  3. CNC PCB milling
CNC PCB milling
933 Posts 28 Posters 823.4k Views 27 Watching
    I hope these heatsinks that came with the kit don't short things out. Seems rather dicey.
    In any case, until I can find my Dragon, I'm going to limp along with GRBL 0.9j so I can finish up the build. I'll upgrade later after I find it.
    andrewA
    andrewA
    andrew
    @neverdie the er-11 should be permanent. this spindle is not powerful enough to handle bigger tools and to mill harder materials.
    you can start with grbl 0.9j, but it is worth to upgrade to 1.1f.
    to the fw upgrade you can use a simple arduino as ISP programmer as well if you do not find your dragon.
    with chilipeppr (in case of grbl 0.9j go for http://chilipeppr.com/grbl , for 1.1.f go for http://chilipeppr.com/jpadie) you can quickly run its default logo engraving path for testing / demo purposes.
      Done! Jack was certainly, uh, generous with the length of the wiring. I provisionally tacked it out of the way with the zip ties provided. I'll secure it better after I'm sure it's all working.
      andrewA 1 Reply Last reply
        andrewA
        andrewA
        andrew
        wrote on last edited by andrew
        #173
        @neverdie for the cable issue I ordered this cable organizer spiral, although not yet installed it :)
        • andrewA andrew
          #174
          Thanks! That provided exactly what I was looking for. I ran the demo with no etching bit installed, and at first both X and Y seemed to be working, but the adapter coupling eventually loosened on both of them to the point where there was no longer X and Y movement. I've re-tightened tem, and it's working again. I hope it lasts.
          Not sure where I should go next from here though.
            andrewA
            andrewA
            andrew
            #175
            so, as this machine does not have limit switches installed, it is your responsibility to move the gantry to a position, from where you would like to start the job and which provides enough space for each direction movement. usually you have to set a relative zero at the given starting point.
            what is next? did you adjusted the stepper drivers? if not, then do it (I shared the link above). this is necessary to be sure, that the steppers will be powered with enough current (so they will be powerful enough for the given speed related movement and to provide enough force) or will not be overdriven.
            then, I would say try to engrave the chilipeppr logo to a soft material first, have some experience with the cnc.
            then, as I mentioned, discover the flatcam tool and try to create an isolation routing job for a test pcb.
            I already mentioned my confirmed settings for the given jobs (edge / hole milling, isolation routing).
            you should sacrifice some boards for your experience :)
            also, try to find your ideal g code sender tool by trying multiple ones.
              #176
              I don't see any plugs on the woodpecker board that are designated for connecting to a touch plate. So, I guess it's configured using the woodpecker header pins? How is that best set up?
              By the way, after re-tightening the set-screws on the adapters used to connect the step-motors to the screw rods, they seem to be holding now and not slipping loose. I take it back, one of them just came loose again. :(
              NeverDieN andrewA 2 Replies Last reply
                #177
                And now the other one did too. Is anyone using a threadlocker on the set screws to keep this from happening?
                I think I'll put on some locktite and let it dry overnight and then see if it still happens tomorrow. I'll start with just the threaded rods.
                Anyhow, the good news is that the heat sinks plainly did not short out the GRBL controller boards. I guess the adhesive must act as an electrical insulator.
                  #178
                  Thinking about it now, an alternative might be to grind one side of the threaded rod flat in the region where it fits into the adapter. That would match the concept of the motor rotor, where that has already been done.
                  Ideally I would notch it in just the region where the set screw makes contact. I suppose I could do that with a Dremel.
                  Investigating now, I see that the adapter came loose on the motor rotor also. So, I think locktite will be a must.
                  http://www.loctiteproducts.com/tds/T_LKR_BLUE_tds.pdf
                  Looking at the datasheet, it takes 24 hours to cure.
                    Well, humbug! I'm all out. Maybe tomorrow I'll buy the red threadlocker, which is even stronger.
                    dbemowskD 1 Reply Last reply
                      @rmtucker Which g-code sender is it that you like best?
                      rmtuckerR 1 Reply Last reply
                        dbemowskD
                        dbemowskD
                        @neverdie, or anyone else that can answer this with some logic, just because the topic came up. Why does Loctite red come in a blue container and loctite blue come in a red container?
                        • dbemowskD dbemowsk
                          Made in China?
                            Probably historical reasons.
                            • YveauxY Yveaux
                              Made in China?
                              dbemowskD
                              dbemowskD
                              @yveaux LOL
                                Probably a committee decision. Half liked red, and the other half liked blue. They were deadlocked, and this was their compromise decision. :laughing:
                                  andrewA
                                  andrewA
                                  andrew
                                  @neverdie for the touch sensing you should use A5 connector from the headers, connecting it to the actual tool (bit), then a gnd (header's bottom row) connecting to the pcb's surface.
                                  for the tool connection I use crocodile clamps.
                                  screws: you did not fasten them enough. at the beginning I also missed some endpoints, but since I put the cnc together, I had no issue with any of my screws.
                                  andrewA NeverDieN 2 Replies Last reply
                                  • andrewA andrew
                                    andrewA
                                    andrewA
                                    andrew
                                    @andrew for first go for a single touch probing instead of a whole autoleveling session.
                                    just for testing purposes, start the touch probing from a higher position and touch the gnd wire directly to the spindle's tool to see whether it stops or not. if not, you should stop it manually from the gui, otherwise it could break the tool.
                                    if everything works well (so you proved that you connections to the pins and the belonging settings are ok), then you can run the simple touch probes or the autoleveling as well.
                                      sundberg84S
                                      sundberg84S
                                      For one that will probably buy the same CNC could you document how you solve this with a picture?
                                        rmtuckerR
                                        rmtuckerR
                                        rmtucker
                                        I am not using a g-code sender,i am using mach3.
                                        But i have just started playing with grbl and bCNC seems to do most things.
                                          andrewA
                                          andrewA
                                          andrew
                                          @neverdie one more think I forgot to mention: after I assembled the cnc, I used a little wd40 across each axis and moved each from one end to another. it helped for smooth and "barrier-free" movements.
