  3. Simple binary switch example, trying to add second switch
5 Posts 3 Posters 2.8k Views 4 Watching
  • Mitja BlazinsekM
    Mitja BlazinsekM
    Mitja Blazinsek
    Hello! Firs i'm newbie to arduino and my sensors so please don't be mad on me in know that is for you guys probably basic of arduino coding.
    so i tok the basic exsample of Simple binary switch example and try to add one more switch but i think i have some problem with bounce function because it work only one switch CHILD_ID_ST2 on the code below
    Thanks for any help! Probable master can solve that problem in couple of minutes :) it bother me 2 days :)
     * Simple binary switch example
     * Connect button or door/window reed switch between
     * digitial I/O pin 3 (BUTTON_PIN below) and GND.
     * http://www.mysensors.org/build/binary
    #include <Bounce2.h>
    #define CHILD_ID_ST1 3
    #define CHILD_ID_ST2 4
    #define ST1_PIN  4  // Arduino Digital I/O pin for button/reed switch
    #define ST2_PIN  3
    Bounce debouncer = Bounce();
    int oldValue=-1;
    MyMessage msgst1(CHILD_ID_ST1,V_TRIPPED);
    MyMessage msgst2(CHILD_ID_ST2,V_TRIPPED);
      // Setup the button
      pinMode(ST1_PIN,INPUT);
      pinMode(ST2_PIN,INPUT);
      // Activate internal pull-up
      digitalWrite(ST1_PIN,HIGH);
      digitalWrite(ST2_PIN,HIGH);
      debouncer.attach(ST1_PIN);
      debouncer.attach(ST2_PIN);
      debouncer.interval(5);
    void presentation() {
      present(CHILD_ID_ST1, S_DOOR);
      present(CHILD_ID_ST2, S_DOOR);
      debouncer.update();
      // Get the update value
      int value = debouncer.read();
      if (value != oldValue) {
         // Send in the new value
         send(msgst1.set(value==HIGH ? 1 : 0));
         oldValue = value;
         send(msgst2.set(value==HIGH ? 1 : 0));
         oldValue = value;
    • Mitja BlazinsekM Mitja Blazinsek
      #define ST2_PIN  3
      int oldValue=-1;
        // Setup the button
        debouncer.update();
           oldValue = value;
           oldValue = value;
      @Mitja-Blazinsek the debouncer can only handle one button. You you'll need two debouncers. Change
      to
      Bounce debouncer2 = Bounce();
      and adjust the rest of the code to use both debouncers.
      • Mitja BlazinsekM
        Mitja BlazinsekM
        Mitja Blazinsek
        i try to change that but again i'm doing something wrong now it change it constantly both state when i pressed any button
        #define ST2_PIN  3
        Bounce debouncer1 = Bounce();
        int oldValue=-1;
          // Setup the button
          debouncer1.attach(ST1_PIN);
          debouncer2.attach(ST2_PIN);
          debouncer1.interval(5);
            debouncer2.interval(5);
          debouncer1.update();
          int value = debouncer1.read();
             oldValue = value;
          debouncer2.update();
          int value2 = debouncer2.read();
          if (value2 != oldValue) {
             send(msgst2.set(value2==HIGH ? 1 : 0));
             oldValue = value2;
        Boots33B 1 Reply Last reply
          #define ST2_PIN  3
          int oldValue=-1;
            // Setup the button
               oldValue = value;
               oldValue = value2;
          Boots33B
          Boots33B
          Boots33
          @Mitja-Blazinsek You are using the oldValue variable for both switches. You need to declare and use a unique one for each switch.
          For example
          if (value2 != oldValue2) {
               oldValue2 = value2;
          • Mitja BlazinsekM
            Mitja BlazinsekM
            Mitja Blazinsek
            thank you very much boots33 and mfalkvidd finaly wor also learn a lot on this example, its time now to try with relays i will add 2 relays that i can triger with switch or controler
            my working code for switch:
               The MySensors Arduino library handles the wireless radio link and protocol
               between your home built sensors/actuators and HA controller of choice.
               The sensors forms a self healing radio network with optional repeaters. Each
               repeater and gateway builds a routing tables in EEPROM which keeps track of the
               network topology allowing messages to be routed to nodes.
               Created by Henrik Ekblad <henrik.ekblad@mysensors.org>
               Copyright (C) 2013-2015 Sensnology AB
               Full contributor list: https://github.com/mysensors/Arduino/graphs/contributors
               Documentation: http://www.mysensors.org
               Support Forum: http://forum.mysensors.org
               This program is free software; you can redistribute it and/or
               modify it under the terms of the GNU General Public License
               version 2 as published by the Free Software Foundation.
               DESCRIPTION
               Simple binary switch example updated  for 2 switches
            #define ST1_PIN  3  // Arduino Digital I/O pin for button/reed switch
            #define ST2_PIN  4
            int oldValue = -1;
            int oldValue1 = -1;
            MyMessage msgst1(CHILD_ID_ST1, V_TRIPPED);
            MyMessage msgst2(CHILD_ID_ST2, V_TRIPPED);
              // Setup the button1
              pinMode(ST1_PIN, INPUT);
              digitalWrite(ST1_PIN, HIGH);
              // Setup the button2
              pinMode(ST2_PIN, INPUT);
              digitalWrite(ST2_PIN, HIGH);
                send(msgst1.set(value == HIGH ? 1 : 0));
                oldValue = value;
              int value1 = debouncer2.read();
              if (value1 != oldValue1) {
                send(msgst2.set(value1 == HIGH ? 1 : 0));
                oldValue1 = value1;
