716 Posts 111 Posters 703.1k Views 93 Watching
  • BarnaB Barna
    Hi Sundberg,
    I have read there could be some problem about radio connection if the temperature is ~0C or minus, I have met this issue so I will replace the existing 4.7µ capacitor with a bigger, e.g. ~20µ.
    The battery measurement contains a 0.1 uF capacitor, What do you think I do have to replace it with an another bigger one ?
    thanks
    Barna
    dbemowskD
    dbemowskD
    @barna check out this thread:
    https://forum.mysensors.org/topic/186/new-library-to-read-arduino-vcc-supply-level-without-resistors-for-battery-powered-sensor-nodes-that-do-not-use-a-voltage-regulator-but-connect-directly-to-the-batteries
    It is a way to monitor battery voltage without the need for the 0.1 uf capacitor and resistor setup on the board.
    • BarnaB Barna
      Hi Sundberg,
      thanks
      Barna
      @barna said in 💬 Easy/Newbie PCB for MySensors:
      Hi Sundberg,
      thanks
      Barna
      I don't think you need, it's made to stabilize the measured voltage, in the worst case the measured voltage will be a little bit unstable but your node will still run fine.
      • markjgabbM
        markjgabbM
        markjgabb
        on the subject of batteries i have to say im really impressed with the setup of these boards....
        ive got a DHT and lux resistor measuring every 10 minutes, and i cant even remember how long ago i last changed the batteries...i think its about 3-4 months now....nothing special, just aldi batteries (australian cheap shopping chain)
        last check they are still 65%
        dbemowskD 1 Reply Last reply
        • markjgabbM markjgabb
          dbemowskD
          dbemowskD
          @markjgabb Don't know if it's the same chain, but we have aldi stores here in the US.
          • dbemowskD dbemowsk
            marvin78
            @dbemowsk It is. It's a german chain though ;)
            • M marvin78
              dbemowskD
              dbemowskD
              @marvin78 Never knew that.
              • A
                akamap
                Hi everybody. Finally got my newb pcb and I soldered everything needed for the pro mini 3.3v. But I ran into problems.
                I think it's the cheap chinese pdo mini but I want to ask you guys. Problem id that my node doesn't work. But when I debug my node I plug my pro mini in my computer's usb and then it works.
                What I could see is that when it is battery operated I can read a 3.3v value on the vcc pin of the pro mini. When I also connect via usb this value is about 3.5v.
                Could it be that my pro mini requires 3.5v.
                I did solder the capacitor for the radio and i'm using a 3.3v step up converter also.
                Thank you
                dbemowskD gohanG 2 Replies Last reply
                • A akamap
                  Thank you
                  dbemowskD
                  dbemowskD
                  @akamap an you post a picture of your board setup?
                  • A akamap
                    Thank you
                    @akamap without knowing how you are powering the node, it is difficult to say.
                      sundberg84S
                      sundberg84S
                      #474
                      @akamap - listen to the guys above, let us know with pictures :) Its the best.
                      Did you by any chance miss to solder to jumpers?
                      The best approach is to measure with a multimeter... put the black to GND and measure your way through the circuit from batteries, booster, jumper, pro mini and radio with the red put on each components VCC (or Vout on booster). Then you know where it goes wrong. Try to follow the schematics or the traces in the pcb to figure out how the current flows.
                      • sundberg84S sundberg84
                        dbemowskD
                        dbemowskD
                        @sundberg84 That's why I wanted him to send pictures. There are a number of variables that need to be in place depending on the configuration that you are using with this board. Is he using a 3.3 or 5 volt arduino, does he have a regulator, are the correct jumpers in place. Any one of these missing factors can make it not work.
                        • A
                          akamap
                          wrote on last edited by akamap
                          #476
                          EDIT : Seeing the pictures this big, I think I know why and it is my fault. I tried to save energy by desoldering the led on the arduino. I followed a post here on mysensors.org. But I just realized I might have desoldered the wrong thing on this arduino. I'm not sure what I desoldered, but it might be what is causing the problems (I desoldered the tiny thing below the led) I'll put a fresh one to see if this is working.
