716 Posts 111 Posters 703.1k Views 93 Watching
  • M mickecarlsson
    @sundberg84 I have now a node running with the BAT link removed, the REG link attached and I have used the Arduino_Vcc library.
    The battery report are consistent with the battery voltage measured with a digital volt meter.
    EDIT: Code below had a bug in it, I have fixed the bug and updated the code. The bug affected the temperature readings
    So, to run the RFM69 board on two AA batteries I have done the following:
    1. Removed regulator and led from Arduino
    2. Burned a new bootloader with a 1.7 volt BOD
    3. Put a link in REG position
    4. Solder radio to board
    5. Solder antenna to board.
    6. Solder BME280 to power and A5, A6
      And that's it.
      Here is my code:
     * This is a sketch I use to measure temperature, battery level and signal level on
     * my Easy/Newbie PCB for MySensors (rev 9)
     * Hardware used:
     * Easy/Newbie PCB for MySensors
     * BME280 (I only use temperature and humidity, all code for barometic pressure removed)
    #define   MY_SPLASH_SCREEN_DISABLED  // This saves a couple of bytes
    #define   MY_RADIO_RFM69
    #define   MY_IS_RFM69HW
    #define   MY_RFM69_NEW_DRIVER
    #define   MY_RFM69_FREQUENCY RFM69_868MHZ
    // #define   MY_RFM69_ENABLE_ENCRYPTION
    #include <Wire.h>       // Enables the Wire communication protocol.
    // Bosch BME280 Embedded Adventures MOD-1022 weather multi-sensor Arduino code,
    // written originally by Embedded Adventures.
    // https://github.com/embeddedadventures/BME280
    #include <BME280_MOD-1022.h>
    // Internal battery measurement https://github.com/Yveaux/arduino_vcc
    #include <Vcc.h>
    #define SKETCH_NAME    "Test-4"
    #define SKETCH_VERSION "1.10"
    // Battery measurements
    const float VccMin        = 2.0*1.0;  // Min Vcc level, in Volts. Example for 2xAA Alkaline.
    const float VccMax        = 2.0*1.5;  // Max Vcc level, in Volts. Example for 2xAA Alkaline.
    const float VccCorrection = 3.02/3.12;  // Measured Vcc by multimeter divided by reported Vcc
    Vcc vcc(VccCorrection);
    // VARIABLES YOU CAN CHANGE
    // Send temperature only if it has changed? 1 = Yes 0 = No.
    #define COMPARE_TEMP 0
    // Set this value to the minimum change in temperature to measure.
    // BME280 has +-0.5 degrees precision, so it really doesn't matter that much.
    float tempThreshold = 0.5;
    // Send temperature only if changed? 1 = Yes 0 = No.
    #define COMPARE_HUM 0
    // Set this value to the minimum change in humidity to measure.
    // BME280 has +-3% relative humidity precision, so it really doesn't matter that much.
    float humThreshold = 0.5;
    #define TEMP_CHILD_ID       1
    #define HUM_CHILD_ID        2
    #define VOLTAGE_CHILD_ID    3
    float lastTemperature = -1;   // Store previous measurement
    float lastHumidity =    -1;   // Stores the previous measurement
    int sendBattery = 6;          // report battery level only after 6 loops = 6*4 mintes = 24 minutes
    int batteryLoop = 0;          // Placeholder for batteryloop
    unsigned long FOUR_MINUTE_SEND_FREQUENCY = 4 * 60000;  // Time between send (in milliseconds).
