  3. Wall mounted 'mood light' v2
29 Posts 12 Posters 25.6k Views 15 Watching
  • Tore André RosanderT
    Tore André Rosander
    @AWI
    Amasing! I have been using your v1 sketch on 5 different nodes.
    I was just about to make another one when i saw that you had released another version.
    I have made a similar hack to your v1 with a dimmer/selector switch in domoticz as pattern selector. But your code looks way better :)
    • Cliff KarlssonC
      Cliff KarlssonC
      Cliff Karlsson
      wrote on last edited by Cliff Karlsson
      If I wanted to add a effect like:
      #include "FastLED.h"
      #define NUM_LEDS 60
      CRGB leds[NUM_LEDS];
      #define PIN 6
        FastLED.addLeds<WS2811, PIN, GRB>(leds, NUM_LEDS).setCorrection( TypicalLEDStrip );
      // *** REPLACE FROM HERE ***
        // ---> here we call the effect function <---
      // ---> here we define the effect function <---
      // *** REPLACE TO HERE ***
      void showStrip() {
       #ifdef ADAFRUIT_NEOPIXEL_H
         // NeoPixel
         strip.show();
       #ifndef ADAFRUIT_NEOPIXEL_H
         // FastLED
         FastLED.show();
      void setPixel(int Pixel, byte red, byte green, byte blue) {
         // NeoPixel
         strip.setPixelColor(Pixel, strip.Color(red, green, blue));
         // FastLED
         leds[Pixel].r = red;
         leds[Pixel].g = green;
         leds[Pixel].b = blue;
      void setAll(byte red, byte green, byte blue) {
        for(int i = 0; i < NUM_LEDS; i++ ) {
          setPixel(i, red, green, blue);
        showStrip();
       SnowSparkle(0x10, 0x10, 0x10, 20, random(100,1000));
      void SnowSparkle(byte red, byte green, byte blue, int SparkleDelay, int SpeedDelay) {
       setAll(red,green,blue);
       int Pixel = random(NUM_LEDS);
       setPixel(Pixel,0xff,0xff,0xff);
       showStrip();
       delay(SparkleDelay);
       setPixel(Pixel,red,green,blue);
       showStrip();
       delay(SpeedDelay);
      What would I need to change/add in the code?
      • JurikJ
        JurikJ
        Jurik
        Hi there, I am very happy with this project. Somehow with the transition to the current stable library (2.0) the lights won't turn off completely. I can't figure out what is wrong. Anyone has some suggestions?
        AWIA 1 Reply Last reply
        • JurikJ Jurik
          AWIA
          AWIA
          AWI
          @Jurik Happened to me too... change the auto increments in the updateLightBrightness() routine to ++actualBrightness and --actualBrightness.
          See below
          // Update the light brightness if time
          void updateLightBrightness(){
              // global: curBrightness, actualBrightness, updateBrightnessDelay, lastBrightnessUpdate ;
              static byte actualBrightness ;                          // store real brightness state for slow dim
              unsigned long now = millis() ;
              if (now > lastBrightnessUpdate + updateBrightnessDelay){// check if time for update
                  if ( actualBrightness > curBrightness) {
                      FastLED.setBrightness( --actualBrightness);
                      FastLED.show();
                  } else if ( actualBrightness < curBrightness){
                      FastLED.setBrightness( ++actualBrightness );
                      FastLED.show();
                  lastBrightnessUpdate = now ;
          • Cliff KarlssonC
            Cliff KarlssonC
            Cliff Karlsson
            @AWI what does this mean: "const int numPixel = 16 ; // set to number of pixels (x top / y bottom)" ?
            If I have a strip with 72 leds that are in a row up/down, should I just enter 72?
            I also can't figure out how to control the leds from domoticz. I have copied your sketch and I see the device in domoticz under nrf-radio-gateway (with 7 childs)
            I have tried to create a dummy selector and have tried to add this:
            http://192.168.0.175:8080/json.htm?type=command&param=switchlight&idx=1094&switchcmd=Set Level&level=pFire
            http://192.168.0.175:8080/json.htm?type=command&param=switchlight&idx=1094&switchcmd=Set Level&level=0
            http://192.168.0.175:8080/json.htm?type=command&param=switchlight&idx=1094&switchcmd=Set Level&level=1
            http://192.168.0.175:8080/json.htm?type=command&param=switchlight&idx=1094&switchcmd=Set Level&level=2
            http://192.168.0.175:8080/json.htm?type=command&param=switchlight&idx=1094&switchcmd=Set Level&level=pOn
            But nothing seams to work, I have also tried the commands directly in the chrome url bar with no effect. What am I missing?
            • Cliff KarlssonC
              Cliff KarlssonC
              Cliff Karlsson
              Ahhh, the effects start at 4 ? when trying numbers 4-10 I get effects for most numbers but a few like 8-9 is blank and 0-2 turns strip off. When fiddeling about, I managed to get the alarm at number 4 to speed up somehow. I tried to read the sketch but cant quite understand.
