  3. [SOLVED] Multiple devices demonstrating erratic behavior
temperaturemotionindigoarduinorelay
13 Posts 4 Posters 7.2k Views 2 Watching
  • T Offline
    T Offline
    thermistor1
    wrote on last edited by thermistor1
    First, I'm using a Mac 10.6.8 with Indigo 6 and the MySensors plugin (newest Arduino software, two Diecimillias with 328 chips). I have two arduinos that communicate with each other, and I have caps on the radios for both so they are reliably communicating.
    One of my arduinos has multiple devices attached from a previous project and I'm trying to code them over to MySensors. Specifically, there is a Temp/Humidity sensor, a PIR motion sensor, an RGB LED to indicate what the arduino is doing, and 4 relays. I can get each device/sensor to behave properly on its own, but when I try using them together I get strange behavior, such as:
    1. A build-up of messages or something in a buffer somewhere, so that it takes the Indigo plugin a couple minutes to get through the messages (it processes about one every 10 seconds, and I'm sending 1 to 3 messages every ten seconds. In the code below, after all the devices are registered, the temperature and humidity update once and then the only updates I get are from the PIR sensor.
    2. Extra relays - the plugin mistakes two of the sensors for relays, despite manually registering only 4. This is not a problem in the code below but has happened with previous attempts, I THINK I fixed it when I turned the gw.begin node to false but I could be wrong.
    3. Erratic relay behavior/unreliability. The wrong relay or state is sometimes triggered. With the code below, the relays are not even responding.
    Below is my code, I'm hoping someone can give me insight on why I may be getting such behavior.
    //Temp
    #define CHILD_ID_HUM 10
    #define CHILD_ID_TEMP 20
    #define HUMIDITY_SENSOR_DIGITAL_PIN 7
    //Motion
    #define DIGITAL_INPUT_SENSOR A0
    #define CHILD_ID_PIR 30
    float lastMo;
    // Relay
    #define RELAY_1  3
    #define RELAY_2  4
    #define RELAY_3  5
    #define RELAY_4  6
    #define RELAY_ON 0
    #define RELAY_OFF 1
    // LED
    int red = A5;
    int blue = A4;
    int green = A3;
    DHT dht;
    float lastTemp;
    float lastHum;
    //Timer
    long previousMillis1 = 0;
    long interval1 = 60000;
    long previousMillis2 = 0;
    long interval2 = 5000;
    MyMessage msgPIR(CHILD_ID_PIR, V_TRIPPED);
      //Still unsure on conditions for this:
      gw.begin(NULL, AUTO, false);
      //start temp sensor
      gw.sendSketchInfo("Arduino 2", "1.0");
      gw.present(CHILD_ID_PIR, S_MOTION);
      //LED
      pinMode(red, OUTPUT);
      pinMode(green, OUTPUT);
      pinMode(blue, OUTPUT);
      // Register Relays
      gw.present(RELAY_1, S_LIGHT);
      pinMode(RELAY_1, OUTPUT);
      digitalWrite(RELAY_1,RELAY_OFF);
      gw.present(RELAY_2, S_LIGHT);
      pinMode(RELAY_2, OUTPUT);
      digitalWrite(RELAY_2,RELAY_OFF);
      gw.present(RELAY_3, S_LIGHT);
      pinMode(RELAY_3, OUTPUT);
      digitalWrite(RELAY_3,RELAY_OFF);
      gw.present(RELAY_4, S_LIGHT);
      pinMode(RELAY_4, OUTPUT);
      digitalWrite(RELAY_4,RELAY_OFF);
      digitalWrite(red, HIGH);
      digitalWrite(green, LOW);
      digitalWrite(blue, LOW);
      if(currentMillis - previousMillis1 > interval1) {
        sendTemp();
        delay(500);
        sendHumid();
        previousMillis1 = currentMillis;
      if (currentMillis - previousMillis2 > interval2) {
        float state = digitalRead(DIGITAL_INPUT_SENSOR);
        if (state != lastMo) {
          gw.send(msgPIR.set(state?"1":"0"));
          lastMo = state;
        previousMillis2 = currentMillis;
    void sendTemp(){
      if (isnan(temperature)) {
        lastTemp = temperature;
        Serial.print("T: ");
    void sendHumid(){
      if (isnan(humidity)) {
          lastHum = humidity;
          Serial.print("H: ");
          Serial.println(humidity);
      if (message.type==V_LIGHT) {
    • T thermistor1
      //Temp
      //Motion
      float lastMo;
      // Relay
      #define RELAY_1  3
      #define RELAY_2  4
      #define RELAY_3  5
      #define RELAY_4  6
      #define RELAY_ON 0
      #define RELAY_OFF 1
      // LED
      int red = A5;
      int blue = A4;
      int green = A3;
      DHT dht;
      float lastTemp;
      float lastHum;
      //Timer
        //start temp sensor
        //LED
        // Register Relays
          sendTemp();
          delay(500);
