  3. nRF5 action!
nRF5 action!
1.9k Posts 49 Posters 2.1m Views 44 Watching
  • korttomaK korttoma
    @toyman sure do LINK
    korttomaK
    korttomaK
    korttoma
    @Mika what is your experience regarding battery consumption on these?
    LINK
    I put together a sketch witch seems to work fine but one CR2032 just lasts a couple of days.
    Sketch:
    // Define a static node address, remove if you want auto address assignment
    //#define MY_NODE_ID 26                                                          // Kök
    #define MY_NODE_ID 27                                                          // Test device
    #define MY_RADIO_NRF5_ESB
    #define SN "NRF5 Scene"
    #define SV "1.0"
    #define CHILD_ID_SCENE 1
    // PIN for the buttons
    byte buttonOne = 28;
    //Bounce debouncer[NUMBUTTONS];
    int buttonOneoldValue;
    // Pin definitions
    #define DIGITAL_INPUT_INT 28   // The digital input you attached your interrupt  (Only 2 and 3 generates interrupt!)
    // Sensor messages
    MyMessage msgOn(CHILD_ID_SCENE, V_SCENE_ON);
    // Global settings
    uint16_t SceneOne = 0;
    uint16_t SceneTwo = 1;
    void blinkityBlink(uint8_t repetitions) {
        wait(20);
        wait(100);
        wait(20);
        if (x<(repetitions-1)) {  //skip waiting at the end of the final repetition
          wait(500);
     * Setup code
      blinkityBlink(2);  //signify power-up and start of operations
      hwPinMode(DIGITAL_INPUT_INT, INPUT_PULLUP);
        /// Make input & enable pull-up resistors on switch pins
      hwPinMode(buttonOne, INPUT_PULLUP);
      buttonOneoldValue = -1;
      sendBattLevel();
    void presentation()  {
      sendSketchInfo(SN, SV);
      //present the scene controller to gateway
      wait(10);
      present(CHILD_ID_SCENE, S_SCENE_CONTROLLER);
      wait(10);
     *  Main loop function
      // Check for button activity
      int value = digitalRead(buttonOne);
      if (value != buttonOneoldValue)
          // Send in the new value
          if (value == LOW)
            send(msgOn.set(SceneOne));
            wait(20);
            send(msgOn.set(SceneTwo));
            sendBattLevel();
          buttonOneoldValue = value;
      sleep(digitalPinToInterrupt(DIGITAL_INPUT_INT), CHANGE, 0);
     * Parameters
    void sendBattLevel()
        long vcc = hwCPUVoltage();
        // Calculate percentage
        vcc = vcc - 1800; // subtract 1.9V from vcc, as this is the lowest voltage we will operate at
        long percent = vcc / 14.0;
        sendBatteryLevel(percent);
    I noticed that the chip sais:
    N51822
    QFABC0
    1646UU
    QFAB translates to 16kB RAM, 128kB flash and I can not even select this option in the arduino IDE. Can this be the problem?
    @d00616 refer to his document for some high current consumption issue but I'm not sure what to do with the info.
    Is there something wrong with my sketch or is there just an old crappy chip on the device??
    • Tomas
    Nca78N 1 Reply Last reply
    • MiKaM
      MiKaM
      MiKa
      Same result, battery out within few days, I want to do a check of current consumption, but not yet free time...
      I want to try this:
      https://github.com/ThingPulse/ESP8266PowerMonitor
      https://thingpulse.com/2018/02/25/esp8266-monitoring-power-consumption/
      • Nca78N
        wrote on last edited by Nca78
        #1455
        @korttoma have you tried the code @NeverDie put together using the LPCOMP ? With a QFAAH0 (which I believe is the same version than QFABC0, but with 256K flash) he went down to something like 4µA.
        From the document you link, anomaly 70, it will be necessary to add an extra wait of 36us after that line, it's strange that @NeverDie never had any problem with it. Or maybe I misunderstand the document :)
        void activateLpComp() {
        Test code from @NeverDie using LPCOMP is here:
        https://forum.mysensors.org/topic/6961/nrf5-bluetooth-action/1307
        I will try it on my board (using a module with QFAAH0) tomorrow, if power consumption is as low as expected I'll try on the beacon board.
        [Edit] Just checked quickly my "beacon" board and it's using a QFAAH1 chip (made in 2017), so the test might not be relevant...
        korttomaK Nca78N 2 Replies Last reply
          #1456
          I don't remember. I've lately been using LoRa modules, plus getting distracted by CNC, so my nRF5 work has been on hold. I'm hoping that d00616 continues to work on the software though so that more than one nRF5 interrupt can be active at a time.
