  2. Announcements
  3. 💬 Door, Window and Push-button Sensor
110 Posts 36 Posters 57.5k Views 32 Watching
  • P
    P
    Psilin
    wrote on last edited by Psilin
    #51
    what is the logic of the variable "V_TRIPPED"to use? I just messed a little with the MyController application, and by using the V_TRIPPED the value changes from off to on,and stays on,even if the button is released? ( simular to close an opened door)
    Should the variable not be of a binary type with according sensor type?
      Slimz
      I have my sensor working well, Arduino pro mini with an Ethernet gateway using Home Assistant. .This is the first sensor I'm actually using a battery, so I've never really needed it, I see the battery level in HA as 0, how do I turn that on and use the battery level? Any pointers?
      Jim
      • Steve HadleyS
        Steve HadleyS
        Steve Hadley
        Dumb question, but how would I set this sketch to have an array of 5 switches? I’ve tried a couple of things but I’m lost
        • Mitja BlazinsekM
          Mitja BlazinsekM
          Mitja Blazinsek
          https://forum.mysensors.org/topic/7249/simple-binary-switch-example-trying-to-add-second-switch
          • R
            R
            rodaman
            wrote on last edited by rodaman
            #55
            I rewrite sketch for doors/window/buttons to work with multiple buttons (no rellays) .It shows up in Domoticz but it did not change status buttons if pressed.
            Can someone look for the skech what I am doing wrong
              DESCRIPTION
              Simple binary switch example updated  for 2 switches
              Connect button or door/window reed switch between
              digitial I/O pin 3 (BUTTON_PIN below) and GND.
              http://www.mysensors.org/build/binary
            //#define MY_RADIO_NRF24
            #define MY_GATEWAY_SERIAL
            //#include <SPI.h>
            #define FIRST_PIN  8  // Arduino Digital I/O pin for button/reed switch
            #define noButtons 4
            const int buttonPin[noButtons];
            Bounce debouncer[noButtons] = Bounce();
            int oldValue[noButtons];
            MyMessage msg[noButtons];
             for (int i = 0; i < noButtons; i++) {
               msg[i].type = V_TRIPPED; //
               pinMode(buttonPin[i + FIRST_PIN], INPUT_PULLUP);
               digitalWrite(buttonPin[i + FIRST_PIN], HIGH);
               debouncer[i].attach(buttonPin[i + FIRST_PIN]);
               debouncer[i].interval(30);
             sendSketchInfo("Doors", "1.0");
               present(i, S_DOOR);                               // present sensor to gateway
               debouncer[i].update();
               if (value != oldValue[i]) {
                 // Send in the new value
                 send(msg[i].set(value == HIGH ? 1 : 0));
                 oldValue[i] = value;
            • R rodaman
                DESCRIPTION
              //#include <SPI.h>
              #define noButtons 4
              #56
              @rodaman 0_1474354717994_upload-0e56e228-365f-4d94-90b3-5cf1305c6fae
              I fixed it for you.
              R 1 Reply Last reply
                I fixed it for you.
                R
                R
                rodaman
                @mfalkvidd
                thank you, i hope will be good soul who fix my sketch itself to work... :-)
                  @rodaman said in 💬 Door, Window and Push-button Sensor:
                  What is the purpose of the buttonPin-array?
                  E.g.
                  This will fetch a random (probably 0-initialised) value from the array and set pinmode on that value...
                  R 2 Replies Last reply
                    E.g.
                    R
                    R
                    rodaman
                    @hek
                    That part was in original sketch for establish internal pullup as I understand. I used array to do it for each pins.
                      E.g.
                      R
                      R
                      rodaman
                      @hek
                      I have changed
                      to
                      pinMode(buttonPin[i + FIRST_PIN], INPUT);
                      thanks, but sadlly still does not work...
                        I don't get the buttonPin array thing at all?
                        Why not just:
                        pinMode(i + FIRST_PIN, INPUT_PULLUP);
                        mfalkviddM R 2 Replies Last reply
                          Why not just:
                          @hek if the array was initialized, it could be used to set arbitrary pins. So pin 4,5,6,7,8,A0,A1,A2,A3 could be used for example (to avoid conflicts with the standard nrf24 wiring but still allow a lot of buttons). But as you mentioned before, without initializing the array the behavior will be strange.
                            Why not just:
                            R
                            R
                            rodaman
                            @hek said in 💬 Door, Window and Push-button Sensor:
                            Big Thanks!
                            I have changed all array parts in setup in the same manner like above and it works :-)
                            • R rodaman
                              Big Thanks!
                              R
                              R
                              rodaman
                              #64
                              @rodaman
                              Here is a sketch for multi buttons (no relays, no repeated parts of code for each buttons) just enter number of buttons and first digital pin where buttons are attached.
                              Thanks to @hek for help...
                                 DESCRIPTION
                                 Simple binary switch example updated  for multi switches
                                 Connect buttons or door/window reed switches between
                                 digitial I/O choosen pin  (FIRST_PIN below) and GND.
                              //#include <SPI.h>
                              #define FIRST_PIN  2  // Arduino Digital I/O pin for button/reed switch
                              #define noButtons 6
                              int value;
                                  oldValue[i] = -1;
                                  digitalWrite(i + FIRST_PIN, HIGH);
                                  debouncer[i].attach(i + FIRST_PIN);
                                  debouncer[i].interval(3);
                                Could these reed switches be used in the NC configuration for door/window sensor to save more battery?
                                  #66
                                  @gohan
                                  yes exactly.
                                  i made a nrf5 board using this principle.
                                    did you use those with 3 pins?
                                    Nca78N 1 Reply Last reply
                                      yes no-nc reed, connect them to IOs of your mcu and switch between input and output
                                        wrote on last edited by Nca78
                                        #69
                                        @gohan said in 💬 Door, Window and Push-button Sensor:
                                        I use them, with one wire connected to each interrupt pin (I only activate the one that's not connected) and they work fine.
                                        Else you can cheat with a basic reed switch, you just need an additional magnet on the other side of your switch that's weaker than the door magnet, and turn your reed 180°.
                                        You make the weak magnet close the reed when door is opened and far from the strong door magnet. When you close the door the strong magnet will open the reed switch.
                                          given the low price, I think it is not worth the extra work to "mod" the normal reed switches :D