              • JurikJ
                JurikJ
                Jurik
                wrote on last edited by Jurik
                @AWI Thanx for the advice! i will try it as soon as i get the chance. Great work!! thanx.
                @Cliff-Karlsson Afaik, the numPixels correspond to the total number of leds combined with up/down or left/right. So 16 will make it an 8x8 wall light and 2 would make it a 1 by 1, 72 would make it 36x36. As far as the triggers in Domoticz, i am also new at this. I did manage to get the alarm running and the patterns through the dimmer function, but am unable to set up the patterns on a switch. Domoticz won't let me somehow. Will try to give this more prio.
                Keep trying! and posting please
                • JurikJ
                  JurikJ
                  Jurik
                  @AWI the preincrement trick worked! thanx!
                  • N
                    N
                    Nicklas Starkel
                    Hey @AWI
                    I have some trouble using this with MqTT messages.
                    I can get alarm to go off by sending a payload of '1' to 'InMQTT/62/4/1/0/2' and subsequently turn it off with any other value.
                    But I can't get the rest of your functions to work!
                    If I read your code correct, to set a solid color I would have to send several MqTT messages to the children?
                    Ex, I would have to send 'InMQTT/62/1/1/0/40' and payload ex 'Candle' first.
                    Then 'InMQTT/62/1/1/0/2' with payload of '1' to turn it on?
                    I was looking at the serial protocol and do not find what V_Dimmer is for type. (https://www.mysensors.org/download/serial_api_20#variable-types)
                    Anyways, i cant get it to work properly, maybe you could shed some light (pun not intended :+1: ) )?
                    • D
                      dakipro
                      If someone still needs it, I managed to control it via mqtt (node-red). I am about to integrate it into the openhab, it might be easier to start that but I wanted to have good control over it (and understand mqtt a bit better).
                      In sketch I had to change
                      } else if (message.type == V_DIMMER) { // if DIMMER type, adjust brightness
                      to V_PERCENTAGE for latest api/mqtt
                      and I am still struggling a bit to turn all LEDs off completely. Only way I could achieve this was to set color to black (000000). code as it is always leaves my LEDs to 1% or something. But that might be due to node-red implementation, as I do not have response from node-red on "questions" from the node (at some point in code node will ask controller about some values (color if I remember correctly), but I just send the color and brightness manually via injectors). I guess this can be fixed on the controller side, and most likely works with openhab implementation.
                      Here are the triggers in node-red
                      Here is the node-red code
                      [{"id":"8f6785a0.874838","type":"debug","z":"8cfe95c3.331248","name":"","active":true,"console":"false","complete":"false","x":1210,"y":180,"wires":[]},{"id":"a300f395.f6e59","type":"mqtt out","z":"8cfe95c3.331248","name":"","topic":"mygateway1-in/50/5/0/0/3","qos":"","retain":"","broker":"9daccc99.b6c71","x":490,"y":680,"wires":[]},{"id":"45adf375.e59b6c","type":"inject","z":"8cfe95c3.331248","name":"9 - pOff","topic":"","payload":"9","payloadType":"str","repeat":"","crontab":"","once":false,"x":170,"y":640,"wires":[["a300f395.f6e59"]]},{"id":"859588e.a1bec78","type":"mqtt out","z":"8cfe95c3.331248","name":"","topic":"mygateway1-in/50/1/0/0/40","qos":"","retain":"","broker":"9daccc99.b6c71","x":560,"y":180,"wires":[]},{"id":"39b0ef0e.94ef","type":"inject","z":"8cfe95c3.331248","name":"","topic":"","payload":"22FF22","payloadType":"str","repeat":"","crontab":"","once":false,"x":210,"y":160,"wires":[["859588e.a1bec78"]]},{"id":"9dabd8f3.6033b8","type":"inject","z":"8cfe95c3.331248","name":"Alarm pattern","topic":"","payload":"1","payloadType":"str","repeat":"","crontab":"","once":false,"x":250,"y":40,"wires":[["3a117d06.451d12"]]},{"id":"3a117d06.451d12","type":"mqtt out","z":"8cfe95c3.331248","name":"","topic":"mygateway1-in/50/4/1/0/2","qos":"","retain":"","broker":"9daccc99.b6c71","x":560,"y":40,"wires":[]},{"id":"e3c2d218.e92dc","type":"mqtt out","z":"8cfe95c3.331248","name":"","topic":"mygateway1-in/50/4/1/0/2","qos":"","retain":"","broker":"9daccc99.b6c71","x":550,"y":80,"wires":[]},{"id":"5325f52d.2549fc","type":"inject","z":"8cfe95c3.331248","name":"Alarm OFF","topic":"","payload":"0","payloadType":"str","repeat":"","crontab":"","once":false,"x":230,"y":80,"wires":[["e3c2d218.e92dc"]]},{"id":"f9bc44c0.c1f2d8","type":"mqtt in","z":"8cfe95c3.331248","name":"Magic