  3. CNC PCB milling
CNC PCB milling
933 Posts 28 Posters 823.4k Views 27 Watching
  • andrewA andrew
    @rmtucker it is not 1000rpm, but the pwm control for the whole spindle speed range. see the details in the official document.
    once you use the spindle speed with the value of $30 or above, then the controller will drive the spindle with continuous voltage, without pwm, so it will use its maximum rpm.
    compared to bigger cncs with bigger spindles (e.g. what you can see from @executivul's video above) , 2418's is not that fast (in rpm), on the other hand it should not be "very slow". can you show a video on that?
    rmtuckerR
    rmtuckerR
    rmtucker
    @andrew
    I see.
    So what would be your best guess at your actual spindle rpm when cutting under your feed/depth of cut examples given above.?
    andrewA 1 Reply Last reply
    • andrewA andrew
      firmware settings: it is stored in the EEPROM, but nothing guarantees that the same location will be used for the same parameters in case of different versions, so the output of "$$" command should be saved, this contains everything which you can manually set up if necessary.
      ER11: take extra care during the installation process to not "harm" the motor's axis. usually the ER11 is pretty tight and howtos mention that the motor should be cooled (by the freezer) and the ER11 should be warmed up before putting them together, to help the mounting process and to prevent unwanted distortion.
      I put the CNC 2418 assembly guide to my share, for ones it is interesting.
      Yes, those are exactly the same instructions I received with my kit too.
      • andrewA andrew
        #144
        @andrew
        I tried connecting to the Woodpecker board using the Arduino serial terminal at 115200 baud. It greets me by saying:
        Grbl 0.9j ['$' for help]
        However, if I send it $ I get no response. If I send it $$, I get no response either.
        Is this normal?
        How do I send it $$ and get it to respond?
          @andrew
          Is this normal?
          andrewA
          andrewA
          andrew
          @neverdie no, that is not normal, but this is most probably just a communication issue. which software is used for the terminal connection? try to change the cr/lf settings, or the flow control options.
          • rmtuckerR rmtucker
            @andrew
            I see.
            andrewA
            andrewA
            andrew
            @rmtucker I did not measure the max rpm for the given spindle, but I use it on "max" (so spindle setting is 1000) for the given jobs.
              #147
              Ah, nevermind. I changed the terminal to send it a carriage return, and now it works. Here is the output from asking it $ and $$:
              $$ (view Grbl settings)
              $# (view # parameters)
              $G (view parser state)
              $I (view build info)
              $N (view startup blocks)
              $x=value (save Grbl setting)
              $Nx=line (save startup block)
              $C (check gcode mode)
              $X (kill alarm lock)
              $H (run homing cycle)
              ~ (cycle start)
              ! (feed hold)
              ? (current status)
              ctrl-x (reset Grbl)
              ok
              $0=10 (step pulse, usec)
              $1=25 (step idle delay, msec)
              $6=0 (probe pin invert, bool)
              $12=0.002 (arc tolerance, mm)
              $13=0 (report inches, bool)
              $20=0 (soft limits, bool)
              $21=0 (hard limits, bool)
              $22=0 (homing cycle, bool)
              $100=800.000 (x, step/mm)
              $101=800.000 (y, step/mm)
              $102=800.000 (z, step/mm)
              $110=5000.000 (x max rate, mm/min)
              $111=5000.000 (y max rate, mm/min)
              $112=800.000 (z max rate, mm/min)
              $132=200.000 (z max travel, mm)
              ok
                Here's the current build status:
                I'm guessing I'm something more than half-way done.
                • andrewA andrew
                  #149
                  how exactly? Heat gun?
                  I've put the motor assembly in the freezer....
                    I'll let it freeze overnight and then try it in the morning.
                      sundberg84S
                      sundberg84S
                      freeze
                      Why do you want to freeze the motor? :eyes:
                      mfalkviddM dbemowskD 2 Replies Last reply
                      • sundberg84S sundberg84
                        freeze
                        @sundberg84 see andrew's earlier post.
                        Freezing the motor axis makes it a bit smaller.
                          freeze
                          dbemowskD
                          dbemowskD
                          @sundberg84 And heating up the other part makes it expand and get bigger allowing the two to fit together easier. Has to do with tight tolerances.
                            #154
                            @andrew
                            Since I probably have only one shot at this, how hot should I heat up the ER11 before trying to fit it onto the frozen spindle? Should it be burning hot, or is luke-warm enough?
                              @andrew
                              andrewA
                              andrewA
                              andrew
                              wrote on last edited by andrew
                              #155
                              @neverdie unfortunately, as I mentioned, I don't have ER11 (yet), and I just read articles and vendor suggestions on the installation method, so I cannot provide experience based suggestions to that. as far as I remember nor concrete temperature was mentioned, so I would say you should not "overheat" it.
                              • andrewA andrew
                                #156
                                I slipped it on, no problem at all. After freezing the motor overnight, what I did was heat the ER11 with my wife's crafting hot air gun. I held it with an insulated glove as I warmed it up. When it started to become uncomfortable to hold with even the insulated glove, I slipped it on without any resistance.
                                Hopefully this info will help you when you receive yours.
                                andrewA zboblamontZ 2 Replies Last reply
                                  andrewA
                                  andrewA
                                  andrew
                                  @neverdie :) nice, so your wife saved the project :)))
                                  be patient and do not power the spindle for couple of hours, while it is cold, as it could be wet inside which could cause shorts and other issues.
                                    I seem to be finished with the mechanical assembly:
                                    However, these washers came with the kit, and I'm not sure what they're for:
                                    Anyone know? Are they for mounting the woodpecker board to the frame?
                                    Next I need to do the firmware upgrade and then wire things up.
                                    andrewA rmtuckerR 2 Replies Last reply
                                      andrewA
                                      andrewA
                                      andrew
                                      @neverdie yes, it is for "isolating" the pcb from the frame.
                                        zboblamontZ
                                        zboblamontZ
                                        zboblamont
                                        ER11
                                        FYI - Was reading on another forum where the user was going to replace the ER11 with a larger version so he could use 8mm bits (fairly standard metric size for wood routing bits, but incredibly strong)...
                                        Somebody pointed out to the guy that there are collets available for the ER11 specifically for 8mm shafted toolbits...
                                        https://www.sorotec.de/shop/Spannzange-ER-11---8-00mm-DIN-6499B-4008E-Klasse-II.html
                                          rmtuckerR
                                          rmtuckerR
                                          rmtucker
                                          @neverdie
                                          You have gone quiet:relaxed:
                                          Must be beavering away cutting pcb's?