          • Nca78N Nca78
            korttomaK
            korttomaK
            korttoma
            @nca78 thanks for the hint.
            I tried to merge my sketch with the code provided by @NeverDie but I can not seem to get it to detect my button and I don't quite understand where I should attach my button that is on pin 28 to the interrupt thingie.
            Here is my code now:
            //This sketch is applicable to Coincell Multisensor nRF51822, version 10
            #define SV "1.0"
            //#define MY_CORE_ONLY
            #define IS_NRF51  //true iff the target is an nRF51.  If an nRF52, then comment this line out!
            // Pin definitions
            //#define DIGITAL_INPUT_INT 28   // The digital input you attached your interrupt  (Only 2 and 3 generates interrupt!)
            //#define I2C_INTERRUPT_PIN PIN_BUTTON1
            //#define LEAK_DETECTION_PIN PIN_BUTTON1
            #include <nrf.h>
            volatile bool button_pressed=false;
            // Sensor messages
            // Global settings
                for (int i=0;i<pulses;i++) {
                  wait(20);
                  wait(100);
                  wait(500);
            #ifndef IS_NRF51
            void turnOffRadio() {
              NRF_RADIO->TASKS_DISABLE=1;
            void turnOffUarte0() {
            #ifndef IS_NRF51
              NRF_UARTE0->TASKS_STOPRX = 1;
              NRF_UARTE0->TASKS_STOPTX = 1;
            #ifdef IS_NRF51
              NRF_UART0->TASKS_STOPRX = 1;
              NRF_UART0->TASKS_STOPTX = 1;
              NRF_UART0->TASKS_SUSPEND = 1;
            void turnOffAdc() {
            #ifndef IS_NRF51
                NRF_SAADC->TASKS_STOP=1;
            void mySleepPrepare()
              turnOffHighFrequencyClock();
              turnOffRadio();
              turnOffUarte0();
              //NRF_LPCOMP->PSEL=1; // monitor AIN1 (pin P0.03 on nRF52832 test board).
              //while (!(NRF_LPCOMP->PSEL==1)) {} //wait until confirmed
              NRF_LPCOMP->PSEL=3; // monitor AIN3 (pin P0.02 on nRF51822 for coincell_multisensor_v10)
              while (!(NRF_LPCOMP->PSEL==3)) {} //wait until confirmed
              NRF_LPCOMP->REFSEL=1;  // choose 1/4 VDD as the reference voltage
              while (!(NRF_LPCOMP->REFSEL==1)) {} //wait until confirmed
              NRF_LPCOMP->ANADETECT=1;  //detect UP events.
              while (NRF_LPCOMP->ANADETECT!=1) {} //wait until confirmed
              while (!(NRF_LPCOMP->INTENSET==B0100)) {} //wait until confirmed
              NVIC_EnableIRQ(LPCOMP_IRQn);
                while (NRF_LPCOMP->INTENCLR==B0100) {} //wait until confirmed
             * Setup code
              hwInit();
              disableNfc();
              turnOffAdc();
              activateLpComp();
              blinkityBlink(2,1);  //Signify end of setup with two quick pulses.
              mySleepPrepare();
              //NRF_CLOCK->INTENSET=B11;  //enable interrupts for EVENTS_HFCLKSTARTED and  EVENTS_LFCLKSTARTED
             // NRF_CLOCK->TASKS_HFCLKSTART=1;  //start the high frequency crystal oscillator clock
             // while (!(NRF_CLOCK->EVENTS_HFCLKSTARTED)) {} //wait until high frequency crystal oscillator clock is up to speed and working
              //hwPinMode(DIGITAL_INPUT_INT, INPUT_PULLUP);
              //buttonOneoldValue = -1;
              //sendBattLevel();
              wait(10);
              wait(10);
              sendBattLevel();
              sleep(10000);  //sleep for 5 seconds.
              mySleepPrepare();  //An ounce of prevention: Turn-off HF clock, etc, ASAP to save power, just in case the library's sleep() routine resumed them.
              if (button_pressed) {   //if a leak is detected
                suspendLpComp(); //suspend LPCOMP to prevent multiple interrupts
                //blinkityBlink(10,3);  //blink a lot to show that a leak was detected.