    // MYSENSORS COMMUNICATION VARIABLES
    MyMessage temperatureMsg(TEMP_CHILD_ID, V_TEMP);
    MyMessage humidityMsg(HUM_CHILD_ID, V_HUM);
    MyMessage voltageMsg(VOLTAGE_CHILD_ID, V_VOLTAGE);
    #ifdef MY_DEBUG
      Wire.begin(); // For the BME280 sensor
    #ifdef MY_DEBUG
      Serial.println(F("Starting ..."));
      // Present the sensors to the gateway and controller
      present(TEMP_CHILD_ID, S_TEMP, "Temperature Test-4");
      present(HUM_CHILD_ID, S_HUM,   "Relative humidity Test-4");
      present(VOLTAGE_CHILD_ID, S_MULTIMETER, "Battery Test-4" );
    #ifdef MY_DEBUG
      Serial.println(F("Read BME280 and report it's values."));
      GetTemperatureHumidity(); // Get temperature and humidity
      if(batteryLoop > sendBattery) { // Is the batteryLoop higher than sendBattery?
    #ifdef MY_DEBUG
        Serial.println(F("Read the battery voltage and report it."));
        MeasureBattery();         // Measure and report battery level
        batteryLoop = 0;          // Reset batteryLoop count
    #ifdef MY_DEBUG
      Serial.print(F("Go to sleep for: "));
      Serial.print(FOUR_MINUTE_SEND_FREQUENCY / 60000);
      Serial.println(F(" minutes."));
      batteryLoop++;
      sleep(FOUR_MINUTE_SEND_FREQUENCY);        // Sleep for 4 minutes
    void GetTemperatureHumidity()
    #ifdef MY_DEBUG
      Serial.println("");
      Serial.println(F("BME280 - Requesting new data from sensor module."));
      BME280.readCompensationParams();    // Need to read the NVM compensation parameters.
      // Normal mode for regular automatic samples
      BME280.writeStandbyTime(tsb_0p5ms);         // tsb = 0.5ms
      BME280.writeFilterCoefficient(fc_16);       // IIR Filter coefficient 16
      BME280.writeOversamplingPressure(os16x);    // pressure x16
      BME280.writeOversamplingTemperature(os8x);  // temperature x8
      BME280.writeOversamplingHumidity(os8x);     // humidity x8
      BME280.writeMode(smNormal);
    #ifdef MY_DEBUG
      Serial.println(F("Getting new values"));
      while (BME280.isMeasuring()) {  // Wait for BME280 to fininsh reading data
    #ifdef MY_DEBUG
        Serial.println(F("Measuring..."));
        delay(50);
      Serial.println(F("Done!"));
      // Read out the data - must do this before calling the getxxxxx routines
      BME280.readMeasurements();
      float temperature = BME280.getTemperatureMostAccurate();  // Get the temperature first.
      float humidity = BME280.getHumidityMostAccurate();        // Get the humidity.
    #ifdef MY_DEBUG
      Serial.print(F("BME280 - Temperature = "));
      Serial.print(temperature);
      Serial.println(" °C");
      Serial.print(F("BME280 - Humidity = "));
      Serial.print(humidity);
      Serial.println(F(" %"));
      // Now, let's send the measurements to the gateway.
      // Send temperature if the temperature difference bigger than the threshold
      if (COMPARE_TEMP == 1 && abs(temperature - lastTemperature) < tempThreshold) {
    #ifdef MY_DEBUG
        Serial.print(temperature - lastTemperature);
        Serial.println(F(" Temperature difference too small, don't send it to gateway."));
    #ifdef MY_DEBUG
          Serial.println(F("Sending new temperature to the gateway."));
          send(temperatureMsg.set(temperature, 1));
          lastTemperature = temperature; // Save temperatures for compare in the next round.
      // Send humidity if the humidity difference is bigger than the threshold.
      if (COMPARE_TEMP == 1 && abs(humidity - lastHumidity) < humThreshold) {
    #ifdef MY_DEBUG
        Serial.print(humidity - lastHumidity);
        Serial.println(F(" Humidity difference too small, don't send it to the gateway."));
    #ifdef MY_DEBUG
        Serial.println(F("BME280 - Sending the new humidity to the gateway."));
        send(humidityMsg.set(humidity, 1));
        lastHumidity = humidity; // Save new humidity to be able to compare in the next round.
