716 Posts 111 Posters 703.1k Views 93 Watching
  • markjgabbM
    markjgabbM
    markjgabb
    @sundberg84 interesting question...or maybe stupid question not sure...
    i have a tonn of 3v pro mini's but im thinking of mains powering some for motion sensors.... would i set it up as battery, and then just use a voltage regulator on where the step up usually would be? or is there a better way to handle it?
      there is a voltage regulator footprint on the pcb made for that
      dbemowskD 1 Reply Last reply
      • markjgabbM
        markjgabbM
        markjgabb
        ahhh thats cool... so use regulated instead and it will pull down the voltage for antenna over that side
        ...and the board can handle the voltage anyway so it should be fine....
          dbemowskD
          dbemowskD
          @gohan The only voltage regulator that I know of on the board is mainly for the radio. Unless you are talking the one on the pro mini.
          @markjgabb If you want to do them from mains power, you might wan t to look at the HLK modules like these
          https://www.ebay.com/itm/1Pcs-Power-Supply-Step-Down-Buck-Isolated-Hlk-Pm03-220V-To-3-3V-Module-New-Ic-N/332047987473?epid=571729397&hash=item4d4f9a3311:g:nyMAAOSw4GVYPa8q
          Otherwise an old phone charger should work.
          gohanG 1 Reply Last reply
          • dbemowskD dbemowsk
            @dbemowsk if I remember well the regulator Vout is also connected to the pro mini vcc
            dbemowskD 2 Replies Last reply
              dbemowskD
              dbemowskD
              @gohan Have a bare board right in front of me. Ran continuity and no connection from regulator V-Out to VCC. VCC goes to the REG jumper and V-Out goes to the BAT jumper. VCC ties to the V-In on the regulator.
                dbemowskD
                dbemowskD
                @gohan ayou wouldn't want to run the pro mini and the radio both off of that small regulator anyway. Takes too much from the radio.
                • markjgabbM
                  markjgabbM
                  markjgabb
                  @dbemowsk cheers for that...yeah i have a tonn of old 5v bricks lying around from old nokia chargers, so was just going to try use some of them up without having to buy anythiing else, as i have all of it on hand.... i have some LE33a's which should take care of any step down issues i think?
                  • markjgabbM markjgabb
                    dbemowskD
                    dbemowskD
                    @markjgabb If you connect your 5V brick to the RAW pin, the onboard regulator on the pro mini will do.
                    • markjgabbM
                      markjgabbM
                      markjgabb
                      @dbemowsk cheers mate, thats awesome...now i can blitz out some room based designs
                        @hiddenuser I'm missing how can you use a booster to get 3.3v from a lipo battery
                        H
                        H
                        hiddenuser
                        @gohan @sundberg84
                        This is my setup. my battery reading is a constant 2.75v, this is not true the multi meter says ~4v
                        sundberg84S gohanG 2 Replies Last reply
                          sundberg84S
                          sundberg84S
                          @markjgabb @dbemowsk @gohan - I dont have much else to add, thanks for the input here. Using mains power I would also use HLK-PM01 and input the 5v to the pro mini. If you only have 3.3v pro mini you need to input this to RAW. I have made a breakout board for the HLK module if needed as well.
                          https://www.openhardware.io/view/504/HLK-PM01-breakout-board
                          • H hiddenuser
                            @gohan @sundberg84
                            sundberg84S
                            sundberg84S
                            #459
                            Well it looks like your battery goes to some sort of regulator before the Easy board? If so my guess is that that board is providing 2.7 v regardless of battery voltage? Have a look at @gohan and his posts about solar power and different batteries. EasyPCB is designed for 2xAA and it will not work with other voltages out of the box. The voltage divider is also dimensioned for 3.3v max and will not work with higher voltages. Again @gohan has made some experiments with this. Check his posts out. If you re-dimension the voltage divider it will work with your higher voltage.
                            • H hiddenuser
                              @gohan @sundberg84
                              @hiddenuser I don't know why you have a booster in place (unless it is a buck boost) and you need to change the voltage divider resistors if you want to read higher voltages (look at my solar project). In addition I'd put in place a LDO regulator if you want to use a lipo battery since a normal voltage regulator would require a higher Vin than a lipo battery can provide.
                              H 1 Reply Last reply
                                H
                                H
                                hiddenuser
                                wrote on last edited by hiddenuser
                                #461
                                @gohan said in 💬 Easy/Newbie PCB for MySensors:
                                Thanks @gohan for the feedback. Can I have the link to your solar project!
                                • H hiddenuser
                                  @hiddenuser look in the my project section (I'm on mobile now)
                                  • BarnaB
                                    BarnaB
                                    Barna
                                    Hi Sundberg,
                                    I have read there could be some problem about radio connection if the temperature is ~0C or minus, I have met this issue so I will replace the existing 4.7µ capacitor with a bigger, e.g. ~20µ.
                                    The battery measurement contains a 0.1 uF capacitor, What do you think I do have to replace it with an another bigger one ?
                                    thanks
                                    Barna
                                    sundberg84S dbemowskD Nca78N 3 Replies Last reply
                                    • BarnaB Barna
                                      Hi Sundberg,
                                      thanks
                                      Barna
                                      sundberg84S
                                      sundberg84S
                                      @barna - i don't know to be honest. As I wrote I had issues last winter but never with that 0.1 cap. I'm running second winter now (have been as low as -8C so far) without issues.
                                      • BarnaB Barna
                                        Hi Sundberg,
                                        thanks
                                        Barna
                                        dbemowskD
                                        dbemowskD
                                        @barna check out this thread:
                                        https://forum.mysensors.org/topic/186/new-library-to-read-arduino-vcc-supply-level-without-resistors-for-battery-powered-sensor-nodes-that-do-not-use-a-voltage-regulator-but-connect-directly-to-the-batteries
                                        It is a way to monitor battery voltage without the need for the 0.1 uf capacitor and resistor setup on the board.
                                        • BarnaB Barna
                                          Hi Sundberg,
                                          thanks
                                          Barna
                                          @barna said in 💬 Easy/Newbie PCB for MySensors:
                                          Hi Sundberg,
                                          thanks
                                          Barna
                                          I don't think you need, it's made to stabilize the measured voltage, in the worst case the measured voltage will be a little bit unstable but your node will still run fine.