Ball #50","topic":"mygateway1-out/50/#","qos":"2","broker":"9daccc99.b6c71","x":920,"y":180,"wires":[["8f6785a0.874838"]]},{"id":"6a07f043.d5e8a","type":"comment","z":"8cfe95c3.331248","name":"node-id / child-sensor-id / command / ack / type / payload","info":"","x":1030,"y":60,"wires":[]},{"id":"f71ad6cd.2044a8","type":"inject","z":"8cfe95c3.331248","name":"","topic":"","payload":"2222EE","payloadType":"str","repeat":"","crontab":"","once":false,"x":210,"y":200,"wires":[["859588e.a1bec78"]]},{"id":"44e58ecb.748fb","type":"inject","z":"8cfe95c3.331248","name":"","topic":"","payload":"991122","payloadType":"str","repeat":"","crontab":"","once":false,"x":210,"y":240,"wires":[["859588e.a1bec78"]]},{"id":"a91be428.b74eb8","type":"comment","z":"8cfe95c3.331248","name":"Set color manually","info":"","x":170,"y":120,"wires":[]},{"id":"90b541d2.c2abf","type":"mqtt out","z":"8cfe95c3.331248","name":"","topic":"mygateway1-in/50/1/0/0/3","qos":"","retain":"","broker":"9daccc99.b6c71","x":550,"y":340,"wires":[]},{"id":"91fe4122.027e3","type":"inject","z":"8cfe95c3.331248","name":"","topic":"","payload":"80","payloadType":"str","repeat":"","crontab":"","once":false,"x":190,"y":320,"wires":[["90b541d2.c2abf"]]},{"id":"47bc1da0.380374","type":"inject","z":"8cfe95c3.331248","name":"","topic":"","payload":"20","payloadType":"str","repeat":"","crontab":"","once":false,"x":190,"y":360,"wires":[["90b541d2.c2abf"]]},{"id":"baa820db.90109","type":"inject","z":"8cfe95c3.331248","name":"","topic":"","payload":"2","payloadType":"str","repeat":"","crontab":"","once":false,"x":190,"y":400,"wires":[["90b541d2.c2abf"]]},{"id":"709b3196.8abe","type":"comment","z":"8cfe95c3.331248","name":"Set brightnes manually","info":"","x":180,"y":280,"wires":[]},{"id":"1cf7aba7.c34224","type":"mqtt out","z":"8cfe95c3.331248","name":"","topic":"mygateway1-in/50/1/0/0/2","qos":"","retain":"","broker":"9daccc99.b6c71","x":550,"y":480,"wires":[]},{"id":"4263529d.67e44c","type":"inject","z":"8cfe95c3.331248","name":"","topic":"","payload":"1","payloadType":"str","repeat":"","crontab":"","once":false,"x":190,"y":480,"wires":[["1cf7aba7.c34224"]]},{"id":"2528b5c4.d1bc6a","type":"inject","z":"8cfe95c3.331248","name":"","topic":"","payload":"0","payloadType":"str","repeat":"","crontab":"","once":false,"x":190,"y":520,"wires":[["1cf7aba7.c34224"]]},{"id":"e2707070.7e9dc","type":"comment","z":"8cfe95c3.331248","name":"Toggle last brightnes (not needed?)","info":"","x":200,"y":440,"wires":[]},{"id":"3b8f804c.e92f7","type":"inject","z":"8cfe95c3.331248","name":"18 - pOn","topic":"","payload":"18","payloadType":"str","repeat":"","crontab":"","once":false,"x":180,"y":680,"wires":[["a300f395.f6e59"]]},{"id":"d9d700e9.90d03","type":"inject","z":"8cfe95c3.331248","name":"27 - pFire","topic":"","payload":"27","payloadType":"str","repeat":"","crontab":"","once":false,"x":180,"y":760,"wires":[["a300f395.f6e59"]]},{"id":"b2cd2709.3706e8","type":"inject","z":"8cfe95c3.331248","name":"0 - pSolid","topic":"","payload":"0","payloadType":"str","repeat":"","crontab":"","once":false,"x":180,"y":600,"wires":[["a300f395.f6e59"]]},{"id":"a3c976d.8dbe488","type":"comment","z":"8cfe95c3.331248","name":"Patterns: pSolid, pOff, pOn, pAlarm, pFire, pFire2, pCandle, pCircle, pSinelon, pRainbow","info":"","x":660,"y":640,"wires":[]},{"id":"667c092c.9b9298","type":"inject","z":"8cfe95c3.331248","name":"36 - pFire2","topic":"","payload":"36","payloadType":"str","repeat":"","crontab":"","once":false,"x":180,"y":800,"wires":[["a300f395.f6e59"]]},{"id":"ca6823c6.a674","type":"inject","z":"8cfe95c3.331248","name":"25 - pAlarm","topic":"","payload":"25","payloadType":"str","repeat":"","crontab":"","once":false,"x":190,"y":720,"wires":[["a300f395.f6e59"]]},{"id":"75c152f3.3c287c","type":"inject","z":"8cfe95c3.331248","name":"45 - pCandle","topic":"","payload":"45","payloadType":"str","repeat":"","crontab":"","once":false,"x":190,"y":840,"wires":[["a300f395.f6e59"]]},{"id":"6da316d0.eebd68","type":"inject","z":"8cfe95c3.331248","name":"53 - pCircle","topic":"","payload":"53","payloadType":"str","repeat":"","crontab":"","once":false,"x":190,"y":880,"wires":[["a300f395.f6e59"]]},{"id":"2c15c208.c1db0e","type":"inject","z":"8cfe95c3.331248","name":"62 - pSinelon (blocks all!)","topic":"","payload":"62","payloadType":"str","repeat":"","crontab":"","once":false,"x":230,"y":920,"wires":[["a300f395.f6e59"]]},{"id":"431aad05.60f7e4","type":"inject","z":"8cfe95c3.331248","name":"","topic":"","payload":"66 - rainbow","payloadType":"str","repeat":"","crontab":"","once":false,"x":190,"y":960,"wires":[["a300f395.f6e59"]]},{"id":"b1b44b6e.1492a8","type":"comment","z":"8cfe95c3.331248","name":"Set pattern","info":"","x":100,"y":560,"wires":[]},{"id":"70d088e7.889c98","type":"inject","z":"8cfe95c3.331248","name":"0 - doesn't work, use color black","topic":"","payload":"0","payloadType":"str","repeat":"","crontab":"","once":false,"x":390,"y":400,"wires":[["90b541d2.c2abf"]]},{"id":"d5d24b03.2a6288","type":"inject","z":"8cfe95c3.331248","name":"000000 - black turns led off","topic":"","payload":"000000","payloadType":"str","repeat":"","crontab":"","once":false,"x":430,"y":240,"wires":[["859588e.a1bec78"]]},{"id":"9daccc99.b6c71","type":"mqtt-broker","z":"","broker":"localhost","port":"1883","clientid":"","usetls":false,"compatmode":false,"keepalive":"60","cleansession":true,"willTopic":"","willQos":"0","willPayload":"","birthTopic":"","birthQos":"0","birthPayload":""}]
