  3. πŸ’¬ Easy/Newbie PCB for MySensors
716 Posts 111 Posters 703.1k Views 93 Watching
  • M mickecarlsson
    If I don’t use the booster and connect both BAT and REG and feed the board with two AA batteries i can use the battery components to measure the voltage of the battery. That is how I use it today.
    sundberg84S
    sundberg84S
    @mickecarlsson - ahh, I see - good one!
    Let me think and maybe try some in KiCad and i let you know what I descide.
      The flash chip uses pins that are not on the connector.
      I understand that you want to keep it simple, but adding the signing chip and the flash chip to a project it is not very easy either
        sundberg84S
        sundberg84S
        #491
        @gohan - you are right.
        Maybe I can use the back side for the smd parts? Again I will test and see how it works out in KiCad. I might do some testing and post to get feedback. Im really afraid I will lose the easy to use function which the pcb is designed for though and if I feel I do the smd parts will be excluded.
        Maybe I could do a rev 10 which includes more heavy stuff and keep rev 9 as well as the Easy version.
          I don't see it as a complicated thing, since if you don't need it then you just don't use it and you only have a few smd pads unused.
            sundberg84S
            sundberg84S
            @gohan - valid point!
            What makes it complicated is if you are a new user who sees all these pads and dont understand if they have to be populated or used. But by adding those with clear labels on the bottom side might do the trick.
            gohanG 1 Reply Last reply
            • sundberg84S sundberg84
              @sundberg84 Exactly, maybe a label like "signing" and "FOTA" would make it more obvious to the user (of course it needs to be added to the project page too)
              • M mickecarlsson
                sundberg84S
                sundberg84S
                @mickecarlsson said in πŸ’¬ Easy/Newbie PCB for MySensors:
                Why dont you use the internal library to measure the battery voltage? Im thinking about this and can't find a reason to move the voltage divider since without the booster you could just use the internalref and a library to measure the voltage?
                  mickecarlsson
                  @sundberg84 said in πŸ’¬ Easy/Newbie PCB for MySensors:
                  Good point, I have not thought of that. I will test it it. And will probably save some uA in the process. Thanks,
                    mickecarlsson
                    wrote on last edited by mickecarlsson
                    #497
                    @sundberg84 I have now a node running with the BAT link removed, the REG link attached and I have used the Arduino_Vcc library.
                    The battery report are consistent with the battery voltage measured with a digital volt meter.
                    EDIT: Code below had a bug in it, I have fixed the bug and updated the code. The bug affected the temperature readings
                    So, to run the RFM69 board on two AA batteries I have done the following:
                    1. Removed regulator and led from Arduino
                    2. Burned a new bootloader with a 1.7 volt BOD
                    3. Put a link in REG position
                    4. Solder radio to board
                    5. Solder antenna to board.
                    6. Solder BME280 to power and A5, A6
                      And that's it.
                      Here is my code:
                     * This is a sketch I use to measure temperature, battery level and signal level on
                     * my Easy/Newbie PCB for MySensors (rev 9)
                     * Hardware used:
                     * Easy/Newbie PCB for MySensors
                     * BME280 (I only use temperature and humidity, all code for barometic pressure removed)
                    #define   MY_SPLASH_SCREEN_DISABLED  // This saves a couple of bytes
                    #define   MY_RADIO_RFM69
                    #define   MY_IS_RFM69HW
                    #define   MY_RFM69_NEW_DRIVER
                    #define   MY_RFM69_FREQUENCY RFM69_868MHZ
                    // #define   MY_RFM69_ENABLE_ENCRYPTION
                    #include <Wire.h>       // Enables the Wire communication protocol.
                    // Bosch BME280 Embedded Adventures MOD-1022 weather multi-sensor Arduino code,
                    // written originally by Embedded Adventures.
                    // https://github.com/embeddedadventures/BME280
                    #include <BME280_MOD-1022.h>
                    // Internal battery measurement https://github.com/Yveaux/arduino_vcc
                    #include <Vcc.h>
                    #define SKETCH_NAME    "Test-4"
                    #define SKETCH_VERSION "1.10"
                    // Battery measurements
                    const float VccMin        = 2.0*1.0;  // Min Vcc level, in Volts. Example for 2xAA Alkaline.
                    const float VccMax        = 2.0*1.5;  // Max Vcc level, in Volts. Example for 2xAA Alkaline.
                    const float VccCorrection = 3.02/3.12;  // Measured Vcc by multimeter divided by reported Vcc
                    Vcc vcc(VccCorrection);
                    // VARIABLES YOU CAN CHANGE
                    // Send temperature only if it has changed? 1 = Yes 0 = No.
