  3. nRF5 action!
nRF5 action!
1.9k Posts 49 Posters 1.9m Views 44 Watching
    @Nca78
    Here's the board settings that I use:
    Nca78N 1 Reply Last reply
    • korttomaK
      korttomaK
      korttoma
      #1445
      Like NeverDie I am also having some trouble getting started with the NRF5 programming.
      Here is my setup:
      The problem "No valid JTAG Interface Configured":
      Did I miss some step to configure the J-Link somewhere?
      • Tomas
        I've always used the IDC connector. I'm not sure that it works if you don't.
        • korttomaK korttoma
          Here is my setup:
          @korttoma I have the same problem with the official jlink drivers. So I drag/drop the hex file from output directory to the Jlink drive at the moment.
          korttomaK 1 Reply Last reply
          • Nca78N Nca78
            korttomaK
            korttomaK
            korttoma
            #1448
            @nca78 :D that worked! thank you thank you thank you!
            My first NFR5 node is ALIVE!
            • Tomas
              #1449
              @neverdie said in nRF5 Bluetooth action!:
              i.e. the 10-pin connector.
                @Nca78
                @neverdie thank you for pointing to the power problem. I had one jumper left for my adapter to connect GND to GND and "as usual" it had a contact problem, I just replaced it and I can see the module in nRFgo Studio, even without external power.
                • O
                  O
                  Omemanti
                  Question;
                  I've been using the Ebyte modules and I'm making progress. But somehow the energy consumption is far too much. 11,7 mA when I use a clean sketch with hwSleep().
                  When I change to "Normal" Sleep() I get 0.1mA.
                  which one should be the right one to use, keeping in mind, I would like to wake up from an interrupt.
                  • O Omemanti
                    Question;
                    @omemanti sleep. See https://www.mysensors.org/download/sensor_api_20#sleeping for details.
                      @toyman sure do LINK
                      korttomaK
                      korttomaK
                      korttoma
                      @Mika what is your experience regarding battery consumption on these?
                      LINK
                      I put together a sketch witch seems to work fine but one CR2032 just lasts a couple of days.
                      Sketch:
                      // Define a static node address, remove if you want auto address assignment
                      //#define MY_NODE_ID 26                                                          // Kök
                      #define MY_NODE_ID 27                                                          // Test device
                      #define MY_RADIO_NRF5_ESB
                      #define SN "NRF5 Scene"
                      #define SV "1.0"
                      #define CHILD_ID_SCENE 1
                      // PIN for the buttons
                      byte buttonOne = 28;
                      //Bounce debouncer[NUMBUTTONS];
                      int buttonOneoldValue;
                      // Pin definitions
                      #define DIGITAL_INPUT_INT 28   // The digital input you attached your interrupt  (Only 2 and 3 generates interrupt!)
                      // Sensor messages
                      MyMessage msgOn(CHILD_ID_SCENE, V_SCENE_ON);
                      // Global settings
                      uint16_t SceneOne = 0;
                      uint16_t SceneTwo = 1;
                      void blinkityBlink(uint8_t repetitions) {
                          wait(20);
                          wait(100);
                          wait(20);
                          if (x<(repetitions-1)) {  //skip waiting at the end of the final repetition
                            wait(500);
                       * Setup code
                        blinkityBlink(2);  //signify power-up and start of operations
                        hwPinMode(DIGITAL_INPUT_INT, INPUT_PULLUP);
                          /// Make input & enable pull-up resistors on switch pins
                        hwPinMode(buttonOne, INPUT_PULLUP);
                        buttonOneoldValue = -1;
                        sendBattLevel();
                      void presentation()  {
                        sendSketchInfo(SN, SV);
                        //present the scene controller to gateway
                        wait(10);
                        present(CHILD_ID_SCENE, S_SCENE_CONTROLLER);
                        wait(10);
                       *  Main loop function
                        // Check for button activity
                        int value = digitalRead(buttonOne);
                        if (value != buttonOneoldValue)
                            // Send in the new value
                            if (value == LOW)
                              send(msgOn.set(SceneOne));
                              wait(20);
                              send(msgOn.set(SceneTwo));
                              sendBattLevel();
                            buttonOneoldValue = value;
                        sleep(digitalPinToInterrupt(DIGITAL_INPUT_INT), CHANGE, 0);
                       * Parameters
                      void sendBattLevel()
                          long vcc = hwCPUVoltage();
                          // Calculate percentage
                          vcc = vcc - 1800; // subtract 1.9V from vcc, as this is the lowest voltage we will operate at
                          long percent = vcc / 14.0;
                          sendBatteryLevel(percent);
                      I noticed that the chip sais:
                      N51822
                      QFABC0
                      1646UU
                      QFAB translates to 16kB RAM, 128kB flash and I can not even select this option in the arduino IDE. Can this be the problem?
