716 Posts 111 Posters 703.1k Views 93 Watching
  • A
    akamap
    Hi everybody. Finally got my newb pcb and I soldered everything needed for the pro mini 3.3v. But I ran into problems.
    I think it's the cheap chinese pdo mini but I want to ask you guys. Problem id that my node doesn't work. But when I debug my node I plug my pro mini in my computer's usb and then it works.
    What I could see is that when it is battery operated I can read a 3.3v value on the vcc pin of the pro mini. When I also connect via usb this value is about 3.5v.
    Could it be that my pro mini requires 3.5v.
    I did solder the capacitor for the radio and i'm using a 3.3v step up converter also.
    Thank you
    dbemowskD gohanG 2 Replies Last reply
    • A akamap
      Thank you
      dbemowskD
      dbemowskD
      @akamap an you post a picture of your board setup?
      • A akamap
        Thank you
        @akamap without knowing how you are powering the node, it is difficult to say.
          sundberg84S
          sundberg84S
          #474
          @akamap - listen to the guys above, let us know with pictures :) Its the best.
          Did you by any chance miss to solder to jumpers?
          The best approach is to measure with a multimeter... put the black to GND and measure your way through the circuit from batteries, booster, jumper, pro mini and radio with the red put on each components VCC (or Vout on booster). Then you know where it goes wrong. Try to follow the schematics or the traces in the pcb to figure out how the current flows.
          dbemowskD 1 Reply Last reply
          • sundberg84S sundberg84
            dbemowskD
            dbemowskD
            @sundberg84 That's why I wanted him to send pictures. There are a number of variables that need to be in place depending on the configuration that you are using with this board. Is he using a 3.3 or 5 volt arduino, does he have a regulator, are the correct jumpers in place. Any one of these missing factors can make it not work.
            • A
              akamap
              wrote on last edited by akamap
              #476
              EDIT : Seeing the pictures this big, I think I know why and it is my fault. I tried to save energy by desoldering the led on the arduino. I followed a post here on mysensors.org. But I just realized I might have desoldered the wrong thing on this arduino. I'm not sure what I desoldered, but it might be what is causing the problems (I desoldered the tiny thing below the led) I'll put a fresh one to see if this is working.
              Original response :
              Ok, thank for all the answers and here is more information.
              I power it via 2AA battery. I did put a jumper on the battery point. And I am using a pro mini 3.3v (Cheap chinese clone). I am using a step up regulator to step it up to 3.3v for the arduino.
              I measured the voltages and they are as follow :
              Without USB programmer (Not working) :
              Battery : 3.00V
              Input step up : 3.00V
              Output Step UP : 3.35V
              VCC and GND on arduino : 3.34V
              VCC and GND on Radio : 3.01V
              With the USB programmer pluggued in (Working) :
              Battery : 3.00V
              Output Step UP : 3.47V
              VCC and GND on arduino : 3.48V
              VCC and GND on Radio : 3.00V
              Another information, I did not solder directly the arduino pro mini (you will see on the pictures). I don't know what the are called but I'll call them "extender". I use them so I can unplug the arduino in case I fried the pro mini.
              Here are some pictures with and without the usb programmer plugged in :
              sundberg84S gohanG 2 Replies Last reply
              • A akamap
                Original response :
                Battery : 3.00V
                Battery : 3.00V
                sundberg84S
                sundberg84S
                #477
                @akamap thats just the resistor... should not be the problem.
                I cant see anything obvious. I have some radios without silkscreen and they work....... like a clone. Not the best but most work ok. Try adding a capacitor on the booster - might be a noisy one... I would recommend to try a 0,1uF ceramic if you have. Otherwise just wack in what you have... not to big i think.
                If you power it from the booster/bat you cant power it the same time from USB! Disconnect VCC from the ftdi adapter.
                Connet RX/TX and GND to begin with. RST if you need to upload. Two power sources makes one to much.
