  3. nRF5 action!
nRF5 action!
1.9k Posts 49 Posters 2.1m Views 44 Watching
    Maybe someone here can figure out how to 3D print their own nRF52832 smart watch? i.e. one that's meant to be taken apart and put back together so that it's as good as new.
      @toyman said in nRF5 Bluetooth action!:
      "roger clark smartwatch"
      Seems like there is hope then of accessing the screen after all. On http://www.rogerclark.net/arduino-on-the-id100hr-fitness-tracker/ it says: "Display: 0.49 inch OLED display (64×32 pixels) which uses the SSD1306 display controller"
      Toyman
      @neverdie read Issues section in Mark Cooks's repo referenced above. He's just committed a PR to support the display.
      I need nrf52 to able to use Central role in my projects. For Mysensors nrf51 is pretty adequate if someone wants to create something like a wearable weather station :-)
      Everything is in place.
      • T Toyman
        @toyman Seems like it has a lot of potential as an awesome notifier/remote-control that's conveniently always with you. If you succeed in getting it to work, please do post a photo and let us know!
        • alowhumA
          alowhumA
          alowhum
          Note: to hack it you need a J-Link device:
          https://github.com/micooke/arduino-nRF5-smartwatches/blob/master/nrf52_disable_read_protection.txt
          • Nca78N Nca78
            So I made a version of script with MySensors library, it's not a final version and needs some cleaning and improvements but it seems to work well (I didn't test so much yet :)) and shows basic usage. Comments should be enough to understand what to change to adapt to your board. Current script is for my board:
            • BUTTON_1 on pin 1, it's a hall sensor for door so no pullup and sensing on up=>down and down=>up changes
            • BUTTON_2 on pin 3, push button with pullup and debouncing, sensing only on up=>down when button is pressed. At the moment it just makes some light blinking to show it's detected.
            • led on pin 2.
            I join the main script file and the MyBoardNRF5 files, for using with MyBoardNRF5 nrf51822. Files to include are described in the main script file, but don't forget to add a weak attribute in the WInterrupt.c file before the GPIOTE_IRQHandler so it can be overridden.
            __attribute__ ((weak))
            void GPIOTE_IRQHandler()
            On my Windows PC this file is in C:\Users[your user name]\AppData\Local\Arduino15\packages\sandeepmistry\hardware\nRF5\0.5.1\cores\nRF5
            Main script file:
            // Include app_gpiote and related files from NRF5 SDK 12
            extern "C" {
            #include "app_gpiote.h"
            #include "nrf_gpio.h"
            #include "app_error.h"
            // Files to include from SDK:
            // app_error_weak.h + .c
            // app_gpiote.h + .c
            // app_util.h
            // nordic_common.h
            // nrf_error.h
            // nrf_gpio.h
            // sdk_errors.h
            // app_error.h + .c
            //   for this last one (c file) I decided to stop the endless list of includes so I commented the following includes:
            //   #include "sdk_errors.h", #include "nrf_log.h", #include "nrf_log_ctrl.h"  lines
            #include <nrf.h>
            #define IS_NRF51  //true if the target is an nRF51.  If an nRF52, then comment this line out!
            #define APP_GPIOTE_MAX_USERS 1  // max users for app_gpiote, we only use one
            #define MY_RADIO_NRF5_ESB
            #define MY_NODE_ID 60   // To avoid getting a new ID at each flashing of the sensors...
            // variables for app_gpiote calls
            uint32_t err_code;
            static app_gpiote_user_id_t m_gpiote_user_id;
            uint32_t PIN_BUTTON1_MASK; // Mask for PIN_BUTTON1 input
            uint32_t PIN_BUTTON2_MASK; // Mask for PIN_BUTTON2 input
            // defines variables for MySensors
            #define SN "22Board Door Basic"
            #define SV "0.2"
            // Sensor messages
            #define CHILD_ID_DOOR 1
            MyMessage doorMsg(CHILD_ID_DOOR, V_TRIPPED);
            bool last_sent_value;
            bool door_status;
            long last_button2_event = 0;
            // Cause of interrupt
            volatile byte interrupt_cause = 0;
            // Settings to avoid killing coin cell in case of connection problem
            #define MY_TRANSPORT_WAIT_READY_MS  10000
            #define MY_SLEEP_TRANSPORT_RECONNECT_TIMEOUT_MS 5000
            // Battery settings
            #define BATTERY_ALERT_LEVEL 30  // (%) Will triple blink after sending data if battery is equal or below this level
            // Parameters for VCC measurement
            #define BATTERY_VCC_MIN  2400  // Minimum expected Vcc level, in milliVolts.
