  3. CNC PCB milling
CNC PCB milling
933 Posts 28 Posters 823.4k Views 27 Watching
  • rmtuckerR rmtucker
    @neverdie
    yes
    andrewA 1 Reply Last reply
      yes
      andrewA
      andrewA
      andrew
      @neverdie sorry, I'm abroad, with very limited availability, so cannot answer too quickly.
      • andrewA andrew
        Thanks! You nailed it. It turns out the solder connection on the atmega328p pin corresponding to D5 just wasn't good enough. I resoldered it, and now the X-axis works in both directions. :)
              #440
              There's a huge difference between being able to evolve a single PCB design to perfect it rather than having to work on a "dumbed down" design (for a CNC or some other DIY etching process) before being able to get "the real deal" from a PCB fabricator. So, I'm very relieved that the first option now seems possible. :)
              andrewA 2 Replies Last reply
                andrewA
                andrewA
                andrew
                @neverdie I told you since the very beginning to make the firmware upgrade! ;)
                  andrewA
                  andrewA
                  andrew
                  @neverdie as I see from the picture, you can decrease the cutting depth. this could help you to soften the force against the carving bits and it could also help you to use faster feed rates without risking a missing step or bit damage.
                  • andrewA andrew
                    @andrew
                    Cutting depth: 0.03
                    Feedrate:80mm
                    • E executivul
                      @neverdie I use a wood screw in the sacrificial board holding a piece of metal as a "clamp" I slide it over the board (1mm overlap) and clip one alligator clip to the screw, the other to the bit. After probing I slide it out of the way. The metal piece is about 10cm long and it's left in place for the life of the wood board.
                      #444
                      Do you have a photo of that?
                        #445
                        @andrew
                        NeverDieN E 2 Replies Last reply
                          @andrew
                            @andrew
                            E
                            E
                            executivul
                            wrote on last edited by executivul
                            #447
                            @neverdie
                            • E executivul
                              @neverdie
                              #448
                                  NeverDieN andrewA 2 Replies Last reply
                                    #451
                                      E 1 Reply Last reply
                                        E
                                        E
                                        executivul
                                        @neverdie 0.4-0.5mm for vias using 0.3mm silver plated "wrapping wire". 0.9 for TH and alignment holes.
                                          #454
