Issues since upgrading to v1.4.1
Yes, I did the gateway upgrade to V1.4.1 . I'm using Mqtt Gwy.
i've tried also to used SofSpi but get the same problem as mentionned in an another post (compil error in RF24.h) . I've let my Mqtt Gateway in V1.4.1 but not with softspi , using ports 11,12,13 instead of A0,A1,A2.
I've rollbacked all my nodes to V1.4.
So my config is now : Nodes V1.4 + Gateway V1.4.1 , all run fine.You say that V1.4.1 is only a BugFix release but , for example, SofSPI was not present in V1.4 but only in V1.4.1. Maybe other differences ?
You didn't mention that you were running Ethernet... Which ethernet module type?
I'm not running the MQTT gateway myself unfortunately.
Not sure if @Damme has done any tests with SoftSPI enabled but it shouldn't affect things if you keep it disabled (default). -