            #define BATTERY_VCC_MAX  2900  // Maximum expected Vcc level, in milliVolts.
            // This a a coefficient to fix the imprecision of measurement of the battery voltage
            #define BATTERY_COEF 1000.0f  // (reported voltage / voltage) * 1000
            uint16_t currentBatteryPercent;
            uint16_t lastBatteryPercent = -1;
            // Enables/disables sleeps between sendings to optimize for CR2032 or similar coin cell
            #define USE_COIN_CELL
            // Called before initialization of the library
            void before() {
              hwPinMode(LED_BUILTIN, OUTPUT_D0H1);
              blinkityBlink(2, 3);
            // Setup node
            void setup(void) {
              //Configure button pins as inputs
              nrf_gpio_cfg_input(PIN_BUTTON1, NRF_GPIO_PIN_NOPULL);
              nrf_gpio_cfg_input(PIN_BUTTON2, NRF_GPIO_PIN_PULLUP);
              APP_GPIOTE_INIT(APP_GPIOTE_MAX_USERS);               //Only initialize once. Increase value of APP_GPIOTE_MAX_USERS if needed
              // Initialize value of pin (for DRV5032 hall sensor HIGH = no magnet nearby = door opened);
              door_status = digitalRead(PIN_BUTTON1);
              last_sent_value = !door_status; // so we always send value in first loop
              // Registers user and pins we are "watching"
              //   gpiote_event_handler is handler called by interrupt, see method below
              PIN_BUTTON1_MASK = 1 << PIN_BUTTON1; // Set mask, will be used for registration and interrupt handler
              PIN_BUTTON2_MASK = 1 << PIN_BUTTON2; // Set mask, will be used for registration and interrupt handler
              //  app_gpiote_user_register(p_user_id, pins_low_to_high_mask, pins_high_to_low_mask, event_handler)
              //  to have no trigger for high=>low or low=>high change on your button, pass 0 instead
              //  here I check PIN_BUTTON1 on both low=>high and high=>low changes and PIN_BUTTON2 only on high=>low change when someone presses the button
              err_code = app_gpiote_user_register(&m_gpiote_user_id, PIN_BUTTON1_MASK, PIN_BUTTON1_MASK | PIN_BUTTON2_MASK, gpiote_event_handler);
              APP_ERROR_CHECK(err_code);  // will reset if user registration fails
              // Enable SENSE and interrupt
              err_code = app_gpiote_user_enable(m_gpiote_user_id);
              APP_ERROR_CHECK(err_code);  // will reset if SENSE enabling fails
              // initialize last event for button2 debounce
              last_button2_event = millis();
            void presentation()  {
              sendSketchInfo(SN, SV);
              present(CHILD_ID_DOOR, S_DOOR);
            // Sleep between sendings to preserve coin cell
            //  if not using button cell just make sure the #define USE_COIN_CELL is commented at the beginning of the sketch and it will do nothing
            void sleepForCoinCell() {
            #ifdef USE_COIN_CELL
              sleep(400);
            // main loop
            void loop(void)
              // for sending battery level at first run
              if (lastBatteryPercent < 0) {
                sendBatteryStatus();
                sleepForCoinCell();
              if (interrupt_cause == PIN_BUTTON1) {
                // if door status changed, we send door message
                if (door_status != last_sent_value) {
                  sendDoorStatus();
              else if (interrupt_cause == PIN_BUTTON2) {
                if (millis() < last_button2_event || (millis() - last_button2_event > 100)) {
                  blinkityBlink(2, 3); // not so useful, just for testing :)
              else {  // end of sleeping period, we send battery level
              // Low battery warning or confirm status of door
