  3. CNC PCB milling
CNC PCB milling
933 Posts 28 Posters 823.4k Views 27 Watching
    #176
    I don't see any plugs on the woodpecker board that are designated for connecting to a touch plate. So, I guess it's configured using the woodpecker header pins? How is that best set up?
    By the way, after re-tightening the set-screws on the adapters used to connect the step-motors to the screw rods, they seem to be holding now and not slipping loose. I take it back, one of them just came loose again. :(
    NeverDieN andrewA 2 Replies Last reply
      #177
      And now the other one did too. Is anyone using a threadlocker on the set screws to keep this from happening?
      I think I'll put on some locktite and let it dry overnight and then see if it still happens tomorrow. I'll start with just the threaded rods.
      Anyhow, the good news is that the heat sinks plainly did not short out the GRBL controller boards. I guess the adhesive must act as an electrical insulator.
        #178
        Thinking about it now, an alternative might be to grind one side of the threaded rod flat in the region where it fits into the adapter. That would match the concept of the motor rotor, where that has already been done.
        Ideally I would notch it in just the region where the set screw makes contact. I suppose I could do that with a Dremel.
        Investigating now, I see that the adapter came loose on the motor rotor also. So, I think locktite will be a must.
        http://www.loctiteproducts.com/tds/T_LKR_BLUE_tds.pdf
        Looking at the datasheet, it takes 24 hours to cure.
          Well, humbug! I'm all out. Maybe tomorrow I'll buy the red threadlocker, which is even stronger.
          dbemowskD 1 Reply Last reply
            @rmtucker Which g-code sender is it that you like best?
            rmtuckerR 1 Reply Last reply
              dbemowskD
              dbemowskD
              @neverdie, or anyone else that can answer this with some logic, just because the topic came up. Why does Loctite red come in a blue container and loctite blue come in a red container?
              • dbemowskD dbemowsk
                Made in China?
                  Probably historical reasons.
                  • YveauxY Yveaux
                    Made in China?
                    dbemowskD
                    dbemowskD
                    @yveaux LOL
                      Probably a committee decision. Half liked red, and the other half liked blue. They were deadlocked, and this was their compromise decision. :laughing:
                      andrewA 1 Reply Last reply
                        andrewA
                        andrewA
                        andrew
                        @neverdie for the touch sensing you should use A5 connector from the headers, connecting it to the actual tool (bit), then a gnd (header's bottom row) connecting to the pcb's surface.
                        for the tool connection I use crocodile clamps.
                        screws: you did not fasten them enough. at the beginning I also missed some endpoints, but since I put the cnc together, I had no issue with any of my screws.
                        andrewA NeverDieN 2 Replies Last reply
                        • andrewA andrew
                          andrewA
                          andrewA
                          andrew
                          @andrew for first go for a single touch probing instead of a whole autoleveling session.
                          just for testing purposes, start the touch probing from a higher position and touch the gnd wire directly to the spindle's tool to see whether it stops or not. if not, you should stop it manually from the gui, otherwise it could break the tool.
                          if everything works well (so you proved that you connections to the pins and the belonging settings are ok), then you can run the simple touch probes or the autoleveling as well.
                            sundberg84S
                            sundberg84S
                            For one that will probably buy the same CNC could you document how you solve this with a picture?
                              rmtuckerR
                              rmtuckerR
                              rmtucker
                              I am not using a g-code sender,i am using mach3.
                              But i have just started playing with grbl and bCNC seems to do most things.
                                andrewA
                                andrewA
                                andrew
                                @neverdie one more think I forgot to mention: after I assembled the cnc, I used a little wd40 across each axis and moved each from one end to another. it helped for smooth and "barrier-free" movements.
                                • andrewA andrew
                                  Does using A5 somehow automagically just work, or does it require additional software configuration?
                                  • sundberg84S sundberg84
                                    #192
                                    @sundberg84 said in CNC PCB milling:
                                    OK, here is what I'm doing in pictures. I'm applying blue 242 Loctite:
                                    to the threads of the 4 set screws on the coupler:
                                    That should keep them from loosening up after they are screwed into position. Note, you have at most 10 minutes of working time before it sets.
                                      #193
                                      I applied it to the motor set screws first and let it set:
                                      Note: I used rare earth magnets to help secure the set screw to the allen wrench. That insures that the set screw doesn't drop off and disappear somewhere on the floor. Works great.
                                      The couplers are made from anodized aluminum, so I'm not sure how well the loctite will work on them. However, I think it will still work, as the set screws themselves are steel.
                                        #194
                                        I found an intro to bCNC:
                                        https://www.youtube.com/watch?v=c-2k48TwU-8
                                        It looks easy and intuitive, so I'll probably go with that.
                                        As usual, it's the software that has the best tutorial that wins.
                                          zboblamontZ
                                          zboblamontZ
                                          zboblamont
                                          @neverdie I used to use nail varnish on threads as it was just as effective, even though it annoyed the partner whose nail varnish it was. It is not the bond between the metals which is that important, it is adding resistance between the threads to prevent unscrewing, were it to completely bond, you would shear the bolt before it was removed, which is a whole lot of trouble....