    #ifdef MY_DEBUG
      Serial.println(F("BME280 - Measurement complete. Putting sensor to sleep."));
      BME280.writeMode(smSleep);  // set the BME280to sleep mode, save battery
    } // GetTemperatureHumidity
    * MeasureBattery
    void MeasureBattery() //The battery calculations
      float Vbat = vcc.Read_Volts();
      int batteryPercent = static_cast<int>(vcc.Read_Perc(VccMin, VccMax));
    #ifdef MY_DEBUG
      Serial.print(F("Battery percent: "));
      Serial.print(batteryPercent);
      Serial.println(" %");
      Serial.print(F("Battery Voltage: "));
      Serial.print(Vbat);
      Serial.println(F(" Volts"));
        send(voltageMsg.set(Vbat,2)); //send battery in Volt 2 decimal places
    sundberg84S
    sundberg84S
    #498
    @mickecarlsson - nice work! Let us know how it turns out :)
    Any pictures of this you can share?
    I did see you put VccMin to 1,2V and this might calculate so the battery will be @ 30% when the BOD hits you. I would put this to 2.0v if you are using a internal 8mhz bootloader. https://forum.mysensors.org/topic/7296/how-to-burn-fuses-so-that-pro-mini-3-3v-would-go-down-to-1-8v-solved/15
      Mr_sensor
      wrote on last edited by Mr_sensor
      #499
      @sundberg84 Hi, I soldered a board holding a humidity and temperature sensor. That is working fine and reporting to may gateway (mqtt). Only thing which I do not get working ok is the battery level measurement. As I already posted in an other topic here.
      Here are some pictures of my board. The bat jumper is connected with a wire on the bottom. And the code I use on it right now.
      I already changed the pro mini for a fresh soldered one but still getting the the same result. Just ones giving the volt and % and after that only giving 0 volt as output.
      tried to include delay(500) in the sketch but that did not help. So how to solve this?
      #define MY_NODE_ID 2
      #define MY_PARENT_NODE_ID 0
      // Enable debug prints
      //#define MY_RS485
      #include <SparkFunHTU21D.h>
      //static const uint8_t FORCE_UPDATE_N_READS = 10;
      #define CHILD_ID_HUM 0
      #define CHILD_ID_TEMP 1
      #define CHILD_ID_BATTERY 2
      //#define CHILD_ID_VOLT 2
      #define CHILD_ID_PRCNT 3
      float lastTemp;
      float lastHum;
      uint8_t nNoUpdatesTemp;
      uint8_t nNoUpdatesHum;
      boolean metric = true;
        sendSketchInfo("Humidity", "2.0");
        present(CHILD_ID_HUM, S_HUM);
        //metric = getControllerConfig().isMetric;
      unsigned long SLEEP_TIME = 60000; // Sleep time between reads (in milliseconds)
      static int oldBatteryPcnt = 0;
      HTU21D myHumidity;
      MyMessage msgBattery(CHILD_ID_BATTERY, V_VOLTAGE);
      //MyMessage msgBattery(CHILD_ID_BATTERY, V_PRCNT);
          myHumidity.begin();
          analogReference(INTERNAL1V1);
          analogReference(INTERNAL);
        float temperature = myHumidity.readTemperature();
        //if (!metric) {
        //    temperature = (temperature * 1.8) + 32.0;
        Serial.print("T: ");
        float humidity = myHumidity.readHumidity();
        Serial.print("H: ");
        Serial.println(humidity);
         // get the battery Voltage
          delay(500);
      #ifdef MY_DEBUG
          Serial.println(sensorValue);
      #ifdef MY_DEBUG
          Serial.print("Child ID ");
          Serial.print(CHILD_ID_BATTERY);
          Serial.print(batteryV);
          Serial.println(" V");
          Serial.print("Battery Percent: ");
          Serial.print(batteryPcnt);
              // Power up radio after sleep
              oldBatteryPcnt = batteryPcnt;
      0_1518613859739_IMG_5970.jpg 0_1518613878092_IMG_5971.jpg 0_1518613893620_IMG_5972.jpg 1_1518613931939_IMG_5907.jpg 0_1518613931939_IMG_5906.jpg 0_1518613977125_IMG_5908.jpg
        I don't think it is PCB related, try to make sure it is not a faulty arduino
          Mr_sensor
          @gohan said in 💬 Easy/Newbie PCB for MySensors:
          I already changed the arduino for a fresh soldered one but that did not alter things.