                      • T
                        Tinnyt
                        that sounds good
                        • A
                          adds666
                          Hello all, many thanks to @AWI for this great sketch - it performs very well and is my 'go to' for a WS28XX interface with Mysensors and Openhab.
                          I am however, starting to experience problems introduced with the FastLED 'wait' commands and the radio receiving a command - essentially, if I command the node to a pattern that is particularly blocking - I cant them command it to off, solid colour or another pattern.
                          Anyone solved this problem - or able to point me in the direction of solving. I'd be happy to refresh the sketch and re-share.
                          • A
                            adds666
                            Morning all, apologies for waking up an old thread, but it's pertinent to this chain of thought:
                            I'd like to build on this code and introduce a few more LED settings according to the percentage figure sent in the RGB dimmer.
                            Can anyone explain which part looks at the percentage and translates it out to the pattern?
                            How would I go about adding a new pattern to a chosen percentage value?
                            Many thanks
                            Adam
                             PROJECT: MySensors / RGB light NEOPIXEL
                             PROGRAMMER: AWI
                             DATE: october 10, 2015/ last update: september 20, 2016
                             FILE: AWI_Wall_LIght_x.ino
                             LICENSE: Public domain
                             https://forum.mysensors.org/topic/4934/wall-mounted-mood-light-v2
                             Hardware: Nano and MySensors 2.0, Wall light 16 WS2812B leds (neopixel)
                             Special:
                              uses Fastled library with NeoPixel (great & fast RBG/HSV universal library)       https://github.com/FastLED/FastLED
                             SUMMARY:
                              Different patterns and brightness settings
                              Button switches on/off and cycles through all Color patterns on long press
                             Remarks:
                              Fixed node-id
                             Change log:
                             20160915 - Updated to MySensors 2.0
                             20160920 - Changed state change to dimmer i.s.o. switch()
                            RGB Dimmer percentages = pattern
                            0 - 6 = Solid Colour
                            7 - 19 = Dim (think supposed to be off)
                            20 - 26 - Alarm (white and red light)
                            27 - 34 = Fire
                            35 - 46 = Fire2
                            47 - = one way Runner (set the colour first)
                            = Two way Runner (White)
                            You will be limited by RAM as to how many LEDs you can run
                            Using a Mega you can run 2000 LEDs
                            Arduino Nano = 2kb ram = 600 pixels
                            Arduino Uno = 2kb ram = 600 pixels
                            Arduino Mega = 8kb ram = 2400 pixels
                            //****  MySensors *****
                            //#define MY_RADIO_NRF24                    // Enable and select radio type attached
                            //#define MY_RF24_CHANNEL 80                // radio channel, default = 76
                            #define MY_RS485
                            #define MY_RS485_DE_PIN 2
                            #define MY_NODE_ID 2
                            #define NODE_TXT "WS2812 N2"                   // Text to add to sensor name
                            // #define MY_RF24_CE_PIN 7                 // Ceech board, 3.3v (7,8)  (pin default 9,10)
                            // #define MY_RF24_CS_PIN 8
                            // helpers
                            #define LOCAL_DEBUG                     // enable if print wanted
                            #ifdef LOCAL_DEBUG
                            #define Sprint(a) (Serial.print(a))             // macro as substitute for print, enable if no print wanted