                          Original response :
                          Ok, thank for all the answers and here is more information.
                          I power it via 2AA battery. I did put a jumper on the battery point. And I am using a pro mini 3.3v (Cheap chinese clone). I am using a step up regulator to step it up to 3.3v for the arduino.
                          I measured the voltages and they are as follow :
                          Without USB programmer (Not working) :
                          Battery : 3.00V
                          Input step up : 3.00V
                          Output Step UP : 3.35V
                          VCC and GND on arduino : 3.34V
                          VCC and GND on Radio : 3.01V
                          With the USB programmer pluggued in (Working) :
                          Battery : 3.00V
                          Output Step UP : 3.47V
                          VCC and GND on arduino : 3.48V
                          VCC and GND on Radio : 3.00V
                          Another information, I did not solder directly the arduino pro mini (you will see on the pictures). I don't know what the are called but I'll call them "extender". I use them so I can unplug the arduino in case I fried the pro mini.
                          Here are some pictures with and without the usb programmer plugged in :
                          sundberg84S gohanG 2 Replies Last reply
                          • A akamap
                            Original response :
                            Battery : 3.00V
                            Battery : 3.00V
                            sundberg84S
                            sundberg84S
                            #477
                            @akamap thats just the resistor... should not be the problem.
                            I cant see anything obvious. I have some radios without silkscreen and they work....... like a clone. Not the best but most work ok. Try adding a capacitor on the booster - might be a noisy one... I would recommend to try a 0,1uF ceramic if you have. Otherwise just wack in what you have... not to big i think.
                            If you power it from the booster/bat you cant power it the same time from USB! Disconnect VCC from the ftdi adapter.
                            Connet RX/TX and GND to begin with. RST if you need to upload. Two power sources makes one to much.
                            • A akamap
                              Original response :
                              Battery : 3.00V
                              Battery : 3.00V
                              @akamap remember also the cap on the battery measurement side if you want to get good readings. If you want to use batteries you need to remove the voltage regulator from the pro mini, once you done your troubleshooting
                              • A
                                akamap
                                #479
                                Thank you everyone. Everythings seems to be working now. I did solder a capacitor on the booster.
                                But I don't think this was all that was bad. I also find out that when I touched the capacitor for the radio, I was having mixed result. So I soldered the capacitor directly on the radio.
                                Now, everything works fine. I guess I burned the trace or something was creating a short with this part.
                                I just need to remove the voltage regulator as suggested by gohan now and I can start testing my battery life.
                                Thanks again. Great library, great forum but most of all, great community.
                                • sundberg84S
                                  sundberg84S
                                  #480
                                  So its coming up for a new revision of the EasyPCB (both Nrf + RFM edition).
                                  I have had some suggestions from the community so far and some thoughs of myself:
                                  • ATSHA204A (signing)
                                  • Change 0,1uF and 10uF capacitor so now 10uF is on the input and 0,1uF on the output
                                  • Line up MysX connector for a more clean placement of daugherboards.
                                  Anyone have any other input before i start the work?
                                  I will not take any suggestions that will make the board heavy or non user-friendly. Still the same goal - only easy to use components, easy to assemble and easy to understand.
                                    How about a flash chip + 2 resistors for FOTA ? :innocent:
                                      sundberg84S
                                      sundberg84S
                                      @gohan - interesting. What would be the easiest way to do this do you think? Placement?
                                      Can I avoid SMD components?
                                        wrote on last edited by gohan
                                        #483
                                        the flash chip is 8 pins smd unless you choose a specific breakout board, resistors are your choice; they could fit unterneath the pro mini or on the back side
                                        Also you may need to work on the NRF5x version too :D
                                          mickecarlsson
                                          wrote on last edited by mickecarlsson
                                          #484
                                          Put the battery measurement components under the Arduino. This makes the board more generic and frees up space on the right side of the board that can be used for more sensors. Expand the prototype area so that more sensors can be installed on the board.
                                          And if one uses the board for battery only, the whole right section can be cut off but the battery measurement circuit is still there.