          sendHumid();
            lastMo = state;
      void sendTemp(){
      void sendHumid(){
            lastHum = humidity;
      T Offline
      T Offline
      thermistor1
      @thermistor1 I should add that the I want the relays to start with pins HIGH which makes the relays OFF every time I start the arduino. There are appliances that I want to remain off unless the pin goes low (e.g. the home router is ON when the pin is HIGH and I don't want it to reset every time the arduino is energized).
      • H Offline
        H Offline
        You don't write how you power the relays.
        • H hek
          T Offline
          T Offline
          thermistor1
          @hek I have an 8 relay board and I'm using only 4. The board is powered off the arduino 5V pin.
          • H Offline
            H Offline
            This is probably the cause of your problems. The Arduino 5V pin cannot provide the necessary power needed.
            You have to power them separately.
            T 2 Replies Last reply
            • H hek
              T Offline
              T Offline
              thermistor1
              @hek Thank you - it worked without the addition of the NRF24L01+ so I'm guessing that pushed it over the edge. I'll try without it and let you know, thanks!
              • H hek
                T Offline
                T Offline
                thermistor1
                @hek ok, I think I solved some of this. The extra sensors were coming from previous trials and errors. I removed the device and added it again, and bingo, no extra relays.
                As for the relays not responding, I found an error in the code AND I think the motion sensor is getting stuck in a loop. When I activate all sensors there is still enough power for the relays to go. The problem is when I uncomment the code monitoring the motion sensor, everything becomes stuck again. There's a problem with the code to continuously monitor the motion sensor:
                  if (state == HIGH) {
                      lastMo = state;
                and here is the current version of the code:
                //Temp
                //Motion
                float lastMo;
                // Relay
                #define RELAY_1  3
                #define RELAY_2  4
                #define RELAY_3  5
                #define RELAY_4  6
                #define RELAY_ON 0
                #define RELAY_OFF 1
                // LED
                int red = A5;
                int blue = A4;
                int green = A3;
                DHT dht;
                float lastTemp;
                float lastHum;
                //Timer
                  gw.begin(incomingMessage, AUTO, false);
                  //start temp sensor
                //  gw.present(CHILD_ID_PIR, S_MOTION);
                  //LED
                  // Register Relays
                    sendTemp();
                    delay(500);
                    sendHumid();
                /* float state = digitalRead(DIGITAL_INPUT_SENSOR);
                      lastMo = state;
                void sendTemp(){
                void sendHumid(){
                      lastHum = humidity;
                     digitalWrite(message.sensor, message.getBool()?RELAY_ON:RELAY_OFF);
                R 1 Reply Last reply
                • T thermistor1
                        lastMo = state;
                  //Temp
                  //Motion
                  float lastMo;
                  // Relay
                  #define RELAY_1  3
                  #define RELAY_2  4
                  #define RELAY_3  5
                  #define RELAY_4  6
                  #define RELAY_ON 0
                  #define RELAY_OFF 1
                  // LED
                  int red = A5;
                  int blue = A4;
                  int green = A3;
                  DHT dht;
                  float lastTemp;
                  float lastHum;
                  //Timer
                    //start temp sensor
                    //LED
                    // Register Relays
                      sendTemp();
                      delay(500);
                      sendHumid();
                        lastMo = state;
                  void sendTemp(){
                  void sendHumid(){
                        lastHum = humidity;
                  R Offline
                  R Offline
                  RJ_Make
                  @thermistor1 What is the Serial Monitor outputting?
