  3. Only first transmission comes through.
10 Posts 5 Posters 3.0k Views 1 Watching
  • M Offline
    M Offline
    Mrlynx
    Hi
    I have a problem with a temp sensor that only sends in values after first boot and all subsequent transmissions fails.
    if I press reset then I get a all values first time but it fails after that first transmission.
    Has anyone had the same problem and have a solution?
    I have a feeling that the radio dosent wake up after sleep.
    sensor started, id 15
    send: 15-15-0-0 s=255,c=0,t=17,pt=0,l=5,st=ok:1.4.1
    send: 15-15-0-0 s=255,c=3,t=6,pt=1,l=1,st=ok:0
    send: 15-15-0-0 s=255,c=3,t=11,pt=0,l=25,st=ok:Dallas Temperature Sensor
    send: 15-15-0-0 s=255,c=3,t=12,pt=0,l=3,st=ok:1.0
    send: 15-15-0-0 s=0,c=0,t=6,pt=0,l=5,st=ok:1.4.1
    send: 15-15-0-0 s=1,c=0,t=6,pt=0,l=5,st=ok:1.4.1
    send: 15-15-0-0 s=2,c=0,t=6,pt=0,l=5,st=ok:1.4.1
    send: 15-15-0-0 s=3,c=0,t=6,pt=0,l=5,st=ok:1.4.1
    send: 15-15-0-0 s=4,c=0,t=6,pt=0,l=5,st=ok:1.4.1
    send: 15-15-0-0 s=5,c=0,t=6,pt=0,l=5,st=ok:1.4.1
    send: 15-15-0-0 s=6,c=0,t=6,pt=0,l=5,st=ok:1.4.1
    requesting temps from bus
    sensor035.69
    sending in value
    send: 15-15-0-0 s=0,c=1,t=0,pt=7,l=5,st=ok:35.7
    sensor126.19
    sending in value
    send: 15-15-0-0 s=1,c=1,t=0,pt=7,l=5,st=ok:26.2
    sensor229.25
    sending in value
    send: 15-15-0-0 s=2,c=1,t=0,pt=7,l=5,st=ok:29.3
    sensor325.75
    sending in value
    send: 15-15-0-0 s=3,c=1,t=0,pt=7,l=5,st=ok:25.8
    sensor465.69
    sending in value
    send: 15-15-0-0 s=4,c=1,t=0,pt=7,l=5,st=ok:65.7
    sensor529.69
    sending in value
    send: 15-15-0-0 s=5,c=1,t=0,pt=7,l=5,st=ok:29.7
    sensor668.25
    sending in value
    send: 15-15-0-0 s=6,c=1,t=0,pt=7,l=5,st=ok:68.3
    sensor035.25
    sending in value
    send: 15-15-0-0 s=0,c=1,t=0,pt=7,l=5,st=fail:35.3
    sensor126.19
    sending in value
    send: 15-15-0-0 s=1,c=1,t=0,pt=7,l=5,st=fail:26.2
    sensor229.19
    sending in value
    send: 15-15-0-0 s=2,c=1,t=0,pt=7,l=5,st=fail:29.2
    sensor325.81
    sending in value
    send: 15-15-0-0 s=3,c=1,t=0,pt=7,l=5,st=fail:25.8
    sensor465.62
    sending in value
    send: 15-15-0-0 s=4,c=1,t=0,pt=7,l=5,st=fail:65.6
    sensor529.62
    sending in value
    send: 15-15-0-0 s=5,c=1,t=0,pt=7,l=5,st=fail:29.6
    sensor668.25
    sending in value
    send: 15-15-0-0 s=6,c=1,t=0,pt=7,l=5,st=fail:68.3
    send: 15-15-255-255 s=255,c=3,t=7,pt=0,l=0,st=fail:
    sensor034.94
    sending in value
    send: 15-15-0-0 s=0,c=1,t=0,pt=7,l=5,st=fail:34.9
    sensor126.12
    sending in value
    send: 15-15-0-0 s=1,c=1,t=0,pt=7,l=5,st=fail:26.1
    sensor229.19
    sending in value
    sensor325.75
    sending in value
    sensor465.62
    sending in value
    sensor529.62
    http://www.sa2avr.se
    • M Mrlynx
      Hi
      sensor035.69
      sending in value
      sensor126.19
      sending in value
      sensor229.25
      sending in value
      sensor325.75
      sending in value
      sensor465.69
      sending in value
      sensor529.69
      sending in value
      sensor668.25
      sending in value
      sensor035.25
      sending in value
      sensor126.19
      sending in value
      sensor229.19
      sending in value
      sensor325.81
      sending in value
      sensor465.62
      sending in value
      sensor529.62
      sending in value
      sensor668.25
      sending in value
      sensor034.94
      sending in value
      sensor126.12
      sending in value
      sensor229.19
      sending in value
      sensor325.75
      sending in value
      sensor465.62
      sending in value
      sensor529.62
      M Offline
      M Offline
      mbj
      @Mrlynx If you describe what unit is sending and what controller/gateway is receiving then it might be easier for someone to assist you.
      • M Offline
        M Offline
        Mrlynx
        see log in previous post from sensor.
        messages logged OK get through and messages logged fail doesnt reach gateway.
        • M Mrlynx
          M Offline
          M Offline
          mbj
          Yes, that is obvious. My question was actually what type of sensor/controller/gateway you are using. I have the Dallas temperature sensor sending via MQTT (both nano) to OpenHab and it works quite well. But if the radio communication has a weak reception there might be quite a lot of failures too. I have seen several posts describing that 3,3 V from a nano can be a problem so the radio comm might be a good starting point for your further investigation.
          • H Offline
            H Offline
            Tried switching cap on radio?
            • S Offline
              samppa
              I have a similar problem but the connection is lost after a few days. With Dallas temp and DHT22 in Arduino nano node connecting wirelessly to Serial USB Gateway in Vera3. Both sensor and gateway have capacitors. The "solution" for my situation seems to be reboot after it works well.. for awhile. I was wondering if the restart could be automated by the node if it would see the transmission failures and reboot itself.
              @hek So 2 questions; how can I get the comm failure status in the code (send returns void instead of state) and is there a function to reboot the Arduino nano?
              S 1 Reply Last reply
              • K Offline
                K Offline
                korttoma
                I had a node that would communicate for a while and then stop. I found that I accidentally powered the radio with 5V.
                • Tomas
                • M Offline
                  M Offline
                  Mrlynx
                  My problem seems to be the distance between node and gateway.
                  I have now built a repeater node and it seems to cure the problem.
                  Node and gateway is in different buildings and about 20m apart with near line of sight.
                  I have also ordered a ethernet shield and a PA+LNA 24L01+ module as I already have optofiber between the buildings.
                  • S samppa
                    samppa
                    Actually I now noticed that send should return bool, but is that working only if ack is requested?
                    • K korttoma
                      samppa
                      @korttoma
                      Thanks for the tip. I will check the wiring (once again).
                      Still it would be interesting to know if arduino can restart itself since for increased reliability (if any?) that could be done every night.
                      12.2k
