From my notes I see I did experiment with using GDB in combination with a Black Magic Probe (BMP) to debug the blue pill. You can probably convert your SWD adapter to a BMP device:
              https://madnessinthedarkness.transsys.com/blog:2017:0122_black_magic_probe_bmp_on_st-link_v2_clones
              https://github.com/blacksphere/blackmagic/wiki
              • F freynder
                O
                O
                ooznerol
                wrote on last edited by ooznerol
                #68
                Hi all, it's me again.
                So finally Gateway is working fine. The problem was that the driver (specially on windows) seems little bit unstable (I must open the serial just after strating and close it after I finish my test).
                So now I am playing with consumption.
                I take the low power implementation from freynder and reach 860uA. This implemenation used STOP mode. If I change this to STANDBY mode I reach 4.1uA. But in this case when I wake up, the CPU react as it has been reseted and relaunch all mysensors init and presenation etc etc . So the trick will be to check the wake up reason, and in case of wake up from standby not relaunch mysensors init. Do you think it is possible inside mysensors architecture?
                • O ooznerol
                  F
                  F
                  freynder
                  @ooznerol I suppose you intend to run on battery? I desoldered the power led and voltage regulator on mine to reach 100uA (if readings were correct) using STOP mode. It ran on 2 AAA batteries for several months.
                  I'm unsure about using the STANDBY mode. Since RAM and registers contents are lost and pins are high impedance, full reinitialization seems necessary. Do you want to prevent the presentation communication specifically from happening? You can control that from your sketch directly in the presentation function I suppose...
                  • F freynder
                    O
                    O
                    ooznerol
                    @freynder Yes I have of course remove unless hardware. ( i can't reach 3.3uA with it). In STOP mode, we are suppose to reach around 20-30uA (from datasheet). I will try yo investigate
                    I can of course handle reset cause into presentation, but I don't know if other init are done inside mysensors architecture.
                    For STANDBY mode , we can save usefull data for mysensors into backup register. I had done something similar in the past but not in stm32duino environnement.
                    Nca78N 1 Reply Last reply
                    • O ooznerol
                      wrote on last edited by Nca78
                      #71
                      @ooznerol said in STM32?:
                      Yes, before the presentation MySensors will initialize radio, check radio link/parent etc
                      There's no easy way to avoid it at the moment, but I think it should be a feature request, as we have the same situation with chips like NRF51/NRF52 which are also ARM based, if you want really low power consumption you need to go through a reset and MySensors initialization phase makes the wake up slow and power hungry.
                      • nagelcN
                        nagelcN
                        nagelc
                        Just got a blue-pill, RFM69 node working. It was a bit of a learning curve moving from Atmega.
                        • Cheap J-Link: Never got it working. Cheap ST-Link: Worked
                        • Arduino (and VisualMicro) uploaded blink sketch with ST-Link: no problems
                        • Uploaded the USB bootloader using the ST-Link: no problems
                        • Took a while to figure out I didn't have the dfu driver loaded (Windows 10), but after that no problems using the usb
                        • MySensors security personalizer: no problems.
                        • Mock MySensors node: no problems. Talked to my gateway. Uses RFM69 encryption.
                        Seems like this is the Nano of the future, but without needing to level shift for 3.3V. I'm looking forward to making some real blue pill nodes and gateways.
                        • B
                          B
                          Brasletti
                          Does anybody get the Serial Gateway with RS485 working? I can't get debug messages on serial console.
                          • alowhumA alowhum
                            So.. I accidentally bought something from Aliexpress that I thought was a cheap Arduino Nano.
                            But it's not.
                            It's an STM32F103C8T6. It has an arm chip.
                            Is it useable with MySensors? Does it emulate an Arduino Nano? Of so, it looks like it has more memory, so could that be useful? It's cheaper too, and it has lots of 3v lines.
                            I just found this page where someone talks about their adventures with this board. Hmm...
                            @alowhum You may want to consider the nRF5 series instead.
                            • B
                              B
                              Brasletti
                              wrote on last edited by Brasletti
                              #75
                              OK it is working with Hardware Serial. But still no debug message on startup. Maybe it's because the switching of the usb mode.
                              Is it possible to wait 2sec before starting up the gateway on stm32 boards?
                              • alowhumA
                                alowhumA
                                alowhum
                                @neverdie Thanks! I ordered one, they look very interesting.
                                • F freynder
                                  @freynder said in STM32?:
                                  stm32 sensor is unable to connect to gateway:
                                  After further testing, this seems to work now. I'm not exactly sure why unfortunately. I'm now using the new RFM69 library. I noticed that communication seems to fail after uploading the sketch over stlink, even when clicking the reset button. When disconnecting/reconnecting the usb power all works well. Maybe that was the issue previously as well.
                                  F
                                  F
                                  freynder
                                  #77
                                  Just following up on this as I finally found out why this is happening. I was using encryption and using serial upload (using stm32flash), the simulated eeprom would get overwritten by the flash erase. Not sure if this happens for dfu or stlink as well. Uploading using the black magic probe (which uses dbg) does not have this problem. I hope this may help someone struggling with the same issue.
                                  Edit: not sure about dfu or stlink.
                                  • nagelcN
                                    nagelcN
                                    nagelc
                                    Has anyone been able to do OTA programming with the STM32 yet?
                                    D 1 Reply Last reply
                                    • nagelcN nagelc
                                      Dab0G
                                      wrote on last edited by Dab0G
                                      #79
                                      @nagelc Yes I did. My bootloader - https://github.com/mysensors-rus/STM32_Mysensors_bootloader. My modified MySensors library - https://github.com/mysensors-rus/MySensors. Short description in Russian - https://mysensors-rus.github.io/STM32-OTA-MySensors
                                      nagelcN 1 Reply Last reply
                                      • D Dab0G
                                        nagelcN
                                        nagelcN
                                        nagelc
                                        @dab0g Wow! I did not expect anyone to answer. This is really great. I have a remote control lamp and a thermostat that use the STM32 and it would great to be able to program them OTA. I'll check it out.
                                        alowhumA 1 Reply Last reply
                                        • nagelcN nagelc
                                          alowhumA
                                          alowhumA
                                          alowhum
                                          @nagelc said in STM32?:
                                          If you do, be sure to create an English write-up for the rest of us!