          • M Mr_sensor
            //#define MY_RS485
            float lastTemp;
            float lastHum;
            HTU21D myHumidity;
                myHumidity.begin();
              //if (!metric) {
                delay(500);
            #ifdef MY_DEBUG
            #ifdef MY_DEBUG
            sundberg84S
            sundberg84S
            @mr_sensor - I can not see any errors on the pictures you posted.
            Can you measure the voltage on Booster-Vout and also on this pad.
            • sundberg84S sundberg84
              Mr_sensor
              @sundberg84 said in 💬 Easy/Newbie PCB for MySensors:
              I did measure the parts you mentioned. Booster is 3,36 v and the other pad is 0,00 the input strait from the batteries is 2,80 v
              Also, Just for my info, does it matter how the resistors or capacitors are soldered on the board? My biggest problem is always determine the right resistors value and the right way to solder them (+ -). On the pcb some of them are coded (very handy for me as a beginner) with a G but not all of them?
              So my worry was that I maybe have soldered the "battery measurer" ones in the wring direction? Could that be the problem here?
                Resistors can be soldered either way, but if you read 0v on that capacitor pin it mean you have a problem between the battery and the capacitor, so you have to backtrack the connection that is missing
                  Mr_sensor
                  I measured the capacitor again and get a 0,10 output.
                    What are the resistor values you used? 0.1v is quite low
                      Mr_sensor
                      Maybe I used the wrong capacitor it says 1uf (50v) but now I see it has to be 0,1uf could that be the problem here?
                      • sundberg84S
                        sundberg84S
                        #508
                        Capacitor value does not change the voltage. The resistors does... I would double check that you use the right resistors. For example it's easy to use a resistor marked 1k instead of 1M. With 3.3v you should have around 1v on the capacitor.
                          you are also missing the capacitor on the booster output for better stability
                            Mr_sensor
                            Ok, I assumed it was not needed when using a battery. Which one to use there?
                              It is needed if you use a booster. Look at project page for details.
                              • M Mr_sensor
                                sundberg84S
                                sundberg84S
                                @mr_sensor a advice is to measure the resistance again over the resistors.
                                  Mr_sensor
                                  @sundberg84 Well I tried that but did not get the measurement straight from the pcb si I decided t solder a new board using the right capacitor this time (0,1uf instead of 1uf) made sure using the right resistors as well and adding a capacitor after the booster. Than with the same mini pro from the other board tested again and wow it is working as intended.