                      @d00616 refer to his document for some high current consumption issue but I'm not sure what to do with the info.
                      Is there something wrong with my sketch or is there just an old crappy chip on the device??
                      • Tomas
                      • MiKaM
                        MiKaM
                        MiKa
                        Same result, battery out within few days, I want to do a check of current consumption, but not yet free time...
                        I want to try this:
                        https://github.com/ThingPulse/ESP8266PowerMonitor
                        https://thingpulse.com/2018/02/25/esp8266-monitoring-power-consumption/
                        • Nca78N
                          wrote on last edited by Nca78
                          #1455
                          @korttoma have you tried the code @NeverDie put together using the LPCOMP ? With a QFAAH0 (which I believe is the same version than QFABC0, but with 256K flash) he went down to something like 4µA.
                          From the document you link, anomaly 70, it will be necessary to add an extra wait of 36us after that line, it's strange that @NeverDie never had any problem with it. Or maybe I misunderstand the document :)
                          void activateLpComp() {
                          Test code from @NeverDie using LPCOMP is here:
                          https://forum.mysensors.org/topic/6961/nrf5-bluetooth-action/1307
                          I will try it on my board (using a module with QFAAH0) tomorrow, if power consumption is as low as expected I'll try on the beacon board.
                          [Edit] Just checked quickly my "beacon" board and it's using a QFAAH1 chip (made in 2017), so the test might not be relevant...
                          korttomaK Nca78N 2 Replies Last reply
                            #1456
                            I don't remember. I've lately been using LoRa modules, plus getting distracted by CNC, so my nRF5 work has been on hold. I'm hoping that d00616 continues to work on the software though so that more than one nRF5 interrupt can be active at a time.
                            • Nca78N Nca78
                              korttomaK
                              korttomaK
                              korttoma
                              @nca78 thanks for the hint.
                              I tried to merge my sketch with the code provided by @NeverDie but I can not seem to get it to detect my button and I don't quite understand where I should attach my button that is on pin 28 to the interrupt thingie.
                              Here is my code now:
                              //This sketch is applicable to Coincell Multisensor nRF51822, version 10
                              #define SV "1.0"
                              //#define MY_CORE_ONLY
                              #define IS_NRF51  //true iff the target is an nRF51.  If an nRF52, then comment this line out!
                              // Pin definitions
                              //#define DIGITAL_INPUT_INT 28   // The digital input you attached your interrupt  (Only 2 and 3 generates interrupt!)
                              //#define I2C_INTERRUPT_PIN PIN_BUTTON1
                              //#define LEAK_DETECTION_PIN PIN_BUTTON1
                              #include <nrf.h>
                              volatile bool button_pressed=false;
                              // Sensor messages
                              // Global settings
                                  for (int i=0;i<pulses;i++) {
                                    wait(20);
                                    wait(100);
                                    wait(500);
                              #ifndef IS_NRF51
                              void turnOffRadio() {
                                NRF_RADIO->TASKS_DISABLE=1;
                              void turnOffUarte0() {
                              #ifndef IS_NRF51
                                NRF_UARTE0->TASKS_STOPRX = 1;
                                NRF_UARTE0->TASKS_STOPTX = 1;
                              #ifdef IS_NRF51
                                NRF_UART0->TASKS_STOPRX = 1;
                                NRF_UART0->TASKS_STOPTX = 1;
                                NRF_UART0->TASKS_SUSPEND = 1;
                              void turnOffAdc() {
                              #ifndef IS_NRF51
                                  NRF_SAADC->TASKS_STOP=1;
                              void mySleepPrepare()
                                turnOffHighFrequencyClock();
                                turnOffRadio();
                                turnOffUarte0();
                                //NRF_LPCOMP->PSEL=1; // monitor AIN1 (pin P0.03 on nRF52832 test board).
                                //while (!(NRF_LPCOMP->PSEL==1)) {} //wait until confirmed
                                NRF_LPCOMP->PSEL=3; // monitor AIN3 (pin P0.02 on nRF51822 for coincell_multisensor_v10)
                                while (!(NRF_LPCOMP->PSEL==3)) {} //wait until confirmed
                                NRF_LPCOMP->REFSEL=1;  // choose 1/4 VDD as the reference voltage
                                while (!(NRF_LPCOMP->REFSEL==1)) {} //wait until confirmed
                                NRF_LPCOMP->ANADETECT=1;  //detect UP events.