                            #define Sprintln(a) (Serial.println(a))           // macro as substitute for println
                            #define Sprint(a)
                            #define Sprintln(a)
                            #include <SPI.h>                      // My Sensors
                            #include <FastLED.h>                    // https://github.com/FastLED/FastLED
                            #include "JC_Button.h"                     // https://github.com/JChristensen/Button
                            const int stripPin = 4 ;                  // pin where 2812 LED strip is connected
                            const int buttonPin = 5 ;                 // push button
                            const int numPixel = 156 ;                 // set to number of pixels (x top / y bottom)
                            const int RGB_LightChild = 0 ;                // Child Id's, standard light child on/off/ dim
                            const int RGB_RGBChild = 1 ;                // RGB light child (on/off/dim/color, if controller supports V_RBG))
                            const int RGB_SolidColorChild = 2 ;             // when set, node reads Color text from ColorTextChild
                            const int RGB_TextColorChild = 3 ;              // Holds Text value for color (custom colors from controller)
                            const int RGB_AlarmPatternChild = 4 ;           // Switches to alarm status
                            const int RGB_NextPatternChild = 5 ;            // Move to next pattern when set
                            CRGB leds[numPixel];
                            // Kelving colors: Light & daylight (in Fastled reference only)
                            /// 1900 Kelvin Candle=0xFF9329 /* 1900 K, 255, 147, 41 */,
                            /// 2600 Kelvin Tungsten40W=0xFFC58F /* 2600 K, 255, 197, 143 */,
                            /// 2850 Kelvin Tungsten100W=0xFFD6AA /* 2850 K, 255, 214, 170 */,
                            /// 3200 Kelvin Halogen=0xFFF1E0 /* 3200 K, 255, 241, 224 */,
                            /// 5200 Kelvin CarbonArc=0xFFFAF4 /* 5200 K, 255, 250, 244 */,
                            /// 5400 Kelvin HighNoonSun=0xFFFFFB /* 5400 K, 255, 255, 251 */,
                            /// 6000 Kelvin DirectSunlight=0xFFFFFF /* 6000 K, 255, 255, 255 */,
                            /// 7000 Kelvin OvercastSky=0xC9E2FF /* 7000 K, 201, 226, 255 */,
                            /// 20000 Kelvin ClearBlueSky=0x409CFF /* 20000 K, 64, 156, 255 */
                            char setRGBvalue[] = "FFC58F";                // Controller sent RGB value, default tungsten40W
                            uint16_t curBrightness = 0x7F, setBrightness = 0x7F ;   // Brightness globals (actualBrightness)
                            unsigned long updateBrightnessDelay, lastBrightnessUpdate ; // Brightness timers
                            int RGBonoff ;                        // OnOff flag
                            enum { pSolid, pOff, pOn, pAlarm, pFire, pFire2, pCandle, pCircle, pSinelon, pRainbow}  ; // Pattern states (stored in int for convenience)
                            const int lastPatternIdx = pRainbow + 1 ;         // use last pattern for patterncount
                            int curPattern = pSolid ;                 // current pattern
                            int setPattern = pSolid ;                 // set pattern (controller)
                            unsigned long updatePatternDelay, lastPatternUpdate ;   // Pattern timers
                            unsigned long idleTimer = millis() ;            // return to idle timer
                            const unsigned long idleTime = 10000UL;         // return to idle after 10 secs
                            const unsigned long dimTime = 1000UL;           // dim period
                            const unsigned long heartbeatInterval = 1 * 60UL * 1000UL ; // heartbeatinterval, just to let the controller know I am alive
                            unsigned long heartbeatCounter = 0 ;
                            MyMessage lightRGBMsg(RGB_LightChild,  V_RGB);        // standard messages, light
                            MyMessage lightdimmerMsG(RGB_LightChild ,V_DIMMER);
                            MyMessage lightOnOffMessage(RGB_LightChild, V_STATUS);
                            Button myBtn(buttonPin, true, true, 20);          //Declare the button (pin, pull_up, invert, debounce_ms)
                            // Simple state machine for button state
                            enum {sIdle, sBrightness, sPattern} ;            // simple state machine for button press
                            int State ;
                              FastLED.addLeds<WS2812B, stripPin, RGB >(leds, numPixel);   // initialize led strip (NEOPIXEL =WS...)