                    wait(20);
                    sendBattLevel();
                button_pressed=false;  //Clear the semaphore
                NRF_LPCOMP->EVENTS_UP=0;  //Clear the semaphore
                resumeLpComp();  //operations of LPCOMP were suspended after detecting the LPCOMP iterrupt
              else {
                blinkityBlink(1,1);  //otherwise, just one short blink to indicate the wakeup was scheduled by the RTC
            #if __CORTEX_M == 0x04
                    event = 0;        \
                    (void)event
            // This must be in one line
            extern "C" { void LPCOMP_IRQHandler(void) {button_pressed=true; NRF5_RESET_EVENT(NRF_LPCOMP->EVENTS_UP); NRF_LPCOMP->EVENTS_UP=0; MY_HW_RTC->CC[0]=(MY_HW_RTC->COUNTER+2);}}
            I thought that I should do it like this:
               NRF_LPCOMP->PSEL=28; // monitor AIN3 (pin P0.02 on nRF51822 for coincell_multisensor_v10)
              while (!(NRF_LPCOMP->PSEL==28)) {} //wait until confirmed
            But then it does not seem to run the loop anymore because I do not get the 10s blink.
            • Tomas
            • T
              Toyman
              Guys, help me understand: when do I need to enable DC-DC?
              My breakout board consists of Ebyte module and a couple of buttons. Battery is CR2450 directly connected to the module.
              Do I need DC-DC?
              • T Toyman
                Do I need DC-DC?
                #1459
                @toyman With DC-DC, it uses roughly half the current during Tx and Rx. Seems like a no brainer to me, but you don't literally "need" to have it. I'm not aware of any downsides to it.
                  Toyman
                  @neverdie thx. What is needed hardware-wise? Two inductors between dc and dec4? Like in your breakout board?
                  • T Toyman
                    @toyman Correct. You can review the schematic for this project: https://www.openhardware.io/view/472/Ebyte-nRF52832-Prototyping-Board
                    • korttomaK
                      korttomaK
                      korttoma
                      #1462
                      I guess this is why I cant get LPCOMP to work on the device.
                      Eight input options (AIN0 to AIN7)
                      I would have to use the analog inputs because pin 28 is just a general purpose I/O pin.
                      • Tomas
                      • T
                        Toyman
                        ebyte module is currently on sale at roughly $2.5
                        Total bargain!
                          @korttoma using MySensors NRF5 boards you should be able to assign one AINx pin to physical pin 28.
                          The index you need to put in the code is the AIN index not the pin number.
                          korttomaK 1 Reply Last reply
                          • Nca78N Nca78
                            korttomaK
                            korttomaK
                            korttoma
                            @nca78 sorry but I cannot figure out how to do this. Should I do it in the MyBoardNRF5.cpp, MyBoardNRF5.h or in the sketch?
                            • Tomas
                              #1466
                              @korttoma sorry I said stupid things as I'm a beginner too, you can't reassign analog inputs and LPCOMP to different pins on NRF5 chips.
                              • Nca78N Nca78
                                korttomaK
                                korttomaK
                                korttoma
                                @nca78 it is ok, I think I will have to set up a test system with a different device with witch I can measure current consumption, attach serial logging and then try to fiddle with the code. I'm flying in the dark with this bluetooth beacon device since I cannot access any pins.
                                • Tomas
                                  Toyman
                                  @neverdie thx. Why don't you have a capacitor between DEC4 to GND? I can see only 2 inductors, while Nordic power guidelines prescribe an LC filter between DCC and DEC, ie inductors and a capacitor. nrf52dk also has it.
                                  • T Toyman
                                    #1469
                                    @toyman I guess I made an error then. Thanks for pointing that out. In general, I haven't gotten much feedback on the PCB's that I've posted, so any feedback is always appreciated. :)
                                    O YveauxY 2 Replies Last reply
                                      O
                                      O
                                      Omemanti
                                      @neverdie Question is, did the DC/DC still work without the cap?
                                      • O Omemanti
                                        #1471
                                        @omemanti said in nRF5 Bluetooth action!:
                                        I believe it did. If you look at: https://www.openhardware.io/view/471/Ebyte-nRF52832-Small-Breakout-Board
                                        which has the inductors soldered on, I believe that is the one that I tested. Enough time has passed though that I can't be 100% sure now. I made a number of different variations, and I didn't post all of them.
                                        O 1 Reply Last reply
                                          O
                                          O
                                          Omemanti
                                          wrote on last edited by Omemanti
                                          #1472
                                          @neverdie said in nRF5 Bluetooth action!:
                                          I used your schematic for a PCB I ordered yesterday :), did saw the post about the cap until it was too late :(
                                          part of the game!
                                          Edit: according to your post https://forum.mysensors.org/topic/6961/nrf5-bluetooth-action/797 it did work