                    #define COMPARE_TEMP 0
                    // Set this value to the minimum change in temperature to measure.
                    // BME280 has +-0.5 degrees precision, so it really doesn't matter that much.
                    float tempThreshold = 0.5;
                    // Send temperature only if changed? 1 = Yes 0 = No.
                    #define COMPARE_HUM 0
                    // Set this value to the minimum change in humidity to measure.
                    // BME280 has +-3% relative humidity precision, so it really doesn't matter that much.
                    float humThreshold = 0.5;
                    #define TEMP_CHILD_ID       1
                    #define HUM_CHILD_ID        2
                    #define VOLTAGE_CHILD_ID    3
                    float lastTemperature = -1;   // Store previous measurement
                    float lastHumidity =    -1;   // Stores the previous measurement
                    int sendBattery = 6;          // report battery level only after 6 loops = 6*4 mintes = 24 minutes
                    int batteryLoop = 0;          // Placeholder for batteryloop
                    unsigned long FOUR_MINUTE_SEND_FREQUENCY = 4 * 60000;  // Time between send (in milliseconds).
                    // MYSENSORS COMMUNICATION VARIABLES
                    MyMessage temperatureMsg(TEMP_CHILD_ID, V_TEMP);
                    MyMessage humidityMsg(HUM_CHILD_ID, V_HUM);
                    MyMessage voltageMsg(VOLTAGE_CHILD_ID, V_VOLTAGE);
                    #ifdef MY_DEBUG
                      Wire.begin(); // For the BME280 sensor
                    #ifdef MY_DEBUG
                      Serial.println(F("Starting ..."));
                      // Present the sensors to the gateway and controller
                      present(TEMP_CHILD_ID, S_TEMP, "Temperature Test-4");
                      present(HUM_CHILD_ID, S_HUM,   "Relative humidity Test-4");
                      present(VOLTAGE_CHILD_ID, S_MULTIMETER, "Battery Test-4" );
                    #ifdef MY_DEBUG
                      Serial.println(F("Read BME280 and report it's values."));
                      GetTemperatureHumidity(); // Get temperature and humidity
                      if(batteryLoop > sendBattery) { // Is the batteryLoop higher than sendBattery?
                    #ifdef MY_DEBUG
                        Serial.println(F("Read the battery voltage and report it."));
                        MeasureBattery();         // Measure and report battery level
                        batteryLoop = 0;          // Reset batteryLoop count
                    #ifdef MY_DEBUG
                      Serial.print(F("Go to sleep for: "));
                      Serial.print(FOUR_MINUTE_SEND_FREQUENCY / 60000);
                      Serial.println(F(" minutes."));
                      batteryLoop++;
                      sleep(FOUR_MINUTE_SEND_FREQUENCY);        // Sleep for 4 minutes
                    void GetTemperatureHumidity()
                    #ifdef MY_DEBUG
                      Serial.println("");
                      Serial.println(F("BME280 - Requesting new data from sensor module."));
                      BME280.readCompensationParams();    // Need to read the NVM compensation parameters.
                      // Normal mode for regular automatic samples
                      BME280.writeStandbyTime(tsb_0p5ms);         // tsb = 0.5ms
                      BME280.writeFilterCoefficient(fc_16);       // IIR Filter coefficient 16
                      BME280.writeOversamplingPressure(os16x);    // pressure x16
                      BME280.writeOversamplingTemperature(os8x);  // temperature x8
                      BME280.writeOversamplingHumidity(os8x);     // humidity x8
                      BME280.writeMode(smNormal);
                    #ifdef MY_DEBUG
                      Serial.println(F("Getting new values"));
                      while (BME280.isMeasuring()) {  // Wait for BME280 to fininsh reading data
                    #ifdef MY_DEBUG
                        Serial.println(F("Measuring..."));
                        delay(50);
                      Serial.println(F("Done!"));
                      // Read out the data - must do this before calling the getxxxxx routines
                      BME280.readMeasurements();
                      float temperature = BME280.getTemperatureMostAccurate();  // Get the temperature first.
                      float humidity = BME280.getHumidityMostAccurate();        // Get the humidity.
