  3. 💬 Arduino Pro Mini Shield for RFM69(H)W
atmega328patmega328pressureinterstitialhumiditywirelesspcbrfm69hwsensorbme280rfm69temperaturearduinosi7021
53 Posts 13 Posters 18.8k Views 11 Watching
    @Cliff-Karlsson
    I suppose setting Pin 4 to INPUT after running a wire from Pin 4 to Pin 2 would patch it. Or you could solder bridge between 2 and 3, and then solder bridge again between 3 and 4. In that case, you'd set both Pin 3 and Pin 4 to input, assuming they weren't being used for something else.
    If you have the boards but haven't yet soldered the headers, then I suggest doing the solder bridges, but don't connect header pins to pins 3 and 4. Then there's no need to set pins 3 and 4 to INPUT. I think that would be the cleanest fix.
    That said, if the firmware you're running isn't relying on interrupts, then no patch would be needed. For instance, I had previously tested the PCB using lowpowerlab's node and gateway example code, which doesn't use interrupts for send and receive. That's why I didn't notice the bug until it was pointed out by Korttoma.
    Also, I shrunk the board a little bit in Version 15, so it should cost less to get fab'd. On OSH-PARK, for example, it would now cost exactly $4 for 3 boards.
      For some reason the Version 015 files disappeared after I posted them. So, I re-posted them this morning. Hopefully they stick this time.
      • A
        andre_x
        Hi guys!
        Thanks to NeverDie, I've just received my first batch!
        Can anyone post the code for the board with the sensor?
        Thanks!!!
        • A
          andre_x
          THAAAAAANKS!!!
          gohanG 1 Reply Last reply
          • A andre_x
            THAAAAAANKS!!!
            @andre_x it is pretty straightforward, there are already examples rfm69 examples around the forum: it's basically the node example sketch with added sensor library and a few lines of code to read and send temperature/humidity
            • J
              J
              jeti
              Hi Guys,
              I am having troubles with the Version 015 ( i have checked that DI00 is routed to PIN2).
              My definition for the radio looks like this:
              #define MY_RADIO_RFM69
              #define MY_IS_RFM69HW
              but i still get a error:
              !TSM:FPAR:FAIL
              Adding a capacitor did nit help either. Does someone have a similar Issue?
              • pepsonP
                pepsonP
                pepson
                Hi
                Is any chance to also project it for Arduino Pro Mini but for version 5V ?
                • pepsonP pepson
                  Hi
                  @pepson I guess not since it would need a logic level converter if you don't want to fry the rfm69 module
                  • pepsonP
                    pepsonP
                    pepson
                    But it is not only other voltage power ? I use it on my Arduino Pro Mini 5V and use reduce power from 5V to 3,3V by stabilizer... But i use version 5V because i use it with sketch to control relay...
                      read rfm69 datasheed, the pins can only take up to 3.6V, they are not 5V tolerant like the NF24
                      • pepsonP
                        pepsonP
                        pepson
                        Yes
                        But i reduce power from 5V to 3,3V by AMS1117
                          I'm not talking about vcc, I'm talking about data pins
                            #24
                            @pepson
                            if your arduino VCC is 5v, then arduino SPI lines are running at 5v and sending 5v to RFM69 SPI pins which is not ok. like gohan said, you need level shifter, or use a 3v arduino pro mini
                            • pepsonP
                              pepsonP
                              pepson
                              i use it on arduino pro mini 5v and works ok. no problem. Also use RFM69HW on RPi3 and also works ok.
                              When i use on Arduino Pro Mini 5V i can not use RFM69HW with AMS1117 ? Radio will be destroy after some times ?
                              • pepsonP
                                pepsonP
                                pepson
                                Also on mysensors show how connect it to Arduino 5V
                                https://www.mysensors.org/build/connect_radio
                                • pepsonP pepson
                                  zboblamontZ
                                  zboblamontZ
                                  zboblamont
                                  @pepson "NOTE: The NSS, MOSI and SCK are not 5V tolerant on RFM69. You will need to use a level converter if you're using a 5V Arduino."....
                                  • pepsonP
                                    pepsonP
                                    pepson
                                    Ok but why nothing is describe on MySensors on page where show how connect radio ?
                                    But i have connected and works ok 5V without logic level converter...
                                    If i not use this logic level converter what will be happen ?
                                    I can use this https://pl.aliexpress.com/item/8CH-IIC-I2C-Logic-Level-Converter-Bi-Directional-Module-DC-DC-5V-to-3-3V-Setp/32238089139.html?spm=a2g17.search0104.3.299.voV8Dr&ws_ab_test=searchweb0_0,searchweb201602_4_10152_5000015_10151_10065_10344_10068_10342_10343_51102_10340_10341_5130015_10084_10083_10304_10307_10301_10312_10059_10313_10314_10534_5790011_100031_10604_10103_10594_5060015_10142,searchweb201603_32,ppcSwitch_4&algo_expid=1efe59eb-1872-47dd-8d87-8a30137c624f-24&algo_pvid=1efe59eb-1872-47dd-8d87-8a30137c624f&rmStoreLevelAB=5 ?
                                    zboblamontZ gohanG 2 Replies Last reply
                                      #29
                                      @pepson
                                      You're messing things, you should recheck.
                                      zboblamont extracted the note exactly from here https://www.mysensors.org/build/connect_radio
                                      If you check the rfm69 section, then you'll see it's not 5v tolerant. You can also check min and max input voltage in rfm69 datasheet if you need.
                                      In the above link, it is not mentioned that it is using a 5v arduino (i agree the regulator on the pic can be misleading, but there is the note..).As there is no level shifter on the pic, you should consider it as 3v arduino with use of additional regulator in case the arduino is not beefy enough for the radio module.. :)
                                      On your rpi, do you connect the rfm69 vcc to 5v rpi? I don't think so, or you'll fry your radio.. And the Rpi GPIO are 3v, not 5v. So no problem for the radio spi.
                                      3v arduino mini pro has a regulator to convert 5v input to 3v for atmel. So on these boards, the atmel vcc is 3v, and signals too. To not mess with 5v arduinos, which are running full 5v.
                                      I guess these level shifter should work, I have no xp with these. And generally prefer to go simpler, without levelshifting.
                                      • pepsonP
                                        pepsonP
                                        pepson
                                        ok but for arduino pro mini 3v i can not connect relay 5v. I use it to control relay...
                                        Can i use it : https://pl.aliexpress.com/item/8CH-IIC-I2C-Logic-Level-Converter-Bi-Directional-Module-DC-DC-5V-to-3-3V-Setp/32238089139.html?spm=a2g17.search0104.3.299.voV8Dr&ws_ab_test=searchweb0_0,searchweb201602_4_10152_5000015_10151_10065_10344_10068_10342_10343_51102_10340_10341_5130015_10084_10083_10304_10307_10301_10312_10059_10313_10314_10534_5790011_100031_10604_10103_10594_5060015_10142,searchweb201603_32,ppcSwitch_4&algo_expid=1efe59eb-1872-47dd-8d87-8a30137c624f-24&algo_pvid=1efe59eb-1872-47dd-8d87-8a30137c624f&rmStoreLevelAB=5
                                        • pepsonP pepson
                                          zboblamontZ
                                          zboblamontZ
                                          zboblamont
                                          @pepson I suggest you read it again.... The table refers to VCC 3.3v, thereby what is shown NOT a 5v device, the NOTE on that page and which I quoted above spells it out clearly, a converter would be required for 5v.
                                          If you are supplying it with 5v as well as connecting 5v logic, it is working outside it's specifications, that it is working at all is luck, but magic smoke will appear at some point.