                              for(int i = 0 ; i < 6 ; i++) {              // get color value from EEPROM (6 char)
                                setRGBvalue[i] = loadState(i) ;
                              setLightPattern(pSolid, 0) ;              // default controller Solid
                              FastLED.show();
                              State = sIdle ;                     // Initial state
                              //randomSeed(analogRead(0));
                            void presentation(){
                            // MySensors
                              sendSketchInfo("AWI RGB Wall " NODE_TXT, "2.0");
                              present(RGB_RGBChild, S_RGB_LIGHT, "RGB Wall RGB " NODE_TXT);// present to controller
                              present(RGB_LightChild, S_LIGHT, "RGB Wall Light " NODE_TXT);
                              present(RGB_SolidColorChild, S_LIGHT, "RGB Set Solid color (text) " NODE_TXT);
                              present(RGB_TextColorChild, S_INFO, "RGB Wall textcolor " NODE_TXT);
                              present(RGB_AlarmPatternChild, S_BINARY, "RGB Wall Alarm " NODE_TXT);
                              present(RGB_NextPatternChild, S_DIMMER, "RGB Wall Pattern " NODE_TXT);
                            // read button and act accordingly
                            // short press: on/off
                            // longer press: set patterns with following short press
                            // long press: set brightness increase
                              myBtn.read();                             //Read the button (only read)
                              unsigned long now = millis();               // loop timer reference
                              switch (State) {
                                case sIdle:                     // default state, browse through patterns
                                  if (myBtn.wasReleased()){           // light on/ off in idle
                                    RGBonoff = !RGBonoff ;            // invert light state
                                    setLightBrightness((RGBonoff == 1)?setBrightness:0, dimTime);
                                    send(lightOnOffMessage.set(RGBonoff));  // and update controller
                                  } else if (myBtn.pressedFor(800)){        // move to Pattern update state with long press
                                    idleTimer = now ;             // return to idle after ...
                                    State = sPattern ;
                                  break ;
                                case sPattern:                    // entered after long press
                                  if (myBtn.pressedFor(4000)){          // when press even longer move to Brightness update
                                    State = sBrightness ;
                                  } else if (myBtn.wasPressed()){
                                    setPattern = (setPattern + 1) % lastPatternIdx ;  // increase pattern and wrap
                                    setLightPattern((setPattern), 500 );
                                    idleTimer = now ;
                                  } else if ( now > idleTime + idleTimer  ){    // return to idle after ...
                                    State = sIdle ;
                                  break ;
                                case sBrightness:                 // entered after looong press
                                  if (myBtn.wasPressed()){              // if pressed again increase brightness
                                    setLightBrightness((curBrightness+0x1F) % 0xFF, 0) ; // increase brightness and wrap (0..0xFF)
                                    idleTimer = now ;
                                    State = sIdle ;
                                  break ;
                                default :
                                  State = sIdle ;
                                  break ;
                              updateLightBrightness();                // update Brightness if time
                              updateLightPattern();                 // update Pattern if time
                              if ( now > heartbeatCounter  + heartbeatInterval){    // heartbeat every hour
                                  sendHeartbeat();
                                heartbeatCounter = now ;
                            // Sets the light brightness, takes value and time (ms) as input
                            void setLightBrightness(int newBrightness, unsigned long updateTime){
                              updateBrightnessDelay = updateTime / 0xFF ;       // delay = time / max steps
                              curBrightness = newBrightness ;             // set curBrightness to new value, rest is done in update
                                  FastLED.setBrightness( --actualBrightness );
                                  FastLED.show();
                                  FastLED.show();
                            // **** Pattern routines *****
                            // Sets and initializes the light pattern if nescessary
                            void setLightPattern( int newPattern, unsigned long updateDelay){
                              // global: curPattern, updatePatternDelay
                              static int lastPattern = pSolid ;           // last pattern for pOn / pOff virtual patterns
                              if (newPattern == pOff) lastPattern = curPattern ;    // remember last pattern
                              if (newPattern == pOn) curPattern = lastPattern ;   // only for pOn switch to last pattern
                              else curPattern = newPattern ;
                              updatePatternDelay = updateDelay ;            // delay for next pattern update, can be changed in pattern
                              switch(curPattern){
                                case pSolid:                    //  solid is set value in all pixels (and on)
                                  for(int i = 0 ; i < numPixel ; i++) leds[i] = strtol( setRGBvalue, NULL, 16);
                                  setLightBrightness(setBrightness, dimTime) ;  // slow dim to on
                                  FastLED.show();
                                  break ;
                                case pOn:                     //  On is set Brightness in all pixels
                                  FastLED.show();
                                  break ;
                                case pOff:                      //  off state all pixels off (add dim and pOn)
                                  setLightBrightness(0, dimTime) ;          // slow dim to off
                                  FastLED.show();
                                  break ;
