716 Posts 111 Posters 703.1k Views 93 Watching
  • dbemowskD dbemowsk
    @gohan The only voltage regulator that I know of on the board is mainly for the radio. Unless you are talking the one on the pro mini.
    @markjgabb If you want to do them from mains power, you might wan t to look at the HLK modules like these
    https://www.ebay.com/itm/1Pcs-Power-Supply-Step-Down-Buck-Isolated-Hlk-Pm03-220V-To-3-3V-Module-New-Ic-N/332047987473?epid=571729397&hash=item4d4f9a3311:g:nyMAAOSw4GVYPa8q
    Otherwise an old phone charger should work.
    @dbemowsk if I remember well the regulator Vout is also connected to the pro mini vcc
    dbemowskD 2 Replies Last reply
      dbemowskD
      dbemowskD
      @gohan Have a bare board right in front of me. Ran continuity and no connection from regulator V-Out to VCC. VCC goes to the REG jumper and V-Out goes to the BAT jumper. VCC ties to the V-In on the regulator.
        dbemowskD
        dbemowskD
        @gohan ayou wouldn't want to run the pro mini and the radio both off of that small regulator anyway. Takes too much from the radio.
        • markjgabbM
          markjgabbM
          markjgabb
          @dbemowsk cheers for that...yeah i have a tonn of old 5v bricks lying around from old nokia chargers, so was just going to try use some of them up without having to buy anythiing else, as i have all of it on hand.... i have some LE33a's which should take care of any step down issues i think?
          dbemowskD 1 Reply Last reply
          • markjgabbM markjgabb
            dbemowskD
            dbemowskD
            @markjgabb If you connect your 5V brick to the RAW pin, the onboard regulator on the pro mini will do.
            • markjgabbM
              markjgabbM
              markjgabb
              @dbemowsk cheers mate, thats awesome...now i can blitz out some room based designs
                @hiddenuser I'm missing how can you use a booster to get 3.3v from a lipo battery
                H
                H
                hiddenuser
                @gohan @sundberg84
                This is my setup. my battery reading is a constant 2.75v, this is not true the multi meter says ~4v
                sundberg84S gohanG 2 Replies Last reply
                  sundberg84S
                  sundberg84S
                  @markjgabb @dbemowsk @gohan - I dont have much else to add, thanks for the input here. Using mains power I would also use HLK-PM01 and input the 5v to the pro mini. If you only have 3.3v pro mini you need to input this to RAW. I have made a breakout board for the HLK module if needed as well.
                  https://www.openhardware.io/view/504/HLK-PM01-breakout-board
                  • H hiddenuser
                    @gohan @sundberg84
                    sundberg84S
                    sundberg84S
                    #459
                    Well it looks like your battery goes to some sort of regulator before the Easy board? If so my guess is that that board is providing 2.7 v regardless of battery voltage? Have a look at @gohan and his posts about solar power and different batteries. EasyPCB is designed for 2xAA and it will not work with other voltages out of the box. The voltage divider is also dimensioned for 3.3v max and will not work with higher voltages. Again @gohan has made some experiments with this. Check his posts out. If you re-dimension the voltage divider it will work with your higher voltage.
                    • H hiddenuser
                      @gohan @sundberg84
                      @hiddenuser I don't know why you have a booster in place (unless it is a buck boost) and you need to change the voltage divider resistors if you want to read higher voltages (look at my solar project). In addition I'd put in place a LDO regulator if you want to use a lipo battery since a normal voltage regulator would require a higher Vin than a lipo battery can provide.
                      H 1 Reply Last reply
                        H
                        H
                        hiddenuser
                        wrote on last edited by hiddenuser
                        #461
                        @gohan said in 💬 Easy/Newbie PCB for MySensors:
                        Thanks @gohan for the feedback. Can I have the link to your solar project!
                        gohanG 1 Reply Last reply
                        • H hiddenuser
                          @hiddenuser look in the my project section (I'm on mobile now)
                          • BarnaB
                            BarnaB
                            Barna
                            Hi Sundberg,
                            I have read there could be some problem about radio connection if the temperature is ~0C or minus, I have met this issue so I will replace the existing 4.7µ capacitor with a bigger, e.g. ~20µ.
                            The battery measurement contains a 0.1 uF capacitor, What do you think I do have to replace it with an another bigger one ?
                            thanks
                            Barna
                            sundberg84S dbemowskD Nca78N 3 Replies Last reply
                            • BarnaB Barna
                              Hi Sundberg,
                              thanks
                              Barna
                              sundberg84S
                              sundberg84S
                              @barna - i don't know to be honest. As I wrote I had issues last winter but never with that 0.1 cap. I'm running second winter now (have been as low as -8C so far) without issues.
                              • BarnaB Barna
                                Hi Sundberg,
                                thanks
                                Barna
                                dbemowskD
                                dbemowskD
                                @barna check out this thread:
                                https://forum.mysensors.org/topic/186/new-library-to-read-arduino-vcc-supply-level-without-resistors-for-battery-powered-sensor-nodes-that-do-not-use-a-voltage-regulator-but-connect-directly-to-the-batteries
                                It is a way to monitor battery voltage without the need for the 0.1 uf capacitor and resistor setup on the board.
                                • BarnaB Barna
                                  Hi Sundberg,
                                  thanks
                                  Barna
                                  @barna said in 💬 Easy/Newbie PCB for MySensors:
                                  Hi Sundberg,
                                  thanks
                                  Barna
                                  I don't think you need, it's made to stabilize the measured voltage, in the worst case the measured voltage will be a little bit unstable but your node will still run fine.
                                  • markjgabbM
                                    markjgabbM
                                    markjgabb
                                    on the subject of batteries i have to say im really impressed with the setup of these boards....
                                    ive got a DHT and lux resistor measuring every 10 minutes, and i cant even remember how long ago i last changed the batteries...i think its about 3-4 months now....nothing special, just aldi batteries (australian cheap shopping chain)
                                    last check they are still 65%
                                      dbemowskD
                                      dbemowskD
                                      @markjgabb Don't know if it's the same chain, but we have aldi stores here in the US.
                                        marvin78
                                        @dbemowsk It is. It's a german chain though ;)
                                        • M marvin78
                                          dbemowskD
                                          dbemowskD
                                          @marvin78 Never knew that.