                                  Child ID 2Battery Voltage: 3.44 V
                                  Battery Percent: 102 %
                                  2930 TSF:MSG:SEND,2-2-0-0,s=255,c=3,t=0,pt=1,l=1,sg=0,ft=0,st=OK:102
                                  2938 MCO:SLP:MS=60000,SMS=0,I1=255,M1=255,I2=255,M2=255
                                  2945 TSF:TDI:TSL
                                  2947 MCO:SLP:WUP=-1
                                  2949 TSF:TRI:TSB
                                  3065 TSF:MSG:SEND,2-2-0-0,s=1,c=1,t=0,pt=7,l=5,sg=0,ft=0,st=OK:998.0
                                  T: 998.00
                                  3178 TSF:MSG:SEND,2-2-0-0,s=0,c=1,t=1,pt=7,l=5,sg=0,ft=0,st=OK:998.0
                                  H: 998.00
                                  957
                                  Child ID 2Battery Voltage: 3.22 V
                                  Battery Percent: 95 %
                                  3690 TSF:MSG:SEND,2-2-0-0,s=255,c=3,t=0,pt=1,l=1,sg=0,ft=0,st=OK:95
                                  3698 MCO:SLP:MS=60000,SMS=0,I1=255,M1=255,I2=255,M2=255
                                  3704 TSF:TDI:TSL
                                  3706 MCO:SLP:WUP=-1
                                  3708 TSF:TRI:TSB
                                  3815 TSF:MSG:SEND,2-2-0-0,s=1,c=1,t=0,pt=7,l=5,sg=0,ft=0,st=OK:998.0
                                  T: 998.00
                                  3932 TSF:MSG:SEND,2-2-0-0,s=0,c=1,t=1,pt=7,l=5,sg=0,ft=0,st=OK:998.0
                                  H: 998.00
                                  955
                                  Child ID 2Battery Voltage: 3.21 V
                                  4442 MCO:SLP:MS=60000,SMS=0,I1=255,M1=255,I2=255,M2=255
                                  4452 TSF:TDI:TSL
                                  4454 MCO:SLP:WUP=-1
                                  4456 TSF:TRI:TSB
                                  4560 TSF:MSG:SEND,2-2-0-0,s=1,c=1,t=0,pt=7,l=5,sg=0,ft=0,st=OK:998.0
                                  T: 998.00
                                  4673 TSF:MSG:SEND,2-2-0-0,s=0,c=1,t=1,pt=7,l=5,sg=0,ft=0,st=OK:998.0
                                  H: 998.00
                                  953
                                  5185 MCO:SLP:MS=60000,SMS=0,I1=255,M1=255,I2=255,M2=255
                                  5193 TSF:TDI:TSL
                                  5195 MCO:SLP:WUP=-1
                                  5197 TSF:TRI:TSB
                                  5304 TSF:MSG:SEND,2-2-0-0,s=1,c=1,t=0,pt=7,l=5,sg=0,ft=0,st=OK:998.0
                                  T: 998.00
                                  5416 TSF:MSG:SEND,2-2-0-0,s=0,c=1,t=1,pt=7,l=5,sg=0,ft=0,st=OK:998.0
                                  H: 998.00
                                  952
                                  Child ID 2Battery Voltage: 3.20 V
                                  5926 MCO:SLP:MS=60000,SMS=0,I1=255,M1=255,I2=255,M2=255
                                  5935 TSF:TDI:TSL
                                  5939 MCO:SLP:WUP=-1
                                  5941 TSF:TRI:TSB
                                  6045 TSF:MSG:SEND,2-2-0-0,s=1,c=1,t=0,pt=7,l=5,sg=0,ft=0,st=OK:998.0
                                  T: 998.00
                                  6158 TSF:MSG:SEND,2-2-0-0,s=0,c=1,t=1,pt=7,l=5,sg=0,ft=0,st=OK:998.0
                                  H: 998.00
                                  952
                                  6670 MCO:SLP:MS=60000,SMS=0,I1=255,M1=255,I2=255,M2=255
                                  6678 TSF:TDI:TSL
                                  6680 MCO:SLP:WUP=-1
                                  6682 TSF:TRI:TSB
                                  6789 TSF:MSG:SEND,2-2-0-0,s=1,c=1,t=0,pt=7,l=5,sg=0,ft=0,st=OK:998.0
                                  T: 998.00
