  3. 💬 MySensors NRF5 Platform
contest2017nrf52mysensorsnrf5nrf51
210 Posts 20 Posters 88.8k Views 18 Watching
    on my Windows machine, all boards are located in c:\Users<username>\AppData\Local\Arduino15\packages
    Strange that they've been installed to C:\Users\David\Documents\Arduino\libraries\ on your machine.
    Maybe just delete the folders and re-install using the board manager?
    @mfalkvidd All I know is that if I put a library in the folder: C:\Users\David\Documents\Arduino\libraries
    it always gets detected and used. It also means you can completely uninstall/re-install the arduino IDE, and nothing gets lost. I'm not sure about other locations.
    Am I the only one doing it this way?
      @NeverDie for libraries, doing what you do should result in the same behavior as when using the Library Manager.
      But I'm not sure it works with boards (especially given that the Arduino IDE complains when you put boards in the libraries folder).
        I use the board manager to manage the boards. I believe it connects directly into github.
        Anyhow, I stripped out all the non-library stuff, and now Windows IDE works without complaining.
          #79
          Has anyone here yet figured out how to have more than one type of interrupt at a time wake-up the MCU from sleep? Based on the examples so far, it seems as though only one type at a time can be active. I'm sure there must be some way to do it. For instance, it would be desirable if the MCU could wake up not just from a timer event every, say, 5 minutes, to take a temperature reading, but also immediately if there is a leak detected. Right now it's just one or the other.
          rmtuckerR 1 Reply Last reply
            rmtuckerR
            rmtuckerR
            rmtucker
            So we can not use the normal statement
            int8_t sleep(int interrupt, int mode, unsigned long ms=0);
            I did not realize that was the case as i have never tried it.
              #81
              I believe hwSleep(..) is the preferred incantation, but beyond that I'm not sure of anything. Maybe @d00616 can comment?
              I should be receiving a number of different PCB projects tomorrow for final assembly and test, and if I can't resolve this soon, I'm simply going to release them without full demo code.
              scalzS 1 Reply Last reply
                #82
                @NeverDie said in 💬 MySensors NRF5 Platform:
                In MySensors, the regular way to use sleep mode is by using the sleep() functions:
                https://www.mysensors.org/download/sensor_api_20#sleeping
                But like you said, you can also use the raw hwSleep() from the hw abstraction layer. Or you could also rewrite it!
                Which means at each abstraction layer, there are additional logics. sleep() functions have more logics (regarding MySensors states and features) than the raw hwSleep for example (like testing if there is an ongoing ota, smartsleep, heartbeat etc..). I have nodes where i use raw or not, but it's good to know what's behind.
                • scalzS scalz
                  rmtuckerR
                  rmtuckerR
                  rmtucker
                  @scalz
                  So the statement
                  Can be used for timer and pin interrupt at he same time on the NRF5 platform just like the arduino?
                    I'll try it, but I have strong doubts that it's going to work.
                    FWIW, here's the pin mapping currently being supplied by digitalPinToInterrupt(..) for the nRF5:
                    Digital pin 0 = interrupt pin 0
                    Digital pin 1 = interrupt pin 1
                    Digital pin 2 = interrupt pin 2
                    Digital pin 3 = interrupt pin 3
                    Digital pin 4 = interrupt pin 4
                    Digital pin 5 = interrupt pin 5
                    Digital pin 6 = interrupt pin 6
                    Digital pin 7 = interrupt pin 7
                    Digital pin 8 = interrupt pin 8
                    Digital pin 9 = interrupt pin 9
                    Digital pin 10 = interrupt pin 10
                    Digital pin 11 = interrupt pin 11
                    Digital pin 12 = interrupt pin 12
                    Digital pin 13 = interrupt pin 13
                    Digital pin 14 = interrupt pin 14
                    Digital pin 15 = interrupt pin 15
                    Digital pin 16 = interrupt pin 16
                    Digital pin 17 = interrupt pin 17
                    Digital pin 18 = interrupt pin 18
                    Digital pin 19 = interrupt pin 19
                    Digital pin 20 = interrupt pin 20
                    Digital pin 21 = interrupt pin 21
                    Digital pin 22 = interrupt pin 22
                    Digital pin 23 = interrupt pin 23
                    Digital pin 24 = interrupt pin 24
                    Digital pin 25 = interrupt pin 25
                    Digital pin 26 = interrupt pin 26
                    Digital pin 27 = interrupt pin 27
                    Digital pin 28 = interrupt pin 28
                    Digital pin 29 = interrupt pin 29
                    Digital pin 30 = interrupt pin 30
                      #85
                      The last I heard, from @d00616 , we had to supply code such as:
                          // Enable interrupt
                        NVIC_EnableIRQ(RTC0_IRQn);
                      and
                      // This must be in one line
                      extern "C" { void RTC0_IRQHandler(void) {rtcInterruptCounter++; NRF5_RESET_EVENT(NRF_RTC0->EVENTS_OVRFLW); NRF_RTC0->EVENTS_OVRFLW=0; }}
                      to get interrupts to work. Even with that approach, though, I haven't gotten it to support any interrupts in addition to a timed sleeping, though I have gotten it to support one interrupt that's separate from a timed sleeping (basically, sleeps indefinitely until the interrupt happens).