              if (lastBatteryPercent < BATTERY_ALERT_LEVEL) {
                blinkityBlink(3, 1);
              else {
                blinkityBlink((last_sent_value == true ? 2 : 1), 1);
              // Go to sleep
              mySleepPrepare();
              interrupt_cause = 0; // reset interrupt cause
              sleep(300000);
            void sendDoorStatus() {
              send(doorMsg.set(door_status));
              last_sent_value = door_status;
            #define CHILD_ID_VOLT 254
            MyMessage voltMsg(CHILD_ID_VOLT, V_VOLTAGE);
            void sendBatteryStatus() {
              uint16_t batteryVoltage = hwCPUVoltage();
              if (batteryVoltage > BATTERY_VCC_MAX) {
                currentBatteryPercent = 100;
              else if (batteryVoltage < BATTERY_VCC_MIN) {
                currentBatteryPercent = 0;
              else {
                currentBatteryPercent = (100 * (batteryVoltage - BATTERY_VCC_MIN)) / (BATTERY_VCC_MAX - BATTERY_VCC_MIN);
              if (currentBatteryPercent != lastBatteryPercent) {
                sendBatteryLevel(currentBatteryPercent);
                lastBatteryPercent = currentBatteryPercent;
            // "Interrupt handler"
            //  not real handler, but call inside handler to
            void gpiote_event_handler(uint32_t event_pins_low_to_high, uint32_t event_pins_high_to_low)
              MY_HW_RTC->CC[0] = (MY_HW_RTC->COUNTER + 2); // Taken from d0016 example code, ends the sleep delay
              if ((PIN_BUTTON1_MASK & event_pins_low_to_high) || (PIN_BUTTON1_MASK & event_pins_high_to_low)) {
                interrupt_cause = PIN_BUTTON1;
                door_status = !door_status;
              else if ((PIN_BUTTON2_MASK & event_pins_low_to_high) || (PIN_BUTTON2_MASK & event_pins_high_to_low)) {
                interrupt_cause = PIN_BUTTON2;
               Utility functions for NRF51/52, from nerverdie's code here
               https://forum.mysensors.org/topic/6961/nrf5-bluetooth-action/1307
            #ifndef IS_NRF51
              NRF_NFCT->TASKS_DISABLE = 1; //disable NFC
              NRF_NVMC->CONFIG = 1; // Write enable the UICR
              NRF_UICR->NFCPINS = 0; //Make pins 9 and 10 usable as GPIO pins.
              NRF_NVMC->CONFIG = 0; // Put the UICR back into read-only mode.
            void turnOffRadio() {
              NRF_RADIO->TASKS_DISABLE = 1;
            void turnOffUarte0() {
            #ifndef IS_NRF51
              NRF_UARTE0->TASKS_STOPRX = 1;
              NRF_UARTE0->TASKS_STOPTX = 1;
              NRF_UARTE0->ENABLE = 0; //disable UART0
              while (NRF_UARTE0->ENABLE != 0) {}; //wait until UART0 is confirmed disabled.
            #ifdef IS_NRF51
              NRF_UART0->TASKS_STOPRX = 1;
              NRF_UART0->TASKS_STOPTX = 1;
              NRF_UART0->TASKS_SUSPEND = 1;
              NRF_UART0->ENABLE = 0; //disable UART0
              while (NRF_UART0->ENABLE != 0) {}; //wait until UART0 is confirmed disabled.
            void turnOffAdc() {
            #ifndef IS_NRF51
                NRF_SAADC->TASKS_STOP = 1;
                NRF_SAADC->ENABLE = 0; //disable the SAADC
            void mySleepPrepare()
              turnOffHighFrequencyClock();
              turnOffRadio();
              turnOffUarte0();
              for (int x = 0; x < repetitions; x++) {
                // wait only in case there's been a previous blink
                if (x > 0) {
                  sleep(500);
                for (int i = 0; i < pulses; i++) {
                  if (i > 0) {
                    sleep(100);
                  digitalWrite(LED_BUILTIN, HIGH);
                  wait(20);
                  digitalWrite(LED_BUILTIN, LOW);
            MyBoardNRF5.h
              If you don't use an nRF5 board, you can ignore this file.
