  3. CNC PCB milling
CNC PCB milling
933 Posts 28 Posters 823.4k Views 27 Watching
    #429
    BODLEVEL = 2V7
    RSTDISBL = [ ]
    DWEN = [ ]
    SPIEN = [X]
    WDTON = [ ]
    EESAVE = [ ]
    BOOTSZ = 1024W_3C00
    BOOTRST = [X]
    CKDIV8 = [ ]
    CKOUT = [ ]
    EXTENDED = 0x05 (valid)
    HIGH = 0xDA (valid)
    LOW = 0xFF (valid)
      #430
      Grbl 1.1f ['$' for help]
      Because of the upgraded firmware, I'm actually better off now than I was before. :)
      • andrewA andrew
        @neverdie I still use my default settings (see below). I re-applied these settings after I flashed the board to grbl 1.1f.
        $0=10 (step pulse, usec)
        $1=25 (step idle delay, msec)
        $6=0 (probe pin invert, bool)
        $12=0.002 (arc tolerance, mm)
        $13=0 (report inches, bool)
        $20=0 (soft limits, bool)
        $21=0 (hard limits, bool)
        $22=0 (homing cycle, bool)
        $100=800.000 (x, step/mm)
        $101=800.000 (y, step/mm)
        $102=800.000 (z, step/mm)
        #431
        $0=10
        $1=25
        $2=0
        $3=5
        $4=0
        $5=0
        $6=0
        $10=3
        $11=0.010
        $12=0.002
        $13=0
        $20=0
        $21=0
        $22=0
        $23=0
        $24=25.000
        $25=500.000
        $26=250
        $27=1.000
        $30=1000
        $31=0
        $32=0
        $100=800.000
        $101=800.000
        $102=800.000
        $110=800.000
        $111=800.000
        $112=500.000
        $120=10.000
        $121=10.000
        $122=10.000
        $130=200.000
        $131=200.000
        $132=200.000
          rmtuckerR 1 Reply Last reply
            rmtuckerR
            rmtuckerR
            rmtucker
            wrote on last edited by rmtucker
            #433
            @neverdie
              $0=10
              $1=25
              $2=0
              $3=5
              $4=0
              $5=0
              $6=0
              $10=3
              $11=0.010
              $12=0.002
              $13=0
              $20=0
              $21=0
              $22=0
              $23=0
              $24=25.000
              $25=500.000
              $26=250
              $27=1.000
              $30=1000
              $31=0
              $32=0
              $100=800.000
              $101=800.000
              $102=800.000
              $110=800.000
              $111=800.000
              $112=500.000
              $120=10.000
              $121=10.000
              $122=10.000
              $130=200.000
              $131=200.000
              $132=200.000
              I found out what they mean:
              $31=0.	Min spindle speed, RPM
              $32=0	Laser mode, boolean
              • rmtuckerR rmtucker
                @neverdie
                yes
                andrewA 1 Reply Last reply
                  yes
                  andrewA
                  andrewA
                  andrew
                  @neverdie sorry, I'm abroad, with very limited availability, so cannot answer too quickly.
                  • andrewA andrew
                    Thanks! You nailed it. It turns out the solder connection on the atmega328p pin corresponding to D5 just wasn't good enough. I resoldered it, and now the X-axis works in both directions. :)
                          #440
                          There's a huge difference between being able to evolve a single PCB design to perfect it rather than having to work on a "dumbed down" design (for a CNC or some other DIY etching process) before being able to get "the real deal" from a PCB fabricator. So, I'm very relieved that the first option now seems possible. :)
                          andrewA 2 Replies Last reply
                            andrewA
                            andrewA
                            andrew
                            @neverdie I told you since the very beginning to make the firmware upgrade! ;)
                              andrewA
                              andrewA
                              andrew
                              @neverdie as I see from the picture, you can decrease the cutting depth. this could help you to soften the force against the carving bits and it could also help you to use faster feed rates without risking a missing step or bit damage.
                              • andrewA andrew
                                @andrew
                                Cutting depth: 0.03
                                Feedrate:80mm
                                • E executivul
                                  @neverdie I use a wood screw in the sacrificial board holding a piece of metal as a "clamp" I slide it over the board (1mm overlap) and clip one alligator clip to the screw, the other to the bit. After probing I slide it out of the way. The metal piece is about 10cm long and it's left in place for the life of the wood board.
                                  #444
                                  Do you have a photo of that?
                                    #445
                                    @andrew
                                    NeverDieN E 2 Replies Last reply
                                      @andrew
                                        @andrew
                                        E
                                        E
                                        executivul
                                        wrote on last edited by executivul
                                        #447
                                        @neverdie
                                        • E executivul
                                          @neverdie
                                          #448
