  3. 💬 MySensors NRF5 Platform
contest2017nrf52mysensorsnrf5nrf51
210 Posts 20 Posters 88.8k Views 18 Watching
  • O
    O
    Omemanti
    wrote on last edited by Omemanti
    #147
    • O Omemanti
      [[topic:post-is-deleted]]
      @omemanti Shot in the dark: did you swap Tx/Rx by accident?
      • O
        O
        Omemanti
        • O
          O
          Omemanti
          I'm not sure if I destroyed something on the board.ill try another one.. to not fill-up this forum threat I'll delete my previous posts
          • monteM
            monteM
            monte
            Hello, @d00616. Could you tell me which ESB library did you use to port it to arduino environment? The one that comes with Nordic SDK? After searching for few hours I haven't find any other realization of ESB mode for arduino IDE except your port included with MySensors. It's a pity. Are you going to release general purpose library, maybe?
            d00616D 1 Reply Last reply
            • monteM monte
              d00616D
              d00616D
              d00616
              @monte said in 💬 MySensors NRF5 Platform:
              The ESB library is written from scratch. At the time of of starting the Nordic SDK license was incompatible with open source projects. I have no plans to release this as stand-alone library. At the moment there is only an subset of the ESB protocol implemented. Enough to be compatible with MySensors RF24 devices.
              Feel free to use my code to create a stand-alone library. If required, we can talk about dual licensing to code with an additional open source license.
              monteM 1 Reply Last reply
              • d00616D d00616
                monteM
                monteM
                monte
                @d00616 thanks for a reply. I will evaluate my skills for this task, when I actually will get a chip to try it on. I need some really small pcb for my project, and single chip with mcu and rf with the size of nrf51 fits perfectly, but it requires quiet simple communications and full MySensors library will be overkill and hard to adapt for my needs.
                d00616D 2 Replies Last reply
                • monteM monte
                  d00616D
                  d00616D
                  d00616
                  You can use the MY_CORE_ONLY mode -> https://forum.mysensors.org/post/76627
                  monteM 2 Replies Last reply
                  • d00616D d00616
                    monteM
                    monteM
                    monte
                    @d00616 great tip, thanks! I didn't know about that option, to bad it's buried on the deepest level of documentation. I guess this will do the thing. I greatly appreciate your help, it's a pleasure when people are willing to share their knowledge with others :)
                    • d00616D d00616
                      monteM
                      monteM
                      monte
                      wrote on last edited by monte
                      #156
                      @d00616 one more question. Is your driver able to send broadcast messages, without defined address, or should I just use the same node address on multiple receiving nodes?
                      • monteM monte
                        d00616D
                        d00616D
                        d00616
                        @monte Thank you.
                        The broad cast address is hard coded to 0xff (255). Each node must have a uniqe address, because it's not possible to send packages to a node with the same address.
                        • monteM monte
                          d00616D
                          d00616D
                          d00616
                          If possible use the nRF52 series. There are some improvements like better radio sensivity, lower current consumption, more RAM and flash, better ADC and a better CPU. Maybe in the future there is a Firmware update OTA functionality which is easier to adapt to the NRF52 than the NRF51 platform. Another reason to use the NRF52 is, that the official Arduino NRF5 port only supports the NRF52. This port has a lot more capabilities than the arduino-nrf5 port, but MySensors is not compatible at the moment.
                          • Nca78N
                            Should we worry about that ?
                            • Nca78N Nca78
                              d00616D
                              d00616D
                              d00616
                              @nca78 said in 💬 MySensors NRF5 Platform:
                              No. There are some ports of Arduino for NRF5. At the moment MySensors is not compatible with the Primo Port, because it comes with the SoftDevice. It changes nothing for the current state.
                              • O
                                O
                                Omemanti
                                What is the best way to use a pin interrupt to wake up form a sleep?
                                like for instance, I got some sort of motion connected to PIN 8.
                                  The source code for the PIR project gives one possible answer.
                                  O 1 Reply Last reply
                                    O
                                    O
                                    Omemanti
                                    #163
                                    @neverdie
                                    I've been dealing with that code but for some reason, I don't get it to work, code-wise it seems I'm lacking..
                                    First i get this error: struct NRF_UARTE_Type' has no member named 'TASKS_SUSPEND
                                    And when I comment that out it seems like its not waking up.
                                    I made a test sketch, which reported the status every 1000ms. this worked accurately for the last 3 days so it doesn't look like it is a sensor problem.
                                    So my hope was that there was an easier methode available..
                                    • O Omemanti
                                      @neverdie
                                      @omemanti Sounds like maybe you're either missing a library or else not linking to one that's required.
                                        O
                                        O
                                        Omemanti
                                        @neverdie
                                        What am I missing, I just reinstalled the whole shabang.
                                        • Arduino IDE
                                        • Sandeep
                                        • Mysensors 2.2.0
                                        thats all there is installed..
                                        • O Omemanti
                                          @neverdie
                                          • Arduino IDE
                                          • Sandeep
                                          • Mysensors 2.2.0
                                          @omemanti You want the mysensors development fork.