              This file was part of the "My Sensors nRF5 Boards" board repository
              available at https://github.com/mysensors/ArduinoBoards If you have
              questions, please refer the documentation at
              https://github.com/mysensors/ArduinoHwNRF5 first.
              This file is compatible with ArduinoHwNRF5 >= 0.2.0
              This file allows you to change the pins of internal hardware, like the
              serial port, SPI bus or Wire bus.
              All pins referenced here are mapped via the "g_ADigitalPinMap" Array
              defined in "MyBoardNRF5.cpp" to pins of the MCU.
              As an example, if you have at the third position in "g_ADigitalPinMap" the
              12, then all ports referenced in Arduino with 2 are mapped to P0.12. If you
              don't change the "g_ADigitalPinMap" Array, the Arduino pins 0..31 are
              translated to P0.00..P0..31.
              This file is compatible with ArduinoHwNRF5 > 0.1.0
              Copyright (c) 2014-2015 Arduino LLC.  All right reserved.
              Copyright (c) 2016 Sandeep Mistry. All right reserved.
              Copyright (c) 2017 Sensnology AB. All right reserved.
              This library is free software; you can redistribute it and/or
              modify it under the terms of the GNU Lesser General Public
              License as published by the Free Software Foundation; either
              version 2.1 of the License, or (at your option) any later version.
              This library is distributed in the hope that it will be useful,
              but WITHOUT ANY WARRANTY; without even the implied warranty of
              MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.
              See the GNU Lesser General Public License for more details.
              You should have received a copy of the GNU Lesser General Public
              License along with this library; if not, write to the Free Software
              Foundation, Inc., 51 Franklin St, Fifth Floor, Boston, MA  02110-1301  USA
            #ifndef _MYBOARDNRF5_H_
            #define _MYBOARDNRF5_H_
            #ifdef __cplusplus
            extern "C"
            #endif // __cplusplus
            // Number of pins defined in PinDescription array
            #define PINS_COUNT           (32u)
            #define NUM_DIGITAL_PINS     (32u)
            #define NUM_ANALOG_INPUTS    (8u)
            #define NUM_ANALOG_OUTPUTS   (8u)
             *  LEDs
             *  This is optional
             *  With My Sensors, you can use
             *  hwPinMode() instead of pinMode()
             *  hwPinMode() allows to use advanced modes like OUTPUT_H0H1 to drive LEDs.
             *  https://github.com/mysensors/MySensors/blob/development/drivers/NRF5/nrf5_wiring_constants.h
            #define PIN_LED1                (2)
            // #define PIN_LED2                (25)
            // #define PIN_LED3                (26)
            // #define PIN_LED4                (27)
            // #define PIN_LED5                (12)
            // #define PIN_LED6                (14)
            // #define PIN_LED7                (15)
            // #define PIN_LED8                (16)
            // #define USER_LED                (PIN_LED2)
            // #define RED_LED                 (PIN_LED3)
            // #define GREEN_LED               (PIN_LED4)
            // #define BLUE_LED                (PIN_LED1)
            // #define BLE_LED                 BLUE_LED
            #define LED_BUILTIN          PIN_LED1
             *  Buttons
             *  This is optional
            #define PIN_BUTTON1             (1)
            #define PIN_BUTTON2             (3)
            // #define PIN_BUTTON3             (5)
            // #define PIN_BUTTON4             (6)
            // #define PIN_BUTTON5             (7)
            // #define PIN_BUTTON6             (8)
            // #define PIN_BUTTON7             (9)
            // #define PIN_BUTTON8             (10)
             * Analog ports
             * If you change g_APinDescription, replace PIN_AIN0 with
             * port numbers mapped by the g_APinDescription Array.
             * You can add PIN_AIN0 to the g_APinDescription Array if
             * you want provide analog ports MCU independed, you can add
             * PIN_AIN0..PIN_AIN7 to your custom g_APinDescription Array
             * defined in MyBoardNRF5.cpp
            static const uint8_t A0  = ADC_A0;
            static const uint8_t A1  = ADC_A1;
            static const uint8_t A2  = ADC_A2;
            static const uint8_t A3  = ADC_A3;
            static const uint8_t A4  = ADC_A4;
            static const uint8_t A5  = ADC_A5;
            static const uint8_t A6  = ADC_A6;
            static const uint8_t A7  = ADC_A7;
             * Serial interfaces
             * RX and TX are required.