                    #ifdef MY_DEBUG
                      Serial.print(F("BME280 - Temperature = "));
                      Serial.print(temperature);
                      Serial.println(" Β°C");
                      Serial.print(F("BME280 - Humidity = "));
                      Serial.print(humidity);
                      Serial.println(F(" %"));
                      // Now, let's send the measurements to the gateway.
                      // Send temperature if the temperature difference bigger than the threshold
                      if (COMPARE_TEMP == 1 && abs(temperature - lastTemperature) < tempThreshold) {
                    #ifdef MY_DEBUG
                        Serial.print(temperature - lastTemperature);
                        Serial.println(F(" Temperature difference too small, don't send it to gateway."));
                    #ifdef MY_DEBUG
                          Serial.println(F("Sending new temperature to the gateway."));
                          send(temperatureMsg.set(temperature, 1));
                          lastTemperature = temperature; // Save temperatures for compare in the next round.
                      // Send humidity if the humidity difference is bigger than the threshold.
                      if (COMPARE_TEMP == 1 && abs(humidity - lastHumidity) < humThreshold) {
                    #ifdef MY_DEBUG
                        Serial.print(humidity - lastHumidity);
                        Serial.println(F(" Humidity difference too small, don't send it to the gateway."));
                    #ifdef MY_DEBUG
                        Serial.println(F("BME280 - Sending the new humidity to the gateway."));
                        send(humidityMsg.set(humidity, 1));
                        lastHumidity = humidity; // Save new humidity to be able to compare in the next round.
                    #ifdef MY_DEBUG
                      Serial.println(F("BME280 - Measurement complete. Putting sensor to sleep."));
                      BME280.writeMode(smSleep);  // set the BME280to sleep mode, save battery
                    } // GetTemperatureHumidity
                    * MeasureBattery
                    void MeasureBattery() //The battery calculations
                      float Vbat = vcc.Read_Volts();
                      int batteryPercent = static_cast<int>(vcc.Read_Perc(VccMin, VccMax));
                    #ifdef MY_DEBUG
                      Serial.print(F("Battery percent: "));
                      Serial.print(batteryPercent);
                      Serial.println(" %");
                      Serial.print(F("Battery Voltage: "));
                      Serial.print(Vbat);
                      Serial.println(F(" Volts"));
                        send(voltageMsg.set(Vbat,2)); //send battery in Volt 2 decimal places
                    • M mickecarlsson
                        And that's it.
                        Here is my code:
                       * Hardware used:
                      #include <Vcc.h>
                      #ifdef MY_DEBUG
                      #ifdef MY_DEBUG
                      #ifdef MY_DEBUG
                      #ifdef MY_DEBUG
                      #ifdef MY_DEBUG
                        batteryLoop++;
                      #ifdef MY_DEBUG
                        Serial.println("");
                      #ifdef MY_DEBUG
                      #ifdef MY_DEBUG
                          delay(50);
                      #ifdef MY_DEBUG
                      #ifdef MY_DEBUG
                      #ifdef MY_DEBUG
                      #ifdef MY_DEBUG
                      #ifdef MY_DEBUG
                      #ifdef MY_DEBUG
                      * MeasureBattery
                      #ifdef MY_DEBUG
                        Serial.print(Vbat);
                      sundberg84S
                      sundberg84S
                      #498
                      @mickecarlsson - nice work! Let us know how it turns out :)
                      Any pictures of this you can share?
                      I did see you put VccMin to 1,2V and this might calculate so the battery will be @ 30% when the BOD hits you. I would put this to 2.0v if you are using a internal 8mhz bootloader. https://forum.mysensors.org/topic/7296/how-to-burn-fuses-so-that-pro-mini-3-3v-would-go-down-to-1-8v-solved/15
                        Mr_sensor
                        wrote on last edited by Mr_sensor
                        #499
                        @sundberg84 Hi, I soldered a board holding a humidity and temperature sensor. That is working fine and reporting to may gateway (mqtt). Only thing which I do not get working ok is the battery level measurement. As I already posted in an other topic here.
                        Here are some pictures of my board. The bat jumper is connected with a wire on the bottom. And the code I use on it right now.
                        I already changed the pro mini for a fresh soldered one but still getting the the same result. Just ones giving the volt and % and after that only giving 0 volt as output.
                        tried to include delay(500) in the sketch but that did not help. So how to solve this?