                  RJ_Make
                  • B Offline
                    B Offline
                    BulldogLowell
                    @thermistor1 said:
                    float lastMo;
                          lastMo = state;
                    if anything is a binary device it is a motion sensor... total possible states = 2
                    You then introduce all of the problems of arduino's lousy float precision to your sketch?
                    try instead to declare lastMo as a byte or int.
                    byte lastMo;
                    oh... and state too....
                    byte state = digitalRead(DIGITAL_INPUT_SENSOR);
                    • B BulldogLowell
                      @thermistor1 said:
                      float lastMo;
                            lastMo = state;
                      byte lastMo;
                      T Offline
                      T Offline
                      thermistor1
                      @BulldogLowell Thank you! I'm not a programmer, can you tell?
                      I'll implement that. Got the rest of it working and will share the code as well.
                      B 1 Reply Last reply
                      • T Offline
                        T Offline
                        thermistor1
                        So for those who may be wondering, here are a couple things I learned working with multiple sensors + relays:
                        • All radios need capacitors because the 3.3V on the arduino is not sufficient
                        • Extra devices and arduinos that appear in your device list can be cleared out - remove the device and re-scan, and it should sort those problems out. I had mysterious sensors appear and refuse to leave until I did this.
                        • Keep track of and double check your pin numbers.
                        • (Clearly) don't use delay(), instead use millis()
                        • I did some of this piece by piece instead of repeating a function because I was trying to diagnose problems. It could probably be cleaned up but it successfully has seven different devices being controlled and functioning properly.
                        //Temp
                        //Motion
                        byte lastMo;
                        // Relay
                        #define RELAY_1  3
                        #define RELAY_2  4
                        #define RELAY_3  5
                        #define RELAY_4  6
                        #define RELAY_ON 0
                        #define RELAY_OFF 1
                        // LED
                        int red = A5;
                        int blue = A4;
                        int green = A3;
                        DHT dht;
                        float lastTemp;
                        float lastHum;
                        //Timer
                          //start temp sensor
                          gw.sendSketchInfo("Arduino 2", "0.9");
                          //LED
                          // Register Relays
                            sendTemp();
                            delay(500);
                            sendHumid();
                              lastMo = state;
                          if (state == LOW) {
                              lastMo = state;
                        void sendTemp(){
                        void sendHumid(){
                              lastHum = humidity;
                            if (message.sensor==3){
                              digitalWrite(RELAY_1,RELAY_ON);
                              digitalWrite(blue, HIGH);
                            } else if (message.sensor==4){
                            } else if (message.sensor==5){
                            } else if (message.sensor==6){
                              if((digitalRead(RELAY_4))==LOW){  //If relay 4 is on:
                               digitalWrite(red, LOW);
                               digitalWrite(green, HIGH);
                             if((digitalRead(RELAY_4))==HIGH){  //If relay 4 is off and the thing is on:
                        • T thermistor1
                          B Offline
                          B Offline
                          BulldogLowell
                          @thermistor1
                          So... all working OK now?
                          • B BulldogLowell
                            @thermistor1
                            T Offline
                            T Offline
                            thermistor1
                            @BulldogLowell Yes, all is working, thanks. If you want to use this code for reference it is fully functional.
                            12.0k