             * If you have no serial port, use unused pins
             * CTS and RTS are optional.
            #define PIN_SERIAL_RX       (29)
            #define PIN_SERIAL_TX       (28)
            // #define PIN_SERIAL_CTS      (13)
            // #define PIN_SERIAL_RTS      (14)
             * SPI Interfaces
             * This is optional
             * If SPI is defined MISO, MOSI, SCK are required
             * SS is optional and can be used in your sketch.
            #define SPI_INTERFACES_COUNT 0
            #define PIN_SPI_MISO         (6)
            #define PIN_SPI_MOSI         (3)
            #define PIN_SPI_SCK          (4)
            #define PIN_SPI_SS           (5)
            static const uint8_t SS   = PIN_SPI_SS;
            static const uint8_t MOSI = PIN_SPI_MOSI;
            static const uint8_t MISO = PIN_SPI_MISO;
            static const uint8_t SCK  = PIN_SPI_SCK;
             * Wire Interfaces
             * This is optional
            #define WIRE_INTERFACES_COUNT 1
            #define PIN_WIRE_SDA         (9u)
            #define PIN_WIRE_SCL         (10u)
            #define PIN_WIRE_SDA1        (15u)
            #define PIN_WIRE_SCL1        (16u)
            static const uint8_t SDA = PIN_WIRE_SDA;
            static const uint8_t SCL = PIN_WIRE_SCL;
            #ifdef __cplusplus
            MyBoardNRF5.cpp
              This file allows you to change the relation between pins referenced in
              the Arduino IDE (0..31) and pins of the nRF5 MCU (P0.00..P0.31).
              If you can live with addressing the GPIO pins by using the Arduino pins
              0..31 instead of a custom mapping, don't change this file. If you have
              a lot of Arduino code with fixed pin numbers and you need to map these
              pins to specific pins of the nRF5 MCU; you need to change this file.
              If you fill the "g_APinDescription" Array with numbers between 0..31,
              the Arduino pins 0..31 are assigned to pins P0.00..P0.31 of the MCU.
              As an example, if you need to change the pin mapping for Arduino pin 5
              to P0.12 of the MCU, you have to write the 12 after PORT0 into the sixth
              position in the  "g_APinDescription" Array.
              The extended attributes only affects the nRF5 variants provided with
              official Arduino boards. The arduino-nrf5 variant ignores the extended
              attributes.
              The pin mapping effects commands like "pinMode()", "digitalWrite()",
              "analogRead()" and "analogWrite()".
              If you change the pin mapping, you have to modify the pins in
              "MyBoardNRF5.h". Especially the analog pin mapping must be replaced with
              your pin numbers by replacing PIN_AIN0..7 with a number of your mapping
              array. You can use the constants PIN_AIN0..7 in the "g_APinDescription"
              Array if you want to reference analog ports MCU independent. You cannot
              use the pins P0.00 and P0.01 for GPIO, when the 32kHz crystal is connected.
              Copyright (c) 2016 Arduino Srl.  All right reserved.
            #ifdef MYBOARDNRF5
            #include <variant.h>
             * Pins descriptions. Attributes are ignored by arduino-nrf5 variant.