                • A akamap
                  Original response :
                  Battery : 3.00V
                  Battery : 3.00V
                  @akamap remember also the cap on the battery measurement side if you want to get good readings. If you want to use batteries you need to remove the voltage regulator from the pro mini, once you done your troubleshooting
                  • A
                    akamap
                    #479
                    Thank you everyone. Everythings seems to be working now. I did solder a capacitor on the booster.
                    But I don't think this was all that was bad. I also find out that when I touched the capacitor for the radio, I was having mixed result. So I soldered the capacitor directly on the radio.
                    Now, everything works fine. I guess I burned the trace or something was creating a short with this part.
                    I just need to remove the voltage regulator as suggested by gohan now and I can start testing my battery life.
                    Thanks again. Great library, great forum but most of all, great community.
                    • sundberg84S
                      sundberg84S
                      #480
                      So its coming up for a new revision of the EasyPCB (both Nrf + RFM edition).
                      I have had some suggestions from the community so far and some thoughs of myself:
                      • ATSHA204A (signing)
                      • Change 0,1uF and 10uF capacitor so now 10uF is on the input and 0,1uF on the output
                      • Line up MysX connector for a more clean placement of daugherboards.
                      Anyone have any other input before i start the work?
                      I will not take any suggestions that will make the board heavy or non user-friendly. Still the same goal - only easy to use components, easy to assemble and easy to understand.
                        How about a flash chip + 2 resistors for FOTA ? :innocent:
                          sundberg84S
                          sundberg84S
                          @gohan - interesting. What would be the easiest way to do this do you think? Placement?
                          Can I avoid SMD components?
                            wrote on last edited by gohan
                            #483
                            the flash chip is 8 pins smd unless you choose a specific breakout board, resistors are your choice; they could fit unterneath the pro mini or on the back side
                            Also you may need to work on the NRF5x version too :D
                              mickecarlsson
                              wrote on last edited by mickecarlsson
                              #484
                              Put the battery measurement components under the Arduino. This makes the board more generic and frees up space on the right side of the board that can be used for more sensors. Expand the prototype area so that more sensors can be installed on the board.
                              And if one uses the board for battery only, the whole right section can be cut off but the battery measurement circuit is still there.
                                mickecarlsson
                                Now that I think of it, there is a small difference between the NRF and RFM board, the prototype area on the RFM board is not correctly spaced, the holes are a fraction to narrow spaced, one cant fit a header there without bending the pins
                                gohanG 1 Reply Last reply
                                • M mickecarlsson
                                  @mickecarlsson said in 💬 Easy/Newbie PCB for MySensors:
                                  Yes, I noticed that too
                                    sundberg84S
                                    sundberg84S
                                    #487
                                    @gohan @mickecarlsson
                                    Thanks for your input! I will probably redo the Nrf version in KiCad since the old in is in eagle so I will line everything up :)
                                    About the battery measurement components under the Arduino - I was thinking of putting the signing chip there.
                                    If you want to use the battery divider you need the booster as well so therefore its nessecary to have the board uncut. with this in mind I think it does not matter about the voltage divider placement or?
                                    Im not sure a 8 pin SMD component is right for EasyPCB - It seems a bit to advanced and unclear?
                                    Maybe I can do this with a MysX shield?
                                      mickecarlsson
                                      If I don’t use the booster and connect both BAT and REG and feed the board with two AA batteries i can use the battery components to measure the voltage of the battery. That is how I use it today.
                                      sundberg84S 2 Replies Last reply
                                      • M mickecarlsson
                                        sundberg84S
                                        sundberg84S
                                        @mickecarlsson - ahh, I see - good one!
                                        Let me think and maybe try some in KiCad and i let you know what I descide.
                                          The flash chip uses pins that are not on the connector.
                                          I understand that you want to keep it simple, but adding the signing chip and the flash chip to a project it is not very easy either
