  3. 💬 In Wall AC/DC Pcb (with Relay) for MySensors (SMD)
switchin-wallrelayacdchlk-pm01
89 Posts 27 Posters 35.2k Views 29 Watching
  • N
    N
    Nightbodom
    @sundberg84 thanks for advice... I successfully load bootloader through ISP with spare Uno as programmer, then I try to load a sketch with ftdi but it didn't recognize PCB. I also try with arduino uno as ISP and it goes without problem. I use node manager sketch with relay and connect it to AC wires...and nothing!
    After visual checking of PCB I check fuses and notice that thermal fuse is dead. So I think I burn it with soldering. Any advice how to solder it?
    sundberg84S ben999B 2 Replies Last reply
    • N Nightbodom
      sundberg84S
      sundberg84S
      @nightbodom - this can be a bit tricky. Some suggest cooling pincers or tongs to hold it while soldering. Myself I solder as normal and wait it to cool down before continue. As long as you are quick and not heat it up to much it should work.
      If you power the pcb with FTDI it should work without the fuse though. But I guess you power it through AC->HLK and use only RX/TX/GND and Rst from ftdi?
      • N Nightbodom
        ben999B
        ben999B
        ben999
        @nightbodom I use crocodile clips and get fairly good results with very few dead fuses....
        • G
          G
          Grave
          Is it possible to use with RFM69 modul?
            I guess not on as this module is using SMD NRF24 module
              sundberg84S
              sundberg84S
              @Grave - well @gohan is right, I cant fit a RFM69 module on this board.
              • G
                G
                Grave
                I will try to rebuild it in eagle for RFM69. I think the space is there for an RFM69.
                • G
                  G
                  Grave
                  Or I will build an adapter.
                  • G
                    G
                    Grave
                    Hi sundberg84,
                    can you maybe take a look on my board. I have rebuild it so you can use it with rfm69 and NRF24 moduls. I have build an adapter, which will stand vertical behin the HLK-PM01.
                    But how can I upload a picture?
                    • G Grave
                      Hi sundberg84,
                      sundberg84S
                      sundberg84S
                      @grave Sure, you can just copy it into the message box.
                      • G
                        G
                        Grave
                        http://www.directupload.net/file/d/5020/dyi4y337_png.htm
                        • G Grave
                          sundberg84S
                          sundberg84S
                          @grave - at first it looks really good. Hard for me on a image to check every connection but I can not see any errors.
                          • G
                            G
                            Grave
                            I can upload this evening the schematic and the board. But my schematic is not so fine as yours. I didn´t find pinheaders with 2mm distance, so they are single pads.
                            • G
                              G
                              Grave
                              here are my schematic and the layout. I have build also an adapter for the rfm69 modul to use with an Sensebender Micro, because I had still place enough.
                              https://www.file-upload.net/download-13018265/InWallPCB71RFM69.brd.html
                              https://www.file-upload.net/download-13018266/InWallPCB71RFM69.sch.html
                              • G Grave
                                sundberg84S
                                sundberg84S
                                @grave - sorry, I dont run Eagle anymore so I cant check them.
                                • G
                                  G
                                  Grave
                                  Do you use both, thermal fuse and the normal fuse? I can´t see it in your picture. I don´t find a normal fuse with 0,2A in Germany.
                                  • G Grave
                                    sundberg84S
                                    sundberg84S
                                    @grave yes I do for both temp and current protection. I want it to be overkill when it's diy. If you follow the links on openhardware you will find the security discussion.
                                    • G
                                      G
                                      Grave
                                      I have read it. But i didn´t find the fuse on the picture. Do you have one with both fuses? I have problems to find such fuses in this dimension in Germany. For the Varistor I have find one with 120 Jule. I think it´s ok.
                                      • G Grave
                                        sundberg84S
                                        sundberg84S
                                        @grave - I have bought my fuses from China. Im sure its possible to find on mouser or digikey,.
                                          sineverba
                                          @sundberg84 sorry for question. i'm tryng to understand the scope for the SSR Relay. Can you explain me? Is it for some kind of safe or is it governable from the Atmega? Thank you!