             * Definition taken from Arduino Primo Core with ordered ports
            const PinDescription g_APinDescription[]=
              { PORT0,  0, PIO_DIGITAL, (PIN_ATTR_DIGITAL|PIN_ATTR_PWM), No_ADC_Channel, PWM0, NOT_ON_TIMER},  // AREF0 ADC/LPCOMP reference input 0
              { PORT0,  1, PIO_DIGITAL, (PIN_ATTR_DIGITAL|PIN_ATTR_PWM), ADC_A2, PWM1, NOT_ON_TIMER},
              { PORT0,  2, PIO_DIGITAL, (PIN_ATTR_DIGITAL|PIN_ATTR_PWM), ADC_A3, PWM2, NOT_ON_TIMER},
              { PORT0,  3, PIO_DIGITAL, (PIN_ATTR_DIGITAL|PIN_ATTR_PWM), ADC_A4, PWM3, NOT_ON_TIMER},
              { PORT0,  4, PIO_DIGITAL, (PIN_ATTR_DIGITAL|PIN_ATTR_PWM), ADC_A5, PWM4, NOT_ON_TIMER},
              { PORT0,  5, PIO_DIGITAL, (PIN_ATTR_DIGITAL|PIN_ATTR_PWM), ADC_A6, PWM5, NOT_ON_TIMER},
              { PORT0,  6, PIO_DIGITAL, (PIN_ATTR_DIGITAL|PIN_ATTR_PWM), ADC_A7, PWM6, NOT_ON_TIMER}, // AREF1 ADC/LPCOMP reference input 1
              { PORT0,  7, PIO_DIGITAL, (PIN_ATTR_DIGITAL|PIN_ATTR_PWM), No_ADC_Channel, PWM7, NOT_ON_TIMER},
              { PORT0,  8, PIO_DIGITAL, (PIN_ATTR_DIGITAL|PIN_ATTR_PWM), No_ADC_Channel, PWM8, NOT_ON_TIMER},
              { PORT0,  9, PIO_DIGITAL, (PIN_ATTR_DIGITAL|PIN_ATTR_PWM), No_ADC_Channel, PWM9, NOT_ON_TIMER},
              { PORT0, 10, PIO_DIGITAL, (PIN_ATTR_DIGITAL|PIN_ATTR_PWM), No_ADC_Channel, PWM10, NOT_ON_TIMER},
              { PORT0, 11, PIO_DIGITAL, (PIN_ATTR_DIGITAL|PIN_ATTR_PWM), No_ADC_Channel, PWM11, NOT_ON_TIMER},
              { PORT0, 12, PIO_DIGITAL, (PIN_ATTR_DIGITAL|PIN_ATTR_PWM), No_ADC_Channel, NOT_ON_PWM, NOT_ON_TIMER},
              { PORT0, 13, PIO_DIGITAL, (PIN_ATTR_DIGITAL|PIN_ATTR_PWM), No_ADC_Channel, NOT_ON_PWM, NOT_ON_TIMER},
              { PORT0, 14, PIO_DIGITAL, (PIN_ATTR_DIGITAL|PIN_ATTR_PWM), No_ADC_Channel, NOT_ON_PWM, NOT_ON_TIMER},
              { PORT0, 15, PIO_DIGITAL, (PIN_ATTR_DIGITAL|PIN_ATTR_PWM), No_ADC_Channel, NOT_ON_PWM, NOT_ON_TIMER},
              { PORT0, 16, PIO_DIGITAL, (PIN_ATTR_DIGITAL|PIN_ATTR_PWM), No_ADC_Channel, NOT_ON_PWM, NOT_ON_TIMER},
              { PORT0, 17, PIO_DIGITAL, (PIN_ATTR_DIGITAL|PIN_ATTR_PWM), No_ADC_Channel, NOT_ON_PWM, NOT_ON_TIMER},
              { PORT0, 18, PIO_DIGITAL, (PIN_ATTR_DIGITAL|PIN_ATTR_PWM), No_ADC_Channel, NOT_ON_PWM, NOT_ON_TIMER},
              { PORT0, 19, PIO_DIGITAL, (PIN_ATTR_DIGITAL|PIN_ATTR_PWM), No_ADC_Channel, NOT_ON_PWM, NOT_ON_TIMER},
              { PORT0, 20, PIO_DIGITAL, (PIN_ATTR_DIGITAL|PIN_ATTR_PWM), No_ADC_Channel, NOT_ON_PWM, NOT_ON_TIMER},
              { PORT0, 21, PIO_DIGITAL, (PIN_ATTR_DIGITAL|PIN_ATTR_PWM), No_ADC_Channel, NOT_ON_PWM, NOT_ON_TIMER},
              { PORT0, 22, PIO_DIGITAL, (PIN_ATTR_DIGITAL|PIN_ATTR_PWM), No_ADC_Channel, NOT_ON_PWM, NOT_ON_TIMER},
              { PORT0, 23, PIO_DIGITAL, (PIN_ATTR_DIGITAL|PIN_ATTR_PWM), No_ADC_Channel, NOT_ON_PWM, NOT_ON_TIMER},
              { PORT0, 24, PIO_DIGITAL, (PIN_ATTR_DIGITAL|PIN_ATTR_PWM), No_ADC_Channel, NOT_ON_PWM, NOT_ON_TIMER},
              { PORT0, 25, PIO_DIGITAL, (PIN_ATTR_DIGITAL|PIN_ATTR_PWM), No_ADC_Channel, NOT_ON_PWM, NOT_ON_TIMER},
              { PORT0, 26, PIO_DIGITAL, (PIN_ATTR_DIGITAL|PIN_ATTR_PWM), ADC_A0, NOT_ON_PWM, NOT_ON_TIMER},
              { PORT0, 27, PIO_DIGITAL, (PIN_ATTR_DIGITAL|PIN_ATTR_PWM), ADC_A1, NOT_ON_PWM, NOT_ON_TIMER},
