  3. 💬 In Wall AC/DC Pcb (with Relay) for MySensors (SMD)
switchin-wallrelayacdchlk-pm01
89 Posts 27 Posters 35.2k Views 29 Watching
  • G
    G
    Grave
    Hi sundberg84,
    can you maybe take a look on my board. I have rebuild it so you can use it with rfm69 and NRF24 moduls. I have build an adapter, which will stand vertical behin the HLK-PM01.
    But how can I upload a picture?
    • G Grave
      Hi sundberg84,
      sundberg84S
      sundberg84S
      @grave Sure, you can just copy it into the message box.
      • G
        G
        Grave
        http://www.directupload.net/file/d/5020/dyi4y337_png.htm
        • G Grave
          sundberg84S
          sundberg84S
          @grave - at first it looks really good. Hard for me on a image to check every connection but I can not see any errors.
          • G
            G
            Grave
            I can upload this evening the schematic and the board. But my schematic is not so fine as yours. I didn´t find pinheaders with 2mm distance, so they are single pads.
            • G
              G
              Grave
              here are my schematic and the layout. I have build also an adapter for the rfm69 modul to use with an Sensebender Micro, because I had still place enough.
              https://www.file-upload.net/download-13018265/InWallPCB71RFM69.brd.html
              https://www.file-upload.net/download-13018266/InWallPCB71RFM69.sch.html
              • G Grave
                sundberg84S
                sundberg84S
                @grave - sorry, I dont run Eagle anymore so I cant check them.
                • G
                  G
                  Grave
                  Do you use both, thermal fuse and the normal fuse? I can´t see it in your picture. I don´t find a normal fuse with 0,2A in Germany.
                  • G Grave
                    sundberg84S
                    sundberg84S
                    @grave yes I do for both temp and current protection. I want it to be overkill when it's diy. If you follow the links on openhardware you will find the security discussion.
                    • G
                      G
                      Grave
                      I have read it. But i didn´t find the fuse on the picture. Do you have one with both fuses? I have problems to find such fuses in this dimension in Germany. For the Varistor I have find one with 120 Jule. I think it´s ok.
                      • G Grave
                        sundberg84S
                        sundberg84S
                        @grave - I have bought my fuses from China. Im sure its possible to find on mouser or digikey,.
                          sineverba
                          @sundberg84 sorry for question. i'm tryng to understand the scope for the SSR Relay. Can you explain me? Is it for some kind of safe or is it governable from the Atmega? Thank you!
                            It has smaller footprint and it doesn't wear out during time like mechanical relays
                            • S sineverba
                              sundberg84S
                              sundberg84S
                              @sineverba it is much to learn and instead of me trying to make a half ok job I would suggest you search SSR vs mechanical relay. I think greatscott did a great Youtube video about it.
                              • rzyliusR
                                rzyliusR
                                rzylius
                                hi, I get constantly messages Arduino: 1.8.5 (Linux), Board: "Arduino Pro or Pro Mini, ATmega328P (5V, 16 MHz)"
                                avrdude: stk500_getsync() attempt 7 of 10: not in sync: resp=0xde
                                avrdude: stk500_getsync() attempt 8 of 10: not in sync: resp=0x4c
                                avrdude: stk500_getsync() attempt 9 of 10: not in sync: resp=0x9d
                                avrdude: stk500_getsync() attempt 10 of 10: not in sync: resp=0xaa
                                is this hardware problem? I select Arduino Pro Mini board setting with AVRISP mkII programmer. are these ok?
                                • rzyliusR rzylius
                                  sundberg84S
                                  sundberg84S
                                  @rzylius could be a bootloader or hardware settings. I would check the reset resistor. Do you know which bootloader is on or did you manage to upload one though iscp header?
                                  rzyliusR 2 Replies Last reply
                                  • sundberg84S sundberg84
                                    rzyliusR
                                    rzyliusR
                                    rzylius
                                    @sundberg84 said in 💬 In Wall AC/DC Pcb (with Relay) for MySensors (SMD):
                                    header?
                                    No, I did not. I used to work with arduinos, so this is the first time I bought and try mega328p. could you advise where to find a resource with step-by-step instructions on that?
                                      rzyliusR
                                      rzyliusR
                                      rzylius
                                      @sundberg84 , sorry, I meant I did not burn the bootloader and was not aware of that.
                                      Did you mean "reset capacitator", not resistor?
                                      And on that note, am I right that reset to iscp should go to DTS contact?
                                      thanks for help.
                                      • rzyliusR rzylius
                                        thanks for help.
                                        sundberg84S
                                        sundberg84S
                                        @rzylius - some chip have bootloader on it already, some dont. Depends on where you buy it - but the only way to be able to upload through ftdi is if there is a bootloader.
                                        I meant reset capacitor :) Thanks! Yes, reset should go to DTS.
                                        • N
                                          N
                                          nekitoss
                                          I was wondering if 73 defree for thermal fuse is long-operating temperature or blow temperature? (i looked at well-known for you all test, where it heated around 63 degrees at 1hour rated load)
                                          In any case long-time 73C thermal fuse will have around 100C blow temperature (looked at my local store). I'm asking because on ebay link they are rated as 240C...
                                          Other moment i woul like to aware - (as you know, not shure about others) - there are counterfeit G3MB-202P relays everywhere, which are officially discontinued March 2011 (!).
                                          You correcly put there a G3MC-202P relay. But someone may not notice those difference in one letter and buy a counterfeight relay in local store...
                                          Also i was sitting and reading a lot about safety, especially about counterfeits in this high-voltage parts, and found this picture which shows, what happened with those (i think, because of post date)bad relay with 1 Amp load with incandescent lamps.
                                          That is also a problem of all SSR relays - that they heat. So i was wondering how much heats original relay and if it is good idea and possible (i understand that it is very hard to update such small pcb) to move thermal fuse between relay and HLK-PM01, so it can protect both? Or put it verticall (not shure about clearance and creepage in this case) in corner between them.
                                          I was dissapointed about price of relay, especially against counterfeit, but safety is worth it! Also you can make same simple sheme as inside relay (even from datasheet on moc30xx), but you must know a lot in electonics to make it as safe as sealed factory relay i think (but in oppsite in such shemas over internet ushually resistor are recommended up to 2Watt (for 16A shemas) while smd resistors have much less watts...).
                                          Also it would be nice to add in description to what this relay can be applied to. Because not everyone may understand that incandescent lamps at start have bigger current, and at the moment filament is broken a short-ciruit with arc appears. And ssr relays usually die at short-circuit and you need fast fuse to save them, but they are expensive... And you should not use it with motors, etc or use with lower ratings...
                                          I really think they must be warned, even shortly.
                                          And only 100% way to buy original HLK-PM01, is to buy from manufacturer site. but i'm wondering how much will cost shipping. Wholesale price (which is in basket) is even lower than ebays. At the moment it is 2.50$
                                          Sorry for so much text, i may somewhere be wrong, feel free to correct me and discuss. But when it is about safety - i cannot stand aside.