                                case pCircle:                   //  all pixels off
                                  for(int i = 0 ; i < numPixel ; i++) leds[i] = 0 ;
                                  for(int i = 0 ; i < 2 ; i++){
                                    leds[i] = strtol( setRGBvalue, NULL, 16) ; // 1 pixel on
                                  FastLED.show();
                                  break ;
                                default :
                                  FastLED.show();
                                  break ;
                            // Update the light pattern when time for it
                            void updateLightPattern(){
                              // global: curPattern, updatePatternDelay, lastPatternUpdate
                              if (now > lastPatternUpdate + updatePatternDelay){    // check if time for update
                                switch (curPattern) {
                                  case pAlarm:                  // flash light
                                    patternAlarm();
                                    break ;
                                  case pFire:                   // wild fire
                                    patternFire();
                                    break ;
                                  case pFire2:                  // cosy fire
                                    patternFire2();
                                    break ;
                                  case pCandle:                 // flame
                                    patternCandle();
                                    break ;
                                  case pCircle:                 // flame
                                    patternCircle();
                                    break ;
                                  case pRainbow:                  // rotating rainbow
                                    patternRainbow();
                                    break ;
                                  case pSinelon:                  // rotating rainbow
                                    patternSinelon();
                                    break ;
                                  case pSolid:                  // do nothing fall through
                                  case pOff:
                                  case pOn:
                                  default :                   // def
                                    break ;
                                lastPatternUpdate = now ;
                            // Define the different patterns
                            // Alarm - intermittent white and red color, full intensity, intermittent top & bottom half
                            void patternAlarm() {
                                static boolean topBot ;                 // indicates direction for next entry
                              const CRGB colorTop = CRGB(0xFF, 0, 0 );        // red color
                              const CRGB colorBottom = CRGB(0xFF, 0xFF, 0xFF );   // white color
                              FastLED.setBrightness(0xFF);              // set the strip brightness to max for Alarm
                              for(int i=0; i <= (numPixel / 2 - 1) ; i++) {     // for half of strip size
                                leds[i] = topBot?colorTop:colorBottom ;
                                leds[i+ (numPixel/2)] = topBot?colorBottom:colorTop ;
                              topBot = !topBot ;                    // switch direction
                              FastLED.show();
                            // Simulate fire with red color, varying number of leds intensity & tempo
                            void patternFire() {
                                byte numberLeds = random(0,numPixel);         // start number and end of led's for flickering
                                int lum = ((random(100,255) * curBrightness)) / 0xFF ;  // set brightness and scale
                                CRGB color = CRGB(200, random(70,230),0 );        // get red color with varying green
                                for(int i=0; i <= numberLeds; i++) {
                                  leds[i] = color ;
                                  FastLED.setBrightness(lum);             // set the strip brightness
                                  FastLED.show();
                                  wait(random(0,10));                 // (blocking, need to be changed)
                                updatePatternDelay = 100 ;
                            // Simulate fire with red color and varying intensity & tempo
                            void patternFire2() {
                                CRGB color = CRGB(200, random(100,150),0);        // get red color with varying green
                                for (byte p=0; p < numPixel; p++) {
                                  leds[p] = color;
                                FastLED.setBrightness((random(50,255) * curBrightness)/ 0xFF ); // set Brightness and scale
                                FastLED.show();
                                updatePatternDelay = random(20,300);          // variable delay
                            // Simulate candle based on fire with red color, varying number of leds intensity & tempo
                            void patternCandle() {
                                byte lum = ((random(100, 255) * curBrightness)/ 0xFF);  // set brightness
                                CRGB color = CRGB(200, random(90,130),0 );        // get red color with varying green
                                  leds[i] = color ;
                                  FastLED.show();
                                  wait(random(5,10));                 // (blocking, need to be changed)
                            // a colored dot sweeping back and forth, with fading trails, adapted from Fastled sinelon
                            void patternSinelon()
                              fadeToBlackBy( leds, numPixel, 10);           // fade all leds a small amount
                              int pos = beatsin8(25,0,numPixel);            // get a new position for the led (BPM = 13, min, max, )
                              leds[pos] += strtol( setRGBvalue, NULL, 16);
                              FastLED.show();
                              updatePatternDelay = 2 ;
                            // Rotate all Leds with current content and trail
                            void patternCircle() {
                              static int currentLed ;                 // indicated current led to light
                              // CRGB tempLed = leds[0];                // temporary variable for color
                              fadeToBlackBy( leds, numPixel, 128);          // fade all leds for trail..