              { PORT0, 28, PIO_DIGITAL, (PIN_ATTR_DIGITAL|PIN_ATTR_PWM), No_ADC_Channel, NOT_ON_PWM, NOT_ON_TIMER},
              { PORT0, 29, PIO_DIGITAL, (PIN_ATTR_DIGITAL|PIN_ATTR_PWM), No_ADC_Channel, NOT_ON_PWM, NOT_ON_TIMER}
            // Don't remove this line
            #include <compat_pin_mapping.h>
            korttomaK
            korttomaK
            korttoma
            @nca78 I tried to follow your instructions in post #1514 but I must be doing something wrong when I add files from the NRF5 SDK to my sketch folder because I keep getting some errors about missing files, so I keep adding and now I got to this point:
            In file included from C:\Users\Tomas\Documents\Arduino\NRF5SceneCtLC2Protoboard\NRF5SceneCtLC2Protoboard.ino:4:0:
            nrf_gpio.h:67: error: #error "Not supported."
            exit status 1
            • Tomas
            Nca78N 1 Reply Last reply
            • korttomaK korttoma
              exit status 1
              @korttoma sorry it seems I messed up with the files, this one is not from sdk.
              Please take the one here, I'll clean up and reorganize later:
              https://github.com/bitcraze/crazyflie2-nrf-mbs/blob/master/include/nrf/nrf_gpio.h
              korttomaK 1 Reply Last reply
              • Nca78N Nca78
                korttomaK
                korttomaK
                korttoma
                @nca78 still not getting anywhere with this. Would you mind ziping your sketch folder, then I should have all the correct files (right?). If I still have issues to compile I must be missing some library or are using the wrong version of something.
                • Tomas
                  wrote on last edited by Nca78
                  #1542
                  @korttoma said in nRF5 Bluetooth action!:
                  Sure, but unfortunately I cannot upload a zip file here, please send me your email by private message.
                  Ok here is a google drive link, it should be easier:
                  https://drive.google.com/open?id=1IhLIx0nHd5KZR9dJ9qA0-_SMGmjEpbKj
                  • T Toyman
                    @alowhum there is a whole "movement" of people who are trying to reprogram them. Key issue is openability (how hard is to open it)
                    The last easily openable watches are based on nrf51822, but the good thing is that programming pins are easily accesable and even marked SWD/SCLCK.
                    Search Ali for ID107HR and google for "roger clark smartwatch"
                    I am yet to find a watch that would be both nrf52 based AND easily openable
                    #1543
                    Maybe this one?
                    https://www.alibaba.com/product-detail/Leather-Smart-Wristband-Bracelet-NORDIC-NRF52832_60726090170.html?spm=a2700.7724857.main07.29.6deb404ewQickL
                    or, perhaps a little easier, this one?
                    https://www.alibaba.com/product-detail/2018-NEW-Messages-Sync-smart-bracelet_60733935490.html?spm=a2700.7724857.main07.70.6deb404ewQickL
                    or this?
                    https://www.alibaba.com/product-detail/Intelligent-heart-rate-sport-smart-healthy_60734390506.html?spm=a2700.details.maylikever.9.7ec0487aXxyeI2
                    I'm guessing that a typical jeweler would have the right tools to open it. Maybe get a little help with that part of it? I doubt it would cost much.