                        #86
                        OK, I just now tried:
                          sleep(3,CHANGE,3000);
                        and, as I suspected, it does nothing but sleep for 3 seconds. It's not responsive to any changes on pin P03 on an nRF52.
                        @scalz Are you getting a different result? It seems like there's a strong disconnect somewhere between what you're recommending and what I am experiencing.
                          #87
                          I didn't give any recommandation, you misread. I just said the regular way to use sleep feature in mysensors, for users, is with sleep(..). But I agree, I misread you too! when you were asking for the specific nrf52 case I guess :)
                          That said, I got this working when I made my recessed node for door (accelerometer and hall effect sensor with sleeping). Maybe things have changed in the lib?? or not. I'm struggling between different version of the lib, and some are different from the dev branch.. I'll recheck this asap (not sure for this evening).
                            #88
                            I tried toying around with it a bit, and I got a useful result:
                            #define MY_CORE_ONLY
                            #include <nrf.h>
                            const byte ledPin = LED_BUILTIN;
                            const byte interruptPin = 3;
                            volatile byte state = LOW;
                                for (int i=0;i<pulses;i++) {
                                  wait(20);
                                  wait(100);
                                  wait(500);
                              hwPinMode(interruptPin, INPUT);
                              attachInterrupt(digitalPinToInterrupt(interruptPin), blink, RISING);
                              blinkityBlink(2,1);  //signify power-on and start of main loop
                            volatile bool buttonPressed=false;
                              state = !state;
                              digitalWrite(ledPin, state);
                              sleep(digitalPinToInterrupt(interruptPin), RISING, 3000);
                              wait(20);  //wait 20 milliseconds for button to debounce if it was pressed
                              if (digitalRead(interruptPin)) { //if button is pressed
                                blinkityBlink(2,1);
                              if (buttonPressed) {
                                blinkityBlink(20,1);
                            void blink() {
                              buttonPressed=true;
                            So, with this approach, pushing the button on pin 3 does wake up the nRF52 from sleep, whereupon the button press can still be detected and serviced, but it also demonstrates that the ISR per se isn't working.
                            Anyhow, with this I'm able to get the PIR or leak sensor or magnet sensor or light sensor doing useful things in a timely manner, even if it isn't ideal. That puts me further ahead than I was before. :)
                              #include <nrf.h>
                                    wait(20);
                                    wait(100);
                                    wait(500);
                                state = !state;
                                  blinkityBlink(2,1);
                              void blink() {
                                buttonPressed=true;
                              rmtuckerR
                              rmtuckerR
                              rmtucker
                              This is a test program that wakes up from either that i was using some time ago.
                                 REVISION HISTORY
                                 Version 1.0 - Henrik EKblad
                                 DESCRIPTION
                                 This sketch provides an example how to implement a distance sensor using HC-SR04
                                 Use this sensor to measure KWH and Watt of your house meeter
                                 You need to set the correct pulsefactor of your meeter (blinks per KWH).
                                 The sensor starts by fetching current KWH value from gateway.
                                 Reports both KWH and Watt back to gateway.
                                 Unfortunately millis() won't increment when the Arduino is in
                                 sleepmode. So we cannot make this sensor sleep if we also want
                                 to calculate/report watt-number.