                              leds[currentLed] = strtol( setRGBvalue, NULL, 16);    // set to current color
                              currentLed = (currentLed + 1) % numPixel ;        // wrap
                                FastLED.show();
                            void patternRainbow() {
                              static uint16_t hue ;                 // starting color
                              FastLED.clear();
                              // for(hue=10; hue<255*3; hue++) {
                              hue = (hue+1) % 0xFF ;                  // incerease hue and wrap
                              fill_rainbow( leds, numPixel , hue /*static hue value */, 1);// set a rainbow from hue to last in stepsize 1
                              FastLED.show();
                            // Incoming messages from MySensors
                              int ID = message.sensor;
                              Serial.print("Sensor: ");
                              Serial.println(ID);
                              switch (ID){
                                case RGB_LightChild:                // same behaviour as RGB child/ fall through
                                case RGB_RGBChild:                  // if controller can handle V_RGB
                                  if (message.type == V_RGB) {          // check for RGB type
                                    strcpy(setRGBvalue, message.getString()); // get the payload
                                    setLightPattern(pSolid, 0);         // and set solid pattern
                                    setBrightness = map(message.getInt(), 0, 100, 0, 255);
                                  } else if (message.type == V_STATUS) {      // if on/off type, toggle brightness
                                    RGBonoff = message.getInt();
                                  break ;
                                case RGB_SolidColorChild:             // request color from controller
                                  if (message.type == V_STATUS) {         // if get color from text child
                                    request(RGB_TextColorChild, V_TEXT);
                                    setLightPattern(pSolid, 0);         // and set solid pattern (if not alre)
                                  break ;
                                case RGB_TextColorChild:              // Text color from controller
                                  if (message.type == V_TEXT) {         // if get color from text child
                                    for(int i = 0 ; i < 6 ; i++) {        // save color value to EEPROM (6 char)
                                      saveState(i, setRGBvalue[i]) ;}     // Save to EEPROM
                                  break ;
                                case RGB_AlarmPatternChild:             // set Alarm pattern
                                    if (message.getInt() == 1){
                                      setLightPattern(pAlarm, 500);     // set slow alarm pattern
                                      setLightPattern(setPattern, 0);     // and reset pattern
                                      FastLED.setBrightness(setBrightness);
                                  break ;
                                case RGB_NextPatternChild:              // next pattern
                                  if (message.type == V_PERCENTAGE) {       //  Percentage indicates the pattern
                                    setPattern = map(message.getInt(), 0, 100, 0, 15) % lastPatternIdx  ; // mapper dimmer value to state 0..9  and wrap
                                    Sprint("Pattern: ") ; Sprintln(setPattern) ;
                                  } else if (message.type == V_STATUS){     // if off switch pattern to default == 0
                                    setPattern = 0  ;
                                  break ;
                                FastLED.show();
                              dispRGBstat();
                            // debug
                            // display the status of all RGB: controller, requested, real
                            void dispRGBstat(void){
                                Serial.print(" Color: "); Serial.print(setRGBvalue);
                                Serial.print(" Brightness: "); Serial.println(setBrightness);
                            • nagelcN
                              nagelcN
                              nagelc
                              wrote on last edited by nagelc
                              #27
                              Hi @adds666 . I think it is this bit in the receive() function near the bottom of the code. It gets the value from the V_PERCENTAGE message and maps into the setPattern value:
                                  setPattern = 0  ;
                                break ;
                              • A
                                adds666
                                Hi @nagelc , thanks for coming back to me - Apologies I didn't realise you'd replied nearer the time.
                                Am I right in thinking, so long as I define the new patterns function later on in the sketch - I can include it in the switch of function updateLightPattern, and it will be added to the mapping?
                                How do we know what definitive figures the 0 to 100 percentage map to in 0 to 15? Or is that basic arithmetic and each switch state will be called in each 'chunk'. I also only count 10 items in the switch state. Does that mean we can add 5 more? and if wanting more than 15 simply change our mapping size to have more?
                                Appreciate the help.
                                        patternAlarm();
                                        break ;
                                        patternFire();
                                        break ;
                                        patternFire2();
                                        break ;
                                        patternCandle();
                                        break ;
                                        patternCircle();
                                        break ;
                                        patternRainbow();
                                        break ;
                                        patternSinelon();
                                        break ;
                                      case pOff:
                                      case pOn:
                                      default :                   // def
                                        break ;
                                TheoLT 1 Reply Last reply
                                • A adds666
                                          patternAlarm();
                                          break ;
                                          patternFire();
                                          break ;
                                          patternFire2();
                                          break ;
                                          patternCandle();
                                          break ;
                                          patternCircle();
                                          break ;
                                          patternRainbow();
                                          break ;
                                          patternSinelon();
                                          break ;
                                        case pOff:
                                        case pOn:
                                        default :                   // def
                                          break ;
                                  TheoLT
                                  TheoLT
                                  TheoL
                                  @adds666 I'm not sure but I believe Domoticz prresents it's dimmer values in steps from 5 to 100 I believe. It'd about 10 steps. That's why I'm not sure if you can add more patterns. Unless you indeed change it to a percentage. Hope it helps
                                  12.5k