                    Fortunately, there seem to be a plethora of different inexpensive nRF52832 watches available. Gobs of them.
                    https://www.aliexpress.com/item/CACGO-K2-Smart-Watch-Bluetooth-4-0-Nordic-NRF52832-Chip-Sleep-Heart-Rate-Blood-Pressure-Blood/32853451564.html
                    https://www.aliexpress.com/item/CACGO-K2-Bluetooth-Smartwatch-Waterproof-IP68-Heart-Rate-Blood-Pressure-Blood-Oxygen-Smart-Watch-for-iOS/32851202681.html?spm=2114.10010108.1000014.2.667554e38QctWv&traffic_analysisId=recommend_3035_null_null_null&scm=1007.13338.98644.000000000000000&pvid=b215db98-0db7-446e-a11f-3548284b4575&tpp=1
                      Maybe this one?
                      or this?
                      Toyman
                      @neverdie AFAIK, they are all heavily glued to meet IPX67
                      • T
                        Toyman
                        Just curious design consideration, based on my question to Nordic:
                        https://devzone.nordicsemi.com/f/nordic-q-a/33448/led-power
                        LED consumption will not exceed 0.5ma if the pin is configured as s0s1
                        • T Toyman
                          #1546
                          @toyman Maybe that's enough to light a subset of the pixels on the display?
                          In theory these nRF52832 BLE are OTA re-programmable. If someone left the door open for that, then you wouldn't have to crack the case or fight with the glue. Well, maybe someday...
                            Toyman
                            @neverdie I was thinking about that, but that's not gonna work. Why? The bootloader that accepts OTA has a private key. The key in the software should match the key.
                            • T Toyman
                              #1548
                              @toyman Would this work? Buy two. Sacrifice the first so that you can image the firmware on the chip and extract the password. Use that password to unlock the OTA firmware update for the second one.
                              Or, maybe it's the universal bluetooth password: 1234. Maybe try that first. ;)
                                #1549
                                afaik mysensors nrf52 isn't working with softdevice yet (same as your 'bootloader' here). there might be some conflicts with nrf52 resources (timers etc.). so you may need to open it for reprogramming.
                                • alowhumA
                                  alowhumA
                                  alowhum
                                  For me losing Bluetooth would be a feature: it makes you less likely to be tracked while in stores / smart cities.
                                  • alowhumA
                                    alowhumA
                                    alowhum
                                    I turned a ST-Link v2 into a Black Magic Probe using this guide.
                                    The Black Magic Probe creates two virtual serial ports. One to program over, and another one. Can that second one be used to listen to Serial output from the NRF52? If so, how can that be set up?
                                    NeverDieN nagelcN 2 Replies Last reply
                                    • alowhumA alowhum
                                      @alowhum Doesn't answer your question, but I use just regular FTDI to listen to the serial output from the nRF5. So, there's always that for you to fall back on.
                                      • alowhumA alowhum
                                        nagelcN
                                        nagelcN
                                        nagelc
                                        @alowhum I'm using a BMP that I made from a STM32 Blue Pill. The Serial works just fine.
                                        Set a TX pin on your NRF5 in the MyBoardNFR5.h file. Connect it to the RX pin on your BMP. The default pins are TX (PA.2) and RX (PA.3). So if you connect PA.3 on your programmer to the TX pin you select on the NRF5, you should have what you need.
                                        To program, select the lower number serial port.
                                        To see serial output, select the higher number serial port for your serial monitor.
                                        • alowhumA
                                          alowhumA
                                          alowhum
                                          @nagelc I am using a ST-Link V2 that I turned into a BMP. So i don't have a RX pin on that. But I do have these pins left:
                                          • RST
                                          • SWIM
                                          So you suppose any of these two pins are now RX?
                                          nagelcN T 2 Replies Last reply