                                 http://www.mysensors.org/build/pulse_power
                              // Enable debug prints
                              //#define MY_RADIO_NRF24
                              #define MY_RADIO_NRF5_ESB
                              //#define MY_RADIO_RFM95
                              #include <Wire.h> // must be included here so that Arduino library object file references work
                              #include <RtcDS3231.h>
                              RtcDS3231<TwoWire> Rtc(Wire);
                              #define DIGITAL_INPUT_SENSOR 2  // The digital input you attached your light sensor.  (Only 2 and 3 generates interrupt!)
                              //#define SLEEP_MODE false        // Watt-value can only be reported when sleep mode is false.
                              unsigned long SEND_FREQUENCY = 20000; // Minimum time between send (in milliseconds). We don't wnat to spam the gateway.
                              double ppwh = ((double)PULSE_FACTOR) / 1000; // Pulses per watt hour
                              //bool pcReceived = false;
                              volatile unsigned long kwh = 0;
                              unsigned long oldWatt = 0;
                              double oldKwh;
                              unsigned long lastSend;
                              MyMessage wattMsg(CHILD_ID, V_WATT);
                              MyMessage kwhMsg(CHILD_ID, V_KWH);
                                Rtc.Begin();
                                Rtc.Enable32kHzPin(false);
                                Rtc.SetSquareWavePinClockFrequency(DS3231SquareWaveClock_1Hz);
                                Rtc.SetSquareWavePin(DS3231SquareWavePin_ModeClock);
                                attachInterrupt(digitalPinToInterrupt(DIGITAL_INPUT_SENSOR), onPulse, FALLING);
                                //pcReceived = true;
                                lastSend = millis();
                                present(CHILD_ID, S_POWER);
                                unsigned long now = millis();
                                if (sendTime) {
                                  if (watt != oldWatt) {
                                    if (watt < ((unsigned long)MAX_WATT)) {
                                    Serial.print("Watt:");
                                    Serial.println(watt);
                                    oldWatt = watt;
                                  // Pulse count has changed
                                  //kwh = pulseCount;
                                  //double kwh = ((double)pulseCount / ((double)PULSE_FACTOR));
                                  send(kwhMsg.set(pulseCount));  // Send kwh value to gw
                                  Serial.print("Wh = ");
                                  Serial.println(pulseCount);
                                  pulseCount = 0;
                                  lastSend = now;
                                sleep(SEND_FREQUENCY);
                              void onPulse()
                                unsigned long interval = newBlink - lastBlink;
                                if (interval < 50000L) { // Sometimes we get interrupt on RISING
                                  return;
                                watt = (3600000000.0 / interval) / ppwh;
                                lastBlink = newBlink;
                                pulseCount++;
                                #90
                                Well, that's interesting. In the sketch I posted, I invoked sleep with:
                                which caused the mcu to wake up immediately after I press the button, but it didn't process the ISR.
                                Using an invocation like yours in the sketch you just posted above:
                                  sleep(3000);
                                the ISR executes and then terminates when I press the button, but the MCU doesn't wake and continue with the loop as it did with the prior incantation. Instead, it has to wait for the timer cycle to finish.
                                What I want is for it to wake up, do the ISR, and continue with the loop where it left off until it is explicitly put back to sleep again. How do I do that?
                                • d00616D
                                  d00616D
                                  d00616
                                  @NeverDie I have checked the sleep routine in all three variants. It's working with my setup.
                                  There is no API stopping the sleep() by another ISR. Sleep only ends at one of the given conditions.
                                  When you use the MY_CORE_ONLY define, please add "hwInit();" into the setup() routine.
                                  • d00616D d00616
                                    Would you please post the three demo code examples that you tested?
                                      OK, I just now did that, but I'm not getting any difference in the results.
                                        In any case, I'm sure the question will ultimately turn from "How do I wake up based on a pin change?" to "How do I wake up based on the LPCOMP output, which has that pin as its input?" The reason: as covered earlier in this thread, much lower current consumption while sleeping if doing it via LPCOMP rather than the more straightforward pin monitoring.
                                        d00616D 1 Reply Last reply
                                          d00616D
                                          d00616D
                                          d00616
                                          It's a good question about, how to design the API to do this. I have no good idea.
                                          Until an API, you can set MY_HW_RTC->CC[0] to (MY_HW_RTC->COUNTER+2). This ends sleep with some latency.
