  3. Watchdog timer
Watchdog timer
9 Posts 4 Posters 2.7k Views 4 Watching
  • I Offline
    I Offline
    Igpels
    How do I add a watchdog timer to my motion sensor sketch?
    I can get an example watchdog timer sketch to work, and it resets if wdt is not rest in the loop, but I cannot get it work in the motion sensor sketch.
    D 1 Reply Last reply
    • I Igpels
      @igpels-gurrala Could you show us your code. Maybe we can figure out what is wrong.
      I 1 Reply Last reply
        If you have a battery motion sensor I don't think you can effectively run a watchdog
        • S Offline
          In MySensors:
          • if you use deep power down, sleep() without time, it doesn't use watchdog, and can be waken up by a pin interrupt only.
          • if you use sleep(ms) it uses watchdog.
          • during runtime, watchdog is enabled, and it resets at each loop().
          • D dbemowsk
            I Offline
            I Offline
            Igpels
            wrote on last edited by Igpels
            @dbemowsk https://hastebin.com/ilonemimev.cpp
            I am using an arduino nano plugged into a 5V phone charger. I can get the watchdog working on its own. But, not when I put the rest of the motion sensor sketch with it.
              there is no real need to sleep a mains powered sensor
              • I Offline
                I Offline
                Igpels
                @gohan I removed the sleep portion, but still can't get the watchdog to trigger a reset
                https://hastebin.com/xeqavitadu.cpp
                  try adding a 10 seconds delay before resetting the wtd timer, it should trigger
                    I Offline
                    I Offline
                    Igpels
                    @gohan Yep, that did it. Thank you so much.
