  3. 💬 MySensors NRF5 Platform
contest2017nrf52mysensorsnrf5nrf51
210 Posts 20 Posters 88.8k Views 18 Watching
  • d00616D d00616
    @neverdie said in 💬 MySensors NRF5 Platform:
    I have I2C and serial running with a NRF52832.
    Yes, it does seem to work on the nRF52832. Just not presently on the nRF51822.
    Can you check, if the device works with the "Generic NRF51822" board? You can edit the variant files in the arduino-nrf5\variants directory.
    C:\Users...\AppData\Local\Arduino15\packages\sandeepmistry\hardware\nRF5\0.4.0\variants\Generic
    I tried, but I guess I'm not doing it right. I couldn't even get it to blink an LED that way.
    • d00616D d00616
      @d00616 You mentioned that it works only with a particular version of GCC. Does that mean I need to have a particular version of the Arduino IDE installed? I'm currently running the latest version of Windows Arduino IDE, which is 1.8.5.
      The GCC version is part of the arduino-nrf5 distribution.
      Unfortunately, it does not appear that I2C is working.
      You can try to remove the compat_pin_mapping line and add the 0.1.0 pin map at this place. Then the board definition is nearly the 0.1.0 version.
      However, it doesn't seem to be working on the nrf51.
      I check the NRF51 board. What do you mean with no working?
      So, I take it you are suggesting that in myboardnrf5.cpp, where it says:
      #ifdef MYBOARDNRF5
      #include <variant.h>
      #include <compat_pin_mapping.h>
      I replace
      with what exactly? At this point I'm not even sure where 0.1.0 pin-map is, or even what it's called.
        #137
        After I modify the generic variant board definition, is there some trick to making it go "live"?
          #138
          there is no trick.. it should work.
          d00616 said, for a test, to not use his defines, the method that you're used to.
          So change the defines you need in the generic variant file, then in arduino:
            I think this must be where the disconnect is happening. Where do I find the files or directory for Generic nRF51? The closest I see is a directory called just "Generic":
            That's the one I tried modifying:
            and it had no effect. So, I suspect there must be a different "generic nRF51" somewhere which is closely tied with the menu item you show the picture of. However, I don't see where.
            Nca78N 1 Reply Last reply
              @neverdie did you check there ?
                #141
                I didn't try that one, but it's a similar dilemma:
                i.e. Does "Generic" do double duty for both "Generic nRF51" and "Generic nRF52"?
                  #142
                  Aha! That did it. Thanks @NCA78. It's working now, including the I2C.
                  I had to switch nodes though. It's possible that the mysensors code does work, as the node I was testing it on may have had a bad si7021 module on it. I'll post again after I retry with this different node.
                    #143
                    I'm back with the results. The same node where I2C works using the customized "Generic nRF51" does not have working I2c if using the mysensors "MyBoardnRF5 nRF51822".
                    So, I think I've taken this as far as I can. Hopefully this info helps you solve whatever the problem is.
                    I'm grateful I can keep moving along now using a modified "Generic nRF51822". Thanks everybody! :)
                      #144
                      Ashes on my head. The mysensors code is working with I2c after all. I confirmed it on the second (alternate) node. I had switched two of the wires in the myboardnrf5 pinout, but hadn't on the generic nRF51 pinout. Correcting for that, it now works.
                      What threw me completely off was the defective si7021 module on the first node. Well, now everything is sorted. :)
                      d00616D 1 Reply Last reply
                        d00616D
                        d00616D
                        d00616
                        Thank you for reporting this. Great news to hear this.
                        • d00616D d00616
                          #146
                          You're welcome, of course. Though it was a little bit of a wild goose chase, at least your code is now pretty well tested and proven to be "known good," so others can start using it without fear. :)
                          With this now out of the way, please do continue your excellent work!
                          • O
                            O
                            Omemanti
                            wrote on last edited by Omemanti
                            #147
                            • O Omemanti
                              [[topic:post-is-deleted]]
                              @omemanti Shot in the dark: did you swap Tx/Rx by accident?
                              • O
                                O
                                Omemanti
                                • O
                                  O
                                  Omemanti
                                  I'm not sure if I destroyed something on the board.ill try another one.. to not fill-up this forum threat I'll delete my previous posts
                                  • monteM
                                    monteM
                                    monte
                                    Hello, @d00616. Could you tell me which ESB library did you use to port it to arduino environment? The one that comes with Nordic SDK? After searching for few hours I haven't find any other realization of ESB mode for arduino IDE except your port included with MySensors. It's a pity. Are you going to release general purpose library, maybe?
                                    • monteM monte
                                      d00616D
                                      d00616D
                                      d00616
                                      @monte said in 💬 MySensors NRF5 Platform:
                                      The ESB library is written from scratch. At the time of of starting the Nordic SDK license was incompatible with open source projects. I have no plans to release this as stand-alone library. At the moment there is only an subset of the ESB protocol implemented. Enough to be compatible with MySensors RF24 devices.
                                      Feel free to use my code to create a stand-alone library. If required, we can talk about dual licensing to code with an additional open source license.
                                      monteM 1 Reply Last reply
                                      • d00616D d00616
                                        monteM
                                        monteM
                                        monte
                                        @d00616 thanks for a reply. I will evaluate my skills for this task, when I actually will get a chip to try it on. I need some really small pcb for my project, and single chip with mcu and rf with the size of nrf51 fits perfectly, but it requires quiet simple communications and full MySensors library will be overkill and hard to adapt for my needs.
                                        d00616D 2 Replies Last reply
                                        • monteM monte
                                          d00616D
                                          d00616D
                                          d00616
                                          You can use the MY_CORE_ONLY mode -> https://forum.mysensors.org/post/76627
                                          monteM 2 Replies Last reply