                        #define MY_NODE_ID 2
                        #define MY_PARENT_NODE_ID 0
                        // Enable debug prints
                        //#define MY_RS485
                        #include <SparkFunHTU21D.h>
                        //static const uint8_t FORCE_UPDATE_N_READS = 10;
                        #define CHILD_ID_HUM 0
                        #define CHILD_ID_TEMP 1
                        #define CHILD_ID_BATTERY 2
                        //#define CHILD_ID_VOLT 2
                        #define CHILD_ID_PRCNT 3
                        float lastTemp;
                        float lastHum;
                        uint8_t nNoUpdatesTemp;
                        uint8_t nNoUpdatesHum;
                        boolean metric = true;
                          sendSketchInfo("Humidity", "2.0");
                          present(CHILD_ID_HUM, S_HUM);
                          //metric = getControllerConfig().isMetric;
                        unsigned long SLEEP_TIME = 60000; // Sleep time between reads (in milliseconds)
                        static int oldBatteryPcnt = 0;
                        HTU21D myHumidity;
                        MyMessage msgBattery(CHILD_ID_BATTERY, V_VOLTAGE);
                        //MyMessage msgBattery(CHILD_ID_BATTERY, V_PRCNT);
                            myHumidity.begin();
                            analogReference(INTERNAL1V1);
                            analogReference(INTERNAL);
                          float temperature = myHumidity.readTemperature();
                          //if (!metric) {
                          //    temperature = (temperature * 1.8) + 32.0;
                          Serial.print("T: ");
                          float humidity = myHumidity.readHumidity();
                          Serial.print("H: ");
                          Serial.println(humidity);
                           // get the battery Voltage
                            delay(500);
                        #ifdef MY_DEBUG
                            Serial.println(sensorValue);
                        #ifdef MY_DEBUG
                            Serial.print("Child ID ");
                            Serial.print(CHILD_ID_BATTERY);
                            Serial.print(batteryV);
                            Serial.println(" V");
                            Serial.print("Battery Percent: ");
                            Serial.print(batteryPcnt);
                                // Power up radio after sleep
                                oldBatteryPcnt = batteryPcnt;
                        0_1518613859739_IMG_5970.jpg 0_1518613878092_IMG_5971.jpg 0_1518613893620_IMG_5972.jpg 1_1518613931939_IMG_5907.jpg 0_1518613931939_IMG_5906.jpg 0_1518613977125_IMG_5908.jpg
                          I don't think it is PCB related, try to make sure it is not a faulty arduino
                            Mr_sensor
                            @gohan said in πŸ’¬ Easy/Newbie PCB for MySensors:
                            I already changed the arduino for a fresh soldered one but that did not alter things.
                            • M Mr_sensor
                              //#define MY_RS485
                              float lastTemp;
                              float lastHum;
                              HTU21D myHumidity;
                                  myHumidity.begin();
                                //if (!metric) {
                                  delay(500);
                              #ifdef MY_DEBUG
                              #ifdef MY_DEBUG
                              sundberg84S
                              sundberg84S
                              @mr_sensor - I can not see any errors on the pictures you posted.
                              Can you measure the voltage on Booster-Vout and also on this pad.
                                Mr_sensor
                                I did measure the parts you mentioned. Booster is 3,36 v and the other pad is 0,00 the input strait from the batteries is 2,80 v
                                Also, Just for my info, does it matter how the resistors or capacitors are soldered on the board? My biggest problem is always determine the right resistors value and the right way to solder them (+ -). On the pcb some of them are coded (very handy for me as a beginner) with a G but not all of them?
                                So my worry was that I maybe have soldered the "battery measurer" ones in the wring direction? Could that be the problem here?
                                  Resistors can be soldered either way, but if you read 0v on that capacitor pin it mean you have a problem between the battery and the capacitor, so you have to backtrack the connection that is missing
                                    Mr_sensor
                                    I measured the capacitor again and get a 0,10 output.
                                      What are the resistor values you used? 0.1v is quite low
                                        Mr_sensor
                                        Maybe I used the wrong capacitor it says 1uf (50v) but now I see it has to be 0,1uf could that be the problem here?
                                        • sundberg84S
                                          sundberg84S
                                          #508
                                          Capacitor value does not change the voltage. The resistors does... I would double check that you use the right resistors. For example it's easy to use a resistor marked 1k instead of 1M. With 3.3v you should have around 1v on the capacitor.
                                          With your input, this post could be even better πŸ’—