                                  6901 TSF:MSG:SEND,2-2-0-0,s=0,c=1,t=1,pt=7,l=5,sg=0,ft=0,st=OK:998.0
                                  H: 998.00
                                  952
                                  7411 MCO:SLP:MS=60000,SMS=0,I1=255,M1=255,I2=255,M2=255
                                  7419 TSF:TDI:TSL
                                  7424 MCO:SLP:WUP=-1
                                  7426 TSF:TRI:TSB
                                  7530 TSF:MSG:SEND,2-2-0-0,s=1,c=1,t=0,pt=7,l=5,sg=0,ft=0,st=OK:998.0
                                  T: 998.00
                                  7643 TSF:MSG:SEND,2-2-0-0,s=0,c=1,t=1,pt=7,l=5,sg=0,ft=0,st=OK:998.0
                                  H: 998.00
                                  952
                                  8155 MCO:SLP:MS=60000,SMS=0,I1=255,M1=255,I2=255,M2=255
                                  8163 TSF:TDI:TSL
                                  8165 MCO:SLP:WUP=-1
                                  8167 TSF:TRI:TSB
                                  8273 TSF:MSG:SEND,2-2-0-0,s=1,c=1,t=0,pt=7,l=5,sg=0,ft=0,st=OK:998.0
                                  T: 998.00
                                  8388 TSF:MSG:SEND,2-2-0-0,s=0,c=1,t=1,pt=7,l=5,sg=0,ft=0,st=OK:998.0
                                  H: 998.00
                                  955
                                  8898 MCO:SLP:MS=60000,SMS=0,I1=255,M1=255,I2=255,M2=255
                                  8908 TSF:TDI:TSL
                                  8910 MCO:SLP:WUP=-1
                                  8912 TSF:TRI:TSB
                                  9021 TSF:MSG:SEND,2-2-0-0,s=1,c=1,t=0,pt=7,l=5,sg=0,ft=0,st=OK:998.0
                                  T: 998.00
                                  9132 TSF:MSG:SEND,2-2-0-0,s=0,c=1,t=1,pt=7,l=5,sg=0,ft=0,st=OK:998.0
                                  H: 998.00
                                  948
                                  Child ID 2Battery Voltage: 3.19 V
                                  Battery Percent: 94 %
                                  9646 TSF:MSG:SEND,2-2-0-0,s=255,c=3,t=0,pt=1,l=1,sg=0,ft=0,st=OK:94
                                  9654 MCO:SLP:MS=60000,SMS=0,I1=255,M1=255,I2=255,M2=255
                                  9660 TSF:TDI:TSL
                                  9662 MCO:SLP:WUP=-1
                                  9664 TSF:TRI:TSB
                                  9771 TSF:MSG:SEND,2-2-0-0,s=1,c=1,t=0,pt=7,l=5,sg=0,ft=0,st=OK:998.0
                                  T: 998.00
                                  9881 TSF:MSG:SEND,2-2-0-0,s=0,c=1,t=1,pt=7,l=5,sg=0,ft=0,st=OK:998.0
                                  H: 998.00
                                  952
                                  10395 TSF:MSG:SEND,2-2-0-0,s=255,c=3,t=0,pt=1,l=1,sg=0,ft=0,st=OK:95
                                  10403 MCO:SLP:MS=60000,SMS=0,I1=255,M1=255,I2=255,M2=255
                                  10409 TSF:TDI:TSL
                                  10412 MCO:SLP:WUP=-1
                                  10414 TSF:TRI:TSB
                                  10520 TSF:MSG:SEND,2-2-0-0,s=1,c=1,t=0,pt=7,l=5,sg=0,ft=0,st=OK:998.0
                                  T: 998.00
                                  10635 TSF:MSG:SEND,2-2-0-0,s=0,c=1,t=1,pt=7,l=5,sg=0,ft=0,st=OK:998.0
                                  H: 998.00
                                  953
                                  11147 MCO:SLP:MS=60000,SMS=0,I1=255,M1=255,I2=255,M2=255
                                  11155 TSF:TDI:TSL
                                  Now in mqtt I can see the percentage as:
                                  95
                                  qos : 0, retain : false, cmd : publish, dup : false, topic : **mygateway1-out/2/255/3/0/0**, messageId : , length : 30, Raw payload : 5753```
                                  But not the voltage?