                                while (NRF_LPCOMP->ANADETECT!=1) {} //wait until confirmed
                                while (!(NRF_LPCOMP->INTENSET==B0100)) {} //wait until confirmed
                                NVIC_EnableIRQ(LPCOMP_IRQn);
                                  while (NRF_LPCOMP->INTENCLR==B0100) {} //wait until confirmed
                               * Setup code
                                hwInit();
                                disableNfc();
                                turnOffAdc();
                                activateLpComp();
                                blinkityBlink(2,1);  //Signify end of setup with two quick pulses.
                                mySleepPrepare();
                                //NRF_CLOCK->INTENSET=B11;  //enable interrupts for EVENTS_HFCLKSTARTED and  EVENTS_LFCLKSTARTED
                               // NRF_CLOCK->TASKS_HFCLKSTART=1;  //start the high frequency crystal oscillator clock
                               // while (!(NRF_CLOCK->EVENTS_HFCLKSTARTED)) {} //wait until high frequency crystal oscillator clock is up to speed and working
                                //hwPinMode(DIGITAL_INPUT_INT, INPUT_PULLUP);
                                //buttonOneoldValue = -1;
                                //sendBattLevel();
                                wait(10);
                                wait(10);
                                sendBattLevel();
                                sleep(10000);  //sleep for 5 seconds.
                                mySleepPrepare();  //An ounce of prevention: Turn-off HF clock, etc, ASAP to save power, just in case the library's sleep() routine resumed them.
                                if (button_pressed) {   //if a leak is detected
                                  suspendLpComp(); //suspend LPCOMP to prevent multiple interrupts
                                  //blinkityBlink(10,3);  //blink a lot to show that a leak was detected.
                                      wait(20);
                                      sendBattLevel();
                                  button_pressed=false;  //Clear the semaphore
                                  NRF_LPCOMP->EVENTS_UP=0;  //Clear the semaphore
                                  resumeLpComp();  //operations of LPCOMP were suspended after detecting the LPCOMP iterrupt
                                else {
                                  blinkityBlink(1,1);  //otherwise, just one short blink to indicate the wakeup was scheduled by the RTC
                              #if __CORTEX_M == 0x04
                                      event = 0;        \
                                      (void)event
                              // This must be in one line
                              extern "C" { void LPCOMP_IRQHandler(void) {button_pressed=true; NRF5_RESET_EVENT(NRF_LPCOMP->EVENTS_UP); NRF_LPCOMP->EVENTS_UP=0; MY_HW_RTC->CC[0]=(MY_HW_RTC->COUNTER+2);}}
                              I thought that I should do it like this:
                                 NRF_LPCOMP->PSEL=28; // monitor AIN3 (pin P0.02 on nRF51822 for coincell_multisensor_v10)
                                while (!(NRF_LPCOMP->PSEL==28)) {} //wait until confirmed
                              But then it does not seem to run the loop anymore because I do not get the 10s blink.
                              • Tomas
                              • T
                                Toyman
                                Guys, help me understand: when do I need to enable DC-DC?
                                My breakout board consists of Ebyte module and a couple of buttons. Battery is CR2450 directly connected to the module.
                                Do I need DC-DC?
                                • T Toyman
                                  Do I need DC-DC?
                                  #1459
                                  @toyman With DC-DC, it uses roughly half the current during Tx and Rx. Seems like a no brainer to me, but you don't literally "need" to have it. I'm not aware of any downsides to it.
                                    Toyman
                                    @neverdie thx. What is needed hardware-wise? Two inductors between dc and dec4? Like in your breakout board?
                                    • T Toyman
                                      @toyman Correct. You can review the schematic for this project: https://www.openhardware.io/view/472/Ebyte-nRF52832-Prototyping-Board
                                      • korttomaK
                                        korttomaK
                                        korttoma
                                        #1462
                                        I guess this is why I cant get LPCOMP to work on the device.
                                        Eight input options (AIN0 to AIN7)
                                        I would have to use the analog inputs because pin 28 is just a general purpose I/O pin.
                                        • Tomas
                                        • T
                                          Toyman
                                          ebyte module is currently on sale at roughly $2.5
                                          Total bargain!