                                  • M Mr_sensor
                                    2945 TSF:TDI:TSL
                                    2947 MCO:SLP:WUP=-1
                                    2949 TSF:TRI:TSB
                                    T: 998.00
                                    H: 998.00
                                    957
                                    3704 TSF:TDI:TSL
                                    3706 MCO:SLP:WUP=-1
                                    3708 TSF:TRI:TSB
                                    T: 998.00
                                    H: 998.00
                                    955
                                    4452 TSF:TDI:TSL
                                    4454 MCO:SLP:WUP=-1
                                    4456 TSF:TRI:TSB
                                    T: 998.00
                                    H: 998.00
                                    953
                                    5193 TSF:TDI:TSL
                                    5195 MCO:SLP:WUP=-1
                                    5197 TSF:TRI:TSB
                                    T: 998.00
                                    H: 998.00
                                    952
                                    5935 TSF:TDI:TSL
                                    5939 MCO:SLP:WUP=-1
                                    5941 TSF:TRI:TSB
                                    T: 998.00
                                    H: 998.00
                                    952
                                    6678 TSF:TDI:TSL
                                    6680 MCO:SLP:WUP=-1
                                    6682 TSF:TRI:TSB
                                    T: 998.00
                                    H: 998.00
                                    952
                                    7419 TSF:TDI:TSL
                                    7424 MCO:SLP:WUP=-1
                                    7426 TSF:TRI:TSB
                                    T: 998.00
                                    H: 998.00
                                    952
                                    8163 TSF:TDI:TSL
                                    8165 MCO:SLP:WUP=-1
                                    8167 TSF:TRI:TSB
                                    T: 998.00
                                    H: 998.00
                                    955
                                    8908 TSF:TDI:TSL
                                    8910 MCO:SLP:WUP=-1
                                    8912 TSF:TRI:TSB
                                    T: 998.00
                                    H: 998.00
                                    948
                                    9660 TSF:TDI:TSL
                                    9662 MCO:SLP:WUP=-1
                                    9664 TSF:TRI:TSB
                                    T: 998.00
                                    H: 998.00
                                    952
                                    10409 TSF:TDI:TSL
                                    10414 TSF:TRI:TSB
                                    T: 998.00
                                    H: 998.00
                                    953
                                    11155 TSF:TDI:TSL
                                    95
                                    sundberg84S
                                    sundberg84S
                                    @mr_sensor good to hear its working.
                                    It looks like you are only sending the % and not the voltage?
                                    • D
                                      dakipro
                                      @Mr_sensor It happened to me once that capacitor was just shortening the circuit, it was a smd, but when I removed it and tested it it was constantly making shortage, thus the circuit was never working and luckily my power supply had a low enough protection.
                                      I examined cap very closely, all looked fine, but internally it was not working fine.
                                      Since most of us (well, me at least) are buying cheap components I made it a habit now to always measure every passive component before installation, partly eliminates one variable
                                      • sundberg84S
                                        sundberg84S
                                        #516
                                        A short sneak-peak on the upcoming revision...
                                        Still a long way to go...
                                        Rev 10 - Nrf24l01+ ed.
                                        • Completley redesigned in KiCad.
                                        • MysX location changed to accept more MysX boards and align like RFM version.
                                        • Optional signing added
                                        • Optional SPI flash added.
                                        • Extra pins aligned to 2.45 vertical & horisontal
                                        • Relocated Extra + Bat Measurer some to allow more space to booster
                                        • Changed pull-up resistor from D3 to D5 to have one more pin for Interrupt
                                        • Relocated D5 pullup, MysX and IRQ jumper some.
                                        • Changed footprint (silk-screen) on capacitor to easier show Gnd/Pos side.
                                        Need to change footprint on voltage regulator on both nrf and rfm edition back to a square and not a liniar one. (rev 9 change). Not intended to revert back.
                                        Also a bit worried the 4,7uF cap os to far away from radio.
                                        gohanG Nca78N 2 Replies Last reply
                                          Putting it underneath the nrf24 module? I know it is not a "clean solution" but there would be still be unused space under the radio module
